Low res after update - nvidia GT1030 - wayland
Hello,
I’ m on Manjaro / KDE / Wayland
And my graphic card is an nvidia GT1030
My actual driver is 575.64.05
Screen 4k
And all is fine.
If i update the system, I got a low resolution.
I asked Gemini that told me to ignore this packages
/etc/pacman.com
IgnorePkg = libva-nvidia-driver linux-firmware-nvidia linux66-nvidia-575xx mhwd-nvidia mhwd-nvidia-390xx mhwd-nvidia-470xx mhwd-nvidia-570xx mhwd-nvidia-575xx mhwd-nvidia-580xx nvidia-575xx-utils nvidia-driver-assistant nvidia-settings
And it doesn’t help (black screen)
What is the best way to live with this old graphic card and be able to update the system ?
Ignore other packages ?
$ pacman -Q | grep nvidia
libva-nvidia-driver 0.0.17-1
linux-firmware-nvidia 20260519-1
linux66-nvidia-575xx 575.64.05-39
mhwd-nvidia 610.43.02-2
mhwd-nvidia-390xx 390.157-28
mhwd-nvidia-470xx 470.256.02-17
mhwd-nvidia-570xx 570.211.01-1
mhwd-nvidia-575xx 575.64.05-3
mhwd-nvidia-580xx 580.159.04-1
nvidia-575xx-utils 575.64.05-3
nvidia-driver-assistant 0.23.48.01-7
nvidia-settings 610.43.02-2
Return to X11 ?
Thanks
Mod edit: Fixed formatting
Do not ignore packages, that puts you in unsupported state (not to mention the AI got it all wrong).
The right driver for you now is 580. (linux61-nvidia-580xx)
Hi @snaiix, and welcome!
First things first,
There isn’t even a 575.xx driver in the repositories:
$ mhwd --list
0000:01:00.0 (0300:10de:1401) Display controller nVidia Corporation:
    video-nvidia-580xx            2026.03.05               false            PCI
    video-nvidia-470xx            2023.03.23               false            PCI
    video-nvidia-390xx            2023.03.23               false            PCI
           video-linux            2024.05.06                true            PCI
And according to Nvidia’s search the latest driver for that card is 580.173.02.
The only place I can find anything 575.xx -related is in the AUR:
opencl-nvidia-575xx  575.64.05-2                                             AUR
    OpenCL implemention for NVIDIA
lib32-nvidia-575xx-utils  575.64.05-1                                        AUR
    NVIDIA drivers utilities (32-bit) (575xx)
nvidia-575xx-utils  575.64.05-2                                              AUR
nvidia-575xx-open-dkms  575.64.05-2                                          AUR
    NVIDIA open kernel modules - module sources
nvidia-575xx-dkms  575.64.05-2                                               AUR
    NVIDIA kernel modules - module sources
Therefore, I think you have two options:
  1. Install the 580.xx from mhwd:
    sudo mhwd -a pci nonfree 0300
  2. Or:
  • Remove the current 575.xx driver:
    sudo pacman -Rns linux66-nvidia-575xx
  • Rebuild the one from the AUR:
    pamac build nvidia-575xx-dkms
But whatever you do,
  • please do not rely on any answer given by any A.I.
  • as @Teo previously said, do not use IgnorePkg unless you know what you are doing.
That doesn’t match your driver or the driver Nvidia says you should be using (which as @Teo and @Mirdarthos pointed out is 580).
sudo mhwd -r pci video-nvidia-575xx
sudo pacman -Rdd nvidia-settings
sudo mhwd -i pci video-nvidia-580xx
# installing the new driver should pull in nvidia settings
# but if not
sudo pacman -S nvidia-580xx-settings
I’d recommend using linux618 or newer.
sudo mhwd-kernel -i linux618
After a reboot you can remove the old kernel.
sudo mhwd-kernel -r linux66
Edit:
Oops, I overlooked this part of @Mirdarthos’s post:
Indeed, they were removed a while ago.
Hello
Thanks for your answers.
But, something is not clear for me.
In fact you tell me to upgrade to 580, and when I update the system, the driver is indeed upgraded to 580 … and it doesn’t work
That means that something is not enough with just updating the system ?
Maybe I could update and do something after to solve the prob ?
No an automatic update won’t do on its own. Things need to fit together. I presume you have removed IgnorePkg again. Then it looks like you are on an outdated linux 6.6 kernel. The minimum kernel version I would try with is 6.18. Then you need to align the nvidia drivers and tools to this. I think you’ll need
linux618
linux618-nvidia-580xx   // notice: not the open ones
nvidia-settings-580xx
Please post the output of inxi -zv8 (this is also for other users with a similar problem to be able to compare with their systems).
➜  ~ inxi -zv8
  Kernel: 6.6.143-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 16.1.1
    root=UUID=d5b5ef7e-3693-498b-b5d5-0ff769c39d16 rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.6.5 tk: Qt v: N/A info: frameworks v: 6.27.0
  Type: Desktop System: Dell product: OptiPlex 3020 v: 00
    serial: <superuser required> Chassis: type: 6 serial: <superuser required>
  Mobo: Dell model: 040DDP v: A01 serial: <superuser required> part-nu: 0612
    uuid: <superuser required> Firmware: UEFI vendor: Dell v: A20
    date: 05/27/2019
  Device-1: hidpp_battery_0 model: Logitech M720 Triathlon Multi-Device Mouse
    status: discharging
  System RAM: total: 16 GiB available: 15.57 GiB used: 6.47 GiB (41.5%)
  Array-1: capacity: 16 GiB slots: 2 modules: 2 EC: None
  Device-1: DIMM1 type: DDR3 detail: synchronous size: 8 GiB
    speed: 1600 MT/s volts: N/A width (bits): data: 64 total: 64
    manufacturer: Crucial part-no: CT102464BA160B.C16 serial: <filter>
  Device-2: DIMM2 type: DDR3 detail: synchronous size: 8 GiB
  Info: model: Intel Core i5-4590 bits: 64 type: MCP arch: Haswell gen: core 4
    level: v3 note: check built: 2013-15 process: Intel 22nm family: 6
    model-id: 0x3C (60) stepping: 3 microcode: 0x28
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 smt: <unsupported> cache:
    L3: 6 MiB desc: 1x6 MiB
  Speed (MHz): avg: 800 min/max: 800/3700 scaling: driver: intel_cpufreq
    governor: schedutil cores: 1: 800 2: 800 3: 800 4: 800 bogomips: 26348
  Flags: abm acpi aes aperfmperf apic arat arch_perfmon avx avx2 bmi1 bmi2
    bts clflush cmov constant_tsc cpuid cpuid_fault cx16 cx8 de ds_cpl dtes64
    fsgsbase fxsr ht ibpb ibpb_exit_to_user ibrs ida invpcid lahf_lm lm mca
    mce md_clear mmx monitor movbe msr mtrr nonstop_tsc nopl nx pae pat pbe
    pcid pclmulqdq pdcm pdpe1gb pebs pge pln pni popcnt pse pse36 pti pts
    rdrand rdtscp rep_good sdbg sep smep smx ss ssbd sse sse2 sse4_1 sse4_2
    ssse3 stibp syscall tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer
    vme vmx vnmi vpid x2apic xsave xsaveopt xtopology xtpr
    disabled
    STIBP: disabled; RSB filling; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: NVIDIA GP108 [GeForce GT 1030] vendor: PNY driver: nvidia
    v: 575.64.05 alternate: nouveau,nvidia_drm non-free: 550-580.xx+
    status: legacy-active (EOL~2028-09-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 2 speed: 5 GT/s lanes: 4
    ports: active: none off: HDMI-A-1 empty: DVI-D-1 bus-ID: 01:00.0
    chip-ID: 10de:1d01 class-ID: 0300
  Device-2: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.1 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2
    chip-ID: 046d:08e5 class-ID: 0102
  Display: wayland server: X.org v: 1.21.1.23 with: Xwayland v: 24.1.12
    compositor: kwin_wayland driver: X: loaded: nvidia
    gpu: nvidia,nvidia-nvswitch display-ID: 0
  Monitor-1: HDMI-A-1 model: Samsung U28H75x serial: <filter> built: 2018
    res: mode: 3840x2160 hz: 30 scale: 150% (1.5) to: 2560x1440 dpi: 160
    gamma: 1.2 chroma: red: x: 0.635 y: 0.341 green: x: 0.310 y: 0.635 blue:
    x: 0.157 y: 0.059 white: x: 0.314 y: 0.329 size: 608x345mm (23.94x13.58")
    diag: 699mm (27.5") ratio: 16:9 modes: 3840x2160, 2560x1440, 1920x1080,
    1680x1050, 1600x900, 1280x1024, 1440x900, 1280x800, 1152x864, 1280x720,
    1024x768, 800x600, 720x576, 720x480, 640x480
  EDID-Warnings: 1: parse_edid: unhandled CEA mode 95 2: parse_edid:
    unhandled CEA mode 94 3: parse_edid: unhandled CEA mode 93
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia device: 2
    drv: swrast gbm: drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia
    x11: drv: nvidia inactive: device-1
  API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: nvidia mesa v: 575.64.05
    glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GT 1030/PCIe/SSE2
    memory: 1.95 GiB display-ID: :1.0
  API: Vulkan v: 1.4.350 layers: 2 device: 0 type: discrete-gpu
    name: NVIDIA GeForce GT 1030 driver: nvidia v: 575.64.05
    device-ID: 10de:1d01 surfaces: N/A
    wl: wayland-info x11: xdpyinfo,xprop
  Device-1: Intel 8 Series/C220 Series High Definition Audio vendor: Dell
    driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20
    class-ID: 0403
  Device-2: NVIDIA GP108 High Definition Audio vendor: PNY
    driver: snd_hda_intel v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 4
    bus-ID: 01:00.1 chip-ID: 10de:0fb8 class-ID: 0403
  Device-3: Logitech C920 PRO HD Webcam driver: snd-usb-audio,uvcvideo
  Device-4: XMOS EDIFIER S3000 Pro driver: hid-generic,snd-usb-audio,usbhid
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:3
    chip-ID: 20b1:30a0 class-ID: 0300
  API: ALSA v: k6.6.143-1-MANJARO status: kernel-api with: aoss
  Server-3: PipeWire v: 1.6.6 status: active with: 1: pipewire-pulse
    vendor: Dell driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
    port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Local Storage: total: 1.57 TiB used: 60.13 GiB (3.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: SanDisk model: SSD PLUS 480GB
    size: 447.13 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 04RL scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 250GB
    size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 1B6Q scheme: MBR
  ID-3: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD10EZEX-75WN4A0 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: HDD rpm: 7200 serial: <filter>
    fw-rev: 1A01 scheme: GPT
  ID-1: / raw-size: 446.83 GiB size: 438.75 GiB (98.19%)
    used: 60.13 GiB (13.7%) fs: ext4 dev: /dev/sda2 maj-min: 8:2 label: N/A
    uuid: d5b5ef7e-3693-498b-b5d5-0ff769c39d16
    used: 312 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: DE19-CBE9
  ID-1: /dev/sdb1 maj-min: 8:17 size: 232.88 GiB fs: btrfs label: SSD256
    uuid: 5f63fcbb-11bb-4478-a274-9ed6d6b1be92
  ID-2: /dev/sdc1 maj-min: 8:33 size: 931.51 GiB fs: btrfs label: DATA
    uuid: 5844de0d-53e1-4f87-904a-279d5d5df19c
  Hub-1: 1-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-2: 1-1:2 info: Intel Integrated Rate Matching Hub ports: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8008
  Hub-3: 2-0:1 info: full speed or root hub ports: 2 rev: 2.0
  Hub-4: 2-1:2 info: Intel Integrated Rate Matching Hub ports: 6 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 8087:8000
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 10 rev: 2.0
  Device-1: 3-2:2 info: Logitech C920 PRO HD Webcam type: video,audio
    driver: snd-usb-audio,uvcvideo interfaces: 4 rev: 2.1
  Device-2: 3-4:3 info: XMOS EDIFIER S3000 Pro type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 20b1:30a0
    class-ID: 0300
  Device-3: 3-5:4 info: Logitech Keyboard K120 type: keyboard,HID
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 90mA
    chip-ID: 046d:c31c class-ID: 0300
  Device-4: 3-6:5 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Device-5: 3-10:7 info: Google Nexus/Pixel Device (MTP) type: still imaging
    driver: N/A interfaces: 1 rev: 2.1 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 500mA chip-ID: 18d1:4ee1 class-ID: 0601 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.0
  System Temperatures: cpu: 39.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Packages: pm: pacman pkgs: 1657 libs: 415 tools: pamac pm: flatpak pkgs: 0
    1: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    2: https://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    3: https://mirror.csclub.uwaterloo.ca/manjaro/stable/$repo/$arch
    4: https://manjaro.repo.cure.edu.uy/stable/$repo/$arch
    5: https://mirror.dimensiondata.com/mirrors/manjaro.org/stable/$repo/$arch
    6: https://mirror.aarnet.edu.au/pub/manjaro/stable/$repo/$arch
    7: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    8: https://mirrors.ustc.edu.cn/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 220
  1: cpu: 8.4% command: firefox pid: 1110 mem: 1163.3 MiB (7.2%)
  2: cpu: 7.5% command: konsole pid: 66946 mem: 335.1 MiB (2.1%)
  3: cpu: 6.6% command: firefox pid: 1357 mem: 108.7 MiB (0.6%)
  4: cpu: 5.0% command: firefox pid: 5956 mem: 1105.7 MiB (6.9%)
  5: cpu: 2.2% command: kwin_wayland pid: 785 mem: 411.1 MiB (2.5%)
  Memory top: 5 of 220
  1: mem: 1163.3 MiB (7.2%) command: firefox pid: 1110 cpu: 8.4%
  2: mem: 1105.7 MiB (6.9%) command: firefox pid: 5956 cpu: 5.0%
  3: mem: 809.5 MiB (5.0%) command: firefox pid: 2005 cpu: 1.4%
  4: mem: 715.5 MiB (4.4%) command: firefox pid: 5794 cpu: 1.5%
  5: mem: 700.5 MiB (4.3%) command: plasmashell pid: 917 cpu: 0.5%
  Processes: 220 Power: uptime: 9h 0m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.18 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 260 default: graphical
    tool: systemctl
  Compilers: clang: 22.1.6 gcc: 16.1.1 Shell: Zsh v: 5.9.1
    running-in: konsole inxi: 3.3.41
It will if the replaces field is used.
$ pacman -Si linux66-nvidia-580xx
Replaces        : linux66-nvidia-570xx  linux66-nvidia-575xx
Consider upgrading to kernel 6.18 (LTS), or if you already have it installed along with kernel 6.6 (LTS), try booting with kernel 6.18 (LTS) instead.
While this may or may not provide any obvious improvement, it may have other advantages.
There have one or two users with a similar issue; and 580xx has apparently failed to work for them
They too were using the Nvidia 575xx series driver, which is no longer provided via the official Manjaro repositories… I suggested using the nvidia-575xx-dkms driver available via the AUR as a possible workaround:
Thus far, the OP of that topic hasn’t given anyone the courtesy of a response, so it’s unknown whether it resolved their issue, or was even tried.
General information:
Dynamic Kernel Module Support (DKMS) automatically rebuilds kernel modules1 (in this case nvidia.ko, nvidia-drm.ko, nvidia-modeset.ko, nvidia-uvm.ko) whenever the Linux kernel is updated.
These out-of-tree modules interface directly with the kernel for modesetting, GPU and memory management.
  • Without DKMS: Kernel updates can break Nvidia drivers – the module becomes incompatible and you need to manually reinstall.
  • With DKMS: After each kernel upgrade, it’s automatically recompiled against the new kernel headers, keeping the display working across reboots.
To utilise DKMS on Manjaro, rather than using the nvidia package the nvidia-dkms package (and the matching linux*-nvidia-* headers) are used instead to achieve the desired behaviour.
If the OP wishes to explore this further, please open a new dedicated Support topic where others may be able to help, if needed.
Important: The issue might be resolvable without resorting to DKMS – Please make sure to provide accurate information when asked to allow others the opportunity to help when they can.
The third option, besides using 575 from aur and closed source 580 from the repo, will be to use the 610 open source from the repo. (nvidia-open).
I had the same problem. The screen was reported as “none” and falled back to a low resolution. This solved it for me.
  1. Make sure in UEFI/BIOS that fast boot is disabled. This expose all hardware to the kernel at boot.
  2. Boot and open Timeshift. Restore to a previous working snapshot.
  3. Reboot and perform the update again. The nvidia card now worked for me and the screen was found.
  4. Open Timeshift once more and remove the snapshots that include your broken setup.
I hope it work for you too.
Hello
Thanks for all your answers but because you gave me different ways to solve the prob, I don’t know which way to choose.
Also i don’t feel comfortable with all that.
Is it possible to remove all the nvidia stuff
➜  ~ pacman -Qs nvidia
local/egl-gbm 1.1.3-1
    The GBM EGL external platform library
local/egl-wayland 4:1.1.21-1
    EGLStream-based Wayland external platform
local/egl-wayland2 1.0.1-1
    EGLStream-based Wayland external platform (2)
local/egl-x11 1.0.5-1
    NVIDIA XLib and XCB EGL Platform Library
local/lib32-libvdpau 1.5-3
    Nvidia VDPAU library
local/libva-nvidia-driver 0.0.17-1
    VA-API implementation that uses NVDEC as a backend
local/libvdpau 1.5-4
local/libxnvctrl 610.43.02-1
    NVIDIA NV-CONTROL X extension
local/linux-firmware-nvidia 20260519-1
    Firmware files for Linux - Firmware for NVIDIA GPUs and SoCs
local/linux66-nvidia-575xx 575.64.05-39 (linux66-extramodules)
    NVIDIA kernel modules for linux66
local/mhwd-nvidia 610.43.02-2
    MHWD module-ids for nvidia 610.43.02
local/mhwd-nvidia-390xx 390.157-28
    MHWD module-ids for nvidia 390.157
local/mhwd-nvidia-470xx 470.256.02-17
    MHWD module-ids for nvidia 470.256.02
local/mhwd-nvidia-570xx 570.211.01-1
    MHWD module-ids for nvidia 570.211.01
local/mhwd-nvidia-575xx 575.64.05-3
    MHWD module-ids for nvidia 575.64.05
local/mhwd-nvidia-580xx 580.159.04-1
    MHWD module-ids for nvidia 580.159.04
local/nvidia-575xx-utils 575.64.05-3
    NVIDIA 575 drivers utilities
local/nvidia-driver-assistant 0.23.48.01-7
    Detect and install the best NVIDIA driver packages for the system
local/nvidia-settings 610.43.02-2
    Tool for configuring the NVIDIA graphics driver
Update the system with a “default graphic driver”
And after install 580 ?
Or, if I have backups, I should do a fresh install, like this, I suppose all will be updated and maybe also work ?
Mod Edit: Fixed formatting
I’d update, then before rebooting install linux618, then reboot into 6.18.
sudo pacman -Syu
# reboot into 6.18
If you still have issues then install nouveau or nvidia-575xx-dkms
# first remove 580
sudo mhwd -r pci video-nvidia-580xx
# install nouveau
sudo mhwd -i pci video-linux
# alternatively install nvidia-575xx-dkms
yay -S nvidia-575xx-dkms
# or if you prefer pamac
Reboot to test.
Also remove linux66, this can’t be done whilst you’re running 6.6
Hello
So
sudo pacman -Syu
# reboot into 6.18
not installed
Black screen
So
Now I’ll reinstall
Much faster and easier
:wink:
Thanks a lot
-I’ve set a timer for this topic to auto-close after a few days following the last post, to give you an opportunity to report back on how this went.-
Edit: Topic has been closed as requested. :wink:
So you can close the topic.
Thank you all
