When I use the wine menu in Lutris to launch winetricks it fails to launch. If I look at a trace of Lutris, I see the following:
Using winetricks 20210206-next - sha256sum: 87dabceee91cbb4c58928d3ddeee57449e591df1b1e7f6011b2eec80e5047eda with wine-4.11-22119-gba748becc9e (Staging) and WINEARCH=win64
zenity: symbol lookup error: /usr/lib/libwebkit2gtk-4.0.so.37: undefined symbol: gst_element_request_pad_simple
winetricks GUI enabled, using zenity
Monitored process exited.
Initial process has exited (return code: 0)
If I search around for the errors I find:
https://bbs.archlinux.org/viewtopic.php?id=274455
But on my system everything is up to date, zenity, everything.
I have tried pamac reinstall
on gstreamer, zenity, lutris and webkit2gtk.
Any ideas?
