It already happened to me two times. I did not notice that my battery was to low and the laptop shut down while working on a project. I am looking for a gnome program that gives me a warning sound when the battery is too low. Is there any program like that?
Thanks.
(Yup; that’s a Star Trek “Computer has initiated self-destruct sequence” when my battery is critically low and my computer is about to hibernate…)
Please don’t forget to come back and click the 3 dots below the answer to mark a solution like this below the answer that helped you most:
