Is it possible to install macOS as a virtual machine on Manjaro?
Some advice?
Thanks.
Some advice?
Thanks.
Yes, it probably is. However, I believe that licensing only allows you to do that in macOS; possibly using VMware Fusion, or Parallels Desktop, for example.
Maybe. However, we will not help you potentially violate the terms you agreed to when you purchased a license for macOS.
