Low memory, I have 16 Gigs
I have played Mortsl Online 2 before, no issues. I have changed nothing, but the kernel shuts down all background app, only 1 is MO2. I have no clue, no background apps are running & info Center says I am using 4.6 is that ok with just KDE running?
Wow, MO2 blew up to using 9 when I hade the game started not even logged in yet. I use to play it fine.
But you did - according to your more recent posts …
(and PM’s to me …)
Ok, but how could that be at fault? Just was a partition issue. I meant didn’t change anything that should have messed with RAM.
I have NO idea about what you are saying,
… literally as well as figuratively …
It’s unlikely that this is because of my perhaps still tenuous grasp of the english language.
… use a few more words to describe your issue …
Sorry, I have played Mortal Online 2 with no issues, until a few days back ^ now I get a kernel warning about low memory. Have no idea what changed.
Try another kernel?
I did mention swap in the other thread. Do you have any configured?
I don’t think I’ve seen a current inxi -zv8 report from you yet; this may help (and will answer the above question).
Cheers! :smiley_cat:
Very unlikely.
Nor @Edward78 do we, until you do as requested, and supply more information. Information that has been requested, more than once.
Maybe you should test your RAM with memtest86+. Be sure to let it run for about 24 hours.
  • If it finds any errors, then that’s a guarantee that you have a bad memory module.
  • If it does not find any errors, than that’s still no guarantee that you do not have a bad memory module, because the failure could be intermittent.
I just booted up with kernel 6.6.03-1. I will test MO2 when everyone else isn’t sleeping.
So now you will provide the inxi -zv8 report, as requested.
Well, this kernel does it too. Now for Windows.
  Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    root=UUID=0647dad9-3687-4eba-8d09-acc5ce30021d rw quiet splash
    udev.log_priority=3
  Desktop: KDE Plasma v: 6.3.3 tk: Qt v: N/A info: frameworks v: 6.11.0
  Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x
    serial: <superuser required> uuid: <superuser required> UEFI: American
    Megatrends LLC. v: FE date: 03/22/2024
  System RAM: total: 16 GiB available: 15.54 GiB used: 3.67 GiB (23.6%)
  Device-1: Channel-A DIMM 0 type: no module installed
    (unregistered) size: 8 GiB speed: 3200 MT/s volts: note: check curr: 1
    min: 1 max: 1 width (bits): data: 64 total: 64 manufacturer: TeamGroup
    part-no: UD4-3200 serial: <filter>
  Device-3: Channel-B DIMM 0 type: no module installed
  Info: model: AMD Ryzen 7 5800X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201210
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 1752 min/max: 550/4851 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 1752 2: 1752 3: 1752
    4: 1752 5: 1752 6: 1752 7: 1752 8: 1752 9: 1752 10: 1752 11: 1752 12: 1752
    13: 1752 14: 1752 15: 1752 16: 1752 bogomips: 121420
    xsaves xtopology
    affected
  Device-1: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
    vendor: eVga.com. driver: nvidia v: 550.144.03 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 05:00.0 chip-ID: 10de:2489
    class-ID: 0300
  Display: x11 server: X.Org v: 21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_x11 driver: X: loaded: N/A failed: nvidia gpu: nvidia
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 264 s-size: 369x208mm (14.53x8.19")
    s-diag: 424mm (16.68")
  Monitor-1: Unknown-1 mapped: DP-4 res: N/A size: 600x340mm (23.62x13.39")
    modes: 1024x768
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia v: 550.144.03 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060 Ti/PCIe/SSE2
    memory: 7.81 GiB
  API: Vulkan v: 1.4.304 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3060 Ti driver: N/A device-ID: 10de:2489 surfaces: xcb,xlib
  Device-1: NVIDIA GA104 High Definition Audio vendor: eVga.com.
    bus-ID: 05:00.1 chip-ID: 10de:228b class-ID: 0403
    vendor: Gigabyte driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 07:00.4 chip-ID: 1022:1487 class-ID: 0403
  API: ALSA v: k6.12.19-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Realtek RTL8125 2.5GbE vendor: Gigabyte driver: r8169 v: kernel
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: e000 bus-ID: 03:00.0
  Device-2: Realtek RTL8852CE PCIe 802.11ax Wireless Network
    driver: rtw89_8852ce v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
    port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c852 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-1: Realtek Bluetooth Radio driver: btusb v: 0.8 type: USB rev: 1.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-8:3 chip-ID: 0bda:0852
  Local Storage: total: 1.82 TiB used: 158.97 GiB (8.5%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT1000MX500SSD1
    tech: SSD serial: <filter> fw-rev: 045 scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Smart Modular Tech.
    model: SHGS31-1000GS-2 size: 931.51 GiB block-size: physical: 4096 B
    logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 0Q00
    scheme: GPT
  ID-1: / raw-size: 767.48 GiB size: 754.36 GiB (98.29%)
    used: 158.97 GiB (21.1%) fs: ext4 dev: /dev/sda4 maj-min: 8:4 label: N/A
    uuid: 0647dad9-3687-4eba-8d09-acc5ce30021d
    used: 296 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1 label: N/A
    uuid: 6DB0-0A0F
  ID-1: /dev/sda2 maj-min: 8:2 size: 146.59 GiB fs: vfat label: Download
    uuid: 0BDC-29D3
  ID-2: /dev/sdb1 maj-min: 8:17 size: 100 MiB fs: vfat label: NO NAME
    uuid: B362-0880
  ID-3: /dev/sdb2 maj-min: 8:18 size: 549.79 GiB fs: ntfs label: N/A
    uuid: FEDE7716DE76C705
  ID-4: /dev/sdb3 maj-min: 8:19 size: 381.62 GiB fs: ntfs label: Data
    uuid: 01DB99DAC4B15D80
  Device-1: 1-7:2 info: Integrated Express RGB LED Controller type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 048d:5702 class-ID: 0300
  Device-2: 1-8:3 info: Realtek Bluetooth Radio type: bluetooth
    driver: btusb interfaces: 2 rev: 1.0 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0bda:0852 class-ID: e001 serial: <filter>
  Hub-4: 3-4:2 info: VIA Labs USB2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 2109:2822
  Device-1: 3-4.3:3 info: Microsoft Classic IntelliMouse type: mouse,HID
    lanes: 1 mode: 1.1 power: 200mA chip-ID: 045e:0823 class-ID: 0300
  Device-2: 3-4.4:4 info: China Resource Semico USB Keyboard
    type: keyboard,mouse driver: hid-generic,usbhid interfaces: 2 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 500mA
    chip-ID: 1a2c:4b61 class-ID: 0301
  Device-3: 3-4.5:5 info: VIA Labs USB Billboard Device type: billboard
    driver: N/A interfaces: 1 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1
    mode: 2.0 power: 100mA chip-ID: 2109:8886 class-ID: 1100 serial: <filter>
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-4:2 info: VIA Labs USB3.1 Hub ports: 4 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 2109:0822
  System Temperatures: cpu: 47.8 C mobo: 42.0 C gpu: nvidia temp: 46 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 55%
  Packages: pm: pacman pkgs: 1469 libs: 412 tools: pamac pm: flatpak pkgs: 0
    1: https://manjaro.kurdy.org/stable/$repo/$arch
    2: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    3: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    4: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    5: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    6: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    7: https://mirror.ufam.edu.br/manjaro/stable/$repo/$arch
    8: https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 312
  1: cpu: 7.8% command: firefox pid: 3442 mem: 573.1 MiB (3.6%)
  2: cpu: 3.0% command: Xorg pid: 711 mem: 171.8 MiB (1.0%)
  3: cpu: 2.9% command: plasmashell pid: 3242 mem: 589.4 MiB (3.7%)
  4: cpu: 2.8% command: konsole pid: 4219 mem: 158.9 MiB (0.9%)
  5: cpu: 2.4% command: firefox pid: 3691 mem: 243.0 MiB (1.5%)
  Memory top: 5 of 312
  1: mem: 589.4 MiB (3.7%) command: plasmashell pid: 3242 cpu: 2.9%
  2: mem: 573.1 MiB (3.6%) command: firefox pid: 3442 cpu: 7.8%
  3: mem: 550.3 MiB (3.4%) command: kwin_x11 pid: 817 cpu: 2.3%
  4: mem: 300.2 MiB (1.8%) command: firefox pid: 3592 cpu: 0.8%
  5: mem: 243.0 MiB (1.5%) command: firefox pid: 3691 cpu: 2.4%
  Processes: 312 Power: uptime: 11m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.19 GiB services: org_kde_powerdevil,
    tool: systemctl
  Compilers: clang: 19.1.7 gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash
    v: 5.2.37 running-in: konsole inxi: 3.3.37
___`Preformatted text`ystem:
    udev.log_priority=3
    xsaves xtopology
    affected
    class-ID: 0300
    modes: 1024x768
    memory: 7.81 GiB
    scheme: GPT
    uuid: 6DB0-0A0F
    uuid: 0BDC-29D3
    uuid: B362-0880
Processes:
  CPU top: 5 of 312
    tool: systemctl
I have properly formatted your inxi output for better readability., sorry, I have a hard time remembering. Was changging it, then you did it before me. In Windows MO2 was fine. So, not sure.
As I suspected:
This means when RAM gets too full, the system has no alternative but to dump applications, as you describe.
I’d create, say, a 20G swap partition in the space you freed on your hard disk, add it to /etc/fstab and see how you go from there.
What changed? Everything was fine until recently, what is to issue with Linux, Windows is fine?? I thought with 16 Gig, I would be fine.Seems odd, so I just make it in KDE Psrtiton Manager & make it linuxswap in fs choice.
I have seen a significant increase in the “footprint” of my systems over recent times. This is to be expected as new drivers get added; particularly Nvidia-related lately with the open-sourcing of such.
Windows has its own way of managing its cache (swap), which it doesn’t exactly advertise to its users.
Even with all that in Windows it didn’t kick me out. Doesn’t look like swap was even being used.
Heres linux…
Just create the 20 Gig Swap partition for Linux.
Linux is not Windows.
3% disk usage does, to me at least, indicate that Windows is using some form of swap; whether you defined that or not (usually, not, in most user’s setups; I spent ages setting up my Windows systems to define such, when I still used that OS).
I made the mistake of removing the recovery partition from such a system once, on a severely storage-starved device, hoping to free up useful space, only to find that it was using said partition for its secret hibernate “feature” which they (again) neglected to tell us about and subsequently BSOD’d on me. (I’d better plug that thing in to charge the battery, before it gets pregnant).
In Linux, this needs to be defined either automatically during installation e.g. using Calamares, or by the person doing the installation at the time; maybe later, after the event, as long as the user has planned the partition layout.
Does Manjaro support a swap file & how do I make 1?
