Long shut down (~3 min) and reboot, plus boot problems
I have a mutli–boot PC with Windows, Manjaro and a few other Linux distros, but Manjaro KDE has been my main OS for 2 or 3 years. In the last six months or so two problems have shown up, which combine to make things really frustrating.
Problem 1: Intermittantly, Manjaro KDE doesn’t boot fully. The clock widget I have on my home screen is always displayed, but sometimes it’s just there alone on a black screen. Sometimes the desktop image is displayed (with the clock widget) but no task bar at the bottom of the screen and therefore no way to access applications. And sometimes it boots fully and then works just fine. In all cases, ctrl-alt-del will take me to the screen where there is a log-out, reboot, or shut-down choice, so I can reboot and try again. So far, it has always eventually booted OK, but sometime only on the fourth try. Which gets me to problem 2, which exaserbates the situation.
Problem 2. It is taking about 3 minutes for the system to shut down, including for the shutting down part of rebooting. (On reboot, once the system starts the booting-up part of the cycle, it goes quite quickly.) If I only had to experience this delay when I really wanted to shut down, it wouldn’t be so bad, but since I usually have to reboot a couple of times just to get started, it’s really annoying.
I’m hoping someone can help me.
I know you need more information about my system and I’m happy to provide it, but I’m not at all familiar with Linux commands and all the system reports or logs one can get so I’m afraid that I’m going to need someone to tell me what information to supply and how to get that info. My computer is an Asus desktop (- actually an under-the-desk tower). All the operating systems are installed on a 1Tb SSD so read/write should go quickly, and most of the data is a 2 Tb internal HDD (with movies, videos, music and backups stored on external HDDs.
Here is system information from Manjaro:
KDE Plasma Version: 5.22.4
KDE Frameworks Version: 5.85.0
Qt Version: 5.15.2
Kernel Version: 5.9.16-1-MANJARO (64-bit)
Graphics Platform: X11
Processors: 4 × AMD A10-7800 Radeon R7, 12 Compute Cores 4C+8G
Memory: 10.7 GiB of RAM
Graphics Processor: AMD KAVERI
Please let me know what other info you need.
Thanks very much in advance for any attempts to help and for your patience with me.
can you please report
under manjaro , open a terminal
 inxi -Fza
kernel 5.9 is EOL
Thanks stephane for your advice. Here is what I have just copied from my terminal:
[martin@Martin-Manjaro-Desktop ~]$ inxi -Fza
  Kernel: 5.9.16-1-MANJARO x86_64 bits: 64 compiler: gcc
  v: 10.2.0
  parameters: BOOT_IMAGE=/boot/vmlinuz-5.9-x86_64
  root=UUID=19429b29-fa52-4671-86a7-733968f2fe77 rw loglevel=3
  quiet
  Desktop: KDE Plasma 5.22.4 tk: Qt 5.15.2 wm: kwin_x11 vt: 1
  Type: Desktop System: ASUSTeK product: K30BF_M32BF_A_F_K31BF_6
  v: N/A serial: <filter>
  Mobo: ASUSTeK model: K30BF_M32BF_A_F_K31BF_6 v: Rev X.0x
  serial: <filter> UEFI: American Megatrends v: 0501
  date: 07/09/2015
  Device-1: hidpp_battery_0
  model: Logitech Wireless Mouse PID:003c serial: N/A
  charge: 55% (should be ignored) rechargeable: yes
  status: Discharging
  Device-2: hidpp_battery_1
  model: Logitech Wireless Keyboard PID:0060 serial: N/A
  charge: 70% (should be ignored) rechargeable: yes
  status: Discharging
  Device-3: hidpp_battery_2 model: Logitech Wireless Mouse M510
  serial: <filter> charge: 55% (should be ignored)
  rechargeable: yes status: Discharging
  Info: Quad Core
  model: AMD A10-7800 Radeon R7 12 Compute Cores 4C+8G bits: 64
  type: MCP arch: Steamroller family: 15 (21) model-id: 30 (48)
  stepping: 1 microcode: 6003106 cache: L2: 2 MiB
  flags: avx lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm bogomips: 27943
  Speed: 1396 MHz min/max: 1400/3500 MHz boost: enabled
  Core speeds (MHz): 1: 1396 2: 1390 3: 1389 4: 1396
  Type: spec_store_bypass mitigation: Speculative Store Bypass
  disabled via prctl and seccomp
  Type: spectre_v1 mitigation: usercopy/swapgs barriers and
  __user pointer sanitization
  Type: spectre_v2
  mitigation: Full AMD retpoline, STIBP: disabled, RSB filling
  Device-1: AMD Kaveri [Radeon R7 Graphics] vendor: ASUSTeK
  driver: radeon v: kernel alternate: amdgpu bus-ID: 00:01.0
  chip-ID: 1002:130f class-ID: 0300
  Device-2: Logitech Webcam C270 type: USB
  driver: snd-usb-audio,uvcvideo bus-ID: 3-5:5 chip-ID: 046d:0825
  class-ID: 0102 serial: <filter>
  loaded: ati,radeon unloaded: modesetting alternate: fbdev,vesa
  display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3840x2160 s-dpi: 96
  s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
  Monitor-1: HDMI-0 res: 3840x2160 hz: 30 dpi: 157
  size: 621x341mm (24.4x13.4") diag: 708mm (27.9")
  OpenGL:
  renderer: AMD KAVERI (DRM 2.50.0 5.9.16-1-MANJARO LLVM 12.0.1)
  v: 4.5 Mesa 21.1.6 direct render: Yes
  Device-1: AMD Kaveri HDMI/DP Audio vendor: ASUSTeK
  driver: snd_hda_intel v: kernel bus-ID: 00:01.1
  chip-ID: 1002:1308 class-ID: 0403
  Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus-ID: 00:14.2 chip-ID: 1022:780d class-ID: 0403
  Device-3: Logitech Webcam C270 type: USB
  Sound Server-1: ALSA v: k5.9.16-1-MANJARO running: yes
  Sound Server-4: PipeWire v: 0.3.33 running: yes
  Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK H81M-C driver: r8169 v: kernel port: e000
  bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full
  mac: <filter>
  Device-2: Realtek RTL8821AE 802.11ac PCIe Wireless Network
  Adapter
  vendor: AzureWave driver: rtl8821ae v: kernel port: d000
  bus-ID: 04:00.0 chip-ID: 10ec:8821 class-ID: 0280
  IF: wlp4s0 state: down mac: <filter>
  Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb
  v: 0.8 bus-ID: 5-3:2 chip-ID: 13d3:3414 class-ID: e001
  serial: <filter>
  Report: rfkill ID: hci0 rfk-id: 0 state: up
  address: see --recommends
  Local Storage: total: 9.1 TiB used: 5.73 TiB (62.9%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Toshiba model: DT01ACA200
  size: 1.82 TiB block-size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: ABS0
  scheme: GPT
  ID-2: /dev/sdb maj-min: 8:16 vendor: Crucial
  model: CT1000MX500SSD1 size: 931.51 GiB block-size:
  physical: 4096 B logical: 512 B speed: 6.0 Gb/s type: SSD
  serial: <filter> rev: 032 scheme: GPT
  ID-3: /dev/sdc maj-min: 8:32 type: USB vendor: Seagate
  model: Expansion Desk size: 2.73 TiB block-size:
  physical: 4096 B logical: 4096 B type: N/A serial: <filter>
  rev: 0734 scheme: MBR
  ID-4: /dev/sde maj-min: 8:64 type: USB model: 2.0 Flash Disk
  size: 3.76 GiB block-size: physical: 512 B logical: 512 B
  type: SSD serial: <filter> rev: 5.00 scheme: MBR
  SMART Message: Unknown USB bridge. Flash drive/Unsupported
  enclosure?
  ID-5: /dev/sdf maj-min: 8:80 type: USB vendor: Seagate
  model: ST3000DM001-9YN166 size: 2.73 TiB block-size:
  physical: 4096 B logical: 4096 B type: HDD rpm: 7200
  serial: <filter> rev: 0155 scheme: MBR
  ID-6: /dev/sdg maj-min: 8:96 type: USB vendor: Western Digital
  model: WD10EADS-00L5B1 size: 931.51 GiB block-size:
  physical: 512 B logical: 512 B type: N/A serial: <filter>
  scheme: GPT
  ID-1: / raw-size: 146.6 GiB size: 144.17 GiB (98.35%)
  used: 57.49 GiB (39.9%) fs: ext4 dev: /dev/sdb12 maj-min: 8:28
  ID-1: swap-1 type: partition size: 977 MiB
  used: 1024 KiB (0.1%) priority: -2 dev: /dev/sdb5 maj-min: 8:21
  System Temperatures: cpu: 5.9 C mobo: N/A gpu: radeon
  temp: 0.0 C
  Processes: 300 Uptime: 2h 45m wakeups: 12 Memory: 10.66 GiB
  used: 3 GiB (28.1%) Init: systemd v: 248 tool: systemctl
  Compilers: gcc: 11.1.0 clang: 12.0.1 Packages: 1762
  note: see --pkg apt: 0 pacman: 1756 lib: 476 flatpak: 6
  Shell: Bash v: 5.1.8 running-in: konsole inxi: 3.3.06
I don’t understand your last comment: “kernel 5.9 is EOL”
EOL means End of Life, it is no longer supported and you should upgrade to a newer version
Thanks. I just checked Kernel selection on System Setting and installed 5.13.11-1 and rebooted. But when I check the Settings Manager again, it shows 5.13 “installed” but 5.9.16-1 is still the one that’s “running”. What should I be doing to boot into 5.13?
Sorry I’m so clueless and really appreciate the advice.
can you return
sudo mhwd-kernel -li
sudo ls /etc/mkinitcpio.d/*.preset
you should have same number lines & version kernels
check also this return or any error
sudo mkinitcpio -P
Thank you Stephane. I entered all three commands and here is a copy from the terminal. I noticed some ERROR messages but don’t really understand them.
[martin@Martin-Manjaro-Desktop ~]$ sudo mhwd-kernel -li
[sudo] password for martin:
Currently running: 5.9.16-1-MANJARO (linux59)
  • linux510
  • linux511
  • linux513
  • linux59
    [martin@Martin-Manjaro-Desktop ~]$ sudo ls /etc/mkinitcpio.d/*.preset
    /etc/mkinitcpio.d/linux510.preset /etc/mkinitcpio.d/linux57.preset
    /etc/mkinitcpio.d/linux511.preset /etc/mkinitcpio.d/linux58.preset
    /etc/mkinitcpio.d/linux513.preset /etc/mkinitcpio.d/linux59.preset
    [martin@Martin-Manjaro-Desktop ~]$ sudo mkinitcpio -P
    ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘default’
    → -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64.img
    ==> Starting build: 5.10.59-1-MANJARO
    → Running build hook: [base]
    → Running build hook: [udev]
    → Running build hook: [autodetect]
    → Running build hook: [modconf]
    → Running build hook: [block]
    → Running build hook: [keyboard]
    → Running build hook: [keymap]
    → Running build hook: [filesystems]
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64.img
    ==> Building image from preset: /etc/mkinitcpio.d/linux510.preset: ‘fallback’
    → -k /boot/vmlinuz-5.10-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.10-x86_64-fallback.img -S autodetect
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.10-x86_64-fallback.img
    ==> Building image from preset: /etc/mkinitcpio.d/linux511.preset: ‘default’
    → -k /boot/vmlinuz-5.11-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.11-x86_64.img
    ==> Starting build: 5.11.22-2-MANJARO
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.11-x86_64.img
    ==> Building image from preset: /etc/mkinitcpio.d/linux511.preset: ‘fallback’
    → -k /boot/vmlinuz-5.11-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.11-x86_64-fallback.img -S autodetect
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.11-x86_64-fallback.img
    ==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: ‘default’
    → -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64.img
    ==> Starting build: 5.13.11-1-MANJARO
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64.img
    ==> Building image from preset: /etc/mkinitcpio.d/linux513.preset: ‘fallback’
    → -k /boot/vmlinuz-5.13-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.13-x86_64-fallback.img -S autodetect
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.13-x86_64-fallback.img
    ==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: ‘default’
    → -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64.img
    ==> ERROR: ‘/lib/modules/5.7.19-2-MANJARO’ is not a valid kernel module directory
    ==> Building image from preset: /etc/mkinitcpio.d/linux57.preset: ‘fallback’
    → -k /boot/vmlinuz-5.7-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.7-x86_64-fallback.img -S autodetect
    ==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: ‘default’
    → -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64.img
    ==> ERROR: ‘/lib/modules/5.8.18-1-MANJARO’ is not a valid kernel module directory
    ==> Building image from preset: /etc/mkinitcpio.d/linux58.preset: ‘fallback’
    → -k /boot/vmlinuz-5.8-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.8-x86_64-fallback.img -S autodetect
    ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘default’
    → -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64.img
    ==> Starting build: 5.9.16-1-MANJARO
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64.img
    ==> Building image from preset: /etc/mkinitcpio.d/linux59.preset: ‘fallback’
    → -k /boot/vmlinuz-5.9-x86_64 -c /etc/mkinitcpio.conf -g /boot/initramfs-5.9-x86_64-fallback.img -S autodetect
    ==> Creating gzip-compressed initcpio image: /boot/initramfs-5.9-x86_64-fallback.img
you can boot to grub and choose which kernel to boot into over there. To get into grub, you can just hold “shift” or “escape” (1 of these usually works for most) during boot. Then in grub you can choose advanced boot options and you will see all options with kernel names listed. Choose the latest stable (5.13) or latest LTS (5.10) and boot.
Then, once you are in, you can open manjaro settings manager and remove the EOL kernels. If you don’t want the hassle of keeping your kernel updated this often, you can choose an LTS kernel. I think 5.10 is supposed to be the latest LTS.
you have to suppress these files
sudo rm /etc/mkinitcpio.d/linux57.preset
sudo rm /etc/mkinitcpio.d/linux58.preset
then
sudo mkinitcpio -P
update your Grub menu , change this line
GRUB_TIMEOUT_STYLE=menu
sudo nano /etc/default/grub
sudo update-grub
then reboot , you will change with
Grub > advanced > list kernels to choose
you should keep at end
version linux54 , linux510 and linux513
sudo mhwd-kernel -r linux59
sudo mhwd-kernel -r linux511
I’m not quite sure what you mean. Change the line to what? In my /etc/default/grub file, there already is the following line
GRUB_TIMEOUT_STYLE=“menu”
Should I just be removing the quotation marks around the word menu? That is what I have done. However, sudo update-grub returns the following error message
[martin@Martin-Manjaro-Desktop ~]$ sudo update-grub
/usr/bin/grub-probe: error while loading shared libraries: libzfs.so.2: cannot open shared object file: No such file or directory
I really appreciate your advice. Do you have any further suggestions?
Martin.
Thanks Audialche. Since I have a multi-boot system, it always goes into grub - or did you mean a different grub? Nevertheless, I rebooted a couple of times, first holding down the shift key all the way through and then again holding the escape key. In both cases, the boot went as it always had and I ended up with kernel 5.9 running. On the grub menu that I have, the “advanced options” are to run kernel 5.9 or 5.8 or 5.7, although neither of the last two choices work any more because I have removed kernels 5.7 and 5.8, following Stephane’s advice (just below your message.)
something odd , is there any errors after
sudo pacman-mirrors -c all
sudo pacman -Syyu
sudo mkinitcpio -P
There were no errors at the end, after running all three commands. There were intermittant errors while the first command was running and all the mirror sites were being listed. I don’t know whether those errors were significant. Here is the full “print-out” from my terminal:
[martin@Martin-Manjaro-Desktop ~]$ sudo pacman-mirrors -c all
::INFO => Mirror status: http://repo.manjaro.org/status.json
::INFO Using default mirror file
::INFO Querying mirrors - This may take some time
0.745 Australia : https://manjaro.lucassymons.net/
2.286 Australia : AARNet Mirror
1.213 Australia : AARNet Mirror
1.379 Austria : Index of /manjaro
… Austria : ftp://mirror.easyname.at/manjaro/
::ERROR ftp error: timeout(‘timed out’)
1.916 Bangladesh : Index of /manjaro/
1.255 Belarus : http://mirror.datacenter.by/pub/mirrors/manj
1.133 Belgium : Index of /manjaro
0.856 Belgium : Index of /manjaro
2.138 Brazil : https://manjaro.c3sl.ufpr.br/
2.416 Bulgaria : Index of /manjaro
1.706 Bulgaria : Index of /manjaro/
0.970 Bulgaria : Index of /manjaro/
… Bulgaria : ftps://mirror.telepoint.bg/manjaro/
::ERROR unknown url type: ftps
… Bulgaria : http://manjaro.telecoms.bg/
0.505 Canada : Index of /manjaro/
0.612 Canada : https://mirror.0xem.ma/manjaro/
0.621 Canada : http://mirror.0xem.ma/manjaro/
0.551 Canada : https://osmirror.org/manjaro/
1.502 Chile : http://manjaro.dcc.uchile.cl/
2.316 Chile : Index of /manjaro/
1.607 Chile : https://mirror1.cl.netactuate.com/manjaro/
… Chile : http://mirror1.cl.netactuate.com/manjaro/
… Chile : ftp://mirror1.cl.netactuate.com/manjaro/
1.869 China : https://mirrors.huaweicloud.com/manjaro/
0.939 China : http://mirrors.huaweicloud.com/manjaro/
0.437 China : https://mirrors.aliyun.com/manjaro/
1.970 China : Index of /manjaro/
1.774 China : https://mirrors.tuna.tsinghua.edu.cn/manjaro
1.177 China : https://mirrors.tuna.tsinghua.edu.cn/manjaro
2.435 China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/
2.439 Czech : Index of /manjaro/
1.357 Denmark : mirrors.dotsrc.org
1.272 Finland : https://manjaro.kyberorg.fi/
1.004 Finland : http://manjaro.kyberorg.fi/
1.242 France : https://manjaro.ynh.ovh/
1.379 France : Index of /mirrors/repo.manjaro.org
… France : ftp://ftp.free.org/mirrors/repo.manjaro.org/
1.883 Georgia : Index of /manjaro/
1.140 Georgia : Index of /manjaro/
1.291 Germany : Index of /manjaro/
1.577 Germany : https://manjaro.re/
0.910 Germany : http://manjaro.re/
1.580 Germany : Index of /pub/linux/manjaro/
0.876 Germany : Index of /pub/linux/manjaro/
… Germany : ftp://ftp.gwdg.de/pub/linux/manjaro/
1.272 Germany : https://mirror.atysleaks.org/manjaro/
1.482 Germany : http://mirror.atysleaks.org/manjaro/
1.378 Germany : Index of /manjaro/
0.871 Germany : Index of /manjaro/
1.389 Germany : Index of /manjaro
… Germany : ftp://ftp.halifax.rwth-aachen.de/manjaro/
0.976 Germany : FTP-Archivbrowser | FTP-Archiv ftp.tu-chemnitz.de | Anwendungen und Dienste | URZ | TU Chemnitz
… Germany : ftp://ftp.tu-chemnitz.de/pub/linux/manjaro/
::ERROR ftp error: ConnectionRefusedError(111, ‘Connection refused’)
1.344 Germany : Index of /manjaro/
1.128 Germany : https://manjaro.moson.eu/
0.867 Germany : http://manjaro.moson.eu/
1.065 Germany : https://manjaro.moson.org/
0.896 Germany : http://manjaro.moson.org/
0.295 Global : fossho.st
0.095 Global : fossho.st
0.445 Global : https://mirrors.manjaro.org/repo/
0.338 Global : http://mirrors.manjaro.org/repo/
1.597 Greece : ftp.cc.uoc.gr - University of Crete / Computer Center
1.153 Greece : ftp.cc.uoc.gr - University of Crete / Computer Center
… Greece : ftp://ftp.cc.uoc.gr/mirrors/linux/manjaro/
1.416 Hong_Kong : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/
… Hong_Kong : ftp://ftp.cuhk.edu.hk/pub/Linux/manjaro/
1.651 Hungary : https://quantum-mirror.hu/mirrors/pub/manjar
0.929 Hungary : Index of /mirrors/pub/manjaro/
1.552 Iceland : https://mirrors.opensource.is/manjaro/
1.580 Iceland : http://mirrors.opensource.is/manjaro/
… Iceland : ftp://mirrors.opensource.is/manjaro/
::ERROR ftp error: error_perm(‘550 Failed to change directory.’)
0.597 Indonesia : https://mirror.deace.id/manjaro/
0.736 Indonesia : http://mirror.deace.id/manjaro/
… Indonesia : http://kartolo.sby.datautama.net.id/manjaro/
2.490 Iran : https://repo.iut.ac.ir/repo/manjaro/
1.570 Iran : http://repo.iut.ac.ir/repo/manjaro/
1.887 Italy : https://manjaro.mirror.garr.it/manjaro/
2.448 Italy : https://ba.mirror.garr.it/mirrors/manjaro/
2.545 Italy : https://ct.mirror.garr.it/mirrors/manjaro/
0.676 Japan : http://ftp.riken.jp/Linux/manjaro/
… Japan : ftp://ftp.riken.jp/Linux/manjaro/
1.152 Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/
2.728 Kenya : https://manjaro.mirror.liquidtelecom.com/
1.620 Kenya : http://manjaro.mirror.liquidtelecom.com/
1.186 Netherlands : https://mirror.erickochen.nl/manjaro/
0.909 Netherlands : http://mirror.erickochen.nl/manjaro/
1.317 Netherlands : https://manjaro.mirrors.lavatech.top/
0.843 Netherlands : http://manjaro.mirrors.lavatech.top/
1.718 Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manj
… Netherlands : ftp://ftp.nluug.nl/pub/os/Linux/distr/manjar
0.805 Netherlands : http://ftp.snt.utwente.nl/pub/linux/manjaro/
… Netherlands : ftp://ftp.snt.utwente.nl/pub/linux/manjaro/
1.126 Netherlands : https://mirror.koddos.net/manjaro/
1.159 New_Zealand : http://manjaro.mirrors.theom.nz/
1.477 Norway : http://mirror.terrahost.no/linux/manjaro/
1.998 Pakistan : https://repo.inara.pk/manjaro/
1.438 Pakistan : http://repo.inara.pk/manjaro/
1.180 Philippines : http://mirror.rise.ph/manjaro/
… Philippines : ftp://mirror.rise.ph/manjaro/
1.549 Poland : https://repo.skni.umcs.pl/manjaro/
1.008 Poland : http://repo.skni.umcs.pl/manjaro/
0.921 Poland : http://ftp.vectranet.pl/manjaro/
… Poland : ftp://ftp.vectranet.pl/manjaro/
… Portugal : http://ftp.dei.uc.pt/pub/linux/manjaro/
1.319 Russia : https://mirror.yandex.ru/mirrors/manjaro/
1.965 Russia : https://mirror.truenetwork.ru/manjaro/
1.261 Russia : http://mirror.truenetwork.ru/manjaro/
1.677 Singapore : https://download.nus.edu.sg/mirror/manjaro/
… South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/
… South_Africa : http://manjaro.mirror.ac.za/
1.236 South_Korea : https://mirror.d-tl.com/manjaro/
1.972 Spain : https://ftp.caliu.cat/pub/distribucions/manj
0.977 Spain : http://ftp.caliu.cat/pub/distribucions/manja
1.405 Sweden : https://ftp.lysator.liu.se/pub/manjaro/
… Sweden : ftp://ftp.lysator.liu.se/pub/manjaro/
1.643 Sweden : https://mirror.zetup.net/manjaro/
1.518 Sweden : https://ftpmirror1.infania.net/mirror/manjar
0.928 Sweden : http://ftpmirror1.infania.net/mirror/manjaro
… Sweden : ftp://ftpmirror1.infania.net/mirror/manjaro/
1.264 Switzerland : https://manjaro.osmir.ch/
0.907 Switzerland : http://manjaro.osmir.ch/
1.231 Switzerland : https://mirror.init7.net/manjaro/
0.880 Switzerland : http://mirror.init7.net/manjaro/
1.289 Taiwan : http://free.nchc.org.tw/manjaro/
… Turkey : http://ftp.linux.org.tr/manjaro/
… Turkey : ftp://ftp.linux.org.tr/manjaro/
… Ukraine : http://mirrors.colocall.net/manjaro/
… Ukraine : ftp://mirrors.colocall.net/manjaro/
2.185 Ukraine : https://fastmirror.pp.ua/manjaro/
1.569 Ukraine : http://fastmirror.pp.ua/manjaro/
1.322 United_Kingdom : https://www.mirrorservice.org/sites/repo.man
0.727 United_Kingdom : http://manjaro.mirrors.uk2.net/
1.458 United_Kingdom : https://mirrors.gethosted.online/manjaro/rep
0.847 United_Kingdom : http://mirrors.gethosted.online/manjaro/repo
0.527 United_States : https://repo.ialab.dsu.edu/manjaro/
0.732 United_States : http://repo.ialab.dsu.edu/manjaro/
0.479 United_States : http://distro.ibiblio.org/manjaro/
0.555 United_States : https://mirrors.ocf.berkeley.edu/manjaro/
0.614 United_States : https://mirror.math.princeton.edu/pub/manjar
0.899 United_States : https://mirror.clarkson.edu/manjaro/
2.764 United_States : https://mirror.dacentec.com/manjaro/
0.542 United_States : https://mirrors.gigenet.com/manjaro/
0.334 United_States : http://mirrors.gigenet.com/manjaro/
0.468 United_States : https://mirrors.sonic.net/manjaro/
… Uruguay : https://manjaro.repo.cure.edu.uy/
1.146 Uruguay : http://manjaro.repo.cure.edu.uy/
::INFO Writing mirror list
::Global : https://mirrors.fossho.st/manjaro/stable
::United_States : https://mirrors.gigenet.com/manjaro/stable
::Global : https://mirrors.manjaro.org/repo/stable
::China : https://mirrors.aliyun.com/manjaro/stable
::United_States : https://mirrors.sonic.net/manjaro/stable
::United_States : http://distro.ibiblio.org/manjaro/stable
::Canada : https://mirror.csclub.uwaterloo.ca/manjaro/stable
::Canada : https://osmirror.org/manjaro/stable
::United_States : https://mirrors.ocf.berkeley.edu/manjaro/stable
::United_States : https://mirror.math.princeton.edu/pub/manjaro/stabl
::Canada : https://mirror.0xem.ma/manjaro/stable
::United_Kingdom : http://manjaro.mirrors.uk2.net/stable
::United_States : https://repo.ialab.dsu.edu/manjaro/stable
::Indonesia : https://mirror.deace.id/manjaro/stable
::Australia : https://manjaro.lucassymons.net/stable
::Netherlands : https://manjaro.mirrors.lavatech.top/stable
::United_Kingdom : https://mirrors.gethosted.online/manjaro/repos/stab
::Belgium : https://mirror.futureweb.be/manjaro/stable
::Germany : https://manjaro.moson.eu/stable
::Germany : https://mirror.23media.com/manjaro/stable
::Switzerland : https://mirror.init7.net/manjaro/stable
::Germany : https://manjaro.moson.org/stable
::United_States : https://mirror.clarkson.edu/manjaro/stable
::Switzerland : https://manjaro.osmir.ch/stable
::Netherlands : https://mirror.erickochen.nl/manjaro/stable
::Germany : https://manjaro.re/stable
::Hungary : https://quantum-mirror.hu/mirrors/pub/manjaro/stabl
::China : https://mirrors.huaweicloud.com/manjaro/stable
::Bulgaria : https://mirror.telepoint.bg/manjaro/stable
::Spain : https://ftp.caliu.cat/pub/distribucions/manjaro/sta
::Finland : https://manjaro.kyberorg.fi/stable
::Poland : https://repo.skni.umcs.pl/manjaro/stable
::Netherlands : https://mirror.koddos.net/manjaro/stable
::Georgia : https://repos.silknet.com/manjaro/stable
::Uruguay : https://manjaro.repo.cure.edu.uy/stable
::Japan : http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable
::New_Zealand : http://manjaro.mirrors.theom.nz/stable
::China : https://mirrors.tuna.tsinghua.edu.cn/manjaro/stable
::Australia : https://mirror.aarnet.edu.au/pub/manjaro/stable
::South_Korea : https://mirror.d-tl.com/manjaro/stable
::France : https://manjaro.ynh.ovh/stable
::Belarus : http://mirror.datacenter.by/pub/mirrors/manjaro/sta
::Russia : https://mirror.truenetwork.ru/manjaro/stable
::Taiwan : http://free.nchc.org.tw/manjaro/stable
::Germany : https://mirror.alpix.eu/manjaro/stable
::Russia : https://mirror.yandex.ru/mirrors/manjaro/stable
::United_Kingdom : https://www.mirrorservice.org/sites/repo.manjaro.or
::Germany : https://mirror.netcologne.de/manjaro/stable
::Denmark : https://mirrors.dotsrc.org/manjaro/stable
::Pakistan : https://repo.inara.pk/manjaro/stable
::Norway : http://mirror.terrahost.no/linux/manjaro/stable
::Germany : https://mirror.atysleaks.org/manjaro/stable
::Chile : http://manjaro.dcc.uchile.cl/stable
::Ukraine : https://fastmirror.pp.ua/manjaro/stable
::Iran : https://repo.iut.ac.ir/repo/manjaro/stable
::Kenya : https://manjaro.mirror.liquidtelecom.com/stable
::Sweden : https://mirror.zetup.net/manjaro/stable
::Singapore : https://download.nus.edu.sg/mirror/manjaro/stable
::Italy : https://manjaro.mirror.garr.it/manjaro/stable
::Bangladesh : http://mirror.xeonbd.com/manjaro/stable
::China : https://mirrors.ustc.edu.cn/manjaro/stable
::Netherlands : http://ftp.snt.utwente.nl/pub/linux/manjaro/stable
::Brazil : https://manjaro.c3sl.ufpr.br/stable
::Japan : http://ftp.riken.jp/Linux/manjaro/stable
::Germany : https://ftp.gwdg.de/pub/linux/manjaro/stable
::Sweden : https://ftpmirror1.infania.net/mirror/manjaro/stabl
::Germany : https://ftp.halifax.rwth-aachen.de/manjaro/stable
::Chile : https://mirror.ufro.cl/manjaro/stable
::Poland : http://ftp.vectranet.pl/manjaro/stable
::Sweden : https://ftp.lysator.liu.se/pub/manjaro/stable
::France : http://ftp.free.org/mirrors/repo.manjaro.org/repos/
::Bulgaria : https://mirrors.netix.net/manjaro/stable
::China : https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable
::Czech : https://mirror.dkm.cz/manjaro/stable
::Italy : https://ba.mirror.garr.it/mirrors/manjaro/stable
::Chile : https://mirror1.cl.netactuate.com/manjaro/stable
::South_Africa : http://mirror.is.co.za/mirrors/manjaro.org/stable
::Italy : https://ct.mirror.garr.it/mirrors/manjaro/stable
::South_Africa : http://manjaro.mirror.ac.za/stable
::Netherlands : https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/sta
::Greece : https://ftp.cc.uoc.gr/mirrors/linux/manjaro/stable
::United_States : https://mirror.dacentec.com/manjaro/stable
::Turkey : http://ftp.linux.org.tr/manjaro/stable
::Portugal : http://ftp.dei.uc.pt/pub/linux/manjaro/stable
::Philippines : http://mirror.rise.ph/manjaro/stable
::Bulgaria : http://manjaro.telecoms.bg/stable
::Indonesia : http://kartolo.sby.datautama.net.id/manjaro/stable
::Hong_Kong : http://ftp.cuhk.edu.hk/pub/Linux/manjaro/stable
::INFO Mirror list generated and saved to: /etc/pacman.d/mirrorlist
[martin@Martin-Manjaro-Desktop ~]$ sudo pacman -Syyu
core 169.4 KiB 1264 KiB/s 00:00 [###########] 100%
extra 1906.6 KiB 6.35 MiB/s 00:00 [###########] 100%
community 6.6 MiB 6.90 MiB/s 00:01 [###########] 100%
multilib 176.2 KiB 4.78 MiB/s 00:00 [###########] 100%
:: Starting full system upgrade…
there is nothing to do
[martin@Martin-Manjaro-Desktop ~]$ ^C
it’s ok, command pacman-mirrors works well, 100 mirrors available for manjaro and you can use 95 - pacman use only first fastest for you
Thanks, papajoke and stephane.
After running the three commands suggested by Stephane in is most recent message (“something odd…”), seemingly successfully, I ran “sudo update-grub” again, but no luck. Same error message. Still stuck running kernel 5.9.
M.
You are using AUR’s grub-libzfs package instead of Manjaro’s grub. Why?
I am? I installed Manjaro about 3 years ago and it installed a new grub at that time. I can’t really remember the details any more. At one time, I edited the grub using Grub Customizer, but that doesn’t seem to work any more. Might that have introduced AUR’s grub-libzfs package? If you think I now have something “non-standard” in my grub that is causing the problem, is there a way I can revert back to the proper Manjaro grub?
you will in this case reinstall GRUB manjaro
before , keep any last USB iso update
pacman -Qs grub
inxi -Mza
test -d /sys/firmware/efi && echo efi || echo bios
sudo parted -l
sudo efibootmgr -v
Hello Stephane:
I followed your advice, entering each of the commands into the terminal, one at a time. I have pasted the proceedings below. But then I rebooted Manjaro and there had been no change. Still the same grub menu and still running kernel 5.9.
Is there anything further I should try?
[martin@Martin-Manjaro-Desktop ~]$ pacman -Qs grub
local/grub-customizer 5.1.0-2
A graphical grub2 settings manager
local/grub-theme-manjaro 20.2-12
Manjaro Linux grub theme
local/grub-vanilla 2.04-5
GNU GRand Unified Bootloader (2)
local/python-markdown 3.3.4-1
Python implementation of John Gruber’s Markdown.
[martin@Martin-Manjaro-Desktop ~]$ inxi -Mza
v: N/A serial:
serial: UEFI: American Megatrends v: 0501
date: 07/09/2015
[martin@Martin-Manjaro-Desktop ~]$ test -d /sys/firmware/efi && echo efi || echo bios
efi
[martin@Martin-Manjaro-Desktop ~]$ sudo parted -l
Model: ATA TOSHIBA DT01ACA2 (scsi)
Disk /dev/sda: 2000GB
Sector size (logical/physical): 512B/4096B
Partition Table: gpt
Disk Flags:
Number Start End Size File system Name Flags
5 1049kB 2000GB 2000GB ntfs Data msftdata
Model: ATA CT1000MX500SSD1 (scsi)
Disk /dev/sdb: 1000GB
Disk Flags:
1 1049kB 106MB 105MB fat32 SYSTEM msftdata
2 106MB 123MB 16.8MB
3 123MB 161GB 161GB ntfs Windows msftdata
4 161GB 162GB 524MB ntfs msftdata
5 162GB 163GB 1024MB linux-swap(v1) swap
6 163GB 265GB 102GB ext4 Mint 18.3 KDE Root
7 265GB 419GB 154GB ext4 Mint 18.3 KDE Home
8 419GB 587GB 168GB ext4 Mint 18.3 Cinnamon
9 587GB 599GB 11.8GB linux-swap(v1) swap
10 599GB 599GB 537MB fat32 Manjaro Grub/EFI boot, esp
11 599GB 616GB 17.2GB linux-swap(v1) Manjaro Swap swap
12 616GB 774GB 157GB ext4 Manjaro 20.0
13 774GB 804GB 29.9GB ext4 Mint 20 Cinnamon
14 804GB 1000GB 197GB lvm
Model: Seagate Expansion Desk (scsi)
Disk /dev/sdc: 3001GB
Sector size (logical/physical): 4096B/4096B
Partition Table: msdos
Disk Flags:
Number Start End Size Type File system Flags
1 8389kB 2665GB 2665GB primary ntfs
2 2665GB 3001GB 336GB primary ext4
Model: Seagate FA GoFlex Desk (scsi)
Disk /dev/sdd: 3001GB
Disk Flags:
1 258kB 3001GB 3001GB primary boot
Error: The backup GPT table is corrupt, but the primary appears OK, so that will
be used.
OK/Cancel? OK
Model: WDC WD10 EADS-00L5B1 (scsi)
Disk /dev/sdf: 1000GB
Disk Flags:
1 1049kB 106MB 105MB fat32 msftdata
2 123MB 161GB 161GB ntfs msftdata
3 161GB 162GB 524MB ntfs msftdata
4 162GB 163GB 1024MB linux-swap(v1) swap
5 163GB 265GB 102GB ext4
6 265GB 419GB 154GB ext4
7 419GB 587GB 168GB ext4
8 587GB 599GB 11.8GB linux-swap(v1) swap
9 600GB 835GB 235GB ntfs Basic data partition msftdata
10 835GB 996GB 161GB ntfs msftdata
Model: General UDisk (scsi)
Disk /dev/sdg: 4027MB
Disk Flags:
2 3120MB 3124MB 4194kB primary esp
> [martin@Martin-Manjaro-Desktop ~]$ sudo efibootmgr -v
> BootCurrent: 0000
> Timeout: 2 seconds
> BootOrder: 0000,0002,0004,0009,000D,0010,0011,0015,0001,0016,0017,0008,0007,000C
> Boot0000* manjaro       HD(10,GPT,a2061ba3-04df-459d-b8c9-080794914d89,0x45ae9000,0x100000)/File(\EFI\manjaro\grubx64.efi)
> Boot0001* ubuntu        HD(10,GPT,a2061ba3-04df-459d-b8c9-080794914d89,0x45ae9000,0x100000)/File(\EFI\ubuntu\shimx64.efi)
> Boot0002* opensuse      HD(10,GPT,a2061ba3-04df-459d-b8c9-080794914d89,0x45ae9000,0x100000)/File(\EFI\opensuse\grubx64.efi)
> Boot0004* Windows Boot Manager  HD(10,GPT,a2061ba3-04df-459d-b8c9-080794914d89,0x45ae9000,0x100000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)WINDOWS.........x...B.C.D.O.B.J.E.C.T.=.{.9.d.e.a.8.6.2.c.-.5.c.d.d.-.4.e.7.0.-.a.c.c.1.-.f.3.2.b.3.4.4.d.4.7.9.5.}...M................
> Boot0007* Hard Drive    BBS(HD,,0x0)AMGOAMNO........o.C.T.1.0.0.0.M.X.5.0.0.S.S.D.1....................A...........................>..Gd-.;.A..MQ..L.0.2.2.2.2.E.7.A.6.A.E.D. . . . . . . . ......AMBO
> Boot0008* CD/DVD Drive  BBS(CDROM,,0x0)AMGOAMNO........o.A.S.U.S. . . . . .S.H.-.2.2.4.D.B....................A...........................>..Gd-.;.A..MQ..L.1.S.E.1.8.6.G.E.0.4.C.0.S.D. . . . . . ......AMBO
> Boot0009* Windows Boot Manager  HD(1,GPT,789c39bc-4d9a-4c0c-8d82-50069053e992,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)
> Boot000C* Generic-Multiple Reader       BBS(HD,,0x0)AMGOAMNO........q.G.e.n.e.r.i.c.-.M.u.l.t.i.p.l.e. .R.e.a.d.e.r....................A.......................D..Gd-.;.A..MQ..L.G.e.n.e.r.i.c.-.M.u.l.t.i.p.l.e. .R.e.a.d.e.r......AMBOAMNO........o.T.O.S.H.I.B.A. .D.T.0.1.A.C.A.2.0.0....................A...........................>..Gd-.;.A..MQ..L. . . . . . . . . . .3. .A.5.N.K.D.0.S.K......AMBOAMNO........i.W.D.C. .W.D.1.0.E.A.D.S.-.0.0.L.5.B.1....................A.......................<..Gd-.;.A..MQ..L.W.D.C. .W.D.1.0.E.A.D.S.-.0.0.L.5.B.1......AMBOAMNO........].G.e.n.e.r.a.l. .U.D.i.s.k....................A.......................0..Gd-.;.A..MQ..L.G.e.n.e.r.a.l. .U.D.i.s.k......AMBO
> Boot000D* UEFI OS       HD(10,GPT,a2061ba3-04df-459d-b8c9-080794914d89,0x45ae9000,0x100000)/File(\EFI\BOOT\BOOTX64.EFI)
> Boot0010* ubuntu        HD(1,GPT,789c39bc-4d9a-4c0c-8d82-50069053e992,0x800,0x32000)/File(EFI\Ubuntu\grubx64.efi)
> Boot0011* ubuntu        HD(10,GPT,a2061ba3-04df-459d-b8c9-080794914d89,0x45ae9000,0x100000)/File(EFI\Ubuntu\grubx64.efi)
> Boot0015* Windows Boot Manager  HD(1,GPT,d940c384-81de-45d1-8923-4aec4fbc24f2,0x800,0x32000)/File(\EFI\Microsoft\Boot\bootmgfw.efi)
> Boot0016* ubuntu        HD(1,GPT,d940c384-81de-45d1-8923-4aec4fbc24f2,0x800,0x32000)/File(EFI\Ubuntu\grubx64.efi)
> Boot0017* UEFI: General UDisk   PciRoot(0x0)/Pci(0x10,0x0)/USB(2,0)/HD(1,MBR,0x0,0x5cf8f0,0x2000)AMBO
