Lost Bootentry in BIOS
Hello I had a crash during the update due to lack of space after having resolved the problem by deleting old snapshots on restart it is the bios which opens, impossible to access manjaro kde which is the only Os Installed on my PC.
The only way I found is by restoring a snapshot in the grub. but whoever chooses the punishment after restarting remains the same bios. What can I do to get out of this?
Welcome to the Manjaro Community @rando !
This may help with an interrupted update:
I was thinking of moving this to its own topic, but I think it’s better left here (at least for now) as it may help others reading this thread.
Thank you, I will try this and I will keep you informed of the result
I just finished Recovering from an interrupted update/upgrade which did not resolve my problem. another idea that would save me from a complete reinstallation
What did that look like?
It did involve chroot, didn’t it?
If you can successfully chroot, you are essentially in your system - and can diagnose and repair it.
Easily (I’d say …)
If there was a lack of space:
did you address it?
inxi -zv8
may help you and others further
It seemed best to give you an extra thread. To prevent clutter from the update-thread.
A few questions up front so as not to waste time:
  • Please specify inxi -zv8 (collected when booting from Manjaro ISO (or timeshift))
  • Is this a legacy system with BIOS-MBR or GPT-UEFI or mixed?
:warning:
You mention a timeshift restore. Did you complete the restore according to the timeshift instructions in the system that was then running?
You have landed in the BIOS. Is there an entry for booting that matches Manjaro? Does it work? Have you marked it as the default in the BIOS and saved it?
