Hi all
Since a few days my lutris is not starting - I have not changed anything regarding lutris specifically, but there were some system updates here and there and I have downloaded them and everything else is working fine (as far as I can tell atm).
So, first: here is my inxi --admin --verbosity=7 --filter --no-host --width
Kernel: 5.10.56-1-MANJARO x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=a69ef131-f555-42d2-be96-305d87f71d4e rw quiet apparmor=1
Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop System: ASUS product: N/A v: N/A serial: <filter>
Mobo: ASUSTeK model: ROG STRIX B550-A GAMING v: Rev X.0x serial: <filter>
UEFI: American Megatrends v: 1205 date: 11/17/2020
RAM: total: 31.3 GiB used: 5.6 GiB (17.9%)
Info: 6-Core model: AMD Ryzen 5 5600X bits: 64 type: MT MCP arch: Zen 3
family: 19 (25) model-id: 21 (33) stepping: 0 microcode: A201009 cache:
L2: 3 MiB bogomips: 88661
Speed: 2053 MHz min/max: 2200/3700 MHz boost: enabled Core speeds (MHz):
1: 2053 2: 2053 3: 2044 4: 2052 5: 2051 6: 3596 7: 2053 8: 2054 9: 2053
10: 2051 11: 2053 12: 3591
cr8_legacy cx16 cx8 de decodeassists erms extapic extd_apicid f16c
flushbyasid fma fpu fsgsbase fsrm fxsr fxsr_opt ht hw_pstate ibpb ibrs ibs
invpcid irperf lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor
movbe msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke osvw
overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
perfctr_llc perfctr_nb pfthreshold pge pku pni popcnt pse pse36 rdpid rdpru
rdrand rdseed rdt_a rdtscp rep_good sep sha_ni skinit smap smca smep ssbd
sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce
topoext tsc tsc_scale umip v_vmsave_vmload vaes vgif vmcb_clean vme vmmcall
vpclmulqdq wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, IBRS_FW,
STIBP: always-on, RSB filling
Device-1: NVIDIA TU106 [GeForce RTX 2060 Rev. A] vendor: ZOTAC
driver: nvidia v: 470.57.02 alternate: nouveau,nvidia_drm bus-ID: 06:00.0
chip-ID: 10de:1f08 class-ID: 0300
Screen-1: 0 s-res: 3839x1080 s-dpi: 91 s-size: 1069x301mm (42.1x11.9")
s-diag: 1111mm (43.7")
Monitor-1: DP-3 res: 1920x1080 dpi: 92 size: 530x300mm (20.9x11.8")
diag: 609mm (24")
Monitor-2: DP-4 res: 1920x1080 dpi: 82 size: 598x336mm (23.5x13.2")
diag: 686mm (27")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2
v: 4.6.0 NVIDIA 470.57.02 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ZOTAC
driver: snd_hda_intel v: kernel bus-ID: 06:00.1 chip-ID: 10de:10f9
class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 08:00.4 chip-ID: 1022:1487
class-ID: 0403
Device-3: Razer USA Kraken Tournament Edition type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 1532:0520
class-ID: 0300 serial: <filter>
Sound Server-1: ALSA v: k5.10.56-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.33 running: no
Device-1: Intel Ethernet I225-V vendor: ASUSTeK driver: igc v: kernel
port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp5s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 3.87 TiB used: 2.21 TiB (57.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 500GB
type: SSD serial: <filter> rev: 1B6Q scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1500DL003-9VT16L
size: 1.36 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: HDD rpm: 5900 serial: <filter> rev: CC32 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 vendor: Samsung model: SSD 850 EVO 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 2B6Q scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 vendor: Samsung model: SSD 860 QVO 2TB
size: 1.82 TiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
ID-1: / raw-size: 465.75 GiB size: 457.37 GiB (98.20%)
used: 396.03 GiB (86.6%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
uuid: a69ef131-f555-42d2-be96-305d87f71d4e
used: 25.2 MiB (26.3%) fs: vfat dev: /dev/sdc1 maj-min: 8:33 label: N/A
uuid: 745E-D2B9
ID-3: /mnt/SSDX raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 1.45 TiB (79.5%) fs: ntfs dev: /dev/sdd2 maj-min: 8:50 label: SSD
uuid: CEE2DB6EE2DB58F3
ID-4: /run/media/mercedes/B65C629C5C6256E1 raw-size: 232.27 GiB
size: 232.27 GiB (100.00%) used: 110.16 GiB (47.4%) fs: ntfs dev: /dev/sdc3
maj-min: 8:35 label: N/A uuid: B65C629C5C6256E1
ID-5: /run/media/mercedes/HDD raw-size: 1.36 TiB size: 1.36 TiB (100.00%)
used: 273.29 GiB (19.6%) fs: ntfs dev: /dev/sdb1 maj-min: 8:17 label: HDD
uuid: 90307E7D307E69DC
ID-1: /dev/sda1 maj-min: 8:1 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 449 MiB fs: ntfs label: N/A
uuid: EA3E0B513E0B15EB
ID-3: /dev/sdc2 maj-min: 8:34 size: 16 MiB fs: <superuser required>
ID-4: /dev/sdc4 maj-min: 8:36 size: 515 MiB fs: ntfs label: N/A
uuid: A08CFCC68CFC984C
ID-5: /dev/sdd1 maj-min: 8:49 size: 16 MiB fs: <superuser required>
Device-1: 1-1:2 info: Razer USA Kraken Tournament Edition type: Audio,HID
driver: hid-generic,snd-usb-audio,usbhid interfaces: 6 rev: 2.0
speed: 12 Mb/s power: 500mA chip-ID: 1532:0520 class-ID: 0300
serial: <filter>
Device-2: 1-3:3
info: SHARKOON 2.4GHz Wireless rechargeable vertical mouse [More&Better]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 1ea7:0064 class-ID: 0301
Device-3: 1-6:4 info: ASUSTek AURA LED Controller type: HID
driver: hid-generic,usbhid interfaces: 2 rev: 2.0 speed: 12 Mb/s power: 16mA
chip-ID: 0b05:1939 class-ID: 0300 serial: <filter>
Hub-2: 1-7:5 info: Genesys Logic Hub ports: 4 rev: 2.0 speed: 480 Mb/s
power: 100mA chip-ID: 05e3:0610 class-ID: 0900
Hub-3: 2-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 2.0
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
Device-1: 5-1:2 info: Razer USA Basilisk type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:0064 class-ID: 0300
Device-2: 5-4:3 info: Corsair CORSAIR K55 RGB PRO Gaming Keyboard
type: Keyboard,HID driver: hid-generic,usbhid interfaces: 3 rev: 1.1
speed: 12 Mb/s power: 500mA chip-ID: 1b1c:1ba4 class-ID: 0300
serial: <filter>
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 57.6 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 33%
Processes: 304 Uptime: 49m wakeups: 0 Init: systemd v: 248 tool: systemctl
Compilers: gcc: 11.1.0 Packages: 1450 pacman: 1441 lib: 422 flatpak: 0
snap: 9 Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
Now, when I want to start lutris I get this:
File "/usr/bin/lutris", line 52, in <module>
from lutris.gui.application import Application # pylint: disable=no-name-in-module
File "/usr/lib/python3.9/site-packages/lutris/gui/application.py", line 53, in <module>
from .lutriswindow import LutrisWindow
File "/usr/lib/python3.9/site-packages/lutris/gui/lutriswindow.py", line 26, in <module>
from lutris.gui.widgets.sidebar import LutrisSidebar
File "/usr/lib/python3.9/site-packages/lutris/gui/widgets/sidebar.py", line 6, in <module>
from lutris import platforms, runners, services
File "/usr/lib/python3.9/site-packages/lutris/platforms.py", line 19, in <module>
_init_platforms()
File "/usr/lib/python3.9/site-packages/lutris/platforms.py", line 14, in _init_platforms
runner = runners.import_runner(runner_name)()
File "/usr/lib/python3.9/site-packages/lutris/runners/wine.py", line 229, in __init__
"default": dxvk.DXVKManager().version,
File "/usr/lib/python3.9/site-packages/lutris/util/wine/dxvk.py", line 56, in version
if self.versions:
File "/usr/lib/python3.9/site-packages/lutris/util/wine/dxvk.py", line 45, in versions
self._versions = self.load_dxvk_versions()
File "/usr/lib/python3.9/site-packages/lutris/util/wine/dxvk.py", line 70, in load_dxvk_versions
dxvk_versions = [v["tag_name"] for v in json.load(dxvk_version_file)]
File "/usr/lib/python3.9/json/__init__.py", line 293, in load
return loads(fp.read(),
File "/usr/lib/python3.9/json/__init__.py", line 346, in loads
return _default_decoder.decode(s)
File "/usr/lib/python3.9/json/decoder.py", line 337, in decode
obj, end = self.raw_decode(s, idx=_w(s, 0).end())
File "/usr/lib/python3.9/json/decoder.py", line 355, in raw_decode
raise JSONDecodeError("Expecting value", s, err.value) from None
json.decoder.JSONDecodeError: Expecting value: line 1 column 1 (char 0)
When I FIRST started to check it in Konsole, it told me this:
Gtk-Message: 12:55:02.135: Failed to load module "appmenu-gtk-module"
2021-08-14 12:55:02,344: Magic not available. Unable to automatically find game executables. Please install python-magic
But I resolved this part at least, with installing these packages:
- appmenu-gtk-module
- python-magic
- python-lxml
I have also tried this, but it did not work: python-gobject gtk3
How could I resolve this issue?
Otherwise, could I safely uninstall and reinstall lutris on my system without loosing some game-locations or anything else?
Thank you!
- or I did not get the message, sorryâŚ
