I’m looking for something like iTunes version 5, where you have a relatively simple list, but also the ability to filter by genre, artist, etc. iTunes did this really well in the old days, before it got so insanely bloated.
I found a few decently good music players/organizers, but I haven’t been able to find one with that kind of simple filter UI. It’s hard to describe it well, and I can’t find good pictures of it online. It was a drop-down on the main iTunes screen, and there aren’t a ton of screenshots of it. It was easier to use than trying to find your desired artist/album in the long list.
The best screenshot I was able to locate is:
is (dot) gd (slash) HL4eYP
Full (obfsucated) URL for those who are skittish about URL shorteners:
www (dot) blogcdn (dot) com (slash) www (dot) tuaw (dot) com (slash) media (slash) 2006 (slash) 09 (slash) itunes6 (dot) jpg
I’m just gonna go the other way and say cmus because its glorious.
But what you are describing sounds … sadly … a bit like rhythmbox.
(…I cant get my partner off of it either)
Close to that … but QT and more minimal … is qoob.
And if you want an uncluttered-but-abit-like-winamp sort of modular player then deadbeef is great.
My understanding is that I don’t have permissions to post links. I haven’t tried it though.
Clementine works pretty well, although at 218MiB of RAM, I wouldn’t quite call it lightweight.
BUT, the organization is decent. I’ll try it for a while.
No … theres technically nothing wrong with it.
Just feels a bit stale to me (too heavy for my tastes…but not actually all that heavy), and its GTK
(which isnt a big deal … but on a QT desktop I kinda try to favor QT apps)
If you want lightweight then mpd + ncmpcpp is great, and I think ncmpcpp can do everything you’re describing. But if cmus is too terminal-y for you then you probably wouldn’t like it.
