Loooooong boot and blinking cursor terminal
Hi there,
For some time now, my laptop has been taking a long time to boot up, and there’s this strange terminal with a blinking cursor for about 80% of that time.
How can I fix this ? I have 0 ideas how to
  Kernel: 6.6.46-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: hpet avail: acpi_pm
    root=UUID=561bd575-fc83-4aac-b59f-0b43df48b740 rw quiet apparmor=1
  Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
    with: xfce4-panel tools: light-locker vt: 7 dm: LightDM v: 1.32.0
  Type: Laptop System: LENOVO product: 81H1 v: Lenovo ideapad 530S-14ARR
    serial: <superuser required> Chassis: type: 10 v: Lenovo ideapad 530S-14ARR
  Mobo: LENOVO model: LNVNB161216 v: SDK0J40709 WIN
    part-nu: LENOVO_MT_81H1_BU_idea_FM_ideapad 530S-14ARR
    uuid: <superuser required> UEFI: LENOVO v: 8PCN45WW date: 08/17/2018
  ID-1: BAT0 charge: 16.4 Wh (65.3%) condition: 25.1/45.5 Wh (55.2%)
    power: 24.4 W volts: 8.5 min: 7.6 model: SANYO L17C4PB0 type: Li-poly
    serial: <filter> status: charging
  Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M560
    status: discharging
  Info: model: AMD Ryzen 7 2700U with Radeon Vega Mobile Gfx bits: 64
    type: MT MCP arch: Zen level: v3 note: check built: 2017-19 process: GF 14nm
    family: 0x17 (23) model-id: 0x11 (17) stepping: 0 microcode: 0x810100B
    L1: 384 KiB desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB
    desc: 1x4 MiB
  Speed (MHz): avg: 1547 high: 1878 min/max: 1600/2200 boost: enabled
    scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 1359 2: 1641
    3: 1878 4: 1600 5: 1331 6: 1600 7: 1600 8: 1368 bogomips: 35148
  Type: retbleed mitigation: untrained return thunk; SMT vulnerable
  Device-1: AMD Raven Ridge [Radeon Vega Series / Radeon Mobile Series]
    vendor: Lenovo driver: amdgpu v: kernel arch: GCN-5 code: Vega
    process: GF 14nm built: 2017-20 pcie: gen: 3 speed: 8 GT/s lanes: 16 ports:
    active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:15dd
    class-ID: 0300 temp: 69.0 C
  Device-2: IMC Networks Integrated Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2:2 chip-ID: 13d3:56b2
    class-ID: 0e02
  Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
    X: loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa dri: radeonsi
    gpu: amdgpu display-ID: :0.0 screens: 1
    s-diag: 582mm (22.93")
  Monitor-1: eDP-1 mapped: eDP model: AU Optronics 0x403d built: 2016
    res: 1920x1080 hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81")
    diag: 354mm (13.9") ratio: 16:9 modes: max: 1920x1080 min: 640x480
  API: OpenGL Message: Unable to show GL data. glxinfo is missing.
  Device-1: AMD Raven/Raven2/Fenghuang HDMI/DP Audio vendor: Lenovo
    bus-ID: 03:00.1 chip-ID: 1002:15de class-ID: 0403
  Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: Lenovo
    driver: snd_pci_acp3x v: kernel alternate: snd_rn_pci_acp3x, snd_pci_acp5x,
    snd_pci_acp6x, snd_acp_pci, snd_rpl_pci_acp6x, snd_pci_ps,
    snd_sof_amd_renoir, snd_sof_amd_rembrandt, snd_sof_amd_vangogh pcie: gen: 3
    speed: 8 GT/s lanes: 16 bus-ID: 03:00.5 chip-ID: 1022:15e2 class-ID: 0480
  Device-3: AMD Family 17h/19h HD Audio vendor: Lenovo driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 03:00.6
    chip-ID: 1022:15e3 class-ID: 0403
  API: ALSA v: k6.6.46-1-MANJARO status: kernel-api with: aoss
  Server-1: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin tools: pactl,pw-cat,pw-cli,wpctl
  Device-1: Qualcomm Atheros QCA9377 802.11ac Wireless Network Adapter
    vendor: Lenovo driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 bus-ID: 01:00.0 chip-ID: 168c:0042 class-ID: 0280
  Device-1: Qualcomm Atheros driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-4:3 chip-ID: 0cf3:e500
    class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 3 state: down bt-service: enabled,running
  Local Storage: total: 476.94 GiB used: 94.19 GiB (19.7%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
    SDAPMUW-512G-1101 size: 476.94 GiB block-size: physical: 512 B
    logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
    fw-rev: 20210001 temp: 44.9 C scheme: GPT
  ID-1: / raw-size: 476.64 GiB size: 468.09 GiB (98.21%)
    used: 94.19 GiB (20.1%) fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
    used: 312 KiB (0.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 66.8 C mobo: N/A gpu: amdgpu temp: 66.0 C
  Fan Speeds (rpm): N/A
  Memory: total: 8 GiB note: est. available: 7.31 GiB used: 2.12 GiB (29.0%)
  Processes: 270 Power: uptime: 8m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 2.91 GiB services: upowerd,xfce4-power-manager
    Init: systemd v: 256 default: graphical tool: systemctl
  Packages: pm: pacman pkgs: 1729 libs: 432 tools: pamac,trizen,yay
    pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 alt: 13 Shell: Bash
    v: 5.2.32 running-in: xfce4-terminal inxi: 3.3.35
Yes, I already checked some other post but none of them helped me. Did I miss something ?
Thanks in advance !
Run systemd-analyze blame to see the ranking of slower processes and copy here the output.
Switch between Wayland and X11 could maybe help.
Sorry for the delay, been distracted. Do you have quiet and splash in your cmdline in etc/default/grub? … if so, I suggest removing those, then update GRUB.
That way you will at least have a chance to see messages during the boot process.
Also: systemd-analyze blame may be helpful, along with journalctl -p err -b.
