Hello, I have a problem with running lutris on Latest Manjaro KDE in the console it pops up:
(lutris:3115): Gtk-WARNING **: 23:44:03.971: Theme parsing error: gtk.css:68:35: The style property GtkButton:child-displacement-x is deprecated and shouldn't be used anymore. It will be removed in a future version
(lutris:3115): Gtk-WARNING **: 23:44:03.971: Theme parsing error: gtk.css:69:35: The style property GtkButton:child-displacement-y is deprecated and shouldn't be used anymore. It will be removed in a future version
(lutris:3115): Gtk-WARNING **: 23:44:03.971: Theme parsing error: gtk.css:73:46: The style property GtkScrolledWindow:scrollbars-within-bevel is deprecated and shouldn't be used anymore. It will be removed in a future version
2021-03-27 23:44:04,425: Loading of DXVK versions failed, defaulting to locally available versions
2021-03-27 23:44:04,440: Loading of DXVK versions failed, defaulting to locally available versions
2021-03-27 23:44:04,538: Initializing lutris
2021-03-27 23:44:04,541: Loading of DXVK versions failed, defaulting to locally available versions
2021-03-27 23:44:04,562: Loading of DXVK versions failed, defaulting to locally available versions
2021-03-27 23:44:05,053: Runtime steam is not available locally
2021-03-27 23:44:05,060: Runtime lib64 is not available locally
2021-03-27 23:44:05,067: Runtime lib32 is not available locally
I’ve already reinstalled lutris, Python, and blame, also re-installed the latest KDE manjaro and still get the same bug.
I don’t know how to install these lutris libraries is hanging on forever. please help
can you explain a bit why the importance of this? Is it because it will be easier to remove all those packages in case the user wants to remove lutris?
but in that case, how will pacman know those dependencies belong to lutris?
cheers
