You may want to switch to mirrors.manjaro.org/repo which is our global network of mirrors updating every 15 mins.
Okay, my mirror is up-to-date now. I pulled in archlinux-keyring-20210802-1 but I’m still seeing signature failures from Helmut’s key:
sudo pacman -Syu
(221/221) checking keys in keyring [########################################################################################] 100%
(221/221) checking package integrity [########################################################################################] 100%
error: nvidia-utils: signature from "Helmut Stult (schinfo) <helmut.stult@schinfo.de>" is unknown trust
:: File /var/cache/pacman/pkg/nvidia-utils-470.57.02-1-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
Do you want to delete it? [Y/n]
error: pacman: signature from "Helmut Stult (schinfo) <helmut.stult@schinfo.de>" is unknown trust
:: File /var/cache/pacman/pkg/pacman-6.0.0-2-x86_64.pkg.tar.zst is corrupted (invalid or corrupted package (PGP signature)).
error: failed to commit transaction (invalid or corrupted package)
I also tried refreshing just Helmut’s key but I’m getting errors:
sudo pacman-key --refresh-keys helmut.stult@schinfo.de
gpg: error retrieving 'helmut.stult@schinfo.de' via WKD: General error
gpg: error reading key: General error
gpg: error retrieving 'helmut@manjaro.org' via WKD: No data
gpg: error reading key: No data
gpg: error retrieving 'helmut@schinfo-home.de' via WKD: General error
gpg: refreshing 1 key from hkps://keyserver.ubuntu.com
gpg: key CEE477135C5872B0: "Helmut Stult (schinfo) <helmut.stult@schinfo.de>" not changed
gpg: Total number processed: 1
gpg: unchanged: 1
Full command history:
sudo rm -rf /var/cache/pacman/pkg/
sudo pacman -Syy archlinux-keyring
sudo pacman -Syu
sudo pacman -Syu
Am I missing a step here or is Helmut’s key actually hosed?
As @phil mentioned above, Helmut’s key was replaced by the Manjaro Build Server key.
See Pacman troubleshooting - Manjaro
Posts have been removed dealing with bad practices.
Yeah I tried those steps before… Just tried them again now, still no luck, not sure what I’m missing… Here’s my full command history:
sudo rm -rf /etc/pacman.d/gnupg
sudo pacman -Syy gnupg archlinux-keyring manjaro-keyring # fails due to Helmut's key
sudo pacman -Syy gnupg archlinux-keyring # succeeds
sudo pacman-key --init
sudo pacman-key --populate archlinux manjaro
sudo pacman -Syu # fails due to Helmut's key
Can someone who has this working please post the commands you used?
As I am also having the same issue and all the steps above didn’t work for me, I also want to ask what I could do to be able to update my system again.
I tried the removing (from pkg /etc/pacman.d/gnupg), reinstalling, repopulating and reinitalisating of the keys. I removed the zst file from the cache but that also didn’t help.
You (Yochanan) said, that the key has been replaced by the Manjaro Build Server key. Do you mean that there is a new one for Helmut? (How to get that one?) Or are the packages now signed by another user? (Then how to get pacman to use that one?)
I am also still having issues.
I have followed the steps suggested above, ie - See Pacman troubleshooting - Manjaro
I am getting errors importing keys for:
- Levente Polyak
- Christian Hesse
- Helmut Stult
Same problem here too like 3 last posters.
Clears thout loudly
That means delete the corresponding .sig files for packages signed by Helmut.
Vague instructions get vague results, no need to get snarky…
As I mentioned above, I also tried trashing /var/cache/pacman/pkg entirely, which would have obviously taken care of that.
The commands from the Pacman troubleshoot wiki page don’t seem to work at all. Step (2) on that page seems out of order (it fails since there’s no keyring since we just deleted it in step (1)). If you ran Step (2) after init, populate, and refresh under normal circumstances I would expect it to work, but right now it’s still failing due to Helmut’s key.
@Yochanan can you please confirm that this exact command sequence works on your system? If it doesn’t work, can you please share the command sequence you used to get around this problem.
sudo rm -r /etc/pacman.d/gnupg
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring # fails due to missing gpg directory
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring # fails due to helmut's key
sudo pacman -Sy gnupg archlinux-keyring # succeeds
sudo pacman -Sy gnupg archlinux-keyring manjaro-keyring # still fails due to helmut's key
Before that, I would run this command to get the mirrors that are updated the fastest
sudo pacman-mirrors --fasttrack && sudo pacman -Syyu
This fixed the situation on my machine (no explicit key refresh! as suggested above by @mithrial , and I had removed problematic sigs/archives from /var/cache/pacman/pkg in previous attempts to rectify the situation)
sudo pacman-key --populate manjaro
sudo pacman -Syvv manjaro-keyring # just to test for key-problems, as this would fail
After that, I used pamac (gui) to update everything - the machine is up to date now. Helmuts key is valid and not expired on my machine (expires never!), that’s why I think not to refresh the keys manually is important for now – once the situation is cleared up, normal procedures apply (see below)
Thanks @tomterl for posting this - my issues are also now solved. As you indicated the important missing part of the puzzle was NOT to refresh keys (even though it is indicated in the Pacman troubleshooting steps)
Generally speaking, refreshing the keys is encouraged.
Assume, a maintainer accidentally publishes their private key. Usually, then, the key is revoked.
But how does your system know that it is revoked? It doesn’t without refreshing. Anyone with access to this hypothetical private key could now sign any package and your system would happily install them.
In this instance, the user (Helmut) changed the validity of their key to an already gone date and published it to the keyserver. If you refresh, your local copy of this key is updated and every time it is accessed, it’ll error out because the key is not valid anymore. You can still reproduce this issue if you refresh this user’s key from the keyserver.
It works for the other user (Brett) because your local copy of the key has expired and they published a new one with a validity date.
Thanks all of you for this thread. I managed to make it work AND understand the problem.
So this situation is still temporary until Helmut publish a valid key on the keyservers, right ?
Also what about modifying the order of the troubleshooting commands in the wiki ?
Works!
Just have to put sudo rm -r /etc/pacman.d/gnupg instead.
However, if you disagree with my choice, please feel free to take any other answer as the solution to your question or even remove the solution altogether: You are in control! (If you disagree with my choice, just send me a personal message and explain why I shouldn’t have done this or
or
if you agree)
P.S. In the future, please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
great, this worked for me as well. Thanks! Quick question - you say you are upgrading via pamac, I remember having read somewhere here (while r/o) that this was the preferred method (above pacman -Syuu). Does it do anything else, that pacman does not? I could not find anything on that on the Pamac wiki page. Any pointers to documentation gladly taken, in case I missed something. Dank ju wel!
EDIT: I just realized this is probably off-topic. sorry.
EDITEDIT: @Fabby yes, I saw sawdoctor
and thanked by
but did not answer not to pollute the thread. wrong? sorry again. trying to get to grips with the forum etiquette
The main difference or me at least is pamac will update aur packages as well. There have been times the team have recommended pamac upgrade as it automatically fixed some dependency errors
4 posts were split to a new topic: How to install Manjaro from an ISO with outdatek keys
I tried to follow the guideline of @tomterl:
But get some errors:
gpg: error reading key: Kein öffentlicher Schlüssel
-> Disabled 3 keys.
and
-> Disabled 2 keys.
In consequence I cannot update with pamac:
Fehler: vlc: signature from "Antonio Rojas <arojas@archlinux.org>" is unknown trust
Fehler: vulkan-intel: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
Fehler: vulkan-radeon: signature from "Felix Yan <felixonmars@archlinux.org>" is unknown trust
Fehler: xf86-video-amdgpu: signature from "Andreas Radke <andyrtr@archlinux.org>" is unknown trust
Vorgang konnte nicht abgeschlossen werden:
Ungültiges oder beschädigtes Paket:
Can someone help?
