MacBook Pro won't detect or connect to WIFI (BCM4322)
Hi,
I just installed Manjaro on my old 2010 13" MacBook Pro (2.4GHz Core 2 Duo P8600, Nvidia GForce 320M), but unfortunately it doesn’t connect to a WIFI-network, nor does it even detect any.
I have tried to solve the problem using the “Broadcom wifi driver fails to install properly”-guide (I’m sorry, but I can’t paste the link here because otherwise I always get an error message when I try to put the post online) but that didn’t really help.
Every time I follow the instructions under "Drivers detected as “b43-pci-bridge” " (the first part of the instructions doesn’t work for me at all), the system at least recognizes the networks in my area, but I can’t connect to them because supposedly the password is wrong every time. When I then do a reboot, everything is as before.
Since I am realtively new to Linux, it would be great if someone could help me with this problem.
Thanks in advance,
Aaron
PS: Here are a few outputs that might be helpful
**inxi -Fxxxza**
    **System: Kernel:** 5.9.16-1-MANJARO x86_64 **bits:** 64 **compiler:** gcc **v:** 10.2.0
    **parameters:** BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64 root=UUID=d47feabf-aa40-44df-b11a-7110b7417f04 rw quiet
    **Desktop:** KDE Plasma 5.20.4 **tk:** Qt 5.15.2 **wm:** kwin_x11 **dm:** SDDM **Distro:** Manjaro Linux
    **Machine: Type:** Laptop **System:** Apple **product:** MacBookPro7,1 **v:** 1.0 **serial:** <filter> **Chassis:type:** 10 **v:** Mac-F222BEC8
    **Mobo:** Apple **model:** Mac-F222BEC8 **serial:** <filter> **UEFI:** Apple **v:** 68.0.0.0.0 **date:** 06/13/2019
    **Battery: ID-1:** BAT0 **charge:** 25.6 Wh **condition:** 66.0/62.9 Wh (105%) **volts:** 11.5/10.9 **model:** SMP bq20z451 **type:** Li-ion
    **serial:** N/A **status:** Charging **cycles:** 12
    **CPU: Info:** Dual Core **model:** Intel Core2 Duo P8600 **bits:** 64 **type:** MCP **arch:** Penryn **family:** 6 **model-id:** 17 (23)
    **stepping:** A (10) **microcode:** A0B **L2 cache:** 3 MiB
    **flags:** lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx **bogomips:** 9558
    **Speed:** 796 MHz **min/max:** 798/2394 MHz **Core speeds (MHz):1:** 796 **2:** 796
    **Vulnerabilities:Type:** itlb_multihit **status:** KVM: VMX disabled
    **Type:** l1tf **mitigation:** PTE Inversion; VMX: EPT disabled
    **Type:** mds **status:** Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
    **Type:** meltdown **mitigation:** PTI
    **Type:** spec_store_bypass **status:** Vulnerable
    **Type:** spectre_v1 **mitigation:** usercopy/swapgs barriers and __user pointer sanitization
    **Type:** spectre_v2 **mitigation:** Full generic retpoline, STIBP: disabled, RSB filling
    **Type:** srbds **status:** Not affected
    **Type:** tsx_async_abort **status:** Not affected
    **Graphics: Device-1:** NVIDIA MCP89 [GeForce 320M] **vendor:** Apple **driver:** nouveau **v:** kernel **bus ID:** 04:00.0
    **chip ID:** 10de:08a0
    **Device-2:** Apple Built-in iSight **type:** USB **driver:** uvcvideo **bus ID:** 1-6:3 **chip ID:** 05ac:8507 **serial:** <filter>
    **Display:** x11 **server:** X.Org 1.20.10 **compositor:** kwin_x11 **driver:** nouveau **unloaded:** modesetting
    **alternate:** fbdev,nv,vesa **display ID:** :0 **screens:** 1
    **Screen-1:** 0 **s-res:** 1280x800 **s-dpi:** 96 **s-size:** 338x211mm (13.3x8.3") **s-diag:** 398mm (15.7")
    **Monitor-1:** LVDS-1 **res:** 1280x800 **hz:** 60 **dpi:** 114 **size:** 286x179mm (11.3x7.0") **diag:** 337mm (13.3")
    **OpenGL:renderer:** NVAF **v:** 3.3 Mesa 20.3.1 **direct render:** Yes
    **Audio: Device-1:** NVIDIA MCP89 High Definition Audio **driver:** snd_hda_intel **v:** kernel **bus ID:** 00:08.0
    **chip ID:** 10de:0d94
    **Sound Server:** ALSA **v:** k5.9.16-1-MANJARO
    **Network: Device-1:** Broadcom BCM4322 802.11a/b/g/n Wireless LAN **vendor:** Apple AirPort Extreme **driver:** wl **v:** kernel
    **modules:** ssb **port:** 2280 **bus ID:** 02:00.0 **chip ID:** 14e4:432b
    **IF:** wlp2s0 **state:** dormant **mac:** <filter>
    **Device-2:** Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe **driver:** tg3 **v:** kernel **port:** 2280 **bus ID:** 03:00.0
    **chip ID:** 14e4:1684
    **IF:** enp3s0 **state:** down **mac:** <filter>
    **Drives: Local Storage:total:** 523.04 GiB **used:** 11.56 GiB (2.2%)
    **SMART Message:** Unable to run smartctl. Root privileges required.
    **ID-1:** /dev/sda **maj-min:** 8:0 **vendor:** Samsung **model:** SSD 850 EVO 500GB **size:** 465.76 GiB **block size:**
    **physical:** 512 B **logical:** 512 B **speed:** 3.0 Gb/s **serial:** <filter> **rev:** 3B6Q
    **ID-2:** /dev/sdb **maj-min:** 8:16 **type:** USB **vendor:** SanDisk **model:** Ultra Fit **size:** 57.28 GiB **block size:**
    **physical:** 512 B **logical:** 512 B **serial:** <filter> **rev:** 1.00
    **SMART Message:** Unknown USB bridge. Flash drive/Unsupported enclosure?
    **Partition: ID-1:** / **raw size:** 139.48 GiB **size:** 136.29 GiB (97.71%) **used:** 11.54 GiB (8.5%) **fs:** ext4 **dev:** /dev/sda3
    **maj-min:** 8:3
    **ID-2:** /boot/efi **raw size:** 200 MiB **size:** 196.9 MiB (98.45%) **used:** 20 MiB (10.2%) **fs:** vfat **dev:** /dev/sda1
    **maj-min:** 8:1
    **Swap: Alert:** No Swap data was found.
    **Sensors: System Temperatures:cpu:** 49.0 C **mobo:** N/A **gpu:** nouveau **temp:** 58.0 C
    **Fan Speeds (RPM):** N/A
    **Info: Processes:** 178 **Uptime:** 46m **wakeups:** 2 **Memory:** 3.59 GiB **used:** 1014 MiB (27.6%) **Init:** systemd **v:** 247 **Compilers:**
    **gcc:** 10.2.0 **Packages:** 1257 **pacman:** 1252 **lib:** 375 **flatpak:** 0 **snap:** 5 **Shell:** Bash **v:** 5.1.0 **running in:** konsole
    **inxi:** 3.2.01
**dkms status**
    broadcom-wl, 6.30.223.271, 5.9.16-1-MANJARO, x86_64: installed
**rfkill list all**
    0: phy0: Wireless LAN
            Soft blocked: no
            Hard blocked: no
    1: hci0: Bluetooth
            Soft blocked: no
            Hard blocked: no
**lsmod | sort**
    Module                  Size  Used by
    ac                     16384  0
    acpi_als               20480  0
    acpi_cpufreq           28672  1
    agpgart                53248  3 ttm,nouveau,drm
    apple_bl               20480  0
    apple_mfi_fastcharge    20480  0
    applesmc               24576  0
    bcm5974                24576  0
    blake2b_generic        20480  0
    bluetooth             741376  37 btrtl,btintel,btbcm,bnep,btusb,rfcomm
    bnep                   28672  2
    btbcm                  20480  1 btusb
    btintel                32768  1 btusb
    btrfs                1527808  0
    btrtl                  24576  1 btusb
    btusb                  69632  0
    cdrom                  77824  3 hfsplus,hfs,sr_mod
    cec                    73728  1 drm_kms_helper
    cfg80211              913408  1 wl
    coretemp               20480  0
    crc16                  16384  2 bluetooth,ext4
    crc32c_generic         16384  3
    crc_itu_t              16384  1 firewire_core
    crypto_user            16384  0
    dm_mod                163840  0
    drm                   585728  14 drm_kms_helper,ttm,nouveau
    drm_kms_helper        266240  1 nouveau
    ecc                    36864  1 ecdh_generic
    ecdh_generic           16384  1 bluetooth
    ehci_hcd               98304  1 ehci_pci
    ehci_pci               20480  0
    evdev                  28672  14
    ext4                  815104  1
    fat                    86016  2 msdos,vfat
    fb_sys_fops            16384  1 drm_kms_helper
    firewire_core          81920  1 firewire_ohci
    firewire_ohci          45056  0
    fuse                  139264  7
    hfs                    73728  0
    hfsplus               122880  0
    hid                   147456  4 usbhid,hid_apple,hid_generic,hid_appleir
    hid_apple              16384  0
    hid_appleir            16384  0
    hid_generic            16384  0
    i2c_algo_bit           16384  1 nouveau
    industrialio           90112  2 acpi_als,kfifo_buf
    input_leds             16384  0
    ip6_tables             32768  53 ip6table_filter
    ip6t_rt                20480  3
    ip6table_filter        16384  1
    ip_tables              32768  9 iptable_filter
    ipt_REJECT             16384  1
    iptable_filter         16384  1
    irqbypass              16384  1 kvm
    jbd2                  139264  1 ext4
    jfs                   217088  0
    joydev                 28672  0
    kfifo_buf              16384  1 acpi_als
    kvm                   856064  1 kvm_intel
    kvm_intel             323584  0
    ledtrig_audio          16384  1 snd_hda_codec_generic
    libcrc32c              16384  4 nf_conntrack,nf_nat,btrfs,xfs
    libphy                151552  1 tg3
    loop                   36864  8
    mac_hid                16384  0
    mbcache                16384  1 ext4
    mc                     61440  4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
    minix                  45056  0
    mousedev               24576  0
    msdos                  20480  0
    msr                    16384  0
    mxm_wmi                16384  1 nouveau
    nf_conntrack          176128  6 xt_conntrack,nf_nat,nf_nat_ftp,nf_conntrack_netbios_ns,nf_conntrack_broadcast,nf_conntrack_f
    tp
    nf_conntrack_broadcast    16384  1 nf_conntrack_netbios_ns
    nf_conntrack_ftp       24576  1 nf_nat_ftp
    nf_conntrack_netbios_ns    16384  0
    nf_defrag_ipv4         16384  1 nf_conntrack
    nf_defrag_ipv6         24576  1 nf_conntrack
    nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
    nf_log_ipv4            16384  5
    nf_log_ipv6            16384  5
    nf_nat                 53248  1 nf_nat_ftp
    nf_nat_ftp             20480  0
    nf_reject_ipv4         16384  1 ipt_REJECT
    nls_cp437              20480  1
    nls_iso8859_1          16384  1
    nouveau              2355200  10
    ntfs                  233472  0
    ohci_hcd               61440  1 ohci_pci
    ohci_pci               20480  0
    pcspkr                 16384  0
    raid6_pq              122880  1 btrfs
    rc_core                61440  1 cec
    rfcomm                 90112  16
    rfkill                 28672  8 bluetooth,cfg80211
    sbs                    20480  0
    sbshc                  16384  1 sbs
    sg                     40960  0
    snd                   114688  13 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,sn
    d_pcm
    snd_hda_codec         167936  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_cirrus
    snd_hda_codec_cirrus    24576  1
    snd_hda_codec_generic    98304  1 snd_hda_codec_cirrus
    snd_hda_codec_hdmi     73728  3
    snd_hda_core          106496  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_cirrus
    snd_hda_intel          57344  3
    snd_hwdep              16384  1 snd_hda_codec
    snd_intel_dspcfg       24576  1 snd_hda_intel
    snd_pcm               147456  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
    snd_timer              45056  1 snd_pcm
    soundcore              16384  1 snd
    squashfs               73728  4
    sr_mod                 28672  0
    st                     69632  0
    syscopyarea            16384  1 drm_kms_helper
    sysfillrect            16384  1 drm_kms_helper
    sysimgblt              16384  1 drm_kms_helper
    tg3                   184320  0
    ttm                   122880  1 nouveau
    uas                    32768  0
    ufs                    94208  0
    uinput                 20480  0
    usb_storage            81920  3 uas
    usbhid                 65536  0
    uvcvideo              114688  0
    vfat                   24576  1
    videobuf2_common       61440  2 videobuf2_v4l2,uvcvideo
    videobuf2_memops       20480  1 videobuf2_vmalloc
    videobuf2_v4l2         32768  1 uvcvideo
    videobuf2_vmalloc      20480  1 uvcvideo
    videodev              274432  3 videobuf2_v4l2,uvcvideo,videobuf2_common
    wl                   6467584  0
    wmi                    36864  2 mxm_wmi,nouveau
    x_tables               53248  13 ip6table_filter,xt_conntrack,iptable_filter,xt_LOG,xt_tcpudp,xt_addrtype,xt_recent,ip6t_rt,
    ip6_tables,ipt_REJECT,ip_tables,xt_limit,xt_hl
    xfs                  1802240  0
    xor                    24576  1 btrfs
    xt_LOG                 20480  10
    xt_addrtype            16384  4
    xt_conntrack           16384  16
    xt_hl                  16384  22
    xt_limit               16384  13
    xt_recent              24576  0
    xt_tcpudp              20480  18
**sudo mhwd-kernel -li**
   * linux54
   * linux59
**sudo dmesg | grep -Ei 'b43|bcma|brcm|wl|[F]irm|deauth'**
[    0.321819] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-04] only partially covers this bridge
[    0.543227] [Firmware Bug]: ACPI(IGPU) defines _DOD but not _DOS
[    4.108389] usb 4-6: Product: BRCM2046 Hub
[    7.260356] wl: loading out-of-tree module taints kernel.
[    7.260362] wl: module license 'MIXED/Proprietary' taints kernel.
[    7.273886] wl: module verification failed: signature and/or required key missing - tainting kernel
[    7.333214] wlan0: Broadcom BCM432b 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[    7.345627] wl 0000:02:00.0 wlp2s0: renamed from wlan0
[    8.545997] ERROR @wl_notify_scan_status :
[    8.545999] wlp2s0 Scan_results error (-22)
[   24.036033] ERROR @wl_notify_scan_status :
[   24.036038] wlp2s0 Scan_results error (-22)
[   33.156027] ERROR @wl_notify_scan_status :
[   33.156030] wlp2s0 Scan_results error (-22)
[   48.036005] ERROR @wl_notify_scan_status :
[   48.036007] wlp2s0 Scan_results error (-22)
[   68.035992] ERROR @wl_notify_scan_status :
[   68.035994] wlp2s0 Scan_results error (-22)
[   97.022710] ERROR @wl_notify_scan_status :
[   97.022711] wlp2s0 Scan_results error (-22)
[  140.035993] ERROR @wl_notify_scan_status :
[  140.035995] wlp2s0 Scan_results error (-22)
[  204.062765] ERROR @wl_notify_scan_status :
[  204.062770] wlp2s0 Scan_results error (-22)
[  299.049317] ERROR @wl_notify_scan_status :
[  299.049319] wlp2s0 Scan_results error (-22)
[  420.066048] ERROR @wl_notify_scan_status :
[  420.066050] wlp2s0 Scan_results error (-22)
[  421.079361] ERROR @wl_notify_scan_status :
[  421.079365] wlp2s0 Scan_results error (-22)
[  424.119368] ERROR @wl_notify_scan_status :
[  424.119373] wlp2s0 Scan_results error (-22)
[  429.186122] ERROR @wl_notify_scan_status :
[  429.186128] wlp2s0 Scan_results error (-22)
[  436.279360] ERROR @wl_notify_scan_status :
[  436.279365] wlp2s0 Scan_results error (-22)
[  446.409322] ERROR @wl_notify_scan_status :
[  446.409327] wlp2s0 Scan_results error (-22)
[  461.049329] ERROR @wl_notify_scan_status :
[  461.049335] wlp2s0 Scan_results error (-22)
[  481.047298] ERROR @wl_notify_scan_status :
[  481.047300] wlp2s0 Scan_results error (-22)
[  510.035962] ERROR @wl_notify_scan_status :
[  510.035964] wlp2s0 Scan_results error (-22)
[  553.049278] ERROR @wl_notify_scan_status :
[  553.049280] wlp2s0 Scan_results error (-22)
[  617.049321] ERROR @wl_notify_scan_status :
[  617.049323] wlp2s0 Scan_results error (-22)
[  666.061525] [UFW BLOCK] IN=enp3s0 OUT= MAC=33:33:00:00:00:01:34:81:c4:20:8a:b5:86:dd SRC=fe80:0000:0000:0000:3681:c4ff:fe
20:8ab5 DST=ff02:0000:0000:0000:0000:0000:0000:0001 LEN=64 TC=0 HOPLIMIT=255 FLOWLBL=0 PROTO=UDP SPT=53805 DPT=53805 LEN=24
[  678.407398] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=1031930 PROTO=TCP SPT=139 DPT=53710 WIN
DOW=249 RES=0x00 ACK PSH URGP=0
[  678.613183] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:b8:27:eb:0c:e6:9e:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=255 FLOWLBL=1031930 PROTO=TCP SPT=139 DPT=53710 WIN
[  678.833148] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:b8:27:eb:0c:e6:9e:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=255 FLOWLBL=1027135 PROTO=TCP SPT=139 DPT=53710 WIN
[  679.263013] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:b8:27:eb:0c:e6:9e:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=255 FLOWLBL=982007 PROTO=TCP SPT=139 DPT=53710 WIND
[  680.123179] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:b8:27:eb:0c:e6:9e:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=255 FLOWLBL=466944 PROTO=TCP SPT=139 DPT=53710 WIND
[  681.883132] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:b8:27:eb:0c:e6:9e:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=255 FLOWLBL=79315 PROTO=TCP SPT=139 DPT=53710 WINDO
[  685.323175] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:b8:27:eb:0c:e6:9e:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=255 FLOWLBL=866959 PROTO=TCP SPT=139 DPT=53710 WIND
[  692.523171] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:b8:27:eb:0c:e6:9e:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=255 FLOWLBL=201501 PROTO=TCP SPT=139 DPT=53710 WIND
[  706.608633] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=900838 PROTO=TCP SPT=139 DPT=53710 WIND
[  712.035593] ERROR @wl_notify_scan_status :
[  712.035597] wlp2s0 Scan_results error (-22)
[  734.124987] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=807269 PROTO=TCP SPT=139 DPT=53710 WIND
[  789.806764] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=892679 PROTO=TCP SPT=139 DPT=53710 WIND
[  833.079325] ERROR @wl_notify_scan_status :
[  833.079330] wlp2s0 Scan_results error (-22)
[  834.092655] ERROR @wl_notify_scan_status :
[  834.092660] wlp2s0 Scan_results error (-22)
[  837.129318] ERROR @wl_notify_scan_status :
[  837.129323] wlp2s0 Scan_results error (-22)
[  842.195987] ERROR @wl_notify_scan_status :
[  842.195992] wlp2s0 Scan_results error (-22)
[  849.292718] ERROR @wl_notify_scan_status :
[  849.292722] wlp2s0 Scan_results error (-22)
[  859.429388] ERROR @wl_notify_scan_status :
[  859.429392] wlp2s0 Scan_results error (-22)
[  874.035990] ERROR @wl_notify_scan_status :
[  874.035995] wlp2s0 Scan_results error (-22)
[  894.035406] ERROR @wl_notify_scan_status :
[  894.035411] wlp2s0 Scan_results error (-22)
[  902.448022] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=98877 PROTO=TCP SPT=139 DPT=53710 WINDO
[  923.052733] ERROR @wl_notify_scan_status :
[  923.052737] wlp2s0 Scan_results error (-22)
[  966.062213] ERROR @wl_notify_scan_status :
[  966.062217] wlp2s0 Scan_results error (-22)
[ 1025.329734] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=838973 PROTO=TCP SPT=139 DPT=53710 WIND
[ 1030.035973] ERROR @wl_notify_scan_status :
[ 1030.035975] wlp2s0 Scan_results error (-22)
[ 1125.105967] ERROR @wl_notify_scan_status :
[ 1125.105971] wlp2s0 Scan_results error (-22)
[ 1148.209033] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=333251 PROTO=TCP SPT=139 DPT=53710 WIND
[ 1246.035567] ERROR @wl_notify_scan_status :
[ 1246.035572] wlp2s0 Scan_results error (-22)
[ 1247.049022] ERROR @wl_notify_scan_status :
[ 1247.049027] wlp2s0 Scan_results error (-22)
[ 1250.088767] ERROR @wl_notify_scan_status :
[ 1250.088772] wlp2s0 Scan_results error (-22)
[ 1255.155723] ERROR @wl_notify_scan_status :
[ 1255.155728] wlp2s0 Scan_results error (-22)
[ 1262.252689] ERROR @wl_notify_scan_status :
[ 1262.252694] wlp2s0 Scan_results error (-22)
[ 1266.062710] [UFW BLOCK] IN=enp3s0 OUT= MAC=33:33:00:00:00:01:34:81:c4:20:8a:b5:86:dd SRC=fe80:0000:0000:0000:3681:c4ff:fe
[ 1271.087147] [UFW BLOCK] IN=enp3s0 OUT= MAC=58:b0:35:f8:fa:99:34:81:c4:20:8a:b5:86:dd SRC=fd00:0000:0000:0000:c821:4fd7:69
88:fc1b DST=fd00:0000:0000:0000:c925:a2d6:056d:4c75 LEN=76 TC=0 HOPLIMIT=254 FLOWLBL=922834 PROTO=TCP SPT=139 DPT=53710 WIND
[ 1272.384103] ERROR @wl_notify_scan_status :
[ 1272.384108] wlp2s0 Scan_results error (-22)
[ 1287.052551] ERROR @wl_notify_scan_status :
[ 1287.052554] wlp2s0 Scan_results error (-22)
[ 1307.023082] ERROR @wl_notify_scan_status :
[ 1307.023087] wlp2s0 Scan_results error (-22)
[ 1336.039275] ERROR @wl_notify_scan_status :
[ 1336.039280] wlp2s0 Scan_results error (-22)
[ 1379.052681] ERROR @wl_notify_scan_status :
[ 1379.052686] wlp2s0 Scan_results error (-22)
[ 1443.022545] ERROR @wl_notify_scan_status :
[ 1443.022547] wlp2s0 Scan_results error (-22)
[ 1538.039238] ERROR @wl_notify_scan_status :
[ 1538.039243] wlp2s0 Scan_results error (-22)
[ 1659.075888] ERROR @wl_notify_scan_status :
[ 1659.075891] wlp2s0 Scan_results error (-22)
[ 1660.092506] ERROR @wl_notify_scan_status :
[ 1660.092507] wlp2s0 Scan_results error (-22)
[ 1663.129173] ERROR @wl_notify_scan_status :
[ 1663.129175] wlp2s0 Scan_results error (-22)
[ 1668.195886] ERROR @wl_notify_scan_status :
[ 1668.195891] wlp2s0 Scan_results error (-22)
[ 1675.289224] ERROR @wl_notify_scan_status :
[ 1675.289229] wlp2s0 Scan_results error (-22)
[ 1685.422290] ERROR @wl_notify_scan_status :
[ 1685.422295] wlp2s0 Scan_results error (-22)
[ 1700.039220] ERROR @wl_notify_scan_status :
[ 1700.039223] wlp2s0 Scan_results error (-22)
[ 1720.035915] ERROR @wl_notify_scan_status :
[ 1720.035917] wlp2s0 Scan_results error (-22)
[ 1749.052565] ERROR @wl_notify_scan_status :
[ 1749.052569] wlp2s0 Scan_results error (-22)
[ 1792.035900] ERROR @wl_notify_scan_status :
[ 1792.035904] wlp2s0 Scan_results error (-22)
[ 1856.088981] ERROR @wl_notify_scan_status :
[ 1856.088986] wlp2s0 Scan_results error (-22)
[ 1951.075872] ERROR @wl_notify_scan_status :
[ 1951.075877] wlp2s0 Scan_results error (-22)
[ 2072.119202] ERROR @wl_notify_scan_status :
[ 2072.119207] wlp2s0 Scan_results error (-22)
[ 2073.132504] ERROR @wl_notify_scan_status :
[ 2073.132509] wlp2s0 Scan_results error (-22)
[ 2076.172536] ERROR @wl_notify_scan_status :
[ 2076.172541] wlp2s0 Scan_results error (-22)
[ 2081.239214] ERROR @wl_notify_scan_status :
[ 2081.239219] wlp2s0 Scan_results error (-22)
[ 2088.332534] ERROR @wl_notify_scan_status :
[ 2088.332539] wlp2s0 Scan_results error (-22)
[ 2098.465869] ERROR @wl_notify_scan_status :
[ 2098.465874] wlp2s0 Scan_results error (-22)
[ 2113.042524] ERROR @wl_notify_scan_status :
[ 2113.042524] wlp2s0 Scan_results error (-22)
[ 2133.052532] ERROR @wl_notify_scan_status :
[ 2133.052536] wlp2s0 Scan_results error (-22)
[ 2162.062507] ERROR @wl_notify_scan_status :
[ 2162.062511] wlp2s0 Scan_results error (-22)
[ 2205.075815] ERROR @wl_notify_scan_status :
[ 2205.075820] wlp2s0 Scan_results error (-22)
[ 2269.102476] ERROR @wl_notify_scan_status :
[ 2269.102481] wlp2s0 Scan_results error (-22)
[ 2364.035800] ERROR @wl_notify_scan_status :
[ 2364.035804] wlp2s0 Scan_results error (-22)
[ 2485.155834] ERROR @wl_notify_scan_status :
[ 2485.155838] wlp2s0 Scan_results error (-22)
[ 2486.172511] ERROR @wl_notify_scan_status :
[ 2486.172516] wlp2s0 Scan_results error (-22)
[ 2489.212481] ERROR @wl_notify_scan_status :
[ 2489.212486] wlp2s0 Scan_results error (-22)
[ 2494.275829] ERROR @wl_notify_scan_status :
[ 2494.275833] wlp2s0 Scan_results error (-22)
[ 2501.372493] ERROR @wl_notify_scan_status :
[ 2501.372498] wlp2s0 Scan_results error (-22)
[ 2511.505805] ERROR @wl_notify_scan_status :
[ 2511.505810] wlp2s0 Scan_results error (-22)
[ 2526.035832] ERROR @wl_notify_scan_status :
[ 2526.035837] wlp2s0 Scan_results error (-22)
[ 2546.062095] ERROR @wl_notify_scan_status :
[ 2546.062100] wlp2s0 Scan_results error (-22)
[ 2575.048820] ERROR @wl_notify_scan_status :
[ 2575.048825] wlp2s0 Scan_results error (-22)
[ 2618.089106] ERROR @wl_notify_scan_status :
[ 2618.089111] wlp2s0 Scan_results error (-22)
[ 2682.089130] ERROR @wl_notify_scan_status :
[ 2682.089135] wlp2s0 Scan_results error (-22)
[ 2777.049187] ERROR @wl_notify_scan_status :
[ 2777.049192] wlp2s0 Scan_results error (-22)
[ 2898.142401] ERROR @wl_notify_scan_status :
[ 2898.142404] wlp2s0 Scan_results error (-22)
[ 2899.155724] ERROR @wl_notify_scan_status :
[ 2899.155727] wlp2s0 Scan_results error (-22)
[ 2902.199101] ERROR @wl_notify_scan_status :
[ 2902.199106] wlp2s0 Scan_results error (-22)
[ 2907.262389] ERROR @wl_notify_scan_status :
[ 2907.262392] wlp2s0 Scan_results error (-22)
[ 2914.355720] ERROR @wl_notify_scan_status :
[ 2914.355722] wlp2s0 Scan_results error (-22)
[ 2924.489057] ERROR @wl_notify_scan_status :
[ 2924.489059] wlp2s0 Scan_results error (-22)
[ 2939.049105] ERROR @wl_notify_scan_status :
[ 2939.049111] wlp2s0 Scan_results error (-22)
[ 2959.049032] ERROR @wl_notify_scan_status :
[ 2959.049034] wlp2s0 Scan_results error (-22)
[ 2988.062374] ERROR @wl_notify_scan_status :
[ 2988.062376] wlp2s0 Scan_results error (-22)
[ 3031.049119] ERROR @wl_notify_scan_status :
[ 3031.049121] wlp2s0 Scan_results error (-22)
[ 3095.102974] ERROR @wl_notify_scan_status :
[ 3095.102976] wlp2s0 Scan_results error (-22)
[ 3190.115716] ERROR @wl_notify_scan_status :
[ 3190.115721] wlp2s0 Scan_results error (-22)
**grep -r "blacklist\|install\|options"  /etc/modprobe.d/**
/etc/modprobe.d/blacklist.conf:#blacklist b43
/etc/modprobe.d/blacklist.conf:#blacklist b43legacy
/etc/modprobe.d/blacklist.conf:#blacklist ssb
/etc/modprobe.d/blacklist.conf:#blacklist bcm43xx
/etc/modprobe.d/blacklist.conf:#blacklist brcm80211
/etc/modprobe.d/blacklist.conf:#blacklist brcmfmac
/etc/modprobe.d/blacklist.conf:#blacklist brcmsmac
/etc/modprobe.d/blacklist.conf:#blacklist bcma
**pacman -Qsq linux | grep linux | grep -v -E '(arch|util|sys|api|firmware)' | grep -v nvidia**
linux54
linux54-headers
linux59
linux59-headers
**hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"**
  Model: "Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe"
  Driver: "tg3"
  Device File: enp3s0
  Link detected: no
    Driver Status: tg3 is active
    Driver Activation Cmd: "modprobe tg3"
  Model: "Apple AirPort Extreme"
  Driver: "wl"
  Device File: wlp2s0
  Link detected: yes
    Driver Status: ssb is not active
    Driver Activation Cmd: "modprobe ssb"
    Driver Status: wl is active
    Driver Activation Cmd: "modprobe wl"
Welcome here, @AaSchmi
I don’t have a solution for your issue, but in your case I would start here:
I have the exact configuration - 2010 MBP with Nvidia Gforce 320M but DE - Gnome
I removed the Drivers - broadcom-wl instead i have installed broadcom-wl-dkms.
$ sudo pacman -Sy broadcom-wl-dkms
$ sudo modprobe wl
Usually when you use the above commands - it should work, but for me I got an error -
" modprobe: FATAL: Module wl not found in directory /lib/modules/5.4.89-1-MANJARO"
you would have to install linux headers, I have 5.4 and 5.10 kernels, so I have installed corresponding linux headers again.
$ sudo pacman -Sy linux510-headers
$ sudo pacman -Sy linux54-headers
Now, I have wifi working for the Kernel v5.4 only
But for v5.10, I could see the menu “wi-fi not connected” in the top right corner and it does not list any wifi connections.
I will try to create a bug report for - “v5.10 broadcom-wl-dkms not working”.
Hopefully the above steps should work for you, I would recommend to use kernel v5.4 only. I have had issues with v5.8, v5.9 as well in the past for this Hardware config.
Hopefully it works for you as well.
works for 5.13 :+1:
