Hi there!
Just recently switched to the Nvidia hybrid graphics to enable PRIME render offload from my usuall full PRIME set up switching between intel mode and Nvidia mode . My question is this:
What is the lowest possible power state for this type of configuration? Just for my peace of mind.
I was monitoring the P-states via watch -n1 nvidia-smi
and the lowest I can get at idle was P8 with 1W power consumption
| NVIDIA-SMI 450.57 Driver Version: 450.57 CUDA Version: 11.0 |
| GPU Name Persistence-M| Bus-Id Disp.A | Volatile Uncorr. ECC |
| Fan Temp Perf Pwr:Usage/Cap| Memory-Usage | GPU-Util Compute M. |
| | | MIG M. |
| 0 GeForce GTX 1650 Off | 00000000:01:00.0 Off | N/A |
| N/A 42C P8 1W / N/A | 5MiB / 3914MiB | 0% Default |
| | | N/A |
| Processes: |
| GPU GI CI PID Type Process name GPU Memory |
| ID ID Usage |
| 0 N/A N/A 872 G /usr/lib/Xorg 4MiB |
Also, when checking powertop
the Nvidia GPU has a usage of “100%”:
100.0% PCI Device: NVIDIA Corporation TU117M [GeForce GTX 1650 Mobile / Max-Q]
Is this normal for a PRIME render offload setup?
Thanks!
