I’ve just built a new Manjaro system with Cinnamon after transitioning away from KDE - I’ve been trying to install a Real-Time kernel as well as the main one. I’m running 6.1
as the top LTS and I’ve installed 5.15
as a backup.
The only RT kernel options I seem to have in the list, either via the GUI or by calling mhwd-kernel --install
are linux62-rt
and linux63-rt
. I don’t really want to go bleeding edge, and was looking for linux61-rt
(or failing that linux60-rt
) but they aren’t available.
There don’t seem to be any LTS marked RT kernels. I had an older one installed before. Is there any way to get hold of the older kernels or do they disappear completely once they reach end of support?
My issues with using 62 or 63 are twofold - Firstly, risking a more bleeding edge kernel and secondly that the RT then becomes my bootloader default which, as I’d need the RT kernel only rarely, is… annoying.
