I share @campfire 's doubts if the mkinitcpio hooks really are the cause of trouble. Thanks for the informational link, I’ll dig into that.
Still, if the systemd hooks are not mandatory yet, the system ought to boot with the previous mkinitcpio hooks that worked for years.
Now, I am unsure what I am looking at. Which part of the boot process is causing the error messages (posted above)? Is this from some Grub stage, or already from the upstarting kernel in search of its environment?
I don’t think this is hardware-related; but just in case here’s the output from sudo inxi -zv8xxxxx (run from a boot stick):
Kernel: 6.12.48-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc avail: acpi_pm parameters: BOOT_IMAGE=/boot/vmlinuz-x86_64
lang=en_US keytable=us tz=UTC misobasedir=manjaro
misolabel=MANJARO_KDE_25010 quiet systemd.show_status=1 splash
driver=free nouveau.modeset=1 i915.modeset=1 radeon.modeset=1
Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
Type: Laptop System: LENOVO product: 20CD0001GE v: ThinkPad S1 Yoga
serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: LENOVO model: 20CD0001GE v: SDK0E50512 Std serial: <filter>
part-nu: LENOVO_MT_20CD_BU_Think_FM_ThinkPad S1 Yoga
uuid: 26f41301-5375-11cb-a954-f11bbac33892 UEFI: LENOVO
v: GQET61WW (1.41 ) date: 05/16/2019
ID-1: BAT0 charge: 31.9 Wh (78.3%) condition: 40.8/47.1 Wh (86.7%)
volts: 15.8 min: 14.8 model: SONY 45N1705 type: Li-poly serial: <filter>
charging: status: not charging control: start: 0% end: 100% cycles: N/A
System RAM: total: 8 GiB available: 7.67 GiB used: 1.74 GiB (22.7%)
igpu: 32 MiB
Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
Device-1: ChannelA type: DDR3 detail: synchronous size: 4 GiB
speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
manufacturer: Hynix/Hyundai part-no: HMT851S6AMR6R-PB serial: N/A
Device-2: ChannelB type: DDR3 detail: synchronous size: 4 GiB
Slot: 0 type: PCIe status: available length: long volts: 3.3 bus-ID: 00:00.0
Slot: 1 type: PCIe gen: 1 status: available length: short volts: 3.3
bus-ID: 00:00.0
Slot: 2 type: PCIe gen: 2 status: available length: short volts: 3.3
bus-ID: 00:00.0
Slot: 3 type: PCIe gen: 3 status: available length: short volts: 3.3
bus-ID: 00:00.0
Slot: 4 type: PCIe gen: 4 status: available length: short volts: 3.3
bus-ID: 00:00.0
Slot: 5 type: PCIe gen: 5 status: available length: short volts: 3.3
bus-ID: 00:00.0
Info: model: Intel Core i7-4500U socket: rPGA988B (U3E1) note: check
bits: 64 type: MT MCP arch: Haswell gen: core 4 level: v3 note: check
built: 2013-15 process: Intel 22nm family: 6 model-id: 0x45 (69)
stepping: 1 microcode: 0x26
Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 800 min/max: 800/3000 base/boost: 1800/1800 scaling:
driver: intel_cpufreq governor: schedutil volts: 0.7 V ext-clock: 100 MHz
cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 19161
Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
fsgsbase fxsr ht ibpb ibrs ida invpcid lahf_lm lm mca mce md_clear mmx
monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe pcid pclmulqdq
pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts rdrand rdtscp
rep_good sdbg sep smep ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer vme vmx vnmi vpid
xsave xsaveopt xtopology xtpr
vulnerable
STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
affected
Device-1: Intel Haswell-ULT Integrated Graphics vendor: Lenovo driver: i915
v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:0a16
class-ID: 0300
Device-2: Realtek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 2-6:9 chip-ID: 0bda:5720
Display: unspecified server: X.Org v: 21.1.18 with: Xwayland v: 24.1.8
compositor: kwin_x11 driver: X: loaded: modesetting alternate: fbdev,vesa
dri: crocus gpu: i915 display-ID: :0 screens: 1
s-diag: 582mm (22.93")
Monitor-1: eDP-1 model: LG Display 0x0414 built: 2013 res: mode: 1920x1080
hz: 60 scale: 100% (1) dpi: 177 gamma: 1.2 chroma: red: x: 0.600 y: 0.349
green: x: 0.341 y: 0.569 blue: x: 0.153 y: 0.122 white: x: 0.314 y: 0.329
size: 276x156mm (10.87x6.14") diag: 317mm (12.5") ratio: 16:9
modes: 1920x1080
API: EGL v: 1.5 hw: drv: intel crocus platforms: device: 0 drv: crocus
device: 1 drv: swrast gbm: drv: crocus surfaceless: drv: crocus x11:
drv: crocus inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.2.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4400 (HSW
GT2) device-ID: 8086:0a16 memory: 1.46 GiB unified: yes
API: Vulkan v: 1.4.321 layers: 1 device: 0 type: integrated-gpu name: Intel
HD Graphics 4400 (HSW GT2) driver: mesa intel v: 25.2.3-arch1.2
device-ID: 8086:0a16 surfaces: N/A
x11: xdpyinfo, xprop, xrandr
Device-1: Intel Haswell-ULT HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:03.0 chip-ID: 8086:0a0c class-ID: 0403
Device-2: Intel 8 Series HD Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus-ID: 00:1b.0 chip-ID: 8086:9c20 class-ID: 0403
Device-3: Lenovo ThinkPad OneLink Pro Dock Audio
driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 2-3.1.4:8 chip-ID: 17ef:304e class-ID: 0300
API: ALSA v: k6.12.48-1-MANJARO status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.8 status: n/a (root, process) with:
Device-1: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 04:00.0 chip-ID: 8086:08b2 class-ID: 0280
IF: wlp4s0 state: down mac: <filter>
Device-2: Lenovo RTL8153 Gigabit Ethernet [ThinkPad OneLink Pro Dock]
driver: r8152 type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1
bus-ID: 3-3.1.3:5 chip-ID: 17ef:304f class-ID: 0000 serial: <filter>
IF: enp0s20u3u1u3 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Intel Bluetooth wireless interface driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 2-4:4 chip-ID: 8087:07dc
class-ID: e001
Device-1: rootcry maj-min: 254:0 type: LUKS dm: dm-0 size: 300 GiB
Components:
p-1: sda4 maj-min: 8:4 size: 300 GiB
Local Storage: total: 1.88 TiB used: 105.79 GiB (5.5%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT2000MX500SSD1
family: Micron Client SSDs size: 1.82 TiB block-size: physical: 4096 B
logical: 512 B sata: 3.3 speed: 6.0 Gb/s tech: SSD serial: <filter>
fw-rev: 023 temp: 44 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 58d 5h cycles: 1821
written: 2.79 TiB
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: Ultra Fit
size: 57.28 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.0 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 1.00 scheme: MBR
ID-3: /dev/sdc maj-min: 8:32 model: QIMONDA size: 1.92 GiB block-size:
physical: 512 B logical: 512 B type: USB rev: 2.0 spd: 480 Mb/s lanes: 1
mode: 2.0 tech: N/A serial: <filter> fw-rev: PMAP scheme: MBR
ID-1: /mnt raw-size: 300 GiB size: 294.23 GiB (98.08%)
used: 104.67 GiB (35.6%) fs: ext4 block-size: 4096 B dev: /dev/dm-0
maj-min: 254:0 mapped: rootcry label: N/A uuid: N/A
ID-2: /mnt/boot/efi raw-size: 599 MiB size: 597.8 MiB (99.80%)
used: 368.8 MiB (61.7%) fs: vfat block-size: 512 B dev: /dev/sda1
maj-min: 8:1 label: N/A uuid: AB48-5CF2
ID-3: /run/media/manjaro/QIMONDA raw-size: 1.92 GiB
size: 1.92 GiB (99.99%) used: 778.6 MiB (39.6%) fs: vfat block-size: 512 B
dev: /dev/sdc1 maj-min: 8:33 label: QIMONDA uuid: D249-7842
ID-1: /dev/sda2 maj-min: 8:2 size: 500 MiB fs: N/A label: N/A uuid: N/A
ID-2: /dev/sda3 maj-min: 8:3 size: 299.51 GiB fs: N/A label: N/A uuid: N/A
ID-3: /dev/sda6 maj-min: 8:6 size: 1.07 TiB fs: ext4 label: N/A
uuid: e906d85d-aadd-403a-b227-a493530c7c58
ID-4: /dev/sdb1 maj-min: 8:17 size: 5.1 GiB fs: iso9660
ID-5: /dev/sdb2 maj-min: 8:18 size: 4 MiB fs: vfat label: MISO_EFI
uuid: CA66-EF73
Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
Device-1: 1-1.7:3 info: STMicro Sensor Hub type: HID
driver: hid-sensor-hub,usbhid interfaces: 1 rev: 2.0
chip-ID: 0483:91d1 class-ID: 0300 serial: <filter>
Device-2: 1-1.8:4 info: Wacom TPCEC type: mouse driver: usbhid,wacom
interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1
chip-ID: 056a:00ec class-ID: 0301
Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 9 rev: 2.0
Device-1: 2-1:10 info: Phison Kingston DataTraveler / Patriot Xporter
type: mass storage driver: usb-storage interfaces: 1 rev: 2.0
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 200mA
chip-ID: 13fe:1f00 class-ID: 0806 serial: <filter>
Hub-4: 2-3:3 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2812
Hub-5: 2-3.1:5 info: VIA Labs VL812 Hub ports: 4 rev: 2.1
Device-1: 2-3.1.4:8 info: Lenovo ThinkPad OneLink Pro Dock Audio
type: audio,HID driver: hid-generic,snd-usb-audio,usbhid interfaces: 4
rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 100mA
Hub-6: 2-3.2:7 info: Terminus Hub ports: 4 rev: 2.0
chip-ID: 1a40:0101 class-ID: 0900
Device-1: 2-4:4 info: Intel Bluetooth wireless interface type: bluetooth
mode: 1.1 power: 100mA chip-ID: 8087:07dc class-ID: e001
Device-2: 2-5:6 info: Elan Micro Touchscreen type: HID
driver: hid-multitouch,usbhid interfaces: 1 rev: 2.0
chip-ID: 04f3:0254 class-ID: 0300
Device-3: 2-6:9 info: Realtek Integrated Camera type: video
lanes: 1 mode: 2.0 power: 500mA chip-ID: 0bda:5720 class-ID: 0e02
serial: <filter>
Hub-7: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
Device-1: 3-2:3 info: SanDisk Ultra Fit type: mass storage
driver: usb-storage interfaces: 1 rev: 3.0 speed: 5 Gb/s (596.0 MiB/s)
lanes: 1 mode: 3.2 gen-1x1 power: 896mA chip-ID: 0781:5583 class-ID: 0806
serial: <filter>
Hub-8: 3-3:2 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0812
Hub-9: 3-3.1:4 info: VIA Labs VL812 Hub ports: 4 rev: 3.0
Device-1: 3-3.1.3:5 info: Lenovo RTL8153 Gigabit Ethernet [ThinkPad
OneLink Pro Dock] type: Network driver: r8152 interfaces: 1 rev: 3.0
speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 144mA
System Temperatures: cpu: 58.0 C mobo: N/A
Fan Speeds (rpm): N/A
Packages: pm: pacman pkgs: 1282 libs: 329 tools: pamac pm: flatpak pkgs: 0
1: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
2: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
3: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
4: https://mirror1.sox.rs/manjaro/stable/$repo/$arch
5: https://mirrors.atlas.net.co/manjaro/stable/$repo/$arch
Processes:
CPU top: 5 of 204
1: cpu: 0.7% command: zsh pid: 84087 mem: 9.04 MiB (0.1%)
2: cpu: 0.3% command: konsole pid: 1998 mem: 128.6 MiB (1.6%)
3: cpu: 0.2% command: QIMONDA started-by: dolphin pid: 83793
mem: 131.5 MiB (1.6%)
4: cpu: 0.1% command: Xorg pid: 1316 mem: 107.4 MiB (1.3%)
5: cpu: 0.1% command: org_kde_powerdevil pid: 1579 mem: 50.1 MiB (0.6%)
Memory top: 5 of 204
1: mem: 336.0 MiB (4.2%) command: plasmashell pid: 1521 cpu: 0.0%
2: mem: 193.7 MiB (2.4%) command: kwin_x11 pid: 1476 cpu: 0.0%
3: mem: 131.5 MiB (1.6%) command: QIMONDA started-by: dolphin pid: 83793
cpu: 0.2%
4: mem: 128.6 MiB (1.6%) command: konsole pid: 1998 cpu: 0.3%
5: mem: 117.6 MiB (1.4%) command: yakuake pid: 1731 cpu: 0.0%
Processes: 204 Power: uptime: 17h 39m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 3.02 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 257 default: graphical tool: systemctl
Compilers: N/A Shell: Sudo (sudo) v: 1.9.17p1 default: Bash v: 5.3.3
running-in: konsole inxi: 3.3.39
