After the update to a pure 64-bit version of Wine, Lutris seems broken. I can get it to work using Steam’s Proton, but this is not ideal.
For the default installation package of wine-ge-8-26, it just hangs on installing anything, and for playing an existing installed game, it complains about not finding rundll32 or so. I would post logs of this, but I cannot get it to do anything anymore so logs are not an option. On trying to launch anything, it just hangs forever.
Any ideas on a work around? Or is Lutris pretty much dead unless you install Steam?
Note I tried it on a secondary machine, same result.
Edit: I did get it to post some logs while trying to move another game to wine-ge-8-26:
Started initial process 17194 from gamemoderun /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/bin/wine start /unix /home/x/Games/dungeon-keeper-goldtm/drive_c/GOG Games/Dungeon Keeper Gold/Launch Dungeon Keeper Gold.lnk
Start monitoring process.
gamemodeauto:
fsync: up and running.
wine: RLIMIT_NICE is <= 20, unable to use setpriority safely
(wine:17315): GStreamer-WARNING **: 08:04:44.493: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgsttheora.so': libtheoradec.so.1: cannot open shared object file: No such file or directory
(wine:17315): GStreamer-WARNING **: 08:04:44.500: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstvpx.so': libvpx.so.6: cannot open shared object file: No such file or directory
(wine:17315): GStreamer-WARNING **: 08:04:44.605: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstgtkwayland.so': /usr/lib/libatk-bridge-2.0.so.0: undefined symbol: atk_object_get_help_text
(wine:17315): GStreamer-WARNING **: 08:04:44.606: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstdav1d.so': libdav1d.so.6: cannot open shared object file: No such file or directory
(wine:17315): GStreamer-WARNING **: 08:04:44.611: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstflac.so': libFLAC.so.8: cannot open shared object file: No such file or directory
(wine:17315): GStreamer-WARNING **: 08:04:44.613: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstsndfile.so': /usr/lib/libsndfile.so.1: undefined symbol: mpg123_info2
(wine:17315): GStreamer-WARNING **: 08:04:44.614: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstv4l2codecs.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstv4l2codecs.so: undefined symbol: gst_mpeg2_picture_set_user_data
(wine:17315): GStreamer-WARNING **: 08:04:44.621: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstwaylandsink.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstwaylandsink.so: undefined symbol: gst_wl_shm_allocator_get
(wine:17315): GStreamer-WARNING **: 08:04:44.646: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib64/gstreamer-1.0/libgstlibav.so': /usr/lib/librsvg-2.so.2: undefined symbol: pango_font_metrics_get_height
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgsttheora.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgsttheora.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstvpx.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstvpx.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstgtkwayland.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstgtkwayland.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstdav1d.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstdav1d.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstflac.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstflac.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstsndfile.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstsndfile.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstv4l2codecs.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstv4l2codecs.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstwaylandsink.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstwaylandsink.so: wrong ELF class: ELFCLASS32
(wine:17315): GStreamer-WARNING **: 08:04:44.656: Failed to load plugin '/home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstlibav.so': /home/x/.local/share/lutris/runners/wine/wine-ge-8-26-x86_64/lib/gstreamer-1.0/libgstlibav.so: wrong ELF class: ELFCLASS32
