I have a vcf file with all contacts from my mobile.
I have try many apps from aur and also win apps but no one helps me.
Anyone have use similar app?
Thanks in advance
You can open them in any text editor, they’re just a few ASCII lines. What do you want to do with them? You can import them in programs like Thunderbird.
As Yochanan said, you can open them in any text editor. If you want a contacts management app, you can try these:
https://wiki.archlinux.org/index.php/List_of_applications#Contacts_management
I just use Thunderbird.
Finally imported by Thunderbird but displays
And must edit all over from 0
I try to find some program to making easier.
Anyway i make it manually.
Thanks for your help!
