Main screen treated as secondary screen
Hi, after trying to setup my pc with a secondary screen, i’ve ran into an issue : my main screen (1920*1080) has adopted the resolution of my secondary screen (1, and when i change the resolution, it always defaults back to the wrong one after a reboot. Also, the KDE taskbar doesn’t show up anymore (but is present on the second screen when i connect it), making it really annoying to do anything. I think it might be that my laptop screen is treated as a secondary screen for some reason
Does someone knows how to fix this ? Thanks in advance
I saw that the output of xrandr might be useful, so here it is :
creen 0: minimum 16 x 16, current 1280 x 720, maximum 32767 x 32767
XWAYLAND0 connected primary 1280x720+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
   1280x720      59.86*+
   800x600       59.86
   640x480       59.38
   320x240       59.52
   720x480       59.71
   640x400       59.95
   320x200       58.96
   1024x576      59.90
   864x486       59.92
   720x400       59.55
   640x350       59.77
Hi,
Actually not quite … You are running Wayland session.
Use the X11 one.
Well, i guess it worked, but now all my pinned programs are gone, is this normal ?
Nevertheless, thanks a lot !!
X11 and Wayland sessions do not share quite well (yet) the Desktop Settings, hence whatever you did in one might have to do again in the other. Is not normal, but is still in development. :sweat_smile:
