LTS Kernel 6.1.x Inspiron 3180 battery reporting 100%
POWER_SUPPLY_CYCLE_COUNT, POWER_SUPPLY_VOLTAGE_MIN_DESIGN, POWER_SUPPLY_CHARGE_FULL_DESIGN, POWER_SUPPLY_CHARGE_FULL, POWER_SUPPLY_MODEL_NAME, are absent or wrong values.
Bump from LTS kernel 5.15.x to 6.1.x on Dell Inspiron 3180. Have a wifi problem on both that is resolved with kernel boot option acpi_force_table_verification and a Laptop battery reporting issue with Kernel 6.1 that I can’t pin down.
Sometimes it works and the major difference is that the Xfce power manager reports the Model Name as “DELL PGYK586”. I’ve had it not work on a boot but then work when resume from sleep so it feels like miscommunication and/or timing.
The thing is, it does seem to report discharge and maybe remaining time but the battery indication thinks we’re always at 100% charge. Tried various kernel boot options. The lshw output seems to pick up some of that missing information even when xfce4-power-manager doesn’t. Like we’re not communicating something properly.
Based on the ACPI messages these kernel boot options should be used:
acpi_osi=Linux acpi_force_table_verification amd_iommu=off pcie_aspm=off
Errors
journalctl -p 3 -xb --no-pager
Mar 05 12:53:16 computer kernel: tpm_crb MSFT0101:00: can't request region for resource [mem 0xe7bb6000-0xe7bb9fff]
Mar 05 12:53:25 computer kernel: kfd kfd: amdgpu: STONEY  not supported in kfd
Mar 05 12:53:27 computer bluetoothd[752]: src/plugin.c:plugin_init() Failed to init vcp plugin
Mar 05 12:53:27 computer bluetoothd[752]: src/plugin.c:plugin_init() Failed to init mcp plugin
Mar 05 12:53:27 computer bluetoothd[752]: src/plugin.c:plugin_init() Failed to init bap plugin
Mar 05 12:53:46 computer lightdm[1011]: gkr-pam: unable to locate daemon control file
Hardware
$ sudo lshw
computer
    description: Notebook
    product: Inspiron 3180 (087E)
    vendor: Dell Inc.
    version: 1.5.0
    width: 64 bits
    capabilities: smbios-3.1.1 dmi-3.1.1 smp vsyscall32
    configuration: boot=normal chassis=notebook family=Inspiron sku=087E uuid=44454C4C-3700-1037-8057-C7C04F355032
  *-core
       description: Motherboard
       product: 01VW3T
       vendor: Dell Inc.
       physical id: 0
       version: A00
       slot: Type2 - Board Chassis Location
     *-firmware
          description: BIOS
          vendor: Dell Inc.
          physical id: 0
          version: 1.5.0
          date: 07/14/2022
          capacity: 8MiB
          capabilities: pci pnp upgrade shadowing cdboot bootselect edd int13floppynec int13floppytoshiba int13floppy360 int13floppy1200 int13floppy720 int13floppy2880 int9keyboard int10video acpi usb ls120boot zipboot smartbattery biosbootspecification netboot uefi
     *-cpu
          description: CPU
          product: AMD A6-9220e RADEON R4, 5 COMPUTE CORES 2C+3G
          vendor: Advanced Micro Devices [AMD]
          physical id: 4
          bus info: cpu@0
          version: AMD A6-9220e RADEON R4, 5 COMPUTE CORES 2C+3G
          slot: Socket FP4
          width: 64 bits
          clock: 100MHz
          capabilities: lm fpu fpu_exception wp vme de pse tsc msr pae mce cx8 apic sep mtrr pge mca cmov pat pse36 clflush mmx fxsr sse sse2 ht syscall nx mmxext fxsr_opt pdpe1gb rdtscp x86-64 constant_tsc rep_good acc_power nopl nonstop_tsc cpuid extd_apicid aperfmperf pni pclmulqdq monitor ssse3 fma cx16 sse4_1 sse4_2 movbe popcnt aes xsave avx f16c lahf_lm cmp_legacy svm extapic cr8_legacy abm sse4a misalignsse 3dnowprefetch osvw ibs xop skinit wdt lwp fma4 tce nodeid_msr tbm perfctr_core perfctr_nb bpext ptsc mwaitx cpb hw_pstate ssbd vmmcall fsgsbase bmi1 avx2 smep bmi2 xsaveopt arat npt lbrv svm_lock nrip_save tsc_scale vmcb_clean flushbyasid decodeassists pausefilter pfthreshold avic v_vmsave_vmload vgif overflow_recov cpufreq
          configuration: cores=2 enabledcores=2 threads=2
        *-cache:0
             description: L1 cache
             physical id: 7
             slot: L1-Cache
             capacity: 256KiB
             clock: 1GHz (1.0ns)
             capabilities: pipeline-burst internal write-back unified
             configuration: level=1
        *-cache:1
             description: L2 cache
             physical id: 8
             slot: L2-Cache
             capacity: 2MiB
             clock: 1GHz (1.0ns)
             configuration: level=2
     *-memory
          description: System Memory
          physical id: 21
          slot: System board or motherboard
        *-bank
             description: SODIMM DDR4 Synchronous Unbuffered (Unregistered) 1200 MHz (0.8 ns)
             product: 4ATF51264HZ-2G3E1
             vendor: Micron Technology
             physical id: 0
             slot: DIMM 0
             width: 64 bits
             clock: 1200MHz (0.8ns)
     *-pci:0
          description: Host bridge
          product: Family 15h (Models 60h-6fh) Processor Root Complex
          vendor: Advanced Micro Devices, Inc. [AMD]
          physical id: 100
          bus info: pci@0000:00:00.0
          version: 00
          width: 32 bits
          clock: 33MHz
        *-generic:0 UNCLAIMED
             description: IOMMU
             product: Family 15h (Models 60h-6fh) I/O Memory Management Unit
             physical id: 0.2
             bus info: pci@0000:00:00.2
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: msi ht bus_master cap_list
             configuration: latency=0
        *-display
             description: VGA compatible controller
             product: Stoney [Radeon R2/R3/R4/R5 Graphics]
             vendor: Advanced Micro Devices, Inc. [AMD/ATI]
             physical id: 1
             bus info: pci@0000:00:01.0
             version: eb
             width: 64 bits
             clock: 33MHz
             capabilities: pm pciexpress msi vga_controller bus_master cap_list rom
             configuration: driver=amdgpu latency=0
             resources: irq:35 memory:e8000000-efffffff memory:f0000000-f07fffff ioport:2000(size=256) memory:f0b00000-f0b3ffff memory:c0000-dffff
        *-multimedia:0
             description: Audio device
             product: Advanced Micro Devices, Inc. [AMD/ATI]
             physical id: 1.1
             bus info: pci@0000:00:01.1
             version: 00
             width: 64 bits
             clock: 33MHz
             capabilities: pm pciexpress msi bus_master cap_list
             configuration: driver=snd_hda_intel latency=0
             resources: irq:31 memory:f0b60000-f0b63fff
        *-pci
             description: PCI bridge
             product: Family 15h (Models 60h-6fh) Processor Root Port
             physical id: 2.5
             bus info: pci@0000:00:02.5
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pci pm pciexpress msi ht normal_decode bus_master cap_list
             configuration: driver=pcieport
             resources: irq:25 memory:f0a00000-f0afffff
           *-network
                description: Wireless interface
                product: QCA9565 / AR9565 Wireless Network Adapter
                vendor: Qualcomm Atheros
                physical id: 0
                bus info: pci@0000:01:00.0
                logical name: wlp1s0
                version: 01
                width: 64 bits
                clock: 33MHz
                capabilities: pm msi pciexpress bus_master cap_list rom ethernet physical wireless
                configuration: broadcast=yes driver=ath9k driverversion=6.1.12-1-MANJARO firmware=N/A ip=192.168.0.26 latency=0 link=yes multicast=yes wireless=IEEE 802.11
                resources: irq:33 memory:f0a00000-f0a7ffff memory:f0a80000-f0a8ffff
        *-generic:1 UNCLAIMED
             description: Encryption controller
             product: Carrizo Platform Security Processor
             physical id: 8
             bus info: pci@0000:00:08.0
             version: 00
             width: 64 bits
             clock: 33MHz
             capabilities: msix ht pm bus_master cap_list
             resources: memory:f0b40000-f0b5ffff memory:f0900000-f09fffff memory:f0b6f000-f0b6ffff memory:f0b6a000-f0b6bfff
        *-multimedia:1
             description: Computer telephony device
             product: Family 15h (Models 60h-6fh) Audio Controller
             physical id: 9.2
             bus info: pci@0000:00:09.2
             version: 00
             width: 32 bits
             clock: 33MHz
             capabilities: pm bus_master cap_list
             resources: irq:32 memory:f0b64000-f0b67fff
        *-usb:0
             description: USB controller
             product: FCH USB XHCI Controller
             physical id: 10
             bus info: pci@0000:00:10.0
             version: 20
             width: 64 bits
             clock: 33MHz
             capabilities: pm msi msix pciexpress xhci bus_master cap_list
             configuration: driver=xhci_hcd latency=0
             resources: irq:18 memory:f0b68000-f0b69fff
           *-usbhost:0
                product: xHCI Host Controller
                vendor: Linux 6.1.12-1-MANJARO xhci-hcd
                physical id: 0
                bus info: usb@2
                logical name: usb2
                version: 6.01
                capabilities: usb-2.00
                configuration: driver=hub slots=4 speed=480Mbit/s
              *-usb
                   description: Bluetooth wireless interface
                   vendor: Qualcomm Atheros Communications
                   physical id: 2
                   bus info: usb@2:2
                   version: 0.02
                   capabilities: bluetooth usb-1.10
                   configuration: driver=btusb maxpower=100mA speed=12Mbit/s
           *-usbhost:1
                physical id: 1
                bus info: usb@3
                logical name: usb3
                version: 6.01
                capabilities: usb-3.00
                configuration: driver=hub slots=4 speed=5000Mbit/s
        *-sata
             description: SATA controller
             product: FCH SATA Controller [AHCI mode]
             physical id: 11
             bus info: pci@0000:00:11.0
             version: 4b
             width: 32 bits
             clock: 66MHz
             capabilities: sata pm ahci_1.0 bus_master cap_list
             configuration: driver=ahci latency=32
             resources: irq:19 ioport:2118(size=8) ioport:2124(size=4) ioport:2110(size=8) ioport:2120(size=4) ioport:2100(size=16) memory:f0b6c000-f0b6c3ff
        *-usb:1
             product: FCH USB EHCI Controller
             physical id: 12
             bus info: pci@0000:00:12.0
             version: 49
             width: 32 bits
             clock: 66MHz
             capabilities: pm debug ehci bus_master cap_list
             configuration: driver=ehci-pci latency=32
             resources: irq:18 memory:f0b6d000-f0b6d0ff
           *-usbhost
                product: EHCI Host Controller
                vendor: Linux 6.1.12-1-MANJARO ehci_hcd
                physical id: 1
                bus info: usb@1
                logical name: usb1
                version: 6.01
                configuration: driver=hub slots=2 speed=480Mbit/s
              *-usb
                   description: USB hub
                   product: Root Hub
                   physical id: 1
                   bus info: usb@1:1
                   version: 0.18
                   configuration: driver=hub maxpower=100mA slots=4 speed=480Mbit/s
                 *-usb:0
                      description: Video
                      product: Integrated_Webcam_HD
                      vendor: CNFHH46O303430023EB0
                      physical id: 1
                      bus info: usb@1:1.1
                      version: 85.11
                      capabilities: usb-2.01
                      configuration: driver=uvcvideo maxpower=500mA speed=480Mbit/s
                 *-usb:1
                      description: MMC Host
                      product: USB2.0-CRW
                      vendor: Generic
                      physical id: 3
                      bus info: usb@1:1.3
                      logical name: mmc0
                      version: 39.60
                      configuration: driver=rtsx_usb maxpower=500mA speed=480Mbit/s
        *-serial
             description: SMBus
             product: FCH SMBus Controller
             physical id: 14
             bus info: pci@0000:00:14.0
             version: 4b
             width: 32 bits
             clock: 66MHz
             configuration: driver=piix4_smbus latency=0
             resources: irq:0
        *-isa
             description: ISA bridge
             product: FCH LPC Bridge
             physical id: 14.3
             bus info: pci@0000:00:14.3
             version: 11
             width: 32 bits
             clock: 66MHz
             capabilities: isa bus_master
     *-pci:1
          product: Family 15h (Models 60h-6fh) Host Bridge
          physical id: 101
          bus info: pci@0000:00:02.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:2
          physical id: 102
          bus info: pci@0000:00:03.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:3
          product: Carrizo Audio Dummy Host Bridge
          physical id: 103
          bus info: pci@0000:00:09.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:4
          product: Stoney HT Configuration
          physical id: 104
          bus info: pci@0000:00:18.0
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:5
          product: Stoney Address Maps
          physical id: 105
          bus info: pci@0000:00:18.1
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:6
          product: Stoney DRAM Configuration
          physical id: 106
          bus info: pci@0000:00:18.2
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pci:7
          product: Stoney Miscellaneous Configuration
          physical id: 107
          bus info: pci@0000:00:18.3
          version: 00
          width: 32 bits
          clock: 33MHz
          configuration: driver=k10temp
          resources: irq:0
     *-pci:8
          product: Stoney PM Configuration
          physical id: 108
          bus info: pci@0000:00:18.4
          version: 00
          width: 32 bits
          clock: 33MHz
          configuration: driver=fam15h_power
          resources: irq:0
     *-pci:9
          product: Stoney NB Performance Monitor
          physical id: 109
          bus info: pci@0000:00:18.5
          version: 00
          width: 32 bits
          clock: 33MHz
     *-pnp00:00
          product: Motherboard registers
          physical id: 1
          capabilities: pnp
          configuration: driver=system
     *-pnp00:01
          product: AT Real-Time Clock
          physical id: 2
          capabilities: pnp
          configuration: driver=rtc_cmos
     *-pnp00:02
          product: IBM Enhanced keyboard controller (101/2-key)
          physical id: 3
          capabilities: pnp
          configuration: driver=i8042 kbd
     *-pnp00:03
          product: PnP device DLL087e
          vendor: Dell Inc
          physical id: 5
          capabilities: pnp
          configuration: driver=i8042 aux
     *-pnp00:04
          physical id: 6
          capabilities: pnp
     *-pnp00:05
          product: System Board
          physical id: 7
          capabilities: pnp
  *-battery
       description: Lithium Ion Battery
       product: DELL PGYK586
       vendor: Samsung SDI
       physical id: 1
       version: 0
       slot: Battery Bay
       capacity: 31990mWh
       configuration: voltage=7.6V
ACPI/IOMMU info
$ sudo journalctl -k -g '(acpi|efi|mmu)' --no-pager -o cat
Command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=62145428-1875-4077-9d2e-0a971633e1e6 rw quiet apparmor=1 security=apparmor resume=UUID=39e5c245-7e95-43b1-b427-e1d6e95524cd udev.log_priority=3
BIOS-e820: [mem 0x00000000e78bf000-0x00000000e7bbefff] ACPI NVS
BIOS-e820: [mem 0x00000000e7bbf000-0x00000000e7bfefff] ACPI data
efi: EFI v2.50 by Dell Inc.
efi: ACPI 2.0=0xe7bfe014 SMBIOS=0xe7208000 SMBIOS 3.0=0xe7206000 ESRT=0xe7204d18 MEMATTR=0xe3f6d018
ACPI: Early table checksum verification disabled
ACPI: RSDP 0x00000000E7BFE014 000024 (v02 DELL  )
ACPI: XSDT 0x00000000E7BCD188 0000EC (v01 DELL   WN09     00000001      01000013)
ACPI: FACP 0x00000000E7BF8000 00010C (v05 DELL   WN09     00000001 ASL  00040000)
ACPI: DSDT 0x00000000E7BE9000 00815D (v01 DELL   WN09     00040000 ASL  00040000)
ACPI: FACS 0x00000000E7B83000 000040
ACPI: UEFI 0x00000000E7BFD000 000236 (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: SLIC 0x00000000E7BFC000 000176 (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: MSDM 0x00000000E7BFB000 000055 (v03 DELL   WN09     00000001 ASL  00040000)
ACPI: ASF! 0x00000000E7BFA000 0000A5 (v32 DELL   WN09     00000001 ASL  00040000)
ACPI: BOOT 0x00000000E7BF9000 000028 (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: HPET 0x00000000E7BF7000 000038 (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: APIC 0x00000000E7BF6000 000090 (v03 DELL   WN09     00000001 ASL  00040000)
ACPI: MCFG 0x00000000E7BF5000 00003C (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: WDAT 0x00000000E7BF3000 00017C (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: WDRT 0x00000000E7BF2000 000047 (v01 DELL   WN09     00000000 ASL  00040000)
ACPI: UEFI 0x00000000E7BE8000 000042 (v01 DELL   WN09     00000000 ASL  00040000)
ACPI: SSDT 0x00000000E7BE7000 00043C (v01 AMD    Jadeite  00000001 ACPI 00040000)
ACPI: SSDT 0x00000000E7BE2000 004B5B (v02 AMD    Jadeite  00000002 ACPI 00040000)
ACPI: IVRS 0x00000000E7BE1000 0000D0 (v02 DELL   WN09     00000001 ASL  00040000)
ACPI: CRAT 0x00000000E7BE0000 0002E8 (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: VFCT 0x00000000E7BD0000 00FC84 (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: SSDT 0x00000000E7BCF000 000482 (v01 AMD    Jadeite  00001000 ACPI 00040000)
ACPI: TPM2 0x00000000E7BCE000 000038 (v03 DELL   WN09     00000002 ASL  00040000)
ACPI: SSDT 0x00000000E7BCC000 000174 (v01 AMD    Jadeite  00000001 ACPI 00040000)
ACPI: SSDT 0x00000000E7BCA000 0015C5 (v01 AMD    Jadeite  00000001 ACPI 00040000)
ACPI: SSDT 0x00000000E7BC8000 00165E (v01 AMD    Jadeite  00000001 ACPI 00040000)
ACPI: FPDT 0x00000000E7BC7000 000044 (v01 DELL   WN09     00000002 ASL  00040000)
ACPI: BGRT 0x00000000E7BC6000 000038 (v01 DELL   WN09     00000001 ASL  00040000)
ACPI: Reserving FACP table memory at [mem 0xe7bf8000-0xe7bf810b]
ACPI: Reserving DSDT table memory at [mem 0xe7be9000-0xe7bf115c]
ACPI: Reserving FACS table memory at [mem 0xe7b83000-0xe7b8303f]
ACPI: Reserving UEFI table memory at [mem 0xe7bfd000-0xe7bfd235]
ACPI: Reserving SLIC table memory at [mem 0xe7bfc000-0xe7bfc175]
ACPI: Reserving MSDM table memory at [mem 0xe7bfb000-0xe7bfb054]
ACPI: Reserving ASF! table memory at [mem 0xe7bfa000-0xe7bfa0a4]
ACPI: Reserving BOOT table memory at [mem 0xe7bf9000-0xe7bf9027]
ACPI: Reserving HPET table memory at [mem 0xe7bf7000-0xe7bf7037]
ACPI: Reserving APIC table memory at [mem 0xe7bf6000-0xe7bf608f]
ACPI: Reserving MCFG table memory at [mem 0xe7bf5000-0xe7bf503b]
ACPI: Reserving WDAT table memory at [mem 0xe7bf3000-0xe7bf317b]
ACPI: Reserving WDRT table memory at [mem 0xe7bf2000-0xe7bf2046]
ACPI: Reserving UEFI table memory at [mem 0xe7be8000-0xe7be8041]
ACPI: Reserving SSDT table memory at [mem 0xe7be7000-0xe7be743b]
ACPI: Reserving SSDT table memory at [mem 0xe7be2000-0xe7be6b5a]
ACPI: Reserving IVRS table memory at [mem 0xe7be1000-0xe7be10cf]
ACPI: Reserving CRAT table memory at [mem 0xe7be0000-0xe7be02e7]
ACPI: Reserving VFCT table memory at [mem 0xe7bd0000-0xe7bdfc83]
ACPI: Reserving SSDT table memory at [mem 0xe7bcf000-0xe7bcf481]
ACPI: Reserving TPM2 table memory at [mem 0xe7bce000-0xe7bce037]
ACPI: Reserving SSDT table memory at [mem 0xe7bcc000-0xe7bcc173]
ACPI: Reserving SSDT table memory at [mem 0xe7bca000-0xe7bcb5c4]
ACPI: Reserving SSDT table memory at [mem 0xe7bc8000-0xe7bc965d]
ACPI: Reserving FPDT table memory at [mem 0xe7bc7000-0xe7bc7043]
ACPI: Reserving BGRT table memory at [mem 0xe7bc6000-0xe7bc6037]
ACPI: PM-Timer IO Port: 0x408
ACPI: LAPIC_NMI (acpi_id[0x00] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x01] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x02] high edge lint[0x1])
ACPI: LAPIC_NMI (acpi_id[0x03] high edge lint[0x1])
ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 low level)
ACPI: Using ACPI (MADT) for SMP configuration information
ACPI: HPET id: 0x10228210 base: 0xfed00000
clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6370452778343963 ns
Kernel command line: BOOT_IMAGE=/boot/vmlinuz-6.1-x86_64 root=UUID=62145428-1875-4077-9d2e-0a971633e1e6 rw quiet apparmor=1 security=apparmor resume=UUID=39e5c245-7e95-43b1-b427-e1d6e95524cd udev.log_priority=3
AMD-Vi: Disable IOMMU on Stoney Ridge
ACPI: Core revision 20220331
ACPI: PM: Registering ACPI NVS region [mem 0xe78bf000-0xe7bbefff] (3145728 bytes)
ACPI FADT declares the system doesn't support PCIe ASPM, so disable it
acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
ACPI: Added _OSI(Module Device)
ACPI: Added _OSI(Processor Device)
ACPI: Added _OSI(3.0 _SCP Extensions)
ACPI: Added _OSI(Processor Aggregator Device)
ACPI Warning: Type override - [EC0_] had invalid type (Integer) for Scope operator, changed to type ANY (20220331/dswload2-195)
ACPI: 7 ACPI AML tables successfully acquired and loaded
ACPI: [Firmware Bug]: BIOS _OSI(Linux) query ignored
ACPI: Interpreter enabled
ACPI: PM: (supports S0 S3 S4 S5)
ACPI: Using IOAPIC for interrupt routing
PCI: Using host bridge windows from ACPI; if necessary, use "pci=nocrs" and report a bug
ACPI: Enabled 4 GPEs in block 00 to 1F
ACPI: PM: Power Resource [P0U2]
ACPI: PM: Power Resource [P3U2]
ACPI: PM: Power Resource [P0U3]
ACPI: PM: Power Resource [P3U3]
ACPI: PM: Power Resource [P0ST]
ACPI: PM: Power Resource [P3ST]
ACPI: PM: Power Resource [P0SD]
ACPI: PM: Power Resource [P3SD]
ACPI: PCI Root Bridge [PCI0] (domain 0000 [bus 00-ff])
acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
acpi PNP0A08:00: _OSC: platform does not support [SHPCHotplug LTR DPC]
acpi PNP0A08:00: _OSC: OS now controls [PCIeHotplug PME AER PCIeCapability]
acpi PNP0A08:00: FADT indicates ASPM is unsupported, using BIOS configuration
acpi PNP0A08:00: [Firmware Info]: MMCONFIG for domain 0000 [bus 00-3f] only partially covers this bridge
pci 0000:00:01.0: BAR 0: assigned to efifb
ACPI: PCI: Interrupt link LNKA configured for IRQ 0
ACPI: PCI: Interrupt link LNKA disabled
ACPI: PCI: Interrupt link LNKB configured for IRQ 0
ACPI: PCI: Interrupt link LNKB disabled
ACPI: PCI: Interrupt link LNKC configured for IRQ 0
ACPI: PCI: Interrupt link LNKC disabled
ACPI: PCI: Interrupt link LNKD configured for IRQ 0
ACPI: PCI: Interrupt link LNKD disabled
ACPI: PCI: Interrupt link LNKE configured for IRQ 0
ACPI: PCI: Interrupt link LNKE disabled
ACPI: PCI: Interrupt link LNKF configured for IRQ 0
ACPI: PCI: Interrupt link LNKF disabled
ACPI: PCI: Interrupt link LNKG configured for IRQ 0
ACPI: PCI: Interrupt link LNKG disabled
ACPI: PCI: Interrupt link LNKH configured for IRQ 0
ACPI: PCI: Interrupt link LNKH disabled
iommu: Default domain type: Translated
iommu: DMA domain TLB invalidation policy: lazy mode
ACPI: bus type USB registered
Registered efivars operations
PCI: Using ACPI for IRQ routing
pnp: PnP ACPI init
pnp: PnP ACPI: found 6 devices
clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
ACPI: AC: AC Adapter [AC] (off-line)
ACPI: button: Power Button [PWRB]
ACPI: button: Lid Switch [LID]
ACPI: button: Sleep Button [SBTN]
ACPI: button: Power Button [PWRF]
ACPI: \_PR_.C000: Found 2 idle states
ACPI: \_PR_.C001: Found 2 idle states
ACPI: thermal: Thermal Zone [THM] (18 C)
AMD-Vi: AMD IOMMUv2 functionality not available on this system - This is not a bug.
ACPI: bus type drm_connector registered
ACPI: battery: Slot [BAT0] (battery present)
efifb: probing for efifb
efifb: showing boot graphics
efifb: framebuffer at 0xe8000000, using 4224k, total 4224k
efifb: mode is 1366x768x32, linelength=5632, pages=1
efifb: scrolling: redraw
efifb: Truecolor: size=8:8:8:8, shift=24:16:8:0
fb0: EFI VGA frame buffer device
tsc: Refined TSC clocksource calibration: 1597.002 MHz
acpi_cpufreq: overriding BIOS provided _PSD data
ACPI: video: Video Device [VGA] (multi-head: yes  rom: no  post: no)
ACPI: button: The lid device is not compliant to SW_LID.
TLP-STAT
$ sudo tlp-stat --battery
--- TLP 1.5.0 --------------------------------------------
+++ Battery Care
Plugin: generic
Supported features: none available
+++ Battery Status: BAT0
/sys/class/power_supply/BAT0/manufacturer                   = Samsung SDI
/sys/class/power_supply/BAT0/model_name                     = (not available)
/sys/class/power_supply/BAT0/cycle_count                    =      0 (or not supported)
/sys/class/power_supply/BAT0/charge_full_design             = (not available)
/sys/class/power_supply/BAT0/charge_full                    =     84 [mAh]
/sys/class/power_supply/BAT0/charge_now                     =   1787 [mAh]
/sys/class/power_supply/BAT0/current_now                    =    664 [mA]
/sys/class/power_supply/BAT0/status                         = Discharging
/sys/class/power_supply/BAT0/charge_control_start_threshold = (not available)
/sys/class/power_supply/BAT0/charge_control_end_threshold   = (not available)
Charge                                                      = 2127.4 [%]
$ cat /sys/class/power_supply/BAT0/uevent
POWER_SUPPLY_NAME=BAT0
POWER_SUPPLY_TYPE=Battery
POWER_SUPPLY_STATUS=Discharging
POWER_SUPPLY_PRESENT=1
POWER_SUPPLY_TECHNOLOGY=Li-ion
POWER_SUPPLY_CYCLE_COUNT=0
POWER_SUPPLY_VOLTAGE_MIN_DESIGN=0
POWER_SUPPLY_VOLTAGE_NOW=7472000
POWER_SUPPLY_CURRENT_NOW=878000
POWER_SUPPLY_CHARGE_FULL=84000
POWER_SUPPLY_CHARGE_NOW=1784000
POWER_SUPPLY_CAPACITY=2123
POWER_SUPPLY_CAPACITY_LEVEL=Normal
POWER_SUPPLY_MODEL_NAME=
POWER_SUPPLY_MANUFACTURER=Samsung SDI
MODULES
$ lsmod
Module                  Size  Used by
snd_seq_dummy          16384  0
snd_hrtimer            16384  1
snd_seq                94208  7 snd_seq_dummy
snd_seq_device         16384  1 snd_seq
rfcomm                 94208  16
nls_utf8               16384  2
cifs                 2269184  2
cifs_arc4              16384  1 cifs
cifs_md4               16384  1 cifs
dns_resolver           16384  1 cifs
fscache               389120  1 cifs
netfs                  65536  1 fscache
ccm                    20480  6
cmac                   16384  3
algif_hash             16384  1
algif_skcipher         16384  1
af_alg                 36864  6 algif_hash,algif_skcipher
bnep                   32768  2
rtsx_usb_ms            24576  0
memstick               24576  1 rtsx_usb_ms
ath3k                  24576  0
btusb                  65536  0
btrtl                  28672  1 btusb
btbcm                  24576  1 btusb
btintel                45056  1 btusb
qrtr                   57344  4
btmtk                  16384  1 btusb
uvcvideo              163840  4
videobuf2_vmalloc      20480  1 uvcvideo
videobuf2_memops       20480  1 videobuf2_vmalloc
videobuf2_v4l2         40960  1 uvcvideo
videobuf2_common       86016  4 videobuf2_vmalloc,videobuf2_v4l2,uvcvideo,videobuf2_memops
bluetooth             937984  47 btrtl,btmtk,btintel,btbcm,bnep,ath3k,btusb,rfcomm
videodev              319488  5 videobuf2_v4l2,uvcvideo,videobuf2_common
ath9k                 192512  0
edac_mce_amd           57344  0
ath9k_common           45056  1 ath9k
squashfs               86016  0
loop                   36864  0
mc                     77824  6 videodev,videobuf2_v4l2,uvcvideo,videobuf2_common
ecdh_generic           16384  2 bluetooth
kvm_amd               176128  0
ath9k_hw              536576  2 ath9k_common,ath9k
ccp                   135168  1 kvm_amd
ath                    40960  3 ath9k_common,ath9k,ath9k_hw
snd_ctl_led            24576  0
kvm                  1150976  1 kvm_amd
snd_hda_codec_realtek   172032  1
snd_hda_codec_generic    98304  1 snd_hda_codec_realtek
snd_hda_codec_hdmi     86016  1
mac80211             1323008  2 ath9k,ath9k_hw
snd_hda_intel          61440  2
amdgpu              10747904  8
irqbypass              16384  1 kvm
crct10dif_pclmul       16384  1
crc32_pclmul           16384  0
snd_intel_dspcfg       36864  1 snd_hda_intel
dell_laptop            32768  0
libarc4                16384  1 mac80211
polyval_clmulni        16384  0
polyval_generic        16384  1 polyval_clmulni
gf128mul               16384  1 polyval_generic
snd_intel_sdw_acpi     20480  1 snd_intel_dspcfg
dell_wmi               28672  1 dell_laptop
ghash_clmulni_intel    16384  0
dell_smbios            32768  2 dell_wmi,dell_laptop
sha512_ssse3           53248  0
joydev                 28672  0
snd_hda_codec         188416  4 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec_realtek
mousedev               24576  0
dcdbas                 20480  1 dell_smbios
ledtrig_audio          16384  4 snd_ctl_led,snd_hda_codec_generic,dell_wmi,dell_laptop
snd_hda_core          118784  5 snd_hda_codec_generic,snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek
dell_smm_hwmon         28672  0
hid_multitouch         32768  0
aesni_intel           393216  8
sparse_keymap          16384  1 dell_wmi
dell_wmi_descriptor    20480  2 dell_wmi,dell_smbios
snd_hwdep              16384  1 snd_hda_codec
wmi_bmof               16384  0
gpu_sched              49152  1 amdgpu
cfg80211             1138688  4 ath9k_common,ath9k,ath,mac80211
drm_buddy              20480  1 amdgpu
snd_pcm               172032  4 snd_hda_codec_hdmi,snd_hda_intel,snd_hda_codec,snd_hda_core
drm_ttm_helper         16384  1 amdgpu
crypto_simd            16384  1 aesni_intel
cryptd                 24576  3 crypto_simd,ghash_clmulni_intel
snd_timer              49152  3 snd_seq,snd_hrtimer,snd_pcm
ttm                    94208  2 amdgpu,drm_ttm_helper
psmouse               212992  0
wdat_wdt               20480  0
sp5100_tco             20480  0
pcspkr                 16384  0
fam15h_power           16384  0
snd                   131072  17 snd_ctl_led,snd_hda_codec_generic,snd_seq,snd_seq_device,snd_hda_codec_hdmi,snd_hwdep,snd_hda_intel,snd_hda_codec,snd_hda_codec_realtek,snd_timer,snd_pcm
i2c_piix4              36864  0
drm_display_helper    212992  1 amdgpu
k10temp                16384  0
soundcore              16384  2 snd_ctl_led,snd
vfat                   24576  1
cec                    81920  1 drm_display_helper
i2c_hid_acpi           16384  0
dell_rbtn              20480  0
fat                    98304  1 vfat
video                  65536  3 dell_wmi,amdgpu,dell_laptop
rfkill                 32768  8 ath9k,bluetooth,dell_laptop,dell_rbtn,cfg80211
i2c_hid                40960  1 i2c_hid_acpi
wmi                    45056  5 video,dell_wmi,wmi_bmof,dell_smbios,dell_wmi_descriptor
mac_hid                16384  0
acpi_cpufreq           32768  0
crypto_user            24576  0
fuse                  176128  7
bpf_preload            24576  0
ip_tables              36864  0
x_tables               57344  1 ip_tables
ext4                 1032192  1
crc32c_generic         16384  0
crc16                  16384  2 bluetooth,ext4
mbcache                16384  1 ext4
jbd2                  192512  1 ext4
rtsx_usb_sdmmc         32768  0
mmc_core              233472  1 rtsx_usb_sdmmc
serio_raw              20480  0
atkbd                  36864  0
libps2                 20480  2 atkbd,psmouse
rtsx_usb               32768  2 rtsx_usb_sdmmc,rtsx_usb_ms
vivaldi_fmap           16384  1 atkbd
xhci_pci               24576  0
crc32c_intel           24576  2
xhci_pci_renesas       24576  1 xhci_pci
i8042                  49152  1 dell_laptop
serio                  28672  6 serio_raw,atkbd,psmouse,i8042
Note that your post was moved from XFCE to Support as it is not an issue with the Xfce Desktop Environment.
I run a practically identical setup of Manjaro on 10 platforms including stand-alone portable SSD installs. Curiously, I’m also seeing significant audio drop-outs with pipewire/wireplumber, over HDMI, on an A10-7870K AMD rig, that disappears completely when going into Suspend with an immediate Resume.
So… in one case, I have an audio problem, and another, a battery reporting issue, that both clear when the hardware is put to sleep then woken up. Completely different hardware platforms, both AMDGPU but I think this is something to do with the kernel. Something difficult to isolate.
