had to create a bootble USB stick for a Mac and now I am loookin for a programme to do it. It’s a .dmg file btw.
Now surprisingly I found out lately that RUFUS on windows is actually doing a good job. So I have this on windows, and now looking for sth. on Manjaro.
Finally I cloned balena etcher and built it via the pamac GUI. seems to work, it’s still creating the stick…
But my question now: I found there is quite a lot of sooftware by DEEPIN Linux. Can I use that on KDE / Manjaro? Or do I get funny and buggy libraries all over?
Which os do you need to make a bootable stick of? linux stick for mac-machine or vice-versa?
Making a bootable stick has nothing to do with macOS. But if you are looking for something to make a bootable stick scecific for a macbook (assuming making a bootable stick from windows or linux didn’t work), then i’m afraid there’s nothing you can do on a non-macbook. Instead give your friend instructions for it.
