LS50x Usb Sound Wireless Headphones not Working
Hello,
i need help.
I didn´t get my Lucid Sound LS 50x to work.
Things i have tried. Usb Device is not listed as audio device.
inxi -A
Device-1: Intel Sunrise Point-LP HD Audio driver: snd_hda_intel
API: ALSA v: k6.4.3-1-MANJARO status: kernel-api
Server-1: PulseAudio v: 16.1 status: active
cat /proc/asound/cards
0 [PCH ]: HDA-Intel - HDA Intel PCH
HDA Intel PCH at 0x1ff3018000 irq 139
lsusb
Bus 002 Device 002: ID 0424:5534 Microchip Technology, Inc. (formerly SMSC) Hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 007: ID 04ca:706e Lite-On Technology Corp. HP HD Camera
Bus 001 Device 006: ID 138a:00ab Validity Sensors, Inc.
Bus 001 Device 005: ID 8087:0a2b Intel Corp. Bluetooth wireless interface
Bus 001 Device 004: ID 0424:2134 Microchip Technology, Inc. (formerly SMSC) Hub
Bus 001 Device 003: ID 045e:0745 Microsoft Corp. Nano Transceiver v1.0 for Bluetooth
Bus 001 Device 002: ID 2f12:0032 LucidSound LightX USB GIP Dongle Application
aplay -l  127 ✘
**** Liste der Hardware-Geräte (PLAYBACK) ****
Karte 0: PCH [HDA Intel PCH], Gerät 0: CX8200 Analog [CX8200 Analog]
Sub-Geräte: 1/1
Sub-Gerät #0: subdevice #0
Karte 0: PCH [HDA Intel PCH], Gerät 3: HDMI 0 [U28E590]
Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 7: HDMI 1 [HDMI 1]
Sub-Geräte: 1/1
Karte 0: PCH [HDA Intel PCH], Gerät 8: HDMI 2 [HDMI 2]
Sub-Geräte: 1/1
What can i do to make the USB Device work as audio device. There are no drivers available.
There is a hardware scan for LucidSound LightX USB GIP Dongle that also reports device as failed
https://linux-hardware.org/?id=usb:2f12-0032
If device was working as a USB device it should be using snd-usb-audio driver
AFAIK there are no alternative Linux drivers for USB audio devices
Comments on manufacturer website comments suggest USB dongle is for Xbox consoles but headset can also be paired to a PC via Bluetooth
LucidSound LS50X Wireless Gaming Headset for Xbox Series X|S with Bluetooth | Xbox Series X|S Wireless Headsets | LucidSound
STREAM BLUETOOTH SIMULTANEOUSLY WHILE YOU PLAY ON XBOX: Connect and use your Bluetooth devices while you play on Xbox. Play your own music in-game, use team chat apps from your PC, and take calls without interrupting your game.
Compatibility
Bluetooth, Xbox One, Xbox Series X|S
Headset also has a 3.5mm jack cable if Bluetooth is not viable
