This happens during direct login to box through GUI or remote ssh login.
In ssh login no error is reported but when I directly log to the machine, I get an error message:
Unable to get connection to message bus
error spawning command line dbus-launch --autolaunch --binary-syntax --close-stderr
Most things work after that error but I get authentication error when using pamac through terminal:
➜ pamac update
Preparing...
Error: Authentication failed
System info:
➜ lsb_release -a
LSB Version: n/a
Distributor ID: ManjaroLinux
Description: Manjaro Linux
Release: 21.0.7
Codename: Ornara
➜ uname -a
Linux manjaro 5.10.42-1-MANJARO #1 SMP PREEMPT Thu Jun 3 14:37:11 UTC 2021 x86_64 GNU/Linux
Any hint on how to fix this is appreciated
Thanks
