ZaeNae
22 January 2022 20:10
1
Hi, I tried to install Origin. It worked well when I used the integrated GPU.
But that isn’t good for gaming.
So, I switched to the discret Nvidia GPU.
In this case the install crashes. I can see this messages in the window of the install process:
Started initial process 4921 from /home/molnari/.local/share/lutris/runners/wine/lutris-fshack-6.21-6-x86_64/bin/wine /home/molnari/.cache/lutris/installer/origin/client/OriginSetup.exe /silent
Start monitoring process.
0138:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0066EBFC 1 C) semi-stub
0138:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0066E9EC 1 C) semi-stub
0138:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0066E9FC 1 C) semi-stub
0138:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0066EC3C 1 C) semi-stub
0138:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0066EAFC 1 C) semi-stub
0138:fixme:msvcp:_Locinfo__Locinfo_ctor_cat_cstr (0066EAAC 1 C) semi-stub
0140:err:kerberos:kerberos_LsaApInitializePackage no Kerberos support, expect problems
0140:fixme:d3d:wined3d_guess_card No card selector available for card vendor 0000 (using GL_RENDERER "llvmpipe (LLVM 13.0.0, 256 bits)").
wine: Unhandled page fault on execute access to 00000000 at address 00000000 (thread 0140), starting debugger...
0148:fixme:imm:ImeSetActiveContext (0xb60030, 1): stub
0148:fixme:imm:ImmReleaseContext (000100C0, 00B60030): stub
0154:fixme:imm:ImeSetActiveContext (0x4403d0, 0): stub
0154:fixme:imm:ImmReleaseContext (0000000000010082, 00000000004403D0): stub
What should fix in my system?
It appears it can’t find the driver as it’s falling babck to llvmpipe
Please post your system info as outlined here:
This tutorial is superseded by this one. Remember all Tutorials are wiki posts that can be edited by TL2 (Trust Level 2) members and above.
Welcome to Manjaro!
To allow all of us helpful people on this forum TO HELP YOU, we need some basic information about your system. This probably means you described the symptoms of your problem, but now we need some more information to know where the origin of your issue is exactly.
Someone else probably linked you to…
ZaeNae
22 January 2022 20:52
4
Which post contains the correct format of providing information in that topic?
inxi --admin --verbosity=7 --filter --width
Kernel: 5.10.89-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=9a3969dc-0c4f-4c8a-9c7f-4e8cd555f435 rw quiet
udev.log_priority=3
Desktop: Cinnamon 5.0.7 tk: GTK 3.24.31 vt: 7 dm: LightDM 1.30.0
Type: Laptop System: Micro-Star product: GF63 Thin 10SCXR v: REV:1.0
Mobo: Micro-Star model: MS-16R4 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16R4IMS.105 date: 04/17/2020
ID-1: BAT1 charge: 47.3 Wh (100.0%) condition: 47.3/51.3 Wh (92.1%)
volts: 12.7 min: 11.4 model: MSI Corp. MS-16R4 type: Li-ion serial: N/A
status: Full
RAM: total: 31.18 GiB used: 2.81 GiB (9.0%)
RAM Report:
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB desc: 6x256 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62431
arch_capabilities arch_perfmon art avx avx2 bmi1 bmi2 bts clflush clflushopt
cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts
epb ept ept_ad erms est f16c flexpriority flush_l1d fma fpu fsgsbase fxsr
ht hwp hwp_act_window hwp_epp hwp_notify ibpb ibrs ibrs_enhanced ida
intel_pt invpcid invpcid_single lahf_lm lm mca mce md_clear mmx monitor
movbe mpx msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts rdrand rdseed
rdtscp rep_good sdbg sep smap smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3
stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx
vnmi vpid x2apic xgetbv1 xsave xsavec xsaveopt xsaves xtopology xtpr
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Micro-Star MSI
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU117M vendor: Micro-Star MSI driver: nvidia v: 495.44
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f99
class-ID: 0302
Display: x11 server: X.Org 1.21.1.2 driver: loaded: modesetting,nvidia
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x318mm (20.0x12.5")
s-diag: 599mm (23.6")
Monitor-1: HDMI-1-1 res: 1920x1200 hz: 60 dpi: 94
size: 518x324mm (20.4x12.8") diag: 611mm (24.1")
OpenGL: renderer: NVIDIA GeForce GTX 1650 with Max-Q Design/PCIe/SSE2
v: 4.6.0 NVIDIA 495.44 direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel alternate: snd_soc_skl,snd_sof_pci
bus-ID: 00:1f.3 chip-ID: 8086:06c8 class-ID: 0403
Device-2: Corsair VOID ELITE USB Gaming Headset type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-5:4 chip-ID: 1b1c:0a52
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.89-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.42 running: no
Device-1: Intel Comet Lake PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:06f0 class-ID: 0280
vendor: Micro-Star MSI driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
bus-ID: 1-14:5 chip-ID: 8087:0026 class-ID: e001
Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled
rfk-block: hardware: no software: no address: see --recommends
Local Storage: total: 1.38 TiB used: 165.69 GiB (11.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston
model: RBUSNS8154P3512GJ5 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 type: SSD serial: <filter>
rev: E8FK12.D temp: 40.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM048-2E7172
type: HDD rpm: 5400 serial: <filter> rev: 0001 scheme: GPT
ID-1: / raw-size: 238.42 GiB size: 233.68 GiB (98.01%)
used: 37.93 GiB (16.2%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: 9a3969dc-0c4f-4c8a-9c7f-4e8cd555f435
used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: FF3C-41DF
ID-3: /mnt/misc_disk raw-size: 684 GiB size: 672.26 GiB (98.28%)
used: 127.76 GiB (19.0%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: misc
uuid: f417ae0c-6b9f-45d7-affb-827b6ad26286
dev: /dev/sda3 maj-min: 8:3 label: N/A
uuid: 42569afe-0e3a-49ef-9c01-93d866fdac4a
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 300 MiB fs: vfat label: N/A
uuid: D5C5-9B1E
ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 467.84 GiB fs: ext4 label: N/A
uuid: 60356ee5-c51e-460f-bb14-cb1ef46c6b36
ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 8.8 GiB fs: swap label: N/A
uuid: de013c32-62fb-47e9-a4a6-2374f3b01231
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 16 rev: 2.0
Device-1: 1-3:2 info: Logitech M105 Optical Mouse type: Mouse
driver: hid-generic,usbhid interfaces: 1 rev: 2.0 speed: 1.5 Mb/s
power: 100mA chip-ID: 046d:c077 class-ID: 0301
Device-2: 1-4:3 info: Logitech Keyboard K120 type: Keyboard,HID
power: 90mA chip-ID: 046d:c31c class-ID: 0300
Device-3: 1-5:4 info: Corsair VOID ELITE USB Gaming Headset
type: Audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 1b1c:0a52 class-ID: 0300
serial: <filter>
Device-4: 1-14:5 info: Intel AX201 Bluetooth type: Bluetooth driver: btusb
interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 100mA chip-ID: 8087:0026
class-ID: e001
Hub-2: 2-0:1 info: Super-speed hub ports: 8 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 43.0 C pch: 48.0 C mobo: N/A gpu: nvidia
temp: 42 C
Processes: 307 Uptime: 56m wakeups: 1 Init: systemd v: 250 tool: systemctl
Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: 1352 pacman: 1345 lib: 478
flatpak: 0 snap: 7 Shell: Bash v: 5.1.12 running-in: gnome-terminal
inxi: 3.3.12
By doing what? Do you have the option to use discrete graphics enabled in Lutris Preferences under Global Options?
ZaeNae
22 January 2022 21:00
6
I am using the optimus-manager utility to switching between integrated and nvidia gpus.
The Lutris Preferences has no option, there is only one the: Off.
The Use discrete graphics option is a toggle. It will be grayed out if it’s not available. It sounds like you’re looking at the Optimus Launcher option.
ZaeNae
22 January 2022 21:19
8
You are right.
By the way, the discrete graphics option toggle is On state.
ZaeNae
30 January 2022 11:41
9
Do you have more advise in this subject?
The next release of Lutris will include by default support for origin and Ubisoft connect.
Sorry not to help a lot (my knowledge of this is very limited) but maybe in the next version this gets fixed for you?
Hope you find a proper solution in the mean time anyway, just thought you’d like to know.
ZaeNae
2 February 2022 18:19
11
Thanks for the info. That next release could help me.
ZaeNae
2 February 2022 19:01
12
Good news! A lesser miracle happened.
I installed on another drive a completely new system from the scratch.
I was able install Lutris and inside that the Origin.
One strange thing. I can’t see any vulkan related things in the Lutris/Preferences/Global Options.
It would be nice to know, what is in the background. Maybe I could improve something or make better.
system
Closed
5 February 2022 09:02
13
