Exactly 1 hour after connection has been established losing it for 30 sec to 1 min if i do nothing, if i disconnect/connect by myself it takes ~20 seconds.
There is nothing in journalctl while it’s happening, unless i reconnect myself.
Connection is wired, isp only provides cable straight to my apartment, so i can’t mess with router/modem
inxi
Summary
Kernel: 5.4.105-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.0
root=UUID=0b1cd83f-7be5-49a8-90bf-f1e76a306ca6 rw quiet apparmor=1
security=apparmor udev.log_priority=3 systemd.unified_cgroup_hierarchy=true
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel wm: xfwm4 vt: 7
vendor: Micro-Star MSI driver: r8169 v: kernel port: d000 bus-ID: 03:00.0
IF: enp3s0 state: up speed: 100 Mbps duplex: full mac:
connection information:
Summary
connection.id: Wired connection 1
connection.uuid: 95fcce7f-0ed7-3424-87a0-65212a1a57ee
connection.stable-id: –
connection.type: 802-3-ethernet
connection.interface-name: enp3s0
connection.autoconnect: yes
connection.autoconnect-priority: -999
connection.autoconnect-retries: -1 (default)
connection.multi-connect: 0 (default)
connection.auth-retries: -1
connection.timestamp: 1617457148
connection.read-only: no
connection.permissions: –
connection.zone: –
connection.master: –
connection.slave-type: –
connection.autoconnect-slaves: -1 (default)
connection.secondaries: –
connection.gateway-ping-timeout: 0
connection.metered: no
connection.lldp: default
connection.mdns: -1 (default)
connection.llmnr: -1 (default)
connection.wait-device-timeout: -1
802-3-ethernet.port: –
802-3-ethernet.speed: 0
802-3-ethernet.duplex: –
802-3-ethernet.auto-negotiate: no
802-3-ethernet.mac-address: –
802-3-ethernet.cloned-mac-address: –
802-3-ethernet.generate-mac-address-mask:–
802-3-ethernet.mac-address-blacklist: –
802-3-ethernet.mtu: auto
802-3-ethernet.s390-subchannels: –
802-3-ethernet.s390-nettype: –
802-3-ethernet.s390-options: –
802-3-ethernet.wake-on-lan: default
802-3-ethernet.wake-on-lan-password: –
ipv4.method: auto
ipv4.dns-search: –
ipv4.dns-options: –
ipv4.dns-priority: 0
ipv4.addresses: –
ipv4.gateway: –
ipv4.routes: –
ipv4.route-metric: -1
ipv4.route-table: 0 (unspec)
ipv4.routing-rules: –
ipv4.ignore-auto-routes: no
ipv4.ignore-auto-dns: no
ipv4.dhcp-client-id: –
ipv4.dhcp-iaid: –
ipv4.dhcp-timeout: 0 (default)
ipv4.dhcp-send-hostname: yes
ipv4.dhcp-hostname: –
ipv4.dhcp-fqdn: –
ipv4.dhcp-hostname-flags: 0x0 (none)
ipv4.never-default: no
ipv4.may-fail: yes
ipv4.dad-timeout: -1 (default)
ipv4.dhcp-vendor-class-identifier: –
ipv4.dhcp-reject-servers: –
ipv6.method: disabled
ipv6.dns: –
ipv6.dns-search: –
ipv6.dns-options: –
ipv6.dns-priority: 0
ipv6.addresses: –
ipv6.gateway: –
ipv6.routes: –
ipv6.route-metric: -1
ipv6.route-table: 0 (unspec)
ipv6.routing-rules: –
ipv6.ignore-auto-routes: no
ipv6.ignore-auto-dns: no
ipv6.never-default: no
ipv6.may-fail: yes
ipv6.ip6-privacy: 0 (disabled)
ipv6.addr-gen-mode: stable-privacy
ipv6.ra-timeout: 0 (default)
ipv6.dhcp-duid: –
ipv6.dhcp-iaid: –
ipv6.dhcp-timeout: 0 (default)
ipv6.dhcp-send-hostname: yes
ipv6.dhcp-hostname: –
ipv6.dhcp-hostname-flags: 0x0 (none)
ipv6.token: –
proxy.method: none
proxy.browser-only: no
proxy.pac-url: –
proxy.pac-script: –
Activate connection details (95fcce7f-0ed7-3424-87a0-65212a1a57ee)
GENERAL.NAME: Wired connection 1
GENERAL.UUID: 95fcce7f-0ed7-3424-87a0-65212a1a57ee
GENERAL.DEVICES: enp3s0
GENERAL.IP-IFACE: enp3s0
GENERAL.STATE: activated
GENERAL.DEFAULT: yes
GENERAL.DEFAULT6: no
GENERAL.SPEC-OBJECT: –
GENERAL.VPN: no
GENERAL.DBUS-PATH: /org/freedesktop/NetworkManager/ActiveConnection/3
GENERAL.CON-PATH: /org/freedesktop/NetworkManager/Settings/1
GENERAL.ZONE: –
GENERAL.MASTER-PATH: –
