I tried to install Manjaro ARM (aarch64) in a VM on the M1 Mac several times.
I used images with and without EFI support.
As VM software I use VMWare Fusion as well as UTM (QEMU).
No matter which image I use, I always end up at the UEFI prompt after booting.
In principle, aarch64 Linux as well as BSD runs as VM on the M1 Mac - no problem with Debian, Fedora, FreeBSD aarch64 to install and run them!
What do I have to do to get Manjaro ARM to run in a VM?
Manjaro’s arm images is not installation images - they are ready-to-run when you have unpacked the archive.
As such they must be written to the target disk using a tool like dd or another tool capable of writing the image to a target disk.
EDIT
Thinking out loud.
No success - working on a different approach
Download a generic Manjaro ARM image - place it in your Download folder
Unpack the xz to create the img file
Use virtualbox to create a virtual machine
Disk size could be e.g. 32GB
Attach any Manjaro live ISO
Boot the virtual machine
Don’t install Manjaro
Instead map a network folder
Insed the vm open the network folder
Use dd to write the unpacked image file to the virtual disk
When done shutdown the virtual machine
Then use the virtual media manager to copy the disk as a vmdk file.
Transfer that vmdk file to your macbook
Use the file as virtual disk for a new vm in fusion
Start the vm
If success you will get the Manjaro OEM installer to finalize the vm
We have a dedicated internal installer which installs the OS natively as a Linux distribution based on the works Asahi did. However there are some parts not yet supported, like Speakers and other things may not work correctly.
