We use the checkbox left of the reply button to mark an issue solved - if you do not see it - click the three dots to expand.
Out of curiosity I had to see the state of Manjaro the macbook using the a custom ISO on Manjaro unstable branch.
The audio was recognized - I opened the Plasma test audio app - to verify if it was indeed functional. I didnât have any intention of pushing Manjaro onto it - my wife uses the laptop - so not to upset her - it is what it is.
It was actually better than I remembered - still some tweaking is required.
I got these data out using the live ISO - perhaps they can be of use to deduce how to make your audio work - have fun
$ inxi -Fazyc0
Kernel: 6.10.1-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC lang=en_US keytable=dk tz=UTC
misobasedir=manjaro misolabel=NIX_KDEM_2407 quiet systemd.show_status=1
splash driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
rdinit=/vtoy/vtoy
Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A info: frameworks v: 6.4.0
Type: Laptop System: Apple product: MacBookPro14,2 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-CAD6701F7CEA0921
Mobo: Apple model: Mac-CAD6701F7CEA0921 v: MacBookPro14,2
serial: <superuser required> uuid: <superuser required> UEFI: Apple
v: 529.140.2.0.0 date: 06/23/2024
ID-1: BAT0 charge: 32.1 Wh (73.8%) condition: 43.5/49.2 Wh (88.5%)
volts: 11.7 min: 11.4 model: SMP bq20z451 type: Li-ion serial: N/A
status: discharging cycles: 212
Info: model: Intel Core i5-7267U bits: 64 type: MT MCP arch: Amber/Kaby Lake
note: check gen: core 7 level: v3 note: check built: 2017 process: Intel 14nm
family: 6 model-id: 0x8E (142) stepping: 9 microcode: 0xF6
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 425 high: 500 min/max: 400/3500 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 500 3: 400 4: 400
bogomips: 24809
vulnerable
Device-1: Intel Iris Plus Graphics 650 vendor: Apple driver: i915 v: kernel
arch: Gen-9.5 process: Intel 14nm built: 2016-20 ports: active: eDP-1
empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5927
class-ID: 0300
Device-2: Apple iBridge driver: hid-generic,hid-sensor-hub,usbhid,uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-3:2
chip-ID: 05ac:8600 class-ID: 0300
Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: iris gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
s-diag: 798mm (31.43")
Monitor-1: eDP-1 model: Apple Color LCD built: 2015 res: 2560x1600 hz: 60
dpi: 227 gamma: 1.2 size: 286x179mm (11.26x7.05") diag: 337mm (13.3")
ratio: 16:10 modes: 2560x1600
device: 1 drv: swrast surfaceless: drv: iris x11: drv: iris
inactive: gbm,wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.4-manjaro1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Plus Graphics 650
(Kaby Lake GT3e) (KBL GT3) device-ID: 8086:5927 memory: 3.72 GiB
unified: yes
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3 chip-ID: 8086:9d71
class-ID: 0403
API: ALSA v: k6.10.1-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM43602 802.11ac Wireless LAN SoC vendor: Apple
driver: brcmfmac v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
bus-ID: 02:00.0 chip-ID: 14e4:43ba class-ID: 0280
IF: wlp2s0 state: down mac: <filter>
Local Storage: total: 2.73 TiB used: 366.99 GiB (13.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Apple model: SSD AP0512J
size: 465.92 GiB block-size: physical: 4096 B logical: 4096 B
speed: 31.6 Gb/s lanes: 4 tech: SSD serial: <filter> fw-rev: 16.14.01
temp: 36.9 C scheme: GPT
ID-2: /dev/nvme0n2 maj-min: 259:3 vendor: Apple model: SSD AP0512J
C0272220296HRR311 size: 8 KiB block-size: physical: 4096 B logical: 4096 B
temp: 36.9 C
ID-3: /dev/sda maj-min: 8:0 model: Sandberg PCIe size: 465.76 GiB
block-size: physical: 4096 B logical: 512 B type: USB rev: 3.2 spd: 10 Gb/s
lanes: 1 mode: 3.2 gen-2x1 tech: N/A serial: <filter> fw-rev: 0106
scheme: GPT
ID-4: /dev/sdb maj-min: 8:16 vendor: Samsung model: PSSD T7 Shield
size: 1.82 TiB block-size: physical: 512 B logical: 512 B type: USB rev: 3.2
spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD serial: <filter>
scheme: GPT
Message: No partition data found.
System Temperatures: cpu: 47.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 8 GiB available: 7.63 GiB used: 1.49 GiB (19.6%)
Processes: 209 Power: uptime: 2m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 3.01 GiB services: org_kde_powerdevil,
power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
tool: systemctl
Packages: pm: pacman pkgs: 1105 libs: 247 tools: pamac Compilers: N/A
Shell: Zsh v: 5.9 default: Bash v: 5.2.26 running-in: konsole inxi: 3.3.35
$ lspci
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 03)
00:02.0 VGA compatible controller: Intel Corporation Iris Plus Graphics 650 (rev 06)
00:14.0 USB controller: Intel Corporation Sunrise Point-LP USB 3.0 xHCI Controller (rev 21)
00:16.0 Communication controller: Intel Corporation Sunrise Point-LP CSME HECI #1 (rev 21)
00:19.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO UART Controller #2 (rev 21)
00:1c.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #1 (rev f1)
00:1c.4 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #5 (rev f1)
00:1d.0 PCI bridge: Intel Corporation Sunrise Point-LP PCI Express Root Port #9 (rev f1)
00:1d.3 PCI bridge: Intel Corporation Device 9d1b (rev f1)
00:1e.0 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO UART Controller #0 (rev 21)
00:1e.1 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO UART Controller #1 (rev 21)
00:1e.3 Signal processing controller: Intel Corporation Sunrise Point-LP Serial IO SPI Controller #1 (rev 21)
00:1f.0 ISA bridge: Intel Corporation Sunrise Point LPC/eSPI Controller (rev 21)
00:1f.2 Memory controller: Intel Corporation Sunrise Point-LP PMC (rev 21)
00:1f.3 Audio device: Intel Corporation Sunrise Point-LP HD Audio (rev 21)
00:1f.4 SMBus: Intel Corporation Sunrise Point-LP SMBus (rev 21)
01:00.0 Mass storage controller: Apple Inc. S3X NVMe Controller (rev 12)
02:00.0 Network controller: Broadcom Inc. and subsidiaries BCM43602 802.11ac Wireless LAN SoC (rev 02)
03:00.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (rev 02)
04:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
04:01.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
04:02.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
04:04.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
05:00.0 System peripheral: Intel Corporation JHL6540 Thunderbolt 3 NHI (C step) [Alpine Ridge 4C 2016] (rev 02)
06:00.0 USB controller: Intel Corporation JHL6540 Thunderbolt 3 USB Controller (C step) [Alpine Ridge 4C 2016] (rev 02)
79:00.0 PCI bridge: Intel Corporation DSL6540 Thunderbolt 3 Bridge [Alpine Ridge 4C 2015] (rev 02)
7a:00.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
7a:01.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
7a:02.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
7a:04.0 PCI bridge: Intel Corporation JHL6540 Thunderbolt 3 Bridge (C step) [Alpine Ridge 4C 2016] (rev 02)
7b:00.0 System peripheral: Intel Corporation JHL6540 Thunderbolt 3 NHI (C step) [Alpine Ridge 4C 2016] (rev 02)
7c:00.0 USB controller: Intel Corporation JHL6540 Thunderbolt 3 USB Controller (C step) [Alpine Ridge 4C 2016] (rev 02)
$ lsmod | sort
8250_dw 24576 0
ac97_bus 12288 1 snd_soc_core
aesni_intel 364544 4
af_alg 32768 6 algif_hash,algif_skcipher
algif_hash 12288 1
algif_skcipher 12288 1
apple_mfi_fastcharge 16384 0
applesmc 32768 0
applespi 61440 0
bluetooth 1105920 34 btrtl,btqca,btintel,hci_uart,btbcm,bnep,rfcomm
bnep 36864 2
brcmfmac 602112 1 brcmfmac_wcc
brcmfmac_wcc 12288 0
brcmutil 20480 1 brcmfmac
btbcm 24576 1 hci_uart
btintel 65536 1 hci_uart
btqca 28672 1 hci_uart
btrtl 32768 1 hci_uart
cdrom 81920 2 isofs,sr_mod
cec 94208 2 drm_display_helper,i915
cfg80211 1372160 1 brcmfmac
cmac 12288 3
coretemp 20480 0
crc16 12288 3 bluetooth,ext4,applespi
crc32c_generic 12288 0
crc32c_intel 16384 2
crc32_pclmul 12288 0
crct10dif_pclmul 12288 1
cryptd 28672 3 crypto_simd,ghash_clmulni_intel
crypto_simd 16384 1 aesni_intel
crypto_user 20480 0
dm_bufio 57344 1 dm_snapshot
dm_mod 225280 5 dm_snapshot,dm_bufio
dm_snapshot 69632 0
drm_buddy 24576 1 i915
drm_display_helper 262144 1 i915
dw_dmac 12288 0
exfat 114688 0
ext4 1155072 1
fat 106496 1 vfat
gf128mul 16384 1 polyval_generic
ghash_clmulni_intel 16384 0
hci_uart 192512 0
hid_generic 12288 0
hid_sensor_als 16384 0
hid_sensor_hub 32768 3 hid_sensor_trigger,hid_sensor_iio_common,hid_sensor_als
hid_sensor_iio_common 20480 2 hid_sensor_trigger,hid_sensor_als
hid_sensor_trigger 20480 2 hid_sensor_als
i2c_algo_bit 20480 1 i915
i2c_dev 28672 0
i2c_i801 45056 0
i2c_mux 16384 1 i2c_i801
i2c_smbus 20480 1 i2c_i801
i915 4489216 44
idma64 20480 0
industrialio 131072 4 industrialio_triggered_buffer,hid_sensor_trigger,kfifo_buf,hid_sensor_als
industrialio_triggered_buffer 12288 1 hid_sensor_trigger
intel_cstate 20480 0
intel_gtt 28672 1 i915
intel_lpss 12288 1 intel_lpss_pci
intel_lpss_pci 24576 4
intel_pmc_bxt 16384 1 iTCO_wdt
intel_pmc_core 122880 0
intel_pmc_core_pltdrv 12288 0
intel_powerclamp 20480 0
intel_rapl_common 49152 1 intel_rapl_msr
intel_rapl_msr 20480 0
intel_tcc_cooling 12288 0
intel_uncore 266240 0
intel_uncore_frequency 12288 0
intel_uncore_frequency_common 16384 1 intel_uncore_frequency
intel_vsec 20480 1 intel_pmc_core
intel_xhci_usb_role_switch 12288 0
ip_tables 36864 0
isofs 65536 1
iTCO_vendor_support 12288 1 iTCO_wdt
iTCO_wdt 16384 0
jbd2 204800 1 ext4
joydev 28672 0
kfifo_buf 12288 1 industrialio_triggered_buffer
kvm 1368064 1 kvm_intel
kvm_intel 430080 0
loop 45056 8
mac_hid 12288 0
mbcache 16384 1 ext4
mc 90112 5 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
mei 204800 5 mei_hdcp,mei_pxp,mei_me
mei_hdcp 28672 0
mei_me 57344 2
mei_pxp 20480 0
mmc_core 270336 1 brcmfmac
Module Size Used by
mousedev 24576 0
nfnetlink 20480 1
nvme 65536 0
nvme_auth 24576 1 nvme_core
nvme_core 253952 1 nvme
overlay 237568 1
pcspkr 12288 0
pmt_class 16384 1 pmt_telemetry
pmt_telemetry 16384 1 intel_pmc_core
polyval_clmulni 12288 0
polyval_generic 12288 1 polyval_clmulni
qrtr 57344 2
rapl 20480 0
rfcomm 102400 4
rfkill 40960 8 bluetooth,cfg80211
roles 16384 1 intel_xhci_usb_role_switch
sbs 20480 0
sbshc 16384 1 sbs
sg 53248 0
sha1_ssse3 32768 0
sha256_ssse3 36864 0
sha512_ssse3 53248 0
snd 155648 16 snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_codec_cs8409,snd_hda_intel,snd_hda_codec,snd_timer,snd_compress,snd_soc_core,snd_pcm
snd_compress 28672 2 snd_soc_avs,snd_soc_core
snd_hda_codec 212992 8 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_codec_cs8409,snd_hda_intel,snd_soc_hdac_hda,snd_soc_skl
snd_hda_codec_cs8409 36864 1
snd_hda_codec_generic 110592 1 snd_hda_codec_cs8409
snd_hda_codec_hdmi 98304 1
snd_hda_core 147456 10 snd_hda_codec_generic,snd_soc_avs,snd_hda_codec_hdmi,snd_soc_hda_codec,snd_hda_codec_cs8409,snd_hda_intel,snd_hda_ext_core,snd_hda_codec,snd_soc_hdac_hda,snd_soc_skl
snd_hda_ext_core 36864 4 snd_soc_avs,snd_soc_hda_codec,snd_soc_hdac_hda,snd_soc_skl
snd_hda_intel 65536 1
snd_hrtimer 12288 1
snd_hwdep 20480 1 snd_hda_codec
snd_intel_dspcfg 40960 3 snd_soc_avs,snd_hda_intel,snd_soc_skl
snd_intel_sdw_acpi 16384 1 snd_intel_dspcfg
snd_pcm 200704 9 snd_soc_avs,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_compress,snd_soc_core,snd_soc_skl,snd_hda_core,snd_pcm_dmaengine
snd_pcm_dmaengine 16384 1 snd_soc_core
snd_seq 131072 7 snd_seq_dummy
snd_seq_device 16384 1 snd_seq
snd_seq_dummy 12288 0
snd_soc_acpi 16384 2 snd_soc_acpi_intel_match,snd_soc_skl
snd_soc_acpi_intel_match 106496 1 snd_soc_skl
snd_soc_avs 237568 0
snd_soc_core 458752 4 snd_soc_avs,snd_soc_hda_codec,snd_soc_hdac_hda,snd_soc_skl
snd_soc_hdac_hda 28672 1 snd_soc_skl
snd_soc_hda_codec 28672 1 snd_soc_avs
snd_soc_skl 241664 0
snd_soc_sst_dsp 40960 1 snd_soc_skl
snd_soc_sst_ipc 20480 1 snd_soc_skl
snd_timer 53248 3 snd_seq,snd_hrtimer,snd_pcm
soundcore 16384 1 snd
spi_pxa2xx_platform 36864 0
squashfs 94208 4
sr_mod 28672 0
st 73728 0
thunderbolt 565248 0
ttm 102400 1 i915
uas 36864 2
usbhid 86016 0
usb_storage 90112 1 uas
uvc 12288 1 uvcvideo
uvcvideo 180224 2
vfat 24576 0
video 77824 1 i915
videobuf2_common 94208 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videobuf2_memops 16384 1 videobuf2_vmalloc
videobuf2_v4l2 40960 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 393216 3 videobuf2_v4l2,uvcvideo
wmi 32768 1 video
x86_pkg_temp_thermal 16384 0
xhci_pci 24576 0
xhci_pci_renesas 24576 1 xhci_pci
x_tables 65536 1 ip_tables
