I am running Manjaro MATE on a RPI4, and need to find to an HTML/WYSIWYG editor to maintain a website. Options I have found (for example KompoZer) do not appear to be available for ARM.
Any suggestions would be appreciated.
Bluefish is available. Not sure if it fits your requirements though.
Thanks. I’ll check it out.
I think the closest thing is GitHub - brackets-cont/brackets: An open source code editor for the web, written in JavaScript, HTML and CSS.
However any package you find will be probably the old Adobe version that is now discontinued.
Thanks for the suggestion. I tried to install from AUR, but the script downloads the x64 version from github. Compilation from source is a bit beyond my capabilites. I’ll stick with Bluefish.
