Long wait time at shutdown
Hi there,
I recently had the following problem. When shutting down, only a blinking cursor remains for a long time until the PC finally shuts down.
Use the latest Manjaro Gnome
Maybe someone can help me there. :thinking:
Here are the last line sof the of the journalctl:
Jan 18 21:48:49 stefan-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-monitor comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
Jan 18 21:48:49 stefan-laptop systemd[1]: Stopping LVM2 metadata daemon...
Jan 18 21:48:49 stefan-laptop systemd[1]: lvm2-lvmetad.service: Succeeded.
Jan 18 21:48:49 stefan-laptop systemd[1]: Stopped LVM2 metadata daemon.
Jan 18 21:48:49 stefan-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=lvm2-lvmetad comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal=?>
Jan 18 21:48:49 stefan-laptop systemd[1]: Reached target Shutdown.
Jan 18 21:48:49 stefan-laptop systemd[1]: Reached target Final Step.
Jan 18 21:48:49 stefan-laptop systemd[1]: lvm2-lvmetad.socket: Succeeded.
Jan 18 21:48:49 stefan-laptop systemd[1]: Closed LVM2 metadata daemon socket.
Jan 18 21:48:49 stefan-laptop systemd[1]: systemd-reboot.service: Succeeded.
Jan 18 21:48:49 stefan-laptop systemd[1]: Finished Reboot.
Jan 18 21:48:49 stefan-laptop audit[1]: SERVICE_START pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? termina>
Jan 18 21:48:49 stefan-laptop audit[1]: SERVICE_STOP pid=1 uid=0 auid=4294967295 ses=4294967295 subj==unconfined msg='unit=systemd-reboot comm="systemd" exe="/usr/lib/systemd/systemd" hostname=? addr=? terminal>
Jan 18 21:48:49 stefan-laptop systemd[1]: Reached target Reboot.
Jan 18 21:48:49 stefan-laptop systemd[1]: Shutting down.
Jan 18 21:48:49 stefan-laptop systemd[1]: Using hardware watchdog 'wdat_wdt', version 0, device /dev/watchdog
Jan 18 21:48:49 stefan-laptop systemd[1]: Set hardware watchdog to 10min.
Jan 18 21:48:49 stefan-laptop kernel: watchdog: watchdog0: watchdog did not stop!
Jan 18 21:48:49 stefan-laptop systemd-shutdown[1]: Syncing filesystems and block devices.
Jan 18 21:48:49 stefan-laptop systemd-shutdown[1]: Sending SIGTERM to remaining processes...
Jan 18 21:48:49 stefan-laptop haveged[293]: haveged: Stopping due to signal 15
Jan 18 21:48:49 stefan-laptop haveged[293]: haveged starting up
Jan 18 21:48:49 stefan-laptop systemd-journald[294]: Journal stopped
Related to this?
There is a workaround fix in the update announcement thread that you can follow.
This was mentioned in last stable announcement:
Oh my mistake.
I haven’t read that.
Thank you that solved the problem.
