Hello!
I just bought a macbook because I needed something very cheap with backlight so I took that ‘thing’…
MacBook Pro 9.2 Mid 2012 13"
2.5 Ghz Intel Core i5 dual core
4 Go 1600 MHz DDR3
Intel HD Graphics 4000 1536 Mo
I shrinked the HDD on Mac OSX Catalina, installation went smooth with ‘swap’ and ‘/’, I didn’t even required to get on the internet to collect driver and other… Everything works fine except a little something I didn’t found any similar case yet.
When I charge the battery to 100%, on Manjaro and I unplug, my battery become 64% and says it’s full with 2 hours 30 minutes left. So I did reboot ‘alt’ to check on OSX and the battery on OSX Catalina is 100% with 4 hours 30 minutes left… (well actually 99% with 4 hours 29 minutes because of the reboot but nvm)
Anyone has any idea why I have less autonomy on Manjaro Gnome than OSX and how I could correct this?
EDIT: After looking over a bit more here is my tlp-stat --battery
Charging:
— TLP 1.3.1 --------------------------------------------
+++ Battery Features: Charge Thresholds and Recalibrate
natacpi = inactive (laptop not supported)
tpacpi-bat = inactive (laptop not supported)
tp-smapi = inactive (laptop not supported)+++ Battery Status: BAT0
/sys/class/power_supply/BAT0/manufacturer = DP
/sys/class/power_supply/BAT0/model_name = bq20z451
/sys/class/power_supply/BAT0/cycle_count = 2358
/sys/class/power_supply/BAT0/charge_full_design = 5770 [mAh]
/sys/class/power_supply/BAT0/charge_full = 3677 [mAh]
/sys/class/power_supply/BAT0/charge_now = 1827 [mAh]
/sys/class/power_supply/BAT0/current_now = 2168 [mA]
/sys/class/power_supply/BAT0/status = ChargingCharge = 49.7 [%]
Capacity = 63.7 [%]
Discharging: (I see 35% on gnome)
/sys/class/power_supply/BAT0/charge_now = 1992 [mAh]
/sys/class/power_supply/BAT0/current_now = 1117 [mA]
/sys/class/power_supply/BAT0/status = DischargingCharge = 54.2 [%]
Capacity = 63.7 [%]
Thanks,
Cordially.
