i have a problem installing games that require libretro, from lutris. I scrolled through many forums but i didnt find a solution. I would install an older package, but i heard its not recommended for Manjaro.
'ScriptInterpreter' object has no attribute 'script'
Yes, i did see it. I searched up the lutris/installer/interpreter.py and the other one, but didnt find the line with the code that i should change. Sorry, im not familiar with computer science.
As mentioned in the comment, it’s already fixed in the master branch. You can ether wait for the next release or install lutris-git from the AUR (Arch User Repository) if you want to test the bleeding edge.
