Lost ability to print to Canon TS6350a from Manjaro Gnome desktop
The printer is connected to LAN with a static IP. I can print to it from my partner’s Ubuntu desktop. Until very recently I was printing to it from my desktop. This was also via the network connection. The printer sits right next to my desktop and originally I had it connected by USB and working fine (purchased in 2023). But back in July I had a problem printing and ended up talking to a very helpful support staffer at Canon, who got me to unplug the USB and then got it working over the network. Since then I’ve reconnected the USB as that’s the only way I can get the scanner to work. I’m pretty sure (but can’t be certain) I’ve printed successfully since reconnecting USB. I suspect the problem has arisen since doing a general update.
I’ve read so many posts and guides and tried so many times to re-install it my brain is a bit scrambled by now, but most recently I’ve deleted it from CUPS and tried reinstalling.
CUPS finds the printer and offers me two “versions”:
Canon TS6300 series, driverless, cups-filters 2.0.1 (en)
and
Canon TS6300 series Ver.5.90 (en, de, fr, zh, ja)
As I’d been reading all about IPP Everywhere I wondered if that was the way to go so I tried the driverless version first, but that resulted in:
Unable to add printer:
    cups-driverd failed to get PPD file - see error_log for details.
(I’ll post the error log below.)
So then I tried to add the other, Ver.5.90 which seemed to install ok, though with the message: "Note:Printer drivers and raw queues are deprecated and will stop working in a future version of CUPS. " (Which made me think I was right to try driverless.)
But the printer shows:
	Canon_TS6300_series	Canon TS6300 usb	Landing	Canon TS6300 series Ver.5.90	Idle - "cfFilterChain: ghostscript (PID 112391) exited with no errors."
CUPS can communicate with the printer - it’ll print a self test page for example - but it won’t print a standard test page or a document from apps like LibreOffice Writer or Gedit. When I try that, the printer screen lights up for a moment, there’s a pause, then a pop-up on the desktop saying “Printing stopped. name-of-document.odt” And on the CUPS Jobs page it says
stopped
"Filter failed"
Yesterday I enabled debug level and so by now the error log is many megabites, but here’s a section which I think covers my recent attempt to install the printer:
D [05/Sep/2025:16:39:04 +0200] [Client 245] Closing connection.
D [05/Sep/2025:16:39:04 +0200] cupsdSetBusyState: newbusy="Not busy", busy="Not busy"
D [05/Sep/2025:16:39:04 +0200] Expiring subscriptions...
D [05/Sep/2025:16:39:05 +0200] Expiring subscriptions...
D [05/Sep/2025:16:42:01 +0200] cupsdSetBusyState: newbusy="Active clients", busy="Not busy"
D [05/Sep/2025:16:42:01 +0200] [Client 247] Server address is "127.0.0.1".
D [05/Sep/2025:16:42:01 +0200] [Client 247] Accepted from localhost:51672 (IPv4)
D [05/Sep/2025:16:42:01 +0200] [Client 247] Waiting for request.
D [05/Sep/2025:16:42:01 +0200] Expiring subscriptions...
D [05/Sep/2025:16:42:01 +0200] cupsdAddCert: Adding certificate for PID 0
D [05/Sep/2025:16:42:01 +0200] Report: clients=2
D [05/Sep/2025:16:42:01 +0200] Report: jobs=5
D [05/Sep/2025:16:42:01 +0200] Report: jobs-active=0
D [05/Sep/2025:16:42:01 +0200] Report: printers=0
D [05/Sep/2025:16:42:01 +0200] Report: stringpool-string-count=1699
D [05/Sep/2025:16:42:01 +0200] Report: stringpool-alloc-bytes=6488
D [05/Sep/2025:16:42:01 +0200] Report: stringpool-total-bytes=34416
D [05/Sep/2025:16:42:01 +0200] [Client 247] POST /admin HTTP/1.1
D [05/Sep/2025:16:42:01 +0200] cupsdSetBusyState: newbusy="Active clients", busy="Active clients"
D [05/Sep/2025:16:42:01 +0200] [Client 247] Read: status=200, state=6
D [05/Sep/2025:16:42:01 +0200] [Client 247] Authorized as "nick" using Basic.
D [05/Sep/2025:16:42:01 +0200] cupsdIsAuthorized: username="nick"
D [05/Sep/2025:16:42:01 +0200] [Client 247] Read: status=100, state=6
D [05/Sep/2025:16:42:01 +0200] [CGI] argv[0] = "/usr/lib/cups/cgi-bin/admin.cgi"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[0] = "CUPS_CACHEDIR=/var/cache/cups"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[1] = "CUPS_DATADIR=/usr/share/cups"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[2] = "CUPS_DOCROOT=/usr/share/cups/doc"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[3] = "CUPS_REQUESTROOT=/var/spool/cups"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[4] = "CUPS_SERVERBIN=/usr/lib/cups"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[5] = "CUPS_SERVERROOT=/etc/cups"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[6] = "CUPS_STATEDIR=/run/cups"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[7] = "HOME=/var/spool/cups/tmp"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[8] = "PATH=/usr/lib/cups/filter:/usr/bin:/usr/bin:/bin:/usr/bin"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[9] = "SERVER_ADMIN=root@nick-pc3c"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[10] = "SOFTWARE=CUPS/2.4.12"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[11] = "TMPDIR=/var/spool/cups/tmp"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[12] = "USER=root"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[13] = "CUPS_MAX_MESSAGE=2047"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[14] = "CUPS_SERVER=/run/cups/cups.sock"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[15] = "CUPS_ENCRYPTION=IfRequested"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[16] = "IPP_PORT=631"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[17] = "AUTH_TYPE=Basic"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[18] = "LANG=en_GB.UTF8"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[19] = "REDIRECT_STATUS=1"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[20] = "GATEWAY_INTERFACE=CGI/1.1"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[21] = "SERVER_NAME=localhost"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[22] = "SERVER_PORT=631"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[23] = "REMOTE_ADDR=127.0.0.1"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[24] = "REMOTE_HOST=localhost"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[25] = "SCRIPT_NAME=/admin"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[26] = "SCRIPT_FILENAME=/usr/share/cups/doc/admin"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[27] = "REMOTE_USER=nick"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[28] = "SERVER_PROTOCOL=HTTP/1.1"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[29] = "HTTP_COOKIE=org.cups.sid=35dc555124f2cb85cb3f7e8958ee461e"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[30] = "HTTP_USER_AGENT=Mozilla/5.0 (X11; Linux x86_64; rv:142.0) Gecko/20100101 Firefox/142.0"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[31] = "HTTP_REFERER=http://localhost:631/admin"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[32] = "REQUEST_METHOD=POST"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[33] = "CONTENT_LENGTH=2009"
D [05/Sep/2025:16:42:01 +0200] [CGI] envp[34] = "CONTENT_TYPE=multipart/form-data; boundary=----geckoformboundarydd817b14a7841f2991846bdfb7965487"
D [05/Sep/2025:16:42:01 +0200] cupsdAddCert: Adding certificate for PID 108960
D [05/Sep/2025:16:42:01 +0200] [CGI] Started /usr/lib/cups/cgi-bin/admin.cgi (PID 108960)
I [05/Sep/2025:16:42:01 +0200] [Client 247] Started "/usr/lib/cups/cgi-bin/admin.cgi" (pid=108960, file=18)
D [05/Sep/2025:16:42:01 +0200] [Client 247] Waiting for CGI data.
D [05/Sep/2025:16:42:02 +0200] [CGI] admin.cgi started...
D [05/Sep/2025:16:42:02 +0200] Expiring subscriptions...
D [05/Sep/2025:16:42:02 +0200] cupsdSetBusyState: newbusy="Active clients", busy="Active clients"
D [05/Sep/2025:16:42:02 +0200] [Client 248] Server address is "/run/cups/cups.sock".
D [05/Sep/2025:16:42:02 +0200] [Client 248] Accepted from localhost (Domain)
D [05/Sep/2025:16:42:02 +0200] [Client 248] Waiting for request.
D [05/Sep/2025:16:42:02 +0200] [CGI] http=0x563017b3ccf0
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: SECTION=\"admin\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: REFRESH_PAGE=\"\"
D [05/Sep/2025:16:42:02 +0200] [CGI] org.cups.sid cookie is \"35dc555124f2cb85cb3f7e8958ee461e\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: org.cups.sid=\"35dc555124f2cb85cb3f7e8958ee461e\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: OP=\"add-printer\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: printer_name=\"Canon_TS6300_series\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: BAUDRATE=\"\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: BITS=\"\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: PARITY=\"\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: FLOW=\"\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetArray: PRINTER_NAME[1]=\"Canon_TS6300_series\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: PRINTER_INFO=\"Canon TS6300 usb\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: PRINTER_LOCATION=\"Landing\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: DEVICE_URI=\"usb://Canon/TS6300%20series?serial=2130CF&interface=1\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: PRINTER_IS_SHARED=\"\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: PPD_NAME=\"driverless:ipps://Canon%20TS6300%20series._ipps._tcp.local/\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: MAX_FILE_SIZE=\"2097152\"
D [05/Sep/2025:16:42:02 +0200] [CGI] cgiSetVariable: PPD_FILE=\"\"
D [05/Sep/2025:16:42:02 +0200] [CGI] op=\"add-printer\"...
D [05/Sep/2025:16:42:02 +0200] [CGI] do_am_printer: DEVICE_URI=\"usb://Canon/TS6300%20series?serial=2130CF&interface=1\"
D [05/Sep/2025:16:42:02 +0200] [Client 248] POST /admin/ HTTP/1.1
D [05/Sep/2025:16:42:02 +0200] [Client 248] Read: status=200, state=6
D [05/Sep/2025:16:42:02 +0200] [Client 248] No authentication data provided.
D [05/Sep/2025:16:42:02 +0200] cupsdIsAuthorized: username=""
D [05/Sep/2025:16:42:02 +0200] [Client 248] cupsdSendHeader: code=401, type="text/html", auth_type=0
D [05/Sep/2025:16:42:02 +0200] [Client 248] WWW-Authenticate: Basic realm=\"CUPS\", PeerCred, Local trc=\"y\"
D [05/Sep/2025:16:42:02 +0200] [Client 248] Closing connection.
D [05/Sep/2025:16:42:02 +0200] [Client 249] Server address is "/run/cups/cups.sock".
D [05/Sep/2025:16:42:02 +0200] [Client 249] Accepted from localhost (Domain)
D [05/Sep/2025:16:42:02 +0200] [Client 249] Waiting for request.
D [05/Sep/2025:16:42:02 +0200] [Client 250] Server address is "/run/cups/cups.sock".
D [05/Sep/2025:16:42:02 +0200] [Client 250] Accepted from localhost (Domain)
D [05/Sep/2025:16:42:02 +0200] [Client 250] Waiting for request.
D [05/Sep/2025:16:42:02 +0200] [Client 249] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [05/Sep/2025:16:42:02 +0200] [Client 249] Closing connection.
D [05/Sep/2025:16:42:02 +0200] [Client 250] POST /admin/ HTTP/1.1
D [05/Sep/2025:16:42:02 +0200] [Client 250] Read: status=200, state=6
D [05/Sep/2025:16:42:02 +0200] [Client 250] Authorized as nick using Local.
D [05/Sep/2025:16:42:02 +0200] cupsdIsAuthorized: username="nick"
D [05/Sep/2025:16:42:02 +0200] [Client 250] 2.0 CUPS-Add-Modify-Printer 1
D [05/Sep/2025:16:42:02 +0200] CUPS-Add-Modify-Printer ipp://localhost/printers/Canon_TS6300_series
D [05/Sep/2025:16:42:02 +0200] Canon_TS6300_series device-uri: Unknown scheme in URI
I [05/Sep/2025:16:42:02 +0200] Setting Canon_TS6300_series device-uri to "usb://Canon/TS6300%20series?serial=2130CF&interface=1" (was "file:///dev/null".)
I [05/Sep/2025:16:42:02 +0200] Setting Canon_TS6300_series printer-is-accepting-jobs to 1 (was 0.)
D [05/Sep/2025:16:42:02 +0200] cupsdMarkDirty(----S)
D [05/Sep/2025:16:42:02 +0200] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients"
D [05/Sep/2025:16:42:02 +0200] cupsdDeregisterPrinter(p=0x561120ef1db0(Canon_TS6300_series), removeit=1)
I [05/Sep/2025:16:42:02 +0200] Setting Canon_TS6300_series printer-is-shared to 0 (was 1.)
I [05/Sep/2025:16:42:02 +0200] Setting Canon_TS6300_series printer-state to 3 (was 5.)
D [05/Sep/2025:16:42:02 +0200] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files"
D [05/Sep/2025:16:42:02 +0200] copy_model: Running "cups-driverd cat driverless:ipps://Canon%20TS6300%20series._ipps._tcp.local/"...
E [05/Sep/2025:16:42:07 +0200] [CGI] Unable to create PPD file: Could not poll sufficient capability info from the printer (ipps://Canon%20TS6300%20series._ipps._tcp.local/, ipps://1E1D5A000000.local:631/ipp/print) via IPP!
E [05/Sep/2025:16:42:07 +0200] copy_model: empty PPD file
D [05/Sep/2025:16:42:07 +0200] CUPS-Add-Modify-Printer server-error-internal-error: cups-driverd failed to get PPD file - see error_log for details.
D [05/Sep/2025:16:42:07 +0200] cupsdMarkDirty(P----)
D [05/Sep/2025:16:42:07 +0200] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Active clients and dirty files"
D [05/Sep/2025:16:42:07 +0200] cupsdMarkDirty(----S)
D [05/Sep/2025:16:42:07 +0200] cupsdDeregisterPrinter(p=0x561120ef1db0(Canon_TS6300_series), removeit=1)
E [05/Sep/2025:16:42:07 +0200] [Client 250] Returning IPP server-error-internal-error for CUPS-Add-Modify-Printer (ipp://localhost/printers/Canon_TS6300_series) from localhost.
D [05/Sep/2025:16:42:07 +0200] [Client 250] Content-Length: 158
D [05/Sep/2025:16:42:07 +0200] [Client 250] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [05/Sep/2025:16:42:07 +0200] Expiring subscriptions...
D [05/Sep/2025:16:42:07 +0200] PID 108961 (/usr/lib/cups/daemon/cups-driverd) stopped with status 1.
D [05/Sep/2025:16:42:07 +0200] [Client 250] con->http=0x561120fc1eb0
D [05/Sep/2025:16:42:07 +0200] [Client 250] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=158, response=0x561120fc8a70(IPP_STATE_DATA), pipe_pid=0, file=-1
D [05/Sep/2025:16:42:07 +0200] [Client 250] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [05/Sep/2025:16:42:07 +0200] [Client 250] bytes=0, http_state=0, data_remaining=158
D [05/Sep/2025:16:42:07 +0200] [Client 250] Flushing write buffer.
D [05/Sep/2025:16:42:07 +0200] [Client 250] New state is HTTP_STATE_WAITING
D [05/Sep/2025:16:42:07 +0200] [Client 250] Waiting for request.
D [05/Sep/2025:16:42:07 +0200] [Notifier] state=3
D [05/Sep/2025:16:42:07 +0200] [Notifier] PrinterStateChanged
D [05/Sep/2025:16:42:07 +0200] [Notifier] PrinterStopped
D [05/Sep/2025:16:42:07 +0200] [Client 221] POST / HTTP/1.1
D [05/Sep/2025:16:42:07 +0200] [Client 221] Read: status=200, state=6
D [05/Sep/2025:16:42:07 +0200] [Client 221] No authentication data provided.
D [05/Sep/2025:16:42:07 +0200] [Client 221] 2.0 Get-Notifications 160
D [05/Sep/2025:16:42:07 +0200] Get-Notifications /printers/
D [05/Sep/2025:16:42:07 +0200] cupsdIsAuthorized: requesting-user-name="nick"
D [05/Sep/2025:16:42:07 +0200] [Client 221] Returning IPP successful-ok for Get-Notifications (/printers/) from localhost.
D [05/Sep/2025:16:42:07 +0200] [Client 221] Content-Length: 1436
D [05/Sep/2025:16:42:07 +0200] [Client 221] cupsdSendHeader: code=200, type="application/ipp", auth_type=0
D [05/Sep/2025:16:42:07 +0200] [Client 221] con->http=0x561120fb3050
D [05/Sep/2025:16:42:07 +0200] [Client 221] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=1436, response=0x561120fc0ba0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [05/Sep/2025:16:42:07 +0200] [Client 221] Writing IPP response, ipp_state=IPP_STATE_DATA, old wused=0, new wused=0
D [05/Sep/2025:16:42:07 +0200] [Client 221] bytes=0, http_state=0, data_remaining=1436
D [05/Sep/2025:16:42:07 +0200] [Client 221] Flushing write buffer.
D [05/Sep/2025:16:42:07 +0200] [Client 221] New state is HTTP_STATE_WAITING
D [05/Sep/2025:16:42:07 +0200] [Client 221] Waiting for request.
D [05/Sep/2025:16:42:07 +0200] [CGI] cgiSetVariable: TITLE=\"Add Printer\"
D [05/Sep/2025:16:42:07 +0200] [CGI] cgiSetVariable: SERVER_NAME=\"localhost\"
D [05/Sep/2025:16:42:07 +0200] [CGI] cgiSetVariable: REMOTE_USER=\"nick\"
D [05/Sep/2025:16:42:07 +0200] [CGI] cgiSetVariable: CUPS_VERSION=\"CUPS v2.4.12\"
D [05/Sep/2025:16:42:07 +0200] [Client 247] CGI data ready to be sent.
D [05/Sep/2025:16:42:07 +0200] [CGI] cgiSetVariable: MESSAGE=\"Unable to add printer\"
D [05/Sep/2025:16:42:07 +0200] [CGI] cgiSetVariable: ERROR=\"cups-driverd failed to get PPD file - see error_log for details.\"
D [05/Sep/2025:16:42:07 +0200] [Client 250] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [05/Sep/2025:16:42:07 +0200] [Client 250] Closing connection.
D [05/Sep/2025:16:42:07 +0200] [Client 247] con->http=0x561120fad940
D [05/Sep/2025:16:42:07 +0200] [Client 247] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=2147483647, response=(nil)(), pipe_pid=108960, file=18
D [05/Sep/2025:16:42:07 +0200] [Client 247] Waiting for CGI data.
D [05/Sep/2025:16:42:07 +0200] [Client 247] Script header: Content-Type: text/html;charset=utf-8
D [05/Sep/2025:16:42:07 +0200] [Client 247] Sending status 200 for CGI.
D [05/Sep/2025:16:42:07 +0200] [Client 247] cupsdSendHeader: code=200, type="(null)", auth_type=0
D [05/Sep/2025:16:42:07 +0200] PID 108960 (/usr/lib/cups/cgi-bin/admin.cgi) exited with no errors.
D [05/Sep/2025:16:42:07 +0200] [Client 247] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_CHUNKED, data_remaining=0, response=(nil)(), pipe_pid=108960, file=18
D [05/Sep/2025:16:42:07 +0200] [Client 221] 2.0 Get-Notifications 161
D [05/Sep/2025:16:42:07 +0200] [Client 221] Content-Length: 127
D [05/Sep/2025:16:42:07 +0200] [Client 221] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=127, response=0x561120ee5cf0(IPP_STATE_DATA), pipe_pid=0, file=-1
D [05/Sep/2025:16:42:07 +0200] [Client 221] bytes=0, http_state=0, data_remaining=127
D [05/Sep/2025:16:42:07 +0200] [Client 247] Sending 0-length chunk.
D [05/Sep/2025:16:42:07 +0200] [Client 247] Flushing write buffer.
D [05/Sep/2025:16:42:07 +0200] [Client 247] New state is HTTP_STATE_WAITING
D [05/Sep/2025:16:42:07 +0200] [Client 247] Waiting for request.
D [05/Sep/2025:16:42:07 +0200] cupsdSetBusyState: newbusy="Dirty files", busy="Active clients and dirty files"
D [05/Sep/2025:16:42:07 +0200] cupsdSetBusyState: newbusy="Active clients and dirty files", busy="Dirty files"
D [05/Sep/2025:16:42:07 +0200] [Client 221] 2.0 Get-Notifications 162
D [05/Sep/2025:16:42:07 +0200] [Client 221] cupsdWriteClient error=0, used=0, state=HTTP_STATE_POST_SEND, data_encoding=HTTP_ENCODING_LENGTH, data_remaining=127, response=0x561120f92680(IPP_STATE_DATA), pipe_pid=0, file=-1
D [05/Sep/2025:16:42:08 +0200] Expiring subscriptions...
D [05/Sep/2025:16:42:18 +0200] [Client 247] HTTP_STATE_WAITING Closing for error 32 (Broken pipe)
D [05/Sep/2025:16:42:18 +0200] [Client 247] Closing connection.
D [05/Sep/2025:16:42:18 +0200] cupsdSetBusyState: newbusy="Dirty files", busy="Dirty files"
D [05/Sep/2025:16:42:18 +0200] Expiring subscriptions...
D [05/Sep/2025:16:42:19 +0200] Expiring subscriptions...
I [05/Sep/2025:16:42:33 +0200] Saving printers.conf...
I [05/Sep/2025:16:42:33 +0200] Saving subscriptions.conf...
D [05/Sep/2025:16:42:33 +0200] cupsdSetBusyState: newbusy="Not busy", busy="Dirty files"
D [05/Sep/2025:16:42:33 +0200] Expiring subscriptions...
One other thing I tried, after reading the solution in this thread
 New solution for Canon printers at least is the following package: cnrdrvcups-lb I am good to go again now without having to use Avahi
was to try installing cnrdrvcups-lb. But pamac can’t find that package.
This is driving me nuts - can anyone help?
System info:
    ~  inxi -zv8         ✔
  Kernel: 6.15.11-2-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.15-x86_64
    root=UUID=505a427c-a786-41e4-a4bc-690a3c072cbc rw quiet splash apparmor=1
  Desktop: GNOME v: 48.4 tk: GTK v: 3.24.50 wm: gnome-shell
    base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: PRIME Z370-A v: Rev X.0x
    UEFI-[Legacy]: American Megatrends v: 0606 date: 12/12/2017
  System RAM: total: 16 GiB available: 15.48 GiB used: 4.84 GiB (31.3%)
  Array-1: capacity: 32 GiB slots: 4 modules: 2 EC: None
  Device-1: ChannelA-DIMM1 type: no module installed
  Device-2: ChannelA-DIMM2 type: DDR4 detail: synchronous unbuffered
    (unregistered) size: 8 GiB speed: 2400 MT/s volts: curr: 1 width (bits):
    data: 64 total: 64 manufacturer: Corsair part-no: CMK16GX4M2A2400C14
    serial: N/A
  Device-3: ChannelB-DIMM1 type: no module installed
  Device-4: ChannelB-DIMM2 type: DDR4 detail: synchronous unbuffered
    serial: N/A
  Info: model: Intel Core i7-8700 bits: 64 type: MT MCP arch: Coffee Lake
    gen: core 8 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xFA
  Topology: cpus: 1x dies: 1 clusters: 6 cores: 6 threads: 12 tpc: 2
    smt: enabled cache: L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 1.5 MiB
    desc: 6x256 KiB L3: 12 MiB desc: 1x12 MiB
  Speed (MHz): avg: 800 min/max: 800/4600 scaling: driver: intel_pstate
    governor: powersave cores: 1: 800 2: 800 3: 800 4: 800 5: 800 6: 800 7: 800
    8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 76799
    smap smep smx ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall tm tm2
    vulnerable
  Device-1: Intel CoffeeLake-S GT2 [UHD Graphics 630] vendor: ASUSTeK
    ports: active: none empty: DP-2, HDMI-A-2, HDMI-A-3, HDMI-A-4
    bus-ID: 00:02.0 chip-ID: 8086:3e92 class-ID: 0380
  Device-2: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nouveau v: kernel
    alternate: nova_core non-free: 550-580.xx+ status: current (as of 2025-08;
    EOL~2026-12-xx) arch: Pascal code: GP10x process: TSMC 16nm
    built: 2016-2021 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
    speed: 8 GT/s ports: active: DVI-D-1,HDMI-A-1 empty: DP-1 bus-ID: 01:00.0
    chip-ID: 10de:1c82 class-ID: 0300 temp: 46.0 C
  Device-3: Logitech HD Pro Webcam C920 driver: snd-usb-audio,uvcvideo
    type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-13.4.4:7
    chip-ID: 046d:082d class-ID: 0102 serial: <filter>
    compositor: gnome-shell driver: gpu: nouveau display-ID: 0
  Monitor-1: DVI-D-1 model: NEC 20WGX2 serial: <filter> built: 2007
    res: 1680x1050 dpi: 99 gamma: 1.2 chroma: red: x: 0.639 y: 0.341 green:
    x: 0.290 y: 0.612 blue: x: 0.145 y: 0.071 white: x: 0.314 y: 0.329
    size: 433x270mm (17.05x10.63") diag: 510mm (20.1") ratio: 16:10
    modes: 1680x1050, 1400x1050, 1280x1024, 1440x900, 1280x960, 1152x864,
    1280x720, 1024x768, 832x624, 800x600, 640x480, 720x400
  Monitor-2: HDMI-A-1 model: LG (GoldStar) W2243 serial: <filter>
    built: 2009 res: 1920x1080 dpi: 102 gamma: 1.2 chroma: red: x: 0.635
    y: 0.341 green: x: 0.290 y: 0.612 blue: x: 0.145 y: 0.071 white: x: 0.314
    y: 0.329 size: 477x269mm (18.78x10.59") diag: 548mm (21.6") ratio: 16:9
    modes: 1920x1080, 1680x1050, 1280x1024, 1280x960, 1152x864, 1280x720,
    1024x768, 800x600, 720x480, 640x480, 720x400
  API: EGL v: 1.5 hw: drv: intel iris drv: nvidia nouveau platforms:
    device: 0 drv: iris device: 1 drv: nouveau device: 2 drv: swrast gbm:
    drv: iris surfaceless: drv: iris wayland: drv: nouveau x11: drv: nouveau
  API: OpenGL v: 4.6 compat-v: 4.3 vendor: mesa v: 25.2.1-arch1.4 glx-v: 1.4
    direct-render: yes renderer: NV137 device-ID: 10de:1c82 memory: 3.89 GiB
    unified: no display-ID: :0.0
  Info: Tools: api: eglinfo,glxinfo x11: xprop,xrandr
  Device-1: Intel 200 Series PCH HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a2f0 class-ID: 0403
  Device-2: NVIDIA GP107GL High Definition Audio driver: snd_hda_intel
    v: kernel alternate: nova_core pcie: gen: 1 speed: 2.5 GT/s lanes: 16
    link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.1 chip-ID: 10de:0fb9
    class-ID: 0403
  API: ALSA v: k6.15.11-2-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.4.7 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: docker0 state: down mac: <filter>
  Device-1: ASUSTek ASUS USB-BT500 driver: btusb v: 0.8 type: USB rev: 1.1
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-11:4 chip-ID: 0b05:190e
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: N/A
  Local Storage: total: 3.19 TiB used: 1.39 TiB (43.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung
    model: MZVKW512HMJP-00000 size: 476.94 GiB block-size: physical: 512 B
    fw-rev: CXA7500Q temp: 47.9 C scheme: MBR
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    model: SSD 970 EVO Plus 2TB size: 1.82 TiB block-size: physical: 512 B
    fw-rev: 2B2QEXM7 temp: 39.9 C scheme: GPT
  ID-3: /dev/nvme2n1 maj-min: 259:4 vendor: Samsung model: SSD 970 EVO 1TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 45.9 C
    scheme: GPT
  ID-1: / raw-size: 476.93 GiB size: 468.38 GiB (98.21%)
    used: 66.46 GiB (14.2%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:3
    label: N/A uuid: 505a427c-a786-41e4-a4bc-690a3c072cbc
  ID-2: /mnt/2a171f5f-7535-4b7f-a544-66a1c4283d1d raw-size: 1.82 TiB
    size: 1.79 TiB (98.37%) used: 691.48 GiB (37.7%) fs: ext4
    dev: /dev/nvme1n1p1 maj-min: 259:1 label: Data_2
    uuid: 2a171f5f-7535-4b7f-a544-66a1c4283d1d
  ID-3: /mnt/d7449928-d30a-4479-bb48-f02d4213b325 raw-size: 931.51 GiB
    size: 915.82 GiB (98.32%) used: 665.69 GiB (72.7%) fs: ext4
    dev: /dev/nvme2n1p1 maj-min: 259:5 label: Data_1
    uuid: d7449928-d30a-4479-bb48-f02d4213b325
  ID-4: /var/Music raw-size: N/A size: 458.17 GiB used: 145.45 GiB (31.7%)
    fs: nfs4 remote: 192.168.1.77:/home/nick/Music
  Device-1: 1-5:2 info: IBM NetVista Full Width Keyboard type: keyboard
    driver: hid-generic,usbhid interfaces: 1 rev: 1.1
    speed: 1.5 Mb/s (183 KiB/s) lanes: 1 mode: 1.0 power: 70mA
    chip-ID: 04b3:3025 class-ID: 0301
  Device-2: 1-6:3 info: Microsoft IntelliMouse Optical type: mouse
    chip-ID: 045e:0029 class-ID: 0301
  Device-3: 1-11:4 info: ASUSTek ASUS USB-BT500 type: bluetooth
    driver: btusb interfaces: 2 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s) lanes: 1
    mode: 1.1 power: 500mA chip-ID: 0b05:190e class-ID: e001 serial: <filter>
  Hub-2: 1-13:5 info: NEC HighSpeed Hub ports: 4 rev: 2.0
    chip-ID: 0409:005a class-ID: 0900
  Hub-3: 1-13.4:6 info: NEC HighSpeed Hub ports: 4 rev: 2.0
  Device-1: 1-13.4.4:7 info: Logitech HD Pro Webcam C920 type: video,audio
  Device-2: 1-14:10 info: Canon TS6300 series type: printer driver: usblp
    interfaces: 6 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0
    power: 2mA chip-ID: 04a9:188d class-ID: 0701 serial: <filter>
  Hub-4: 2-0:1 info: super-speed hub ports: 10 rev: 3.0
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  System Temperatures: cpu: 43.0 C mobo: N/A gpu: nouveau temp: 46.0 C
  Fan Speeds (rpm): N/A
  Packages: 1820 pm: pacman pkgs: 1781 libs: 413 tools: gnome-software,pamac
    pm: flatpak pkgs: 26 pm: snap pkgs: 13
    1: https://manjaro.ynh.ovh/stable/$repo/$arch
Processes:
  CPU top: 5 of 352
  1: cpu: 43.6% command: soffice.bin pid: 17268 mem: 1974.7 MiB (12.4%)
  2: cpu: 7.6% command: firefox pid: 100785 mem: 385.7 MiB (2.4%)
  3: cpu: 4.4% command: firefox pid: 17612 mem: 846.1 MiB (5.3%)
  4: cpu: 1.7% command: gnome-shell pid: 10713 mem: 469.4 MiB (2.9%)
  5: cpu: 1.6% command: firefox pid: 100712 mem: 334.0 MiB (2.1%)
  Memory top: 5 of 352
  1: mem: 1974.7 MiB (12.4%) command: soffice.bin pid: 17268 cpu: 43.6%
  2: mem: 846.1 MiB (5.3%) command: firefox pid: 17612 cpu: 4.4%
  3: mem: 512.1 MiB (3.2%) command: firefox pid: 17834 cpu: 1.1%
  4: mem: 469.4 MiB (2.9%) command: gnome-shell pid: 10713 cpu: 1.7%
  5: mem: 385.7 MiB (2.4%) command: firefox pid: 100785 cpu: 7.6%
  Processes: 352 Power: uptime: 6h 32m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 6.16 GiB services: gsd-power,
    tool: systemctl
  Compilers: clang: 20.1.8 gcc: 15.2.1 Shell: Zsh v: 5.9 running-in: kgx
    inxi: 3.3.39
Enable AUR support in pamac (hit the 3 vertical dots >> Preferences >> Third Party >> Enable AUR support), the package is there.
Ah! Thanks for that - I hadn’t noticed that it had got disabled! Must have been after an update?
OK, so I’ve installed cnrdrvcups-lb and restarted… what now? Will CUPS automatically find it and use it? Should I delete the printer and then re-install it? I don’t want to mess it up!
To answer my own question: yes, I didn’t have to do anything once I’d restarted the desktop; the printer now works as before. So installing cnrdrvcups-lb is indeed my solution.
