LUKS password for home partition requested twice
This is efi multiboot laptop with Manjaro as the first OS, where Manjaro is installed (May 17, 2026) into 3 partitions: /boot/efi, /root and /home with LUKS encryption. Otherwise Manjaro works OK.
When starting (launching) the system, Manjaro requires to write LUKS password for /home partition twice (two times). Why ? Can I correct it somehow ?
For instance, in Arch Linux once is enough.
Hello @pelka and welcome.
For others to help, they will need more detail from you.
Please provide your system information according to forum guidelines. :point_down:
inxi -zv8 (short-form)
Your privacy is respected
What is a Quark?
Just to add that I recall this issue has arisen in the past, and there is a solution – please use the forum search, and hopefully you might find it. Cheers.
My system in question:
inxi --filter --verbosity=8:
  Kernel: 7.0.9-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-7.0-x86_64
    root=UUID=ef2aebbd-b3b6-45f3-b70f-275ced4a189b rw quiet splash apparmor=1
  Desktop: GNOME v: 50.1 tk: GTK v: 3.24.52 wm: gnome-shell
    tools: gsd-screensaver-proxy dm: GDM v: 50.0 Distro: Manjaro
    base: Arch Linux
  Type: Laptop System: Hewlett-Packard product: HP EliteBook 8570p
    v: A1029D1103 serial: <superuser required> Chassis: type: 10
  Mobo: Hewlett-Packard model: 17A7 v: KBC Version 42.38
    serial: <superuser required> part-nu: C5A87EA#AK8 uuid: <superuser required>
    Firmware: UEFI vendor: Hewlett-Packard v: 68ICF Ver. F.74 date: 04/11/2019
  System RAM: total: 8 GiB available: 7.68 GiB used: 2.59 GiB (33.8%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: Bottom-Slot 2(under) type: DDR3 detail: synchronous size: 4 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Samsung part-no: M471B5273CH0-YK0 serial: <filter>
  Device-2: Bottom-Slot 1(top) type: DDR3 detail: synchronous size: 4 GiB
    manufacturer: Kingston part-no: HP16D3LS1KBG/4G serial: <filter>
  Info: model: Intel Core i7-3540M bits: 64 type: MT MCP arch: Ivy Bridge
    gen: core 3 level: v2 built: 2012-15 process: Intel 22nm family: 6
    model-id: 0x3A (58) stepping: 9 microcode: 0x21
  Topology: cpus: 1x dies: 1 clusters: 2 cores: 2 threads: 4 tpc: 2
    smt: enabled cache: L1: 128 KiB desc: d-2x32 KiB; i-2x32 KiB L2: 512 KiB
    desc: 2x256 KiB L3: 4 MiB desc: 1x4 MiB
  Speed (MHz): avg: 1197 min/max: 1200/3700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 1197 2: 1197 3: 1197 4: 1197 bogomips: 23945
  Flags: acpi aes aperfmperf apic arat arch_perfmon avx bts clflush cmov
    constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64 dtherm dts epb
    ept erms est f16c flexpriority flush_l1d fpu fsgsbase fxsr ht ibpb ibrs
    ida lahf_lm lm mca mce md_clear mmx monitor msr mtrr nonstop_tsc nopl nx
    pae pat pbe pcid pclmulqdq pdcm pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sep smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3
    stibp syscall tm tm2 tpr_shadow tsc tsc_deadline_timer vme vmx vnmi vpid
    x2apic xsave xsaveopt xtopology xtpr
    vulnerable
    STIBP: conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Type: srbds status: Vulnerable: No microcode
  Device-1: Advanced Micro Devices [AMD/ATI] Thames [Radeon HD
    7550M/7570M/7650M] vendor: Hewlett-Packard driver: radeon v: kernel
    alternate: amdgpu arch: TeraScale-2 code: Evergreen process: TSMC 32-40nm
    built: 2009-15 pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 1
    speed: 2.5 GT/s ports: active: LVDS-1 empty: DP-1, DP-2, DP-3, VGA-1
    bus-ID: 01:00.0 chip-ID: 1002:6841 class-ID: 0300 temp: 48.0 C
  Device-2: Primax HP HD Webcam [Fixed] driver: uvcvideo type: USB rev: 2.0
    speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-1.3:4 chip-ID: 0461:4dfe
    compositor: gnome-shell driver: gpu: radeon display-ID: 0
  Monitor-1: LVDS-1 model: Seiko Epson 0x3659 built: 2012 res: 1600x900
    dpi: 118 gamma: 1.2 chroma: red: x: 0.600 y: 0.341 green: x: 0.310 y: 0.561
    blue: x: 0.149 y: 0.129 white: x: 0.314 y: 0.329
    size: 344x194mm (13.54x7.64") diag: 395mm (15.5") ratio: 16:9
    modes: 1600x900, 1440x900, 1280x854, 1280x800, 1280x720, 1152x768,
    1024x768, 800x600, 848x480, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unknown flag 2
  API: EGL v: 1.5 hw: drv: amd r600 platforms: device: 0 drv: r600 device: 1
    drv: swrast gbm: drv: kms_swrast surfaceless: drv: r600 wayland: drv: r600
    x11: drv: r600
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: mesa v: 26.0.6-arch1.1 glx-v: 1.4
    direct-render: yes renderer: AMD TURKS (DRM 2.51.0 / 7.0.9-1-MANJARO)
    device-ID: 1002:6841 memory: 1000 MiB unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop
  Device-1: Intel 7 Series/C216 Family High Definition Audio
    vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
    chip-ID: 8086:1e20 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Turks HDMI Audio [Radeon HD
    6500/6600 / 6700M Series] vendor: Hewlett-Packard driver: snd_hda_intel
    v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 16 link-max: gen: 1
    speed: 2.5 GT/s bus-ID: 01:00.1 chip-ID: 1002:aa90 class-ID: 0403
  API: ALSA v: k7.0.9-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.5 status: active with: 1: pipewire-pulse
  Device-1: Intel 82579LM Gigabit Network vendor: Hewlett-Packard
    driver: e1000e v: kernel port: 5020 bus-ID: 00:19.0 chip-ID: 8086:1502
    class-ID: 0200
  IF: enp0s25 state: down mac: <filter>
  Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
    v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 25:00.0
    chip-ID: 8086:0082 class-ID: 0280
  Device-1: Broadcom HP Portable SoftSailing driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 4-1.6:3
    chip-ID: 0a5c:21e1 class-ID: fe01 serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: enabled,running
  Device-1: luks-c30867e4-4bea-42f2-9ecc-1d1d22c5fcb4 maj-min: 253:0
    type: LUKS dm: dm-0 size: 25.78 GiB
  Components:
  p-1: sda3 maj-min: 8:3 size: 25.78 GiB
  Device-2: luks-5a7624e4-ac7b-440f-a670-d6e1e6c3818d maj-min: 253:2
    type: LUKS dm: dm-2 size: 72.25 GiB
  Components:
  p-1: sda6 maj-min: 8:6 size: 72.27 GiB
  Device-3: luks-60c8cdcf-f4bc-4888-b572-162701670a72 maj-min: 253:1
    type: LUKS dm: dm-1 size: 29.79 GiB
  Components:
  p-1: sdc1 maj-min: 8:33 size: 29.81 GiB
  Local Storage: total: 728.44 GiB used: 14.02 GiB (1.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37480G
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 0100 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Kingston model: SA400S37240G
    size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: B1H5 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 vendor: Kingston model: DataTraveler 3.0
    size: 57.73 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
    fw-rev: 0000 scheme: GPT
  ID-1: / raw-size: 23.44 GiB size: 22.9 GiB (97.71%) used: 12.72 GiB (55.5%)
    fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: man_root
    uuid: ef2aebbd-b3b6-45f3-b70f-275ced4a189b
  ID-2: /boot/efi raw-size: 1.95 GiB size: 1.95 GiB (99.80%)
    used: 328 KiB (0.0%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: man_efi
    uuid: 6FC1-43C1
  ID-3: /home raw-size: 25.78 GiB size: 25.21 GiB (97.78%)
    used: 594.6 MiB (2.3%) fs: ext4 dev: /dev/dm-0 maj-min: 253:0
    mapped: luks-c30867e4-4bea-42f2-9ecc-1d1d22c5fcb4 label: man_home
    uuid: 4f25efaa-0287-44a4-997b-91dae714f286
  ID-4: /run/media/user1/2.y raw-size: 29.79 GiB size: 29.16 GiB (97.87%)
    used: 2.1 MiB (0.0%) fs: ext4 dev: /dev/dm-1 maj-min: 253:1
    mapped: luks-60c8cdcf-f4bc-4888-b572-162701670a72 label: 2.y
    uuid: 2617a82b-6f0b-4976-8bbe-6205f401ecc6
  ID-5: /run/media/user1/F3 raw-size: 27.93 GiB size: 27.91 GiB (99.95%)
    used: 1.5 MiB (0.0%) fs: vfat dev: /dev/sdc2 maj-min: 8:34 label: F3
    uuid: F744-35BD
  ID-6: /run/media/user1/kr1 raw-size: 72.25 GiB size: 70.56 GiB (97.65%)
    used: 735.1 MiB (1.0%) fs: ext4 dev: /dev/dm-2 maj-min: 253:2
    mapped: luks-5a7624e4-ac7b-440f-a670-d6e1e6c3818d label: kr1
    uuid: 895e4986-cdcd-4e4d-96d6-4511481f3da8
  ID-1: swap-1 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
    priority: -1 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 02b9de2a-d506-4ac0-993a-b89fa2e13b29
  ID-1: /dev/sda7 maj-min: 8:7 size: 1000 MiB fs: vfat label: N/A
    uuid: C513-4F3F
  ID-2: /dev/sda8 maj-min: 8:8 size: 25 GiB fs: ext4 label: N/A
    uuid: ddf3f9af-e07b-49c0-8861-de89999abc85
  ID-3: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: N/A
    uuid: BC6C-5E84
  ID-4: /dev/sdb2 maj-min: 8:18 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-5: /dev/sdb3 maj-min: 8:19 size: 130.15 GiB fs: ntfs label: N/A
    uuid: FE066D5D066D1843
  ID-6: /dev/sdb4 maj-min: 8:20 size: 547 MiB fs: ntfs label: N/A
    uuid: 60469E78469E4F22
  ID-7: /dev/sdb5 maj-min: 8:21 size: 2 GiB fs: ext4 label: N/A
    uuid: 136e2bce-d546-4c94-86be-7cb96fea531a
  Hub-1: 1-0:1 info: full speed or root hub ports: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:0024
  Device-1: 1-1.1:3 info: Validity Sensors VFS491 type: <vendor specific>
    driver: N/A interfaces: 1 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 100mA chip-ID: 138a:003d class-ID: ff00 serial: <filter>
  Device-2: 1-1.3:4 info: Primax HP HD Webcam [Fixed] type: video
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 0461:4dfe class-ID: 0e02
    serial: <filter>
  Hub-3: 2-0:1 info: hi-speed hub with single TT ports: 4 rev: 2.0
  Device-1: 2-3:2 info: USB OPTICAL MOUSE type: mouse
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    chip-ID: 275d:0ba6 class-ID: 0301
  Hub-4: 3-0:1 info: super-speed hub ports: 4 rev: 3.0
  Device-1: 3-4:2 info: Kingston DataTraveler 100 G3/G4/SE9 G2/50 Kyson
    type: mass storage driver: usb-storage interfaces: 1 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 power: 144mA
    chip-ID: 0951:1666 class-ID: 0806 serial: <filter>
  Hub-5: 4-0:1 info: full speed or root hub ports: 3 rev: 2.0
  Hub-6: 4-1:2 info: Intel Integrated Rate Matching Hub ports: 8 rev: 2.0
  Device-1: 4-1.6:3 info: Broadcom HP Portable SoftSailing type: Bluetooth
    driver: btusb interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 chip-ID: 0a5c:21e1 class-ID: fe01 serial: <filter>
  System Temperatures: cpu: 54.0 C mobo: N/A gpu: radeon temp: 48.0 C
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1282 libs: 369 tools: gnome-software,pamac
    pm: flatpak pkgs: 0
    1: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    2: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 270
  1: cpu: 34.8% command: kgx pid: 10549 mem: 242.3 MiB (3.0%)
  2: cpu: 22.2% command: firefox pid: 6718 mem: 625.7 MiB (7.9%)
  3: cpu: 17.5% command: firefox pid: 7099 mem: 545.8 MiB (6.9%)
  4: cpu: 9.2% command: gnome-shell pid: 2928 mem: 269.1 MiB (3.4%)
  5: cpu: 6.9% command: firefox pid: 7096 mem: 282.1 MiB (3.5%)
  Memory top: 5 of 270
  1: mem: 780.8 MiB (9.9%) command: firefox pid: 7036 cpu: 6.1%
  2: mem: 625.7 MiB (7.9%) command: firefox pid: 6718 cpu: 22.2%
  3: mem: 545.8 MiB (6.9%) command: firefox pid: 7099 cpu: 17.5%
  4: mem: 436.2 MiB (5.5%) command: firefox pid: 7225 cpu: 0.8%
  5: mem: 282.1 MiB (3.5%) command: firefox pid: 7096 cpu: 6.9%
  Processes: 270 Power: uptime: 41m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.99 GiB services: gsd-power,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: N/A Shell: Zsh v: 5.9 running-in: kgx inxi: 3.3.40
Information on how to format code and command output has already been given (above :point_up:) – The formatting of your inxi output has now been corrected in accordance with forum guidelines.
In future, you are expected to master this skill, and ensure your posts are presentable for those reading.
Thank you for good instructions !
I opened the link and tried to adjust my installation as advised in items 7.1.1 and 7.3.
The 1st command for item 7.1.1 (i.e. β€˜β€˜sudo printf β€˜%s’ …’’) did not allow me to proceed. So, instead I used sudo nano /etc/cryptsetup-keys.d/keyfile.key to create the keyfile.key file and to write and save my passphrase into this file.
Then I added the keyfile.key into LUKS cryptsetup as advised in item 7.3 and rebooted. The result: This Manjaro installation still requires /home password twice.
[ I found this source of info in Issue Β· GitHub advising to 1.) open /etc/crypttab and 2.) replace the luks field none with /crypto_keyfile.bin, 3.) run dracut to rebuild initrd and 4.) reboot. I’ve not tried this method since it covers other distribution. ]
Today (3.5.26) at 1st I dismantled from the system my keyfile.key changes and tried then to repair booting as advised for Mandriva: 1.) I opened /etc/crypttab and 2.) replaced the luks field none with */crypto_keyfile.bin, 3.) run mkinitcpio -g initramfs-7.0-x86.img ==>> resulting with
β€˜β€™ '… Initcpio image generation successful
==> Running post hooks
-> Running post hook: [sbctl]
Secureboot key directory doesn't exist, not signing!
==> Post processing done. β€˜β€™
After reboot Manjaro asks password twice.
