brahma:
sudo mkinitcpio -P
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'default'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64.img
==> Starting build: 5.15.76-1-MANJARO
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [consolefont]
==> WARNING: consolefont: no font found in configuration
-> Running build hook: [fsck]
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux515.preset: 'fallback'
-> -k /boot/vmlinuz-5.15-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.15-x86_64-fallback.img -S autodetect
==> WARNING: Possibly missing firmware for module: qed
==> WARNING: Possibly missing firmware for module: qla2xxx
==> WARNING: Possibly missing firmware for module: bfa
==> WARNING: Possibly missing firmware for module: qla1280
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.15-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux519.preset: 'default'
-> -k /boot/vmlinuz-5.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.19-x86_64.img
==> Starting build: 5.19.17-1-MANJARO
==> WARNING: Possibly missing firmware for module: xhci_pci
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.19-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux519.preset: 'fallback'
-> -k /boot/vmlinuz-5.19-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.19-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-5.19-x86_64-fallback.img
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'default'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64.img
==> Starting build: 6.0.6-1-MANJARO
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64.img
==> Building image from preset: /etc/mkinitcpio.d/linux60.preset: 'fallback'
-> -k /boot/vmlinuz-6.0-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-6.0-x86_64-fallback.img -S autodetect
==> Creating gzip-compressed initcpio image: /boot/initramfs-6.0-x86_64-fallback.img
Output:
Nov 03 00:36:05 keno-titan kernel: Linux version 5.15.76-1-MANJARO (builduser@fv-az214-469) (gcc (GCC) 12.2.0, GNU ld (GNU Binutils) 2.39.0) #1 SMP PREEMPT Sat Oct 29 14:22:16 UTC 2022
Nov 03 00:36:05 keno-titan kernel: Kernel command line: BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64 root=UUID=d3143134-238d-4390-a763-d67ccc6876a3 rw quiet apparmor=1 security=apparmor udev.log_priority=3
Nov 03 00:36:05 keno-titan kernel: Unknown kernel command line parameters "BOOT_IMAGE=/boot/vmlinuz-5.15-x86_64", will be passed to user space.
Nov 03 00:36:05 keno-titan kernel: #2 #3 #4 #5 #6 #7 #8 #9 #10 #11 #12 #13 #14 #15
Nov 03 00:36:05 keno-titan kernel: audit: type=2000 audit(1667432163.176:1): state=initialized audit_enabled=0 res=1
Nov 03 00:36:05 keno-titan kernel: ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
Nov 03 00:36:05 keno-titan kernel: SCSI subsystem initialized
Nov 03 00:36:05 keno-titan kernel: Expanded resource Reserved due to conflict with PCI Bus 0000:00
Nov 03 00:36:05 keno-titan kernel: VFS: Disk quotas dquot_6.6.0
Nov 03 00:36:05 keno-titan kernel: pci 0000:00:00.2: can't derive routing for PCI INT A
Nov 03 00:36:05 keno-titan kernel: pci 0000:00:00.2: PCI INT A: not connected
Nov 03 00:36:05 keno-titan kernel: Initialise system trusted keyrings
Nov 03 00:36:05 keno-titan kernel: Key type blacklist registered
Nov 03 00:36:05 keno-titan kernel: Key type asymmetric registered
Nov 03 00:36:05 keno-titan kernel: Asymmetric key parser 'x509' registered
Nov 03 00:36:05 keno-titan kernel: Loading compiled-in X.509 certificates
Nov 03 00:36:05 keno-titan kernel: Loaded X.509 cert 'Build time autogenerated kernel key: 68a427c4edde4c83cfe81268a7da6ca1fa25f99b'
Nov 03 00:36:05 keno-titan kernel: Key type ._fscrypt registered
Nov 03 00:36:05 keno-titan kernel: Key type .fscrypt registered
Nov 03 00:36:05 keno-titan kernel: Key type fscrypt-provisioning registered
Nov 03 00:36:05 keno-titan kernel: i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
Nov 03 00:36:05 keno-titan kernel: random: lvm: uninitialized urandom read (4 bytes read)
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.313:2): apparmor="STATUS" operation="profile_load" profile="unconfined" name="klogd" pid=377 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.326:3): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe" pid=369 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.326:4): apparmor="STATUS" operation="profile_load" profile="unconfined" name="nvidia_modprobe//kmod" pid=369 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.336:5): apparmor="STATUS" operation="profile_load" profile="unconfined" name="ping" pid=365 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.343:6): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-rpcd" pid=374 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.343:7): apparmor="STATUS" operation="profile_load" profile="unconfined" name="samba-dcerpcd" pid=373 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.343:8): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mariadbd_akonadi" pid=367 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.343:9): apparmor="STATUS" operation="profile_load" profile="unconfined" name="mysqld_akonadi" pid=368 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan kernel: audit: type=1400 audit(1667432165.349:10): apparmor="STATUS" operation="profile_load" profile="unconfined" name="lsb_release" pid=366 comm="apparmor_parser"
Nov 03 00:36:05 keno-titan systemd-random-seed[359]: Kernel entropy pool is not initialized yet, waiting until it is.
Nov 03 00:36:05 keno-titan kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
Nov 03 00:36:05 keno-titan kernel: acpi PNP0C14:01: duplicate WMI GUID ABBC0F6A-8EA1-11D1-00A0-C90629100000 (first instance was on PNP0C14:00)
Nov 03 00:36:05 keno-titan kernel: acpi PNP0C14:01: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:00)
Nov 03 00:36:05 keno-titan kernel: ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PCI0.GP17.VGA.LCD._BCM.AFN7], AE_NOT_FOUND (20210730/psargs-330)
Nov 03 00:36:05 keno-titan kernel: ACPI Error: Aborting method \_SB.PCI0.GP17.VGA.LCD._BCM due to previous error (AE_NOT_FOUND) (20210730/psparse-529)
Nov 03 00:36:05 keno-titan kernel: ccp 0000:06:00.2: ccp: unable to access the device: you might be running a broken BIOS.
Nov 03 00:36:05 keno-titan kernel: ccp 0000:06:00.2: tee enabled
Nov 03 00:36:05 keno-titan kernel: ccp 0000:06:00.2: psp enabled
Nov 03 00:36:06 keno-titan kernel: cfg80211: Loading compiled-in X.509 certificates for regulatory database
Nov 03 00:36:06 keno-titan kernel: cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
Nov 03 00:36:06 keno-titan kernel: iwlwifi 0000:04:00.0: api flags index 2 larger than supported by driver
Nov 03 00:36:06 keno-titan kernel: random: tlp-readconfs: uninitialized urandom read (4 bytes read)
Nov 03 00:36:06 keno-titan ntfs-3g[762]: Version 2022.5.17 external FUSE 29
Nov 03 00:36:06 keno-titan ntfs-3g[762]: Mounted /dev/nvme0n1p3 (Read-Write, label "", NTFS 3.1)
Nov 03 00:36:06 keno-titan ntfs-3g[762]: Cmdline options: rw
Nov 03 00:36:06 keno-titan ntfs-3g[762]: Mount options: allow_other,nonempty,relatime,rw,fsname=/dev/nvme0n1p3,blkdev,blksize=4096
Nov 03 00:36:06 keno-titan ntfs-3g[762]: Ownership and permissions disabled, configuration type 7
Nov 03 00:36:06 keno-titan ntfs-3g[781]: Version 2022.5.17 external FUSE 29
Nov 03 00:36:06 keno-titan ntfs-3g[781]: Mounted /dev/nvme1n1p1 (Read-Write, label "Data", NTFS 3.1)
Nov 03 00:36:06 keno-titan ntfs-3g[781]: Cmdline options: rw
Nov 03 00:36:06 keno-titan ntfs-3g[781]: Mount options: allow_other,nonempty,relatime,rw,fsname=/dev/nvme1n1p1,blkdev,blksize=4096
Nov 03 00:36:06 keno-titan ntfs-3g[781]: Ownership and permissions disabled, configuration type 7
Nov 03 00:36:06 keno-titan kernel: asus_wmi: ASUS Management GUID not found
Nov 03 00:36:06 keno-titan kernel: random: crng init done
Nov 03 00:36:06 keno-titan kernel: random: 7 urandom warning(s) missed due to ratelimiting
Nov 03 00:36:06 keno-titan kernel: clocksource: timekeeping watchdog on CPU4: Marking clocksource 'tsc' as unstable because the skew is too large:
Nov 03 00:36:06 keno-titan kernel: clocksource: 'hpet' wd_nsec: 510861575 wd_now: 22a14ab wd_last: 1ba77fb mask: ffffffff
Nov 03 00:36:06 keno-titan kernel: clocksource: 'tsc' cs_nsec: 509992206 cs_now: bce3598a0 cs_last: b69e9e825 mask: ffffffffffffffff
Nov 03 00:36:06 keno-titan kernel: clocksource: 'tsc' is current clocksource.
Nov 03 00:36:06 keno-titan kernel: TSC found unstable after boot, most likely due to broken BIOS. Use 'tsc=unstable'.
Nov 03 00:36:06 keno-titan kernel: clocksource: Checking clocksource tsc synchronization from CPU 0 to CPUs 1-2,4-5,7,11-12.
Nov 03 00:36:06 keno-titan kernel: thermal thermal_zone1: failed to read out thermal zone (-61)
Nov 03 00:36:06 keno-titan polkitd[859]: Loading rules from directory /etc/polkit-1/rules.d
Nov 03 00:36:06 keno-titan polkitd[859]: Loading rules from directory /usr/share/polkit-1/rules.d
Nov 03 00:36:06 keno-titan polkitd[859]: Finished loading, compiling and executing 8 rules
Nov 03 00:36:06 keno-titan polkitd[859]: Acquired the name org.freedesktop.PolicyKit1 on the system bus
Nov 03 00:36:07 keno-titan systemd[1339]: ConfigurationDirectory 'bluetooth' already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Nov 03 00:36:07 keno-titan kernel: scsi 0:0:0:0: Direct-Access Generic- SD/MMC 1.00 PQ: 0 ANSI: 6
Nov 03 00:36:07 keno-titan kernel: sd 0:0:0:0: Attached scsi generic sg0 type 0
Nov 03 00:36:07 keno-titan kernel: sd 0:0:0:0: [sda] Media removed, stopped polling
Nov 03 00:36:07 keno-titan kernel: sd 0:0:0:0: [sda] Attached SCSI removable disk
Nov 03 00:36:07 keno-titan kernel: hid-generic 0003:1038:12C4.0004: No inputs registered, leaving
Nov 03 00:36:07 keno-titan kernel: usbhid 3-3.1:1.0: couldn't find an input interrupt endpoint
Nov 03 00:36:07 keno-titan wpa_supplicant[1452]: Successfully initialized wpa_supplicant
Nov 03 00:36:09 keno-titan kernel: kauditd_printk_skb: 413 callbacks suppressed
Nov 03 00:36:09 keno-titan kernel: audit: type=1326 audit(1667432169.462:189): auid=4294967295 uid=0 gid=0 ses=4294967295 subj=snap.cups.cupsd (enforce) pid=1264 comm="cupsd" exe="/snap/cups/836/sbin/cupsd" sig=0 arch=c000003e syscall=93 compat=0 ip=0x7fb3c906c39b code=0x50000
Nov 03 00:36:10 keno-titan wpa_supplicant[1452]: wlp4s0: CTRL-EVENT-REGDOM-CHANGE init=DRIVER type=COUNTRY alpha2=DE
Nov 03 00:36:13 keno-titan kernel: audit: type=1130 audit(1667432173.232:190): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-wait-online comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:13 keno-titan kernel: audit: type=1400 audit(1667432173.595:191): apparmor="STATUS" operation="profile_load" profile="unconfined" name="docker-default" pid=1643 comm="apparmor_parser"
Nov 03 00:36:13 keno-titan kernel: audit: type=1300 audit(1667432173.595:191): arch=c000003e syscall=1 success=yes exit=7945 a0=4 a1=5612a30d4670 a2=1f09 a3=0 items=0 ppid=1642 pid=1643 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="apparmor_parser" exe="/usr/bin/apparmor_parser" subj=unconfined key=(null)
Nov 03 00:36:13 keno-titan kernel: audit: type=1327 audit(1667432173.595:191): proctitle=61707061726D6F725F706172736572002D4B72002F7661722F6C69622F646F636B65722F746D702F646F636B65722D64656661756C7432333136393232313835
Nov 03 00:36:14 keno-titan kernel: Bridge firewalling registered
Nov 03 00:36:14 keno-titan kernel: audit: type=1325 audit(1667432174.368:192): table=nat family=2 entries=0 op=xt_register pid=1665 subj=unconfined comm="iptables"
Nov 03 00:36:14 keno-titan kernel: audit: type=1300 audit(1667432174.368:192): arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffda8da1da0 items=0 ppid=1607 pid=1665 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj=unconfined key=(null)
Nov 03 00:36:14 keno-titan kernel: audit: type=1327 audit(1667432174.368:192): proctitle=2F7573722F62696E2F69707461626C6573002D2D77616974002D74006E6174002D4C002D6E
Nov 03 00:36:14 keno-titan kernel: audit: type=1325 audit(1667432174.395:193): table=filter family=2 entries=0 op=xt_register pid=1667 subj=unconfined comm="iptables"
Nov 03 00:36:14 keno-titan kernel: audit: type=1300 audit(1667432174.395:193): arch=c000003e syscall=55 success=yes exit=0 a0=4 a1=0 a2=40 a3=7ffd7baf1fa0 items=0 ppid=1607 pid=1667 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj=unconfined key=(null)
Nov 03 00:36:14 keno-titan kernel: kauditd_printk_skb: 28 callbacks suppressed
Nov 03 00:36:14 keno-titan kernel: audit: type=1325 audit(1667432174.465:203): table=filter family=2 entries=12 op=xt_replace pid=1712 subj=unconfined comm="iptables"
Nov 03 00:36:14 keno-titan kernel: audit: type=1300 audit(1667432174.465:203): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5564c9e9c1b0 items=0 ppid=1607 pid=1712 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj=unconfined key=(null)
Nov 03 00:36:14 keno-titan kernel: audit: type=1327 audit(1667432174.465:203): proctitle=2F7573722F62696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D690062722D373861653165333966633565002D6F0062722D373861653165333966633565002D6A00414343455054
Nov 03 00:36:14 keno-titan kernel: audit: type=1325 audit(1667432174.465:204): table=filter family=2 entries=13 op=xt_replace pid=1714 subj=unconfined comm="iptables"
Nov 03 00:36:14 keno-titan kernel: audit: type=1300 audit(1667432174.465:204): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=55ef6e6c2330 items=0 ppid=1607 pid=1714 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj=unconfined key=(null)
Nov 03 00:36:14 keno-titan kernel: audit: type=1327 audit(1667432174.465:204): proctitle=2F7573722F62696E2F69707461626C6573002D2D77616974002D4900464F5257415244002D690062722D3738616531653339666335650000002D6F0062722D373861653165333966633565002D6A00414343455054
Nov 03 00:36:14 keno-titan kernel: audit: type=1325 audit(1667432174.468:205): table=nat family=2 entries=9 op=xt_replace pid=1716 subj=unconfined comm="iptables"
Nov 03 00:36:14 keno-titan kernel: audit: type=1300 audit(1667432174.468:205): arch=c000003e syscall=54 success=yes exit=0 a0=4 a1=0 a2=40 a3=5600320e0570 items=0 ppid=1607 pid=1716 auid=4294967295 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=0 fsgid=0 tty=(none) ses=4294967295 comm="iptables" exe="/usr/bin/xtables-legacy-multi" subj=unconfined key=(null)
Nov 03 00:36:14 keno-titan kernel: audit: type=1327 audit(1667432174.468:205): proctitle=2F7573722F62696E2F69707461626C6573002D2D77616974002D74006E6174002D4100505245524F5554494E47002D6D006164647274797065002D2D6473742D74797065004C4F43414C002D6A00444F434B4552
Nov 03 00:36:14 keno-titan kernel: audit: type=1325 audit(1667432174.468:206): table=nat family=2 entries=10 op=xt_replace pid=1718 subj=unconfined comm="iptables"
Nov 03 00:36:27 keno-titan kernel: kauditd_printk_skb: 235 callbacks suppressed
Nov 03 00:36:27 keno-titan kernel: audit: type=1131 audit(1667432187.272:286): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:29 keno-titan kernel: audit: type=1130 audit(1667432189.875:287): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=getty@tty3 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:35 keno-titan kernel: audit: type=1100 audit(1667432195.275:288): pid=2166 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:authentication grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="keno" exe="/usr/bin/login" hostname=keno-titan addr=? terminal=/dev/tty3 res=success'
Nov 03 00:36:35 keno-titan kernel: audit: type=1101 audit(1667432195.308:289): pid=2166 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="keno" exe="/usr/bin/login" hostname=keno-titan addr=? terminal=/dev/tty3 res=success'
Nov 03 00:36:35 keno-titan kernel: audit: type=1103 audit(1667432195.308:290): pid=2166 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=pam_securetty,pam_shells,pam_faillock,pam_permit,pam_faillock acct="keno" exe="/usr/bin/login" hostname=keno-titan addr=? terminal=/dev/tty3 res=success'
Nov 03 00:36:35 keno-titan kernel: audit: type=1006 audit(1667432195.308:291): pid=2166 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=tty3 old-ses=4294967295 ses=1 res=1
Nov 03 00:36:35 keno-titan kernel: audit: type=1300 audit(1667432195.308:291): arch=c000003e syscall=1 success=yes exit=4 a0=5 a1=7ffe3d4a46f0 a2=4 a3=7ffe3d4a4404 items=0 ppid=1 pid=2166 auid=1000 uid=0 gid=0 euid=0 suid=0 fsuid=0 egid=0 sgid=1000 fsgid=0 tty=tty3 ses=1 comm="login" exe="/usr/bin/login" subj=unconfined key=(null)
Nov 03 00:36:35 keno-titan kernel: audit: type=1327 audit(1667432195.308:291): proctitle=2F62696E2F6C6F67696E002D70002D2D
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: WPS-CANCEL
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: SME: Trying to authenticate with 98:9b:cb:c2:79:45 (SSID='FRITZ!Box 7530 PX' freq=5620 MHz)
Nov 03 00:36:35 keno-titan kernel: audit: type=1130 audit(1667432195.365:292): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=user-runtime-dir@1000 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:35 keno-titan systemd[2168]: pam_warn(systemd-user:setcred): function=[pam_sm_setcred] flags=0x8002 service=[systemd-user] terminal=[] user=[keno] ruser=[<unknown>] rhost=[<unknown>]
Nov 03 00:36:35 keno-titan kernel: audit: type=1101 audit(1667432195.368:293): pid=2168 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:accounting grantors=pam_access,pam_unix,pam_permit,pam_time acct="keno" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:35 keno-titan kernel: audit: type=1103 audit(1667432195.368:294): pid=2168 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=PAM:setcred grantors=? acct="keno" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=failed'
Nov 03 00:36:35 keno-titan kernel: audit: type=1006 audit(1667432195.368:295): pid=2168 uid=0 subj=unconfined old-auid=4294967295 auid=1000 tty=(none) old-ses=4294967295 ses=2 res=1
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: Trying to associate with 98:9b:cb:c2:79:45 (SSID='FRITZ!Box 7530 PX' freq=5620 MHz)
Nov 03 00:36:35 keno-titan systemd-xdg-autostart-generator[2174]: /home/keno/.config/autostart/org.moson.matray.desktop:15: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Nov 03 00:36:35 keno-titan systemd-xdg-autostart-generator[2174]: /home/keno/.config/autostart/org.kde.latte-dock.desktop:74: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: Associated with 98:9b:cb:c2:79:45
Nov 03 00:36:35 keno-titan systemd-xdg-autostart-generator[2174]: /home/keno/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
Nov 03 00:36:35 keno-titan systemd-xdg-autostart-generator[2174]: /home/keno/.config/autostart/ownCloud.desktop: not generating unit, error parsing Exec= line: No such file or directory
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: WPA: Key negotiation completed with 98:9b:cb:c2:79:45 [PTK=CCMP GTK=CCMP]
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: CTRL-EVENT-CONNECTED - Connection to 98:9b:cb:c2:79:45 completed [id=0 id_str=]
Nov 03 00:36:35 keno-titan wpa_supplicant[1452]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=0 signal=-63 noise=9999 txrate=0
Nov 03 00:36:37 keno-titan wpa_supplicant[1452]: wlp4s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-65 noise=9999 txrate=26000
Nov 03 00:36:41 keno-titan kernel: nvidia: loading out-of-tree module taints kernel.
Nov 03 00:36:41 keno-titan kernel: nvidia: module license 'NVIDIA' taints kernel.
Nov 03 00:36:41 keno-titan kernel: Disabling lock debugging due to kernel taint
Nov 03 00:36:41 keno-titan kernel: nvidia: module verification failed: signature and/or required key missing - tainting kernel
Nov 03 00:36:41 keno-titan kernel: NVRM: loading NVIDIA UNIX x86_64 Kernel Module 520.56.06 Thu Oct 6 21:38:55 UTC 2022
Nov 03 00:36:41 keno-titan kernel: ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Nov 03 00:36:41 keno-titan kernel: ACPI Warning: \_SB.PCI0.GPP0.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20210730/nsarguments-61)
Nov 03 00:36:42 keno-titan kernel: kauditd_printk_skb: 22 callbacks suppressed
Nov 03 00:36:42 keno-titan kernel: audit: type=1130 audit(1667432202.962:312): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-backlight@backlight:nvidia_0 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:45 keno-titan kernel: audit: type=1130 audit(1667432205.359:313): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=rtkit-daemon comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:45 keno-titan pipewire-media-session[2542]: mod.rt: Can't find xdg-portal: (null)
Nov 03 00:36:45 keno-titan pipewire-media-session[2542]: mod.rt: found session bus but no portal
Nov 03 00:36:45 keno-titan pipewire[2541]: mod.rt: Can't find xdg-portal: (null)
Nov 03 00:36:45 keno-titan pipewire[2541]: mod.rt: found session bus but no portal
Nov 03 00:36:45 keno-titan gnome-keyring-daemon[2584]: The Secret Service was already initialized
Nov 03 00:36:45 keno-titan gnome-keyring-d[2584]: The Secret Service was already initialized
Nov 03 00:36:45 keno-titan gnome-keyring-daemon[2550]: discover_other_daemon: 1
Nov 03 00:36:46 keno-titan udisksd[2710]: udisks daemon version 2.9.4 starting
Nov 03 00:36:46 keno-titan kernel: audit: type=1131 audit(1667432206.905:314): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=NetworkManager-dispatcher comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:46 keno-titan kernel: audit: type=1130 audit(1667432206.928:315): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=udisks2 comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:46 keno-titan udisksd[2710]: Cleaning up mount point /media/Data (device 259:6 is not mounted)
Nov 03 00:36:46 keno-titan udisksd[2710]: Error cleaning up mount point /media/Data: Error removing directory: Device or resource busy
Nov 03 00:36:46 keno-titan kernel: audit: type=1334 audit(1667432206.962:316): prog-id=22 op=LOAD
Nov 03 00:36:46 keno-titan kernel: audit: type=1334 audit(1667432206.962:317): prog-id=23 op=LOAD
Nov 03 00:36:46 keno-titan udisksd[2710]: Acquired the name org.freedesktop.UDisks2 on the system message bus
Nov 03 00:36:47 keno-titan kernel: audit: type=1130 audit(1667432207.089:318): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=upower comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:47 keno-titan kernel: audit: type=1400 audit(1667432207.180:319): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=2812 comm="snap-confine" capability=12 capname="net_admin"
Nov 03 00:36:47 keno-titan kernel: audit: type=1400 audit(1667432207.180:319): apparmor="DENIED" operation="capable" profile="/usr/lib/snapd/snap-confine" pid=2812 comm="snap-confine" capability=38 capname="perfmon"
Nov 03 00:36:47 keno-titan kernel: audit: type=1334 audit(1667432207.180:319): prog-id=24 op=LOAD
Nov 03 00:36:47 keno-titan teams.desktop[2812]: /user.slice/user-1000.slice/session-1.scope is not a snap cgroup
Nov 03 00:36:47 keno-titan polkitd[859]: Registered Authentication Agent for unix-session:1 (system bus name :1.89 [/usr/lib/polkit-kde-authentication-agent-1], object path /org/kde/PolicyKit1/AuthenticationAgent, locale de_DE.UTF-8)
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3288]: /home/keno/.config/autostart/org.moson.matray.desktop:15: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3288]: /home/keno/.config/autostart/org.kde.latte-dock.desktop:74: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3288]: /home/keno/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3288]: /home/keno/.config/autostart/ownCloud.desktop: not generating unit, error parsing Exec= line: No such file or directory
Nov 03 00:36:47 keno-titan ntfs-3g[781]: Could not load plugin /usr/lib/ntfs-3g/ntfs-plugin-9000001a.so: Can not access a needed shared library
Nov 03 00:36:47 keno-titan ntfs-3g[781]: Hint /usr/lib/ntfs-3g/ntfs-plugin-9000001a.so: cannot open shared object file: No such file or directory
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3418]: /home/keno/.config/autostart/org.moson.matray.desktop:15: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3418]: /home/keno/.config/autostart/org.kde.latte-dock.desktop:74: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3418]: /home/keno/.config/autostart/org.kde.latte-dock.desktop:114: Unknown key name 'TerminalOptions' in section 'Desktop Entry', ignoring.
Nov 03 00:36:47 keno-titan systemd-xdg-autostart-generator[3418]: /home/keno/.config/autostart/ownCloud.desktop: not generating unit, error parsing Exec= line: No such file or directory
Nov 03 00:36:48 keno-titan pulseaudio[2755]: stat('/etc/pulse/default.pa.d'): No such file or directory
Nov 03 00:36:48 keno-titan pulseaudio[2755]: Doing resync
Nov 03 00:36:48 keno-titan pulseaudio[2755]: Playback too far ahead (100759), drop source 19344
Nov 03 00:36:48 keno-titan pulseaudio[2755]: Could not find org.bluez.BatteryProviderManager1.RegisterBatteryProvider(), is bluetoothd started with experimental features enabled (-E flag)?
Nov 03 00:36:49 keno-titan kernel: kauditd_printk_skb: 3 callbacks suppressed
Nov 03 00:36:49 keno-titan kernel: audit: type=1400 audit(1667432209.258:321): apparmor="DENIED" operation="open" profile="mariadbd_akonadi" name="/sys/block/" pid=3653 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Nov 03 00:36:49 keno-titan kernel: audit: type=1300 audit(1667432209.258:321): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=55dffa8b45e0 a2=90800 a3=0 items=0 ppid=3568 pid=3653 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=1 comm="mysqld" exe="/usr/bin/mariadbd" subj=mariadbd_akonadi (enforce) key=(null)
Nov 03 00:36:49 keno-titan kernel: audit: type=1327 audit(1667432209.258:321): proctitle=2F7573722F62696E2F6D7973716C64002D2D64656661756C74732D66696C653D2F686F6D652F6B656E6F2F2E6C6F63616C2F73686172652F616B6F6E6164692F6D7973716C2E636F6E66002D2D646174616469723D2F686F6D652F6B656E6F2F2E6C6F63616C2F73686172652F616B6F6E6164692F64625F646174612F002D2D
Nov 03 00:36:49 keno-titan kernel: audit: type=1400 audit(1667432209.262:322): apparmor="DENIED" operation="open" profile="mariadbd_akonadi" name="/sys/devices/pci0000:00/0000:00:02.1/0000:03:00.0/nvme/nvme0/nvme0n1/queue/physical_block_size" pid=3653 comm="mysqld" requested_mask="r" denied_mask="r" fsuid=1000 ouid=0
Nov 03 00:36:49 keno-titan kernel: audit: type=1300 audit(1667432209.262:322): arch=c000003e syscall=257 success=no exit=-13 a0=ffffff9c a1=7ffced5f2000 a2=0 a3=0 items=0 ppid=3568 pid=3653 auid=1000 uid=1000 gid=1000 euid=1000 suid=1000 fsuid=1000 egid=1000 sgid=1000 fsgid=1000 tty=(none) ses=1 comm="mysqld" exe="/usr/bin/mariadbd" subj=mariadbd_akonadi (enforce) key=(null)
Nov 03 00:36:49 keno-titan kernel: audit: type=1327 audit(1667432209.262:322): proctitle=2F7573722F62696E2F6D7973716C64002D2D64656661756C74732D66696C653D2F686F6D652F6B656E6F2F2E6C6F63616C2F73686172652F616B6F6E6164692F6D7973716C2E636F6E66002D2D646174616469723D2F686F6D652F6B656E6F2F2E6C6F63616C2F73686172652F616B6F6E6164692F64625F646174612F002D2D
Nov 03 00:36:49 keno-titan kernel: audit: type=1111 audit(1667432209.627:323): pid=878 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=statistics interface="enp2s0" ifindex=2 args=500 pid=3706 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:49 keno-titan kernel: audit: type=1111 audit(1667432209.647:324): pid=878 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='op=statistics interface="wlp4s0" ifindex=3 args=500 pid=3706 uid=1000 result=success exe="/usr/bin/NetworkManager" hostname=? addr=? terminal=? res=success'
Nov 03 00:36:49 keno-titan kernel: audit: type=1334 audit(1667432209.724:325): prog-id=25 op=LOAD
Nov 03 00:36:49 keno-titan kernel: audit: type=1334 audit(1667432209.724:326): prog-id=26 op=LOAD
Nov 03 00:37:19 keno-titan kernel: kauditd_printk_skb: 3 callbacks suppressed
Nov 03 00:37:19 keno-titan kernel: audit: type=1131 audit(1667432239.843:330): pid=1 uid=0 auid=4294967295 ses=4294967295 subj=unconfined msg='unit=systemd-hostnamed comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=? res=success'
Nov 03 00:37:20 keno-titan kernel: audit: type=1334 audit(1667432240.040:331): prog-id=0 op=UNLOAD
Nov 03 00:37:20 keno-titan kernel: audit: type=1334 audit(1667432240.040:332): prog-id=0 op=UNLOAD
Nov 03 00:37:20 keno-titan kernel: audit: type=1334 audit(1667432240.040:333): prog-id=0 op=UNLOAD
Nov 03 00:37:43 keno-titan firefox[4818]: Failed to load module "appmenu-gtk-module"
Nov 03 00:37:44 keno-titan org.a11y.Bus[4885]: dbus-daemon[4885]: Activating service name='org.a11y.atspi.Registry' requested by ':1.0' (uid=1000 pid=2783 comm="/usr/bin/pamac-tray-plasma")
Nov 03 00:37:44 keno-titan org.a11y.Bus[4885]: dbus-daemon[4885]: Successfully activated service 'org.a11y.atspi.Registry'
