Hello,
Since the update, Lutris dont work proper anymore and dont show the installed games anymore.
Same for POL, it starts with errors, the game itself complains about missing dll’s.
It seems like python is broken.
Errors from starting Lutris
2021-12-11 22:32:55,959: Starting Lutris 0.5.9.1
File "/usr/lib/python3.9/site-packages/lutris/gui/application.py", line 211, in do_startup
init_lutris()
File "/usr/lib/python3.9/site-packages/lutris/startup.py", line 163, in init_lutris
runners.RUNNER_NAMES = runners.get_runner_names()
File "/usr/lib/python3.9/site-packages/lutris/runners/__init__.py", line 113, in get_runner_names
return {
File "/usr/lib/python3.9/site-packages/lutris/runners/__init__.py", line 114, in <dictcomp>
runner: import_runner(runner)().human_name for runner in __all__
File "/usr/lib/python3.9/site-packages/lutris/runners/wine.py", line 251, in __init__
"choices": D3DExtrasManager().version_choices,
File "/usr/lib/python3.9/site-packages/lutris/util/wine/dll_manager.py", line 60, in version_choices
for version in self.versions:
File "/usr/lib/python3.9/site-packages/lutris/util/wine/dll_manager.py", line 36, in versions
self._versions = self.load_versions()
File "/usr/lib/python3.9/site-packages/lutris/util/wine/dll_manager.py", line 69, in load_versions
versions = [v["tag_name"] for v in json.load(version_file)]
File "/usr/lib/python3.9/json/__init__.py", line 293, in load
return loads(fp.read(),
File "/usr/lib/python3.9/codecs.py", line 322, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0x82 in position 0: invalid start byte
2021-12-11 22:32:55,978: Using NVIDIA drivers 495.44 for x86_64
2021-12-11 22:32:55,978: GPU: Unknown
2021-12-11 22:32:55,979: GPU: 10DE:1401 1458:368F (nvidia drivers)
2021-12-11 22:32:56,391: No cores found
File "/usr/lib/python3.9/site-packages/lutris/gui/widgets/sidebar.py", line 334, in on_realize
runner = runners.import_runner(runner_name)()
Errors at starting POL
playonlinux
Looking for python... 3.9.9 - skipped
Looking for python2.7... 2.7.18 - wxversion(s): 3.0-gtk3
/usr/lib64/python2.7/site-packages/wx-3.0-gtk3/wx/_core.py:16629: UserWarning: wxPython/wxWidgets release number mismatch
warnings.warn("wxPython/wxWidgets release number mismatch")
selected
1
[main] Message: PlayOnLinux (4.3.4) is starting
[clean_tmp] Message: Cleaning temp directory
[Check_OpenGL] Warning: check_dd_x86 missing, test skipped
[Check_OpenGL] Warning: check_dd_amd64 missing, test skipped
