I have a fresh install of Manjaro and have not been able to get the wifi to work. I have fully been through broadcom-wifi-driver-fails-to-install-properly/46316 twice and I have gotten it to do different functionality but never been able to connect.
On initial install it could see networks and attempt to connect but never able to (both 5g and 2.4 networks). In current state I cannot even see the networks.
Here is the information that might be helpful. Thanks in advance!
inxi -Fxxxza
Kernel: 5.15.21-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=92f41870-02b2-448c-a914-a195e5e75375 rw quiet apparmor=1
Desktop: Xfce 4.16.0 tk: Gtk 3.24.29 info: xfce4-panel wm: xfwm 4.16.1
vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Type: Laptop System: Apple product: MacBookPro7,1 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-F222BEC8
Mobo: Apple model: Mac-F222BEC8 serial: <superuser required> UEFI: Apple
v: MBP71.88Z.0039.B0E.1111071400 date: 11/07/11
ID-1: BAT0 charge: 60.0 Wh (100.0%) condition: 60.0/62.9 Wh (95.4%)
volts: 12.5 min: 10.9 model: DP bq20z451 type: Li-ion serial: N/A
status: Full cycles: 271
Info: model: Intel Core2 Duo P8600 bits: 64 type: MCP arch: Core Yorkfield
family: 6 model-id: 0x17 (23) stepping: 0xA (10) microcode: 0xA0B
Topology: cpus: 1x cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1369 high: 1594 min/max: 798/2394 scaling:
driver: acpi-cpufreq governor: schedutil cores: 1: 1144 2: 1594
bogomips: 9558
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA MCP89 [GeForce 320M] vendor: Apple driver: nouveau
v: kernel ports: active: LVDS-1 empty: DP-1 bus-ID: 04:00.0
chip-ID: 10de:08a0 class-ID: 0300
Device-2: Apple Built-in iSight type: USB driver: uvcvideo bus-ID: 1-6:2
chip-ID: 05ac:8507 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org v: 1.21.1.3 compositor: xfwm v: 4.16.1 driver:
X: loaded: modesetting alternate: fbdev,vesa gpu: nouveau display-ID: :0.0
screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.3x8.3")
s-diag: 398mm (15.7")
Monitor-1: LVDS-1 model: Apple Color LCD built: 2010 res: 1280x800 hz: 61
dpi: 114 gamma: 1.2 size: 286x178mm (11.3x7.0") diag: 347mm (13.6")
ratio: 3:2 or 16/10 modes: max: 1280x800 min: 640x350
Message: Unable to show GL data. Required tool glxinfo missing.
Device-1: NVIDIA MCP89 High Definition Audio driver: snd_hda_intel
v: kernel bus-ID: 00:08.0 chip-ID: 10de:0d94 class-ID: 0403
Sound Server-1: ALSA v: k5.15.21-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.45 running: no
Device-1: Broadcom BCM4322 802.11a/b/g/n Wireless LAN
vendor: Apple AirPort Extreme driver: wl v: kernel modules: ssb pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:432b
class-ID: 0280
IF: wlp2s0 state: dormant mac: <filter>
Device-2: Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 03:00.0
chip-ID: 14e4:1684 class-ID: 0200
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 4-6.1:5 chip-ID: 05ac:8213 class-ID: fe01 serial: <filter>
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
Local Storage: total: 232.89 GiB used: 9.69 GiB (4.2%)
ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: MK2555GSXF
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 1.5 Gb/s
type: HDD rpm: 5400 serial: <filter> rev: 5B scheme: GPT
ID-1: / raw-size: 232.59 GiB size: 227.88 GiB (97.98%)
used: 9.69 GiB (4.3%) fs: ext4 dev: /dev/sda2 maj-min: 8:2
used: 288 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nouveau temp: 56.0 C
Processes: 161 Uptime: 1h 6m wakeups: 2 Memory: 3.58 GiB
used: 1.14 GiB (31.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.1 Packages: pacman: 1093 lib: 316 flatpak: 0
Shell: Bash v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.13
dkms status
broadcom-wl/6.30.223.271, 5.15.21-1-MANJARO, x86_64: installed
rfkill list all
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
1: hci0: Bluetooth
Soft blocked: yes
Hard blocked: no
lsmod | sort
acpi_als 20480 1
acpi_cpufreq 32768 1
apple_bl 20480 0
apple_mfi_fastcharge 20480 0
applesmc 28672 0
bcm5974 28672 0
bluetooth 749568 37 btrtl,btintel,btbcm,bnep,btusb,rfcomm
bnep 32768 2
btbcm 24576 1 btusb
btintel 45056 1 btusb
btrtl 28672 1 btusb
btusb 65536 0
cdrom 81920 1 sr_mod
cfg80211 1073152 1 wl
coretemp 20480 0
crc16 16384 2 bluetooth,ext4
crc32c_generic 16384 2
crc_itu_t 16384 1 firewire_core
crypto_user 24576 0
drm_ttm_helper 16384 1 nouveau
ecdh_generic 16384 1 bluetooth
ext4 1003520 1
fat 90112 1 vfat
firewire_core 86016 1 firewire_ohci
firewire_ohci 53248 0
fuse 176128 3
hid_apple 20480 0
hid_appleir 16384 0
industrialio 102400 3 industrialio_triggered_buffer,acpi_als,kfifo_buf
industrialio_triggered_buffer 16384 1 acpi_als
ip_tables 36864 0
irqbypass 16384 1 kvm
jbd2 192512 1 ext4
joydev 28672 0
kfifo_buf 16384 1 industrialio_triggered_buffer
kvm 1097728 1 kvm_intel
kvm_intel 356352 0
ledtrig_audio 16384 1 snd_hda_codec_generic
libphy 167936 1 tg3
loop 40960 0
mac_hid 16384 0
mbcache 16384 1 ext4
mc 65536 4 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
Module Size Used by
mousedev 24576 0
mxm_wmi 16384 1 nouveau
nouveau 2768896 14
ns 36864 1 qrtr
pcspkr 16384 0
qrtr 24576 4
rfcomm 90112 16
rfkill 32768 5 bluetooth,cfg80211
sbs 20480 0
sbshc 16384 1 sbs
snd 126976 13 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_timer,snd_pcm
snd_hda_codec 184320 4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_cirrus
snd_hda_codec_cirrus 24576 1
snd_hda_codec_generic 98304 1 snd_hda_codec_cirrus
snd_hda_codec_hdmi 86016 3
snd_hda_core 118784 5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_cirrus
snd_hda_intel 61440 3
snd_hwdep 16384 1 snd_hda_codec
snd_intel_dspcfg 32768 1 snd_hda_intel
snd_intel_sdw_acpi 20480 1 snd_intel_dspcfg
snd_pcm 163840 4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
snd_timer 49152 1 snd_pcm
soundcore 16384 1 snd
squashfs 77824 0
sr_mod 28672 0
tg3 204800 0
ttm 86016 2 drm_ttm_helper,nouveau
uas 32768 0
uinput 20480 0
usbhid 73728 0
usb_storage 81920 1 uas
uvcvideo 147456 0
vfat 24576 1
video 57344 1 nouveau
videobuf2_common 86016 4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
videobuf2_memops 20480 1 videobuf2_vmalloc
videobuf2_v4l2 40960 1 uvcvideo
videobuf2_vmalloc 20480 1 uvcvideo
videodev 307200 3 videobuf2_v4l2,uvcvideo,videobuf2_common
wl 6529024 0
wmi 45056 2 mxm_wmi,nouveau
x_tables 57344 1 ip_tables
sudo mhwd-kernel -li
e[32mCurrently running:e[0m 5.15.21-1-MANJARO (linux515)
* linux515
sudo dmesg | grep -Ei 'b43|bcma|brcm|wl|[F]irm|deauth'
[ 0.358518] acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-04] only partially covers this bridge
[ 3.144655] usb 4-6: Product: BRCM2046 Hub
[ 20.119682] ACPI: video: [Firmware Bug]: ACPI(IGPU) defines _DOD but not _DOS
[ 21.253571] wl: loading out-of-tree module taints kernel.
[ 21.253582] wl: module license 'MIXED/Proprietary' taints kernel.
[ 21.264580] wl: module verification failed: signature and/or required key missing - tainting kernel
[ 21.313463] wlan0: Broadcom BCM432b 802.11 Hybrid Wireless Controller 6.30.223.271 (r587334)
[ 21.360110] wl 0000:02:00.0 wlp2s0: renamed from wlan0
[ 96.045895] ERROR @wl_notify_scan_status :
[ 96.045907] wlp2s0 Scan_results error (-22)
[ 125.059392] ERROR @wl_notify_scan_status :
[ 125.059404] wlp2s0 Scan_results error (-22)
[ 168.042599] ERROR @wl_notify_scan_status :
[ 168.042611] wlp2s0 Scan_results error (-22)
[ 232.042605] ERROR @wl_notify_scan_status :
[ 232.042617] wlp2s0 Scan_results error (-22)
[ 327.085973] ERROR @wl_notify_scan_status :
[ 327.085984] wlp2s0 Scan_results error (-22)
[ 448.122729] ERROR @wl_notify_scan_status :
[ 448.122741] wlp2s0 Scan_results error (-22)
[ 449.139294] ERROR @wl_notify_scan_status :
[ 449.139306] wlp2s0 Scan_results error (-22)
[ 452.175892] ERROR @wl_notify_scan_status :
[ 452.175904] wlp2s0 Scan_results error (-22)
[ 457.242606] ERROR @wl_notify_scan_status :
[ 457.242618] wlp2s0 Scan_results error (-22)
[ 464.335911] ERROR @wl_notify_scan_status :
[ 464.335923] wlp2s0 Scan_results error (-22)
[ 474.469258] ERROR @wl_notify_scan_status :
[ 474.469270] wlp2s0 Scan_results error (-22)
[ 489.059386] ERROR @wl_notify_scan_status :
[ 489.059398] wlp2s0 Scan_results error (-22)
[ 509.059310] ERROR @wl_notify_scan_status :
[ 509.059322] wlp2s0 Scan_results error (-22)
[ 538.045904] ERROR @wl_notify_scan_status :
[ 538.045916] wlp2s0 Scan_results error (-22)
[ 581.059306] ERROR @wl_notify_scan_status :
[ 581.059319] wlp2s0 Scan_results error (-22)
[ 645.029279] ERROR @wl_notify_scan_status :
[ 645.029291] wlp2s0 Scan_results error (-22)
[ 740.122629] ERROR @wl_notify_scan_status :
[ 740.122642] wlp2s0 Scan_results error (-22)
[ 861.112575] ERROR @wl_notify_scan_status :
[ 861.112586] wlp2s0 Scan_results error (-22)
[ 862.125992] ERROR @wl_notify_scan_status :
[ 862.126004] wlp2s0 Scan_results error (-22)
[ 865.165859] ERROR @wl_notify_scan_status :
[ 865.165871] wlp2s0 Scan_results error (-22)
[ 870.232527] ERROR @wl_notify_scan_status :
[ 870.232539] wlp2s0 Scan_results error (-22)
[ 877.325896] ERROR @wl_notify_scan_status :
[ 877.325908] wlp2s0 Scan_results error (-22)
[ 887.459350] ERROR @wl_notify_scan_status :
[ 887.459362] wlp2s0 Scan_results error (-22)
[ 902.045917] ERROR @wl_notify_scan_status :
[ 902.045929] wlp2s0 Scan_results error (-22)
[ 922.042804] ERROR @wl_notify_scan_status :
[ 922.042816] wlp2s0 Scan_results error (-22)
[ 951.059258] ERROR @wl_notify_scan_status :
[ 951.059270] wlp2s0 Scan_results error (-22)
[ 994.042586] ERROR @wl_notify_scan_status :
[ 994.042598] wlp2s0 Scan_results error (-22)
[ 1058.045909] ERROR @wl_notify_scan_status :
[ 1058.045920] wlp2s0 Scan_results error (-22)
[ 1153.032474] ERROR @wl_notify_scan_status :
[ 1153.032486] wlp2s0 Scan_results error (-22)
[ 1274.096029] ERROR @wl_notify_scan_status :
[ 1274.096040] wlp2s0 Scan_results error (-22)
[ 1275.109135] ERROR @wl_notify_scan_status :
[ 1275.109146] wlp2s0 Scan_results error (-22)
[ 1278.149103] ERROR @wl_notify_scan_status :
[ 1278.149115] wlp2s0 Scan_results error (-22)
[ 1283.215787] ERROR @wl_notify_scan_status :
[ 1283.215798] wlp2s0 Scan_results error (-22)
[ 1290.309108] ERROR @wl_notify_scan_status :
[ 1290.309120] wlp2s0 Scan_results error (-22)
[ 1300.442511] ERROR @wl_notify_scan_status :
[ 1300.442522] wlp2s0 Scan_results error (-22)
[ 1315.055904] ERROR @wl_notify_scan_status :
[ 1315.055917] wlp2s0 Scan_results error (-22)
[ 1335.055815] ERROR @wl_notify_scan_status :
[ 1335.055827] wlp2s0 Scan_results error (-22)
[ 1364.069203] ERROR @wl_notify_scan_status :
[ 1364.069215] wlp2s0 Scan_results error (-22)
[ 1407.082559] ERROR @wl_notify_scan_status :
[ 1407.082571] wlp2s0 Scan_results error (-22)
[ 1471.056113] ERROR @wl_notify_scan_status :
[ 1471.056126] wlp2s0 Scan_results error (-22)
[ 1566.042485] ERROR @wl_notify_scan_status :
[ 1566.042497] wlp2s0 Scan_results error (-22)
[ 1687.109489] ERROR @wl_notify_scan_status :
[ 1687.109501] wlp2s0 Scan_results error (-22)
[ 1688.122437] ERROR @wl_notify_scan_status :
[ 1688.122449] wlp2s0 Scan_results error (-22)
[ 1691.162444] ERROR @wl_notify_scan_status :
[ 1691.162455] wlp2s0 Scan_results error (-22)
[ 1696.229067] ERROR @wl_notify_scan_status :
[ 1696.229079] wlp2s0 Scan_results error (-22)
[ 1703.322394] ERROR @wl_notify_scan_status :
[ 1703.322407] wlp2s0 Scan_results error (-22)
[ 1713.455717] ERROR @wl_notify_scan_status :
[ 1713.455728] wlp2s0 Scan_results error (-22)
[ 1728.045855] ERROR @wl_notify_scan_status :
[ 1728.045866] wlp2s0 Scan_results error (-22)
[ 1748.045865] ERROR @wl_notify_scan_status :
[ 1748.045877] wlp2s0 Scan_results error (-22)
[ 1777.055712] ERROR @wl_notify_scan_status :
[ 1777.055723] wlp2s0 Scan_results error (-22)
[ 1820.042530] ERROR @wl_notify_scan_status :
[ 1820.042541] wlp2s0 Scan_results error (-22)
[ 1884.069207] ERROR @wl_notify_scan_status :
[ 1884.069220] wlp2s0 Scan_results error (-22)
[ 1979.135760] ERROR @wl_notify_scan_status :
[ 1979.135771] wlp2s0 Scan_results error (-22)
[ 2100.125839] ERROR @wl_notify_scan_status :
[ 2100.125850] wlp2s0 Scan_results error (-22)
[ 2101.142512] ERROR @wl_notify_scan_status :
[ 2101.142524] wlp2s0 Scan_results error (-22)
[ 2104.179075] ERROR @wl_notify_scan_status :
[ 2104.179087] wlp2s0 Scan_results error (-22)
[ 2109.245783] ERROR @wl_notify_scan_status :
[ 2109.245795] wlp2s0 Scan_results error (-22)
[ 2116.339263] ERROR @wl_notify_scan_status :
[ 2116.339274] wlp2s0 Scan_results error (-22)
[ 2126.472573] ERROR @wl_notify_scan_status :
[ 2126.472585] wlp2s0 Scan_results error (-22)
[ 2141.029029] ERROR @wl_notify_scan_status :
[ 2141.029040] wlp2s0 Scan_results error (-22)
[ 2161.059046] ERROR @wl_notify_scan_status :
[ 2161.059058] wlp2s0 Scan_results error (-22)
[ 2190.069357] ERROR @wl_notify_scan_status :
[ 2190.069369] wlp2s0 Scan_results error (-22)
[ 2233.082384] ERROR @wl_notify_scan_status :
[ 2233.082395] wlp2s0 Scan_results error (-22)
[ 2297.085764] ERROR @wl_notify_scan_status :
[ 2297.085775] wlp2s0 Scan_results error (-22)
[ 2392.072479] ERROR @wl_notify_scan_status :
[ 2392.072491] wlp2s0 Scan_results error (-22)
[ 2513.085702] ERROR @wl_notify_scan_status :
[ 2513.085714] wlp2s0 Scan_results error (-22)
[ 2514.099132] ERROR @wl_notify_scan_status :
[ 2514.099143] wlp2s0 Scan_results error (-22)
[ 2517.139033] ERROR @wl_notify_scan_status :
[ 2517.139044] wlp2s0 Scan_results error (-22)
[ 2522.205696] ERROR @wl_notify_scan_status :
[ 2522.205708] wlp2s0 Scan_results error (-22)
[ 2529.302463] ERROR @wl_notify_scan_status :
[ 2529.302474] wlp2s0 Scan_results error (-22)
[ 2539.432382] ERROR @wl_notify_scan_status :
[ 2539.432394] wlp2s0 Scan_results error (-22)
[ 2554.045930] ERROR @wl_notify_scan_status :
[ 2554.045942] wlp2s0 Scan_results error (-22)
[ 2574.042441] ERROR @wl_notify_scan_status :
[ 2574.042453] wlp2s0 Scan_results error (-22)
[ 2603.032433] ERROR @wl_notify_scan_status :
[ 2603.032444] wlp2s0 Scan_results error (-22)
[ 2646.042489] ERROR @wl_notify_scan_status :
[ 2646.042502] wlp2s0 Scan_results error (-22)
[ 2710.095819] ERROR @wl_notify_scan_status :
[ 2710.095830] wlp2s0 Scan_results error (-22)
[ 2805.055673] ERROR @wl_notify_scan_status :
[ 2805.055685] wlp2s0 Scan_results error (-22)
[ 2926.175789] ERROR @wl_notify_scan_status :
[ 2926.175801] wlp2s0 Scan_results error (-22)
[ 2927.192327] ERROR @wl_notify_scan_status :
[ 2927.192339] wlp2s0 Scan_results error (-22)
[ 2930.232429] ERROR @wl_notify_scan_status :
[ 2930.232441] wlp2s0 Scan_results error (-22)
[ 2935.302355] ERROR @wl_notify_scan_status :
[ 2935.302361] wlp2s0 Scan_results error (-22)
[ 2942.395764] ERROR @wl_notify_scan_status :
[ 2942.395775] wlp2s0 Scan_results error (-22)
[ 2952.525694] ERROR @wl_notify_scan_status :
[ 2952.525705] wlp2s0 Scan_results error (-22)
[ 2967.055710] ERROR @wl_notify_scan_status :
[ 2967.055722] wlp2s0 Scan_results error (-22)
[ 2987.059095] ERROR @wl_notify_scan_status :
[ 2987.059106] wlp2s0 Scan_results error (-22)
[ 3016.045835] ERROR @wl_notify_scan_status :
[ 3016.045847] wlp2s0 Scan_results error (-22)
[ 3059.059031] ERROR @wl_notify_scan_status :
[ 3059.059043] wlp2s0 Scan_results error (-22)
[ 3123.109008] ERROR @wl_notify_scan_status :
[ 3123.109020] wlp2s0 Scan_results error (-22)
[ 3218.045771] ERROR @wl_notify_scan_status :
[ 3218.045783] wlp2s0 Scan_results error (-22)
[ 3339.082340] ERROR @wl_notify_scan_status :
[ 3339.082352] wlp2s0 Scan_results error (-22)
[ 3340.095496] ERROR @wl_notify_scan_status :
[ 3340.095529] wlp2s0 Scan_results error (-22)
[ 3343.135565] ERROR @wl_notify_scan_status :
[ 3343.135577] wlp2s0 Scan_results error (-22)
[ 3348.202209] ERROR @wl_notify_scan_status :
[ 3348.202222] wlp2s0 Scan_results error (-22)
[ 3355.295583] ERROR @wl_notify_scan_status :
[ 3355.295595] wlp2s0 Scan_results error (-22)
[ 3365.428975] ERROR @wl_notify_scan_status :
[ 3365.428987] wlp2s0 Scan_results error (-22)
[ 3380.045627] ERROR @wl_notify_scan_status :
[ 3380.045639] wlp2s0 Scan_results error (-22)
[ 3400.042427] ERROR @wl_notify_scan_status :
[ 3400.042440] wlp2s0 Scan_results error (-22)
[ 3429.055703] ERROR @wl_notify_scan_status :
[ 3429.055715] wlp2s0 Scan_results error (-22)
[ 3472.045800] ERROR @wl_notify_scan_status :
[ 3472.045812] wlp2s0 Scan_results error (-22)
[ 3536.093907] ERROR @wl_notify_scan_status :
[ 3536.093919] wlp2s0 Scan_results error (-22)
[ 3631.028832] ERROR @wl_notify_scan_status :
[ 3631.028845] wlp2s0 Scan_results error (-22)
[ 3713.698925] ERROR @wl_notify_scan_status :
[ 3713.698938] wlp2s0 Scan_results error (-22)
[ 3714.708875] ERROR @wl_notify_scan_status :
[ 3714.708887] wlp2s0 Scan_results error (-22)
[ 3718.762195] ERROR @wl_notify_scan_status :
[ 3718.762201] wlp2s0 Scan_results error (-22)
[ 3723.828900] ERROR @wl_notify_scan_status :
[ 3723.828907] wlp2s0 Scan_results error (-22)
[ 3730.922206] ERROR @wl_notify_scan_status :
[ 3730.922212] wlp2s0 Scan_results error (-22)
[ 3740.042256] ERROR @wl_notify_scan_status :
[ 3740.042261] wlp2s0 Scan_results error (-22)
[ 3755.055499] ERROR @wl_notify_scan_status :
[ 3755.055512] wlp2s0 Scan_results error (-22)
[ 3775.058913] ERROR @wl_notify_scan_status :
[ 3775.058925] wlp2s0 Scan_results error (-22)
[ 3804.068878] ERROR @wl_notify_scan_status :
[ 3804.068890] wlp2s0 Scan_results error (-22)
[ 3847.028894] ERROR @wl_notify_scan_status :
[ 3847.028906] wlp2s0 Scan_results error (-22)
[ 3911.112296] ERROR @wl_notify_scan_status :
[ 3911.112308] wlp2s0 Scan_results error (-22)
[ 4006.095560] ERROR @wl_notify_scan_status :
[ 4006.095565] wlp2s0 Scan_results error (-22)
grep -r "blacklist\|install\|options" /etc/modprobe.d/
/etc/modprobe.d/blacklist.conf:blacklist b43
/etc/modprobe.d/blacklist.conf:blacklist b43legacy
/etc/modprobe.d/blacklist.conf:blacklist ssb
/etc/modprobe.d/blacklist.conf:blacklist bcm43xx
/etc/modprobe.d/blacklist.conf:blacklist brcm80211
/etc/modprobe.d/blacklist.conf:blacklist brcmfmac
/etc/modprobe.d/blacklist.conf:blacklist brcmsmac
/etc/modprobe.d/blacklist.conf:blacklist bcma
pacman -Qsq linux | grep linux | grep -v -E '(arch|util|sys|api|firmware)' | grep -v nvidia
linux515
linux515-headers
hwinfo --netcard --wlan --bluetooth | grep -Ei "model\:|driver\:|status\:|cmd\:|file\:|detected\:" | grep -v "Config Status"
Model: "Broadcom NetXtreme BCM5764M Gigabit Ethernet PCIe"
Driver: "tg3"
Device File: enp3s0
Link detected: yes
Driver Status: tg3 is active
Driver Activation Cmd: "modprobe tg3"
Model: "Apple AirPort Extreme"
Driver: "wl"
Device File: wlp2s0
Link detected: yes
Driver Status: ssb is not active
Driver Activation Cmd: "modprobe ssb"
Driver Status: wl is active
Driver Activation Cmd: "modprobe wl"
