Lspci, lshw commands cause total freeze - kernel 5.12
My system after update to 5.12 kernell have some issues:
comands causes freeze (hang):
lspci
lshw
screenfetch
When i go to reboot or shutdown, my laptop not shutting down, stucked on terminal stage
hope someone know what to do
can you provide
inxi -Fza
sudo mhwd-kernel -li
Have freeze like lspci action
Currently running: 5.12.1-2-MANJARO (linux512)
  • linux510
  • linux512
  • linux54
Now im try 5.10 core, and all commands work fine…
So please post that asked for inxi output when booted with 5.10 kernel. That way we can at least see some info about your hardware.
Spoiler
~ >>> inxi -Fza
System:    Kernel: 5.10.34-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
           parameters: BOOT_IMAGE=/boot/vmlinuz-5.10-x86_64 root=UUID=f418a610-1deb-4775-bfo2-b6835bad2ad rw
           raid=noautodetect selinux=0 quiet apparmor=1 security=apparmor udev.log_priority=3
           Desktop: Xfce 4.16.2 wm: awesome 4.3 vt: 7 dm: LightDM 1.30.0 Distro: Manjaro Linux base: Arch Linux
Machine:   Type: Laptop System: HP product: HP Laptop 17-ca0xxx v: N/A serial: <filter> Chassis: type: 10 serial: <filter>
           Mobo: HP model: 84D1 v: 90.44 serial: <filter> UEFI: AMI v: F.53 date: 12/27/2019
Battery:   ID-1: BAT0 charge: 32.1 Wh (100.0%) condition: 32.1/32.1 Wh (100.0%) volts: 13.0 min: 11.6
           model: Hewlett-Packard Primary type: Li-ion serial: <filter> status: Full
CPU:       Info: Dual Core model: AMD A6-9225 RADEON R4 5 COMPUTE CORES 2C+3G bits: 64 type: MCP arch: Excavator
           family: 15 (21) model-id: 70 (112) stepping: 0 microcode: 6006705 cache: L2: 1024 KiB
           flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 10380
           Speed: 2696 MHz min/max: 1300/2600 MHz boost: enabled Core speeds (MHz): 1: 2696 2: 2674
           Type: spectre_v2 mitigation: Full AMD retpoline, IBPB: conditional, STIBP: disabled, RSB filling
Graphics:  Device-1: Advanced Micro Devices [AMD/ATI] Stoney [Radeon R2/R3/R4/R5 Graphics] vendor: Hewlett-Packard
           driver: amdgpu v: kernel bus-ID: 00:01.0 chip-ID: 1002:98e4 class-ID: 0300
           Device-2: Lite-On HP Webcam type: USB driver: uvcvideo bus-ID: 1-1.1:3 chip-ID: 04ca:707d class-ID: 0e02
           serial: <filter>
           Display: x11 server: X.Org 1.20.11 driver: loaded: amdgpu,modesetting display-ID: :0 screens: 1
           Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4") s-diag: 485mm (19.1")
           Monitor-1: eDP res: 1600x900 hz: 60 dpi: 106 size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
Audio:     Device-1: Advanced Micro Devices [AMD/ATI] vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:01.1
           chip-ID: 1002:15b3 class-ID: 0403
           Device-2: Advanced Micro Devices [AMD] Family 15h Audio vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
           bus-ID: 00:09.2 chip-ID: 1022:157a class-ID: 0403
           Sound Server-1: ALSA v: k5.10.34-1-MANJARO running: yes
           Sound Server-4: PipeWire v: 0.3.26 running: yes
Network:   Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: Hewlett-Packard driver: r8169 v: kernel
           port: d000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
           Device-2: Realtek RTL8723DE 802.11b/g/n PCIe Adapter vendor: Hewlett-Packard driver: rtw_8723de v: N/A
           modules: rtw88_8723de port: c000 bus-ID: 03:00.0 chip-ID: 10ec:d723 class-ID: 0280
Bluetooth: Device-1: Realtek Realtek Bluetooth 4.2 Adapter type: USB driver: btusb v: 0.8 bus-ID: 1-1.3:5 chip-ID: 0bda:b009
           Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: disabled rfk-block: hardware: no software: yes
           address: see --recommends
Drives:    Local Storage: total: 1.13 TiB used: 321.81 GiB (27.9%)
           ID-1: /dev/sda maj-min: 8:0 vendor: Kingston model: SA400S37240G size: 223.57 GiB block-size: physical: 512 B
           logical: 512 B speed: 6.0 Gb/s rotation: SSD serial: <filter> rev: B1D1 scheme: GPT
           ID-2: /dev/sdb maj-min: 8:16 vendor: Toshiba model: MQ04ABF100 size: 931.51 GiB block-size: physical: 4096 B
           logical: 512 B speed: 3.0 Gb/s rotation: 5400 rpm serial: <filter> rev: 4C scheme: GPT
Partition: ID-1: / raw-size: 223.28 GiB size: 218.77 GiB (97.98%) used: 148.62 GiB (67.9%) fs: ext4 dev: /dev/sda2
           maj-min: 8:2
           ID-2: /boot/efi raw-size: 300 MiB size: 299.4 MiB (99.80%) used: 292 KiB (0.1%) fs: vfat dev: /dev/sda1
           maj-min: 8:1
Swap:      Alert: No swap data was found.
Sensors:   System Temperatures: cpu: 42.2 C mobo: 0.0 C
           GPU: device: amdgpu temp: 42.0 C device: amdgpu temp: 42.0 C watts: 572.15
Info:      Processes: 183 Uptime: 15h 08m wakeups: 1 Memory: 7.24 GiB used: 2.21 GiB (30.6%) Init: systemd v: 247
           tool: systemctl Compilers: gcc: 10.2.0 Packages: 1302 pacman: 1295 lib: 415 flatpak: 0 snap: 7 Shell: Zsh v: 5.8
           running-in: wezterm-gui inxi: 3.3.04
