Running Manjaro KDE Kernel 6.2.0-1.
I am trying to install lutris from the official repo, however, it just doesn’t open. When I try to launch it, I see the lutris icon with loading for a sec on the taskbar and then it just goes away. The version from flatpak just works fine btw. I have also tried AUR and that doesn’t open too.
What seems to be the problem here?
Run it in the terminal by entering lutris. Post the output here as code.
Usually there is no problem.
File "/usr/bin/lutris", line 52, in <module>
from lutris.gui.application import Application # pylint: disable=no-name-in-module
ModuleNotFoundError: No module named 'lutris'
this is what i get in terminal
What about reinstalling? It looks pretty much that you broke lutris by installing the aur version.
pamac reinstall lutris
still getting the same error
Please run:
sudo pacman -Qkk lutris
and post the output here.
Where is it looking? Please post the output of the following:
which python
python -m site
Please see:
~ which python ✔
/usr/bin/python
~ python -m site ✔
sys.path = [
'/home/noname',
'/usr/lib/python310.zip',
'/usr/lib/python3.10',
'/usr/lib/python3.10/lib-dynload',
'/usr/lib/python3.10/site-packages',
USER_BASE: '/home/noname/.local' (exists)
USER_SITE: '/home/noname/.local/lib/python3.10/site-packages' (doesn't exist)
ENABLE_USER_SITE: True
Okay I solved it, I had previously installed python 3.11.2 directly from the source and that was messing up the whole thing. Uninstalled that and lutris works now! Thank You guys
Please don’t forget to mark your post as a solution
