I wanted to update my system, but I always got “error pgp key”, so I edited the file /etc/pacman.conf with a siglevel = Never. After rebooting I’m stuck at login: I type the correct password but after a little loading sign, the login is always there.
I tried to update by mounting the system from a live version and using chroot, but nothing to do. What else could I do?
so did you run update after you edited the etc/pacman.conf?
Yes, I knew it’s risky, but there were no way otherwise to update
so its something related to the update not the editing the conf…
in the login screen enter (if you can) TTY, press ctrl+alt+f2 or f1-f6, enter your username/password and type:
startx
and post picture of it
I posted the output here: [user@user-pc]$startxX.Org X Server 1.21.1.7X Protocol Version 11, Reuision - Pastebin.com
there is this:
startplasma-x11: error while loading shared libraries: libKF5Notifications.so.5: cannot open shared object fIle: No such file or directory
probably something got messed up during update…
also run this:
sudo ldconfig
if it returns nothing, as it should, proceed with reinstallation of the broken library:
reinstall it + its dependecies, and just in case use overwrite:
sudo pacman -S libcanberra libdbusmenu-qt5 kwindowsystem kconfig kcoreaddons qt5-speech libxtst --overwrite '*'
reboot:
systemctl reboot
Sorry for the delayed response. I tried what you wrote, but it didn’t solve. After rebooting the problem is still there and startx reports always the problem with libkf5notifications
so first thing is, rerun update again:
sudo pacman-mirrors --fasttrack 5 && sudo pacman -Syyu
are you up to date?
Yes, by tty2 I executed these commands and everything is up to date
so you can try the last option, and reinstall everything, its little drastic, but i dont know what else to try since it is still complaining about the k5notifications…:
sudo pacman -Qqn | sudo pacman --overwrite=* -S -
reboot
I just did that, but nothing to do. I also removed plasma with all its dependcies and reinstalled it, but the problem is always there. Isn’t there anything else I could try?
what do you mean with nothing to do?
this command reinstalled every package you have and it did with overwrite, to get rid of some exist in filesystem, some ldconfig issues etc…
boot into manjaro live usb, make sure you are connected to internet, open terminal and chroot:
manjaro-chroot -a
and post output from:
mhwd-kernel -li && mhwd -l -li
ls /etc/modprobe.d
find /etc/X11/ -name "*.conf"
and logs from the failed boot:
journalctl -b-1 -p4 --no-pager
I meant that I run that command but the problem is still there, but I really can’t figure out why, since as you said every package should have been reinstalled.
The outputs are:
`[manjaro /]# mhwd-kernel -li && mhwd -l -li
Currently running: 5.10.36-2-MANJARO (linux510)
- linux510
- linux54
- linux60
- linux61
Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-broadcom-wl 2018.10.07 true PCI
network-r8168 2016.04.20 true PCI
0000:00:02.0 (0300:8086:0166) Display controller Intel Corporation:
video-modesetting 2020.01.13 true PCI
video-vesa 2017.03.12 true PCI
0000:03:00.2 (0200:10ec:8168) Network controller Realtek Semiconductor Co., Ltd.:
[manjaro /]# ls /etc/modprobe.d/ hp.conf iwlwifi.conf nobeep.conf r8169_blacklist.conf ralink-bt.conf
` [manjaro /]# journalctl -b-1 -p4 --no-pager
Feb 20 00:01:02 user-pc kernel: MDS CPU bug present and SMT on, data leak possible. See MDS - Microarchitectural Data Sampling — The Linux Kernel documentation for more details.
Feb 20 00:01:02 user-pc kernel: #3
Feb 20 00:01:02 user-pc kernel: ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
Feb 20 00:01:02 user-pc kernel: ata1.00: supports DRM functions and may not be fully accessible
Feb 20 00:01:02 user-pc kernel: vboxdrv: loading out-of-tree module taints kernel.
Feb 20 00:01:02 user-pc kernel: VBoxNetAdp: Successfully started.
Feb 20 00:01:02 user-pc kernel: VBoxNetFlt: Successfully started.
Feb 20 00:01:03 user-pc kernel: ACPI Warning: SystemIO range 0x0000000000000428-0x000000000000042F conflicts with OpRegion 0x0000000000000400-0x000000000000047F (\PMIO) (20220331/utaddress-204)
Feb 20 00:01:03 user-pc kernel: ACPI Warning: SystemIO range 0x0000000000000540-0x000000000000054F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
Feb 20 00:01:03 user-pc kernel: ACPI Warning: SystemIO range 0x0000000000000530-0x000000000000053F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
Feb 20 00:01:03 user-pc kernel: ACPI Warning: SystemIO range 0x0000000000000500-0x000000000000052F conflicts with OpRegion 0x0000000000000500-0x0000000000000563 (\GPIO) (20220331/utaddress-204)
Feb 20 00:01:03 user-pc kernel: lpc_ich: Resource conflict(s) found affecting gpio_ich
Feb 20 00:01:04 user-pc kernel: iwlwifi 0000:02:00.0: iwlmvm doesn’t allow to disable HW crypto, check swcrypto module parameter
Feb 20 00:01:04 user-pc kernel: iwlwifi 0000:02:00.0: iwlmvm doesn’t allow to disable BT Coex, check bt_coex_active module parameter
Feb 20 00:01:05 user-pc systemd-udevd[335]: cfg80211: Process ‘/usr/bin/set-wireless-regdom’ failed with exit code 1.
Feb 20 00:01:05 user-pc kernel: at24 7-0050: supply vcc not found, using dummy regulator
Feb 20 00:01:05 user-pc dhcpcd[729]: no valid interfaces found
Feb 20 00:01:05 user-pc systemd-udevd[351]: video4linux: Process ‘/usr/lib/snapd/snap-device-helper add snap_brave_brave /class/video4linux 0:0’ failed with exit code 1.
Feb 20 00:01:05 user-pc systemd-udevd[351]: video4linux: Process ‘/usr/lib/snapd/snap-device-helper add snap_discord_discord /class/video4linux 0:0’ failed with exit code 1.
Feb 20 00:01:05 user-pc systemd-udevd[351]: video4linux: Process ‘/usr/lib/snapd/snap-device-helper add snap_telegram-desktop_telegram-desktop /class/video4linux 0:0’ failed with exit code 1.
Feb 20 00:01:05 user-pc libvirtd[803]: Libvirt doesn’t support VirtualBox API version 7000006
Feb 20 00:01:05 user-pc systemd[862]: ConfigurationDirectory ‘bluetooth’ already exists but the mode is different. (File system: 755 ConfigurationDirectoryMode: 555)
Feb 20 00:01:05 user-pc bluetoothd[862]: src/main.c:check_config() Unknown group Controller in /etc/bluetooth/main.conf
Feb 20 00:01:06 user-pc bluetoothd[862]: profiles/audio/vcp.c:vcp_init() D-Bus experimental not enabled
Feb 20 00:01:06 user-pc bluetoothd[862]: src/plugin.c:plugin_init() Failed to init vcp plugin
Feb 20 00:01:06 user-pc bluetoothd[862]: profiles/audio/mcp.c:mcp_init() D-Bus experimental not enabled
Feb 20 00:01:06 user-pc bluetoothd[862]: src/plugin.c:plugin_init() Failed to init mcp plugin
Feb 20 00:01:06 user-pc bluetoothd[862]: profiles/audio/bap.c:bap_init() D-Bus experimental not enabled
Feb 20 00:01:06 user-pc bluetoothd[862]: src/plugin.c:plugin_init() Failed to init bap plugin
Feb 20 00:01:06 user-pc bluetoothd[862]: Failed to set mode: Not Supported (0x0c)
Feb 20 00:01:06 user-pc kernel: rtsx_pci 0000:03:00.0: VPD access failed. This is likely a firmware bug on this device. Contact the card vendor for a firmware update
Feb 20 00:01:07 user-pc sddm-helper[1400]: gkr-pam: no password is available for user
Feb 20 00:01:07 user-pc kernel: kauditd_printk_skb: 55 callbacks suppressed
Feb 20 00:01:07 user-pc s ystemd-xdg-autostart-generator[1411]: Failed to open configuration file ‘/home/user/.config/autostart/mailspring_mailspring.desktop’: Permission denied
Feb 20 00:01:07 user-pc systemd-xdg-autostart-generator[1411]: Failed to parse /home/user/.config/autostart/mailspring_mailspring.desktop, ignoring it
Feb 20 00:01:07 user-pc systemd-xdg-autostart-generator[1411]: /etc/xdg/autostart/octopi-notifier.desktop:12: Unknown key name ‘SingleMainWindow’ in section ‘Desktop Entry’, ignoring.
Feb 20 00:01:08 user-pc systemd[1405]: xdg-user-dirs-update.service: Failed with result ‘exit-code’.
Feb 20 00:01:08 user-pc systemd[1405]: Failed to start Update XDG user dir configuration.
Feb 20 00:01:08 user-pc sddm-helper[1400]: gkr-pam: couldn’t unlock the login keyring.
Feb 20 00:01:08 user-pc sddm[809]: Auth: sddm-helper exited with 127
Feb 20 00:01:10 user-pc sddm[809]: The configured theme “Breeze” doesn’t exist, using the embedded theme instead
Feb 20 00:01:10 user-pc systemd-xdg-autostart-generator[1458]: /etc/xdg/autostart/octopi-notifier.desktop:12: Unknown key name ‘SingleMainWindow’ in section ‘Desktop Entry’, ignoring.
Feb 20 00:01:11 user-pc sddm-greeter[1461]: file:///usr/lib/qt/qml/SddmComponents/LayoutBox.qml:35:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Feb 20 00:01:11 user-pc sddm-greeter[1461]: qrc:/theme/Main.qml:41:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Feb 20 00:01:15 user-pc kernel: kauditd_printk_skb: 20 callbacks suppressed
Feb 20 00:01:16 user-pc sddm-helper[1474]: pam_kwallet5(sddm:session): pam_kwallet5: Impossible to write walletKey to walletPipe
Feb 20 00:01:16 user-pc sddm[809]: Auth: sddm-helper exited with 127
Feb 20 00:01:17 user-pc sddm[809]: The configured theme “Breeze” doesn’t exist, using the embedded theme instead
Feb 20 00:01:17 user-pc sddm-greeter[1504]: file:///usr/lib/qt/qml/SddmComponents/LayoutBox.qml:35:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Feb 20 00:01:17 user-pc sddm-greeter[1504]: qrc:/theme/Main.qml:41:5: QML Connections: Implicitly defined onFoo properties in Connections are deprecated. Use this syntax instead: function onFoo() { … }
Feb 20 00:01:24 user-pc kernel: kauditd_printk_skb: 6 callbacks suppressed
Feb 20 00:01:33 user-pc systemd-xdg-autostart-generator[1547]: Failed to open configuration file ‘/home/user/.config/autostart/mailspring_mailspring.desktop’: Permission denied
Feb 20 00:01:33 user-pc systemd-xdg-autostart-generator[1547]: Failed to parse /home/user/.config/autostart/mailspring_mailspring.desktop, ignoring it
Feb 20 00:01:33 user-pc systemd-xdg-autostart-generator[1547]: /etc/xdg/autostart/octopi-notifier.desktop:12: Unknown key name ‘SingleMainWindow’ in section ‘Desktop Entry’, ignoring.
Feb 20 00:01:33 user-pc systemd[1541]: xdg-user-dirs-update.service: Failed with result ‘exit-code’.
Feb 20 00:01:33 user-pc systemd[1541]: Failed to start Update XDG user dir configuration.
Feb 20 00:01:34 user-pc NetworkManager[762]: [1676847694.3841] device (wlp2s0): no secrets: No agents were available for this request.
Feb 20 00:01:34 user-pc NetworkManager[762]: [1676847694.3853] device (wlp2s0): Activation: failed for connection ‘scrufulicchio 5’
Feb 20 00:01:34 user-pc NetworkManager[762]: [1676847694.4342] device (wlp2s0): no secrets: No agents were available for this request.
Feb 20 00:01:34 user-pc NetworkManager[762]: [1676847694.4355] device (wlp2s0): Activation: failed for connection ‘scrufulicchio’
Feb 20 00:01:34 user-pc NetworkManager[762]: [1676847694.4977] device (wlp2s0): no secrets: No agents were available for this request.
Feb 20 00:01:34 user-pc NetworkManager[762]: [1676847694.4989] device (wlp2s0): Activation: failed for connection ‘DIRECT-07-HP ENVY Photo 6200’
Feb 20 00:01:34
user-pc NetworkManager[762]: [1676847694.5440] device (wlp2s0): no secrets: No agents were available for this request.
Feb 20 00:01:34 user-pc NetworkManager[762]: [1676847694.5452] device (wlp2s0): Activation: failed for connection ‘Mio’
Feb 20 00:03:05 user-pc kernel: kauditd_printk_skb: 10 callbacks suppressed
Feb 20 00:24:11 user-pc sddm-helper[1503]: Signal received: SIGTERM
Feb 20 00:24:11 user-pc sddm[809]: Error from greeter session: “Process crashed”
Feb 20 00:24:11 user-pc sddm[809]: Auth: sddm-helper (–socket /tmp/sddm-autheb67c1a0-75e4-4448-8495-a9db98dc153e --id 5 --start /usr/bin/sddm-greeter --socket /tmp/sddm-:0-cYQOLk --user sddm --greeter) crashed (exit code 1)
Feb 20 00:24:11 user-pc sddm[809]: Auth: sddm-helper exited with 1
Feb 20 00:24:11 user-pc sddm[809]: Signal received: SIGTERM
Feb 20 00:24:13 user-pc systemd[1]: run-credentials-systemd\x2dtmpfiles\x2dsetup.service.mount: Failed with result ‘exit-code’.
Feb 20 00:24:15 user-pc kernel: watchdog: watchdog0: watchdog did not stop!
you have 4 kernels installed, did you tried booting with them all?
