Whenever I wake up from sleep, I would lose sound.
inxi -Fxxx
Host: Kernel: 5.9.11-3-MANJARO x86_64 bits: 64 compiler: gcc
v: 10.2.0 Desktop: Xfce 4.14.3 tk: Gtk 3.24.23 info: xfce4-panel wm: xfwm4
dm: LightDM 1.30.0 Distro: Manjaro Linux
Type: Laptop System: Sony product: VPCEH11FX v: C105NRAH
serial: <superuser/root required> Chassis: type: 10
Mobo: Sony model: VAIO serial: <superuser/root required> BIOS: INSYDE
v: R0180Z9 date: 04/28/2011
ID-1: BAT0 charge: 30.1 Wh condition: 30.1/43.2 Wh (70%) volts: 3.8/10.8
model: Sony Corp. VGP-BPS26 type: Li-ion serial: 314 status: Full
Device-1: hidpp_battery_0 model: Logitech Wireless Touch Keyboard K400
serial: 404b-af-11-a0-cb charge: 100% (should be ignored)
rechargeable: yes status: Discharging
Info: Dual Core model: Intel Pentium B940 bits: 64 type: MCP
arch: Sandy Bridge rev: 7 L2 cache: 2048 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 bogomips: 7984
Speed: 798 MHz min/max: 800/2000 MHz Core speeds (MHz): 1: 911 2: 973
Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
vendor: Sony driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0106
Device-2: Microdia Sony Visual Communication Camera type: USB
driver: uvcvideo bus ID: 1-1.2:3 chip ID: 0c45:6436
Display: x11 server: X.Org 1.20.10 driver: intel unloaded: modesetting
alternate: fbdev,vesa resolution: 1920x1080~60Hz s-dpi: 96
OpenGL: renderer: Mesa DRI Intel HD Graphics 2000 (SNB GT1)
v: 3.3 Mesa 20.2.3 compat-v: 3.0 direct render: Yes
vendor: Sony driver: snd_hda_intel v: kernel bus ID: 00:1b.0
chip ID: 8086:1c20
Sound Server: ALSA v: k5.9.11-3-MANJARO
Device-1: Qualcomm Atheros AR9285 Wireless Network Adapter
vendor: Foxconn T77H126.00 802.11bgn driver: ath9k v: kernel port: 4040
bus ID: 07:00.0 chip ID: 168c:002b
IF: wlp7s0 state: up mac: 90:00:4e:ca:86:68
vendor: Sony driver: r8169 v: kernel port: 2000 bus ID: 13:00.0
chip ID: 10ec:8168
IF: enp19s0 state: down mac: 78:84:3c:e4:3e:14
Local Storage: total: 357.25 GiB used: 50.90 GiB (14.2%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS725032A7E630
size: 298.09 GiB speed: 6.0 Gb/s rotation: 7200 rpm serial: TF645AY1GP6YDL
rev: B550 scheme: MBR
ID-2: /dev/sdb type: USB vendor: SanDisk model: Cruzer Dial
size: 59.16 GiB serial: 4C530001010418106322 rev: 1.00 scheme: MBR
ID-1: / size: 292.41 GiB used: 50.90 GiB (17.4%) fs: ext4 dev: /dev/dm-0
System Temperatures: cpu: 50.0 C mobo: N/A
Processes: 179 Uptime: 6h 13m Memory: 3.79 GiB used: 1.96 GiB (51.7%)
Init: systemd v: 246 Compilers: gcc: 10.2.0 Packages: 1398 pacman: 1391
flatpak: 7 Shell: Bash v: 5.0.18 running in: xfce4-terminal inxi: 3.1.08
Additional info: laptop connected to a tv monitor and I use pulseaudio, and pulseaudio effects
