Long boot times due to device timeouts after motherboard changes
After changing my motherboard, booting my system one time and then updating my UEFI firmware systemd-analyze blame shows me a lot of nvme device units with long run times. My system is using systemd-boot and an encrypted LUKS1 root/swap partition. Those are referenced by /dev/mapper/root and /dev/mapper/swap in /etc/fstab. My kernel cmdline looks like this:
rd.luks.name=e3b81371-df48-4716-aa6e-bf4c85736078=root rd.luks.name=7001dea1-8496-4577-b50f-5cffebeddb11=swap root=/dev/mapper/root resume=/dev/mapper/swap rw quiet splash
systemd-analyze blame shows me:
1min 5.177s sys-devices-pci0000:00-0000:00:02.2-0000:14:00.0-nvme-nvme1-nvme1n1-nvme1n1p3.device
1min 5.177s dev-disk-by\x2did-nvme\x2dSamsung_SSD_970_EVO_500GB_S466NX0K935863A_1\x2dpart3.device
1min 5.177s dev-disk-by\x2dpath-pci\x2d0000:14:00.0\x2dnvme\x2d1\x2dpart3.device
1min 5.177s dev-disk-by\x2dpartuuid-32d5228b\x2d238a\x2d3a4a\x2dba3b\x2dc0b9873a5e09.device
... even more for every nvme device and partition I have (I have 2 NVMEs)
I’m not quire sure what’s going on. Any ideas?
Motherboard: MSI Pro B850M-P Wifi
Bios version: E7E71AMSI.1A44
Bios build date: August 5th 2025
Just a few quick thoughts;
  • Did you reconfigure your BIOS to suit your hardware?
  • Did you check your /etc/fstab to make sure all UUIDs match that of your actual disks?
  • Did you check that the “resume=UUID=” UUID in /etc/default/grub matches that of your swap partition?
Please provide system information as described (below) to help others identify other possible contributors.
Update Announcements
System Information
Output of the inxi command (with appropriate parameters, and formatted according to forum guidelines) will generate information that may be useful for those wishing to help:
inxi --filter --verbosity=8
or the short form:
inxi -zv8c0
Highly Recommended
Technical Resources
Required Reading
I’m sorry but I don’t feel comfortable to put as much information about my system as inxi --filter --verbosity=8 does . If you need anything specific let me know and I’ll post the results.
I’m using systemd-boot btw. I first thought that grub might be the culprit so I replaced it with systemd-boot.
Yes I did cross check the UUIDs, they match my kernel cmdline (see my first post). About UEFI settings: I didn’t really enable anything special in the previous motherboard except enabling Intel XMP and AMD Expo on my new one.
âžś  ~ ls /dev/disk/by-uuid -l
total 0
lrwxrwxrwx 1 root root 15 Aug 30 13:48 4026-72A7 -> ../../nvme1n1p3
lrwxrwxrwx 1 root root 15 Aug 30 13:48 4297-6367 -> ../../nvme0n1p1
lrwxrwxrwx 1 root root 10 Aug 30  2025 4a5ae815-556b-407a-ab9e-72df87f81e28 -> ../../dm-1
lrwxrwxrwx 1 root root 15 Aug 30 13:48 7001dea1-8496-4577-b50f-5cffebeddb11 -> ../../nvme0n1p3
lrwxrwxrwx 1 root root 10 Aug 30  2025 9607223d-6add-4bec-9e4a-a33b600e918b -> ../../dm-0
lrwxrwxrwx 1 root root 15 Aug 30 13:48 D2B8906FB89053B7 -> ../../nvme1n1p2
lrwxrwxrwx 1 root root 15 Aug 30 13:48 e3b81371-df48-4716-aa6e-bf4c85736078 -> ../../nvme0n1p2
âžś  ~ cat /etc/fstab
UUID=4297-6367   /boot/efi vfat    umask=0077 0 2
/dev/mapper/root /         ext4    defaults,noatime 0 1
/dev/mapper/swap swap      swap    defaults,noatime 0 2
The NVME is initialized by the UEFI and then handed over to the kernel. If, for whatever reason, the initialization takes longer than expected or is not triggered, systemd waits until the device finally responds or not.
One possible cause could be “fastboot,” as it can also skip the NVME. Another possible cause could be slow wake-up / switching from power-saving mode.
I couldn’t find any option for fast boot (Intel only?) and I’m booting from cold so no power-saving mode (if that’s what you meant).
This might go a little more smoothly if you provide the system information requested, and logs;
The idea is to provide that information to help others identify anything that might be contributing. Help us to help you.
All right so here you go.
  Kernel: 6.15.11-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
    parameters: rd.luks.name=e3b81371-df48-4716-aa6e-bf4c85736078=root
  Desktop: KDE Plasma v: 6.3.6 tk: Qt v: N/A wm: kwin_wayland with: krunner
    dm: SDDM Distro: Manjaro base: Arch Linux
  Type: Desktop Mobo: Micro-Star model: PRO B850M-P WIFI (MS-7E71) v: 1.0
    serial: <filter> uuid: ab64eb76-c86a-491d-a4ec-345a60d04618 UEFI: American
    Megatrends LLC. v: 1.A44 date: 08/05/2025
  System RAM: total: 32 GiB available: 30.4 GiB used: 5.34 GiB (17.6%)
  Device-1: DIMMA1 type: no module installed
  Device-2: DIMMA2 type: DDR5 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 6000 MT/s volts: curr: 1.1 min: 1.1 max: 1.1
    width (bits): data: 64 total: 64 manufacturer: Kingston
    part-no: KF560C30-16 serial: <filter>
  Device-3: DIMMB1 type: no module installed
  Device-4: DIMMB2 type: DDR5 detail: synchronous unbuffered (unregistered)
  Slot: 1 type: PCIe gen: 1 status: in use length: short volts: 3.3
    bus-ID: 00:01.1 children: 1: 01:00.0 class-ID: 0604 type: bridge children:
    1: 02:00.0 class-ID: 0604 type: bridge children: 1: 03:00.0 class-ID: 0300
    type: display 2: 03:00.1 class-ID: 0403 type: audio
  Slot: N/A type: N/A status: in use info: M.2, J3502 length: short
    volts: 3.3 bus-ID: 00:01.2 children: 1: 04:00.0 class-ID: 0108
    type: mass-storage
  Slot: 3 type: PCIe gen: 3 status: in use length: short volts: 3.3
    bus-ID: 00:02.2 children: 1: 14:00.0 class-ID: 0108 type: mass-storage
  Slot: 4 type: PCIe gen: 4 status: in use length: short volts: 3.3
    bus-ID: 00:02.1 children: 1: 05:00.0 class-ID: 0604 type: bridge children:
    1: 06:00.0 class-ID: 0604 type: bridge 2: 06:01.0 class-ID: 0604
    type: bridge 3: 06:02.0 class-ID: 0604 type: bridge 4: 06:03.0
    class-ID: 0604 type: bridge 5: 06:04.0 class-ID: 0604 type: bridge
    6: 06:05.0 class-ID: 0604 type: bridge 7: 06:06.0 class-ID: 0604
    type: bridge 8: 06:07.0 class-ID: 0604 type: bridge 9: 06:08.0
    class-ID: 0604 type: bridge 10: 06:0a.0 class-ID: 0604 type: bridge
    children: 1: 10:00.0 class-ID: 0200 type: network 11: 06:0b.0
    class-ID: 0604 type: bridge children: 1: 11:00.0 class-ID: 0280
    type: network 12: 06:0c.0 class-ID: 0604 type: bridge children: 1: 12:00.0
    class-ID: 0c03 type: serialbus 13: 06:0d.0 class-ID: 0604 type: bridge
    children: 1: 13:00.0 class-ID: 0106 type: mass-storage
  Info: model: AMD Ryzen 7 9800X3D socket: AM5 bits: 64 type: MT MCP arch: N/A
    level: v4 note: check family: 0x1A (26) model-id: 0x44 (68) stepping: 0
    microcode: 0xB404032
    smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
    desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
  Speed (MHz): avg: 2568 min/max: 603/5272 boost: enabled
    base/boost: 4700/5250 scaling: driver: amd-pstate-epp governor: powersave
    volts: 1.3 V ext-clock: 100 MHz cores: 1: 2568 2: 2568 3: 2568 4: 2568
    5: 2568 6: 2568 7: 2568 8: 2568 9: 2568 10: 2568 11: 2568 12: 2568
    13: 2568 14: 2568 15: 2568 16: 2568 bogomips: 150399
    apic arat avic avx avx2 avx512_bf16 avx512_bitalg avx512_vbmi2
    avx512_vnni avx512_vp2intersect avx512_vpopcntdq avx512bw avx512cd
    avx512dq avx512f avx512ifma avx512vbmi avx512vl avx_vnni bmi1 bmi2 bpext
    bus_lock_detect cat_l3 cdp_l3 clflush clflushopt clwb clzero cmov
    cmp_legacy constant_tsc cpb cppc cpuid cqm cqm_llc cqm_mbm_local
    cqm_mbm_total cqm_occup_llc cr8_legacy cx16 cx8 de decodeassists erms
    extapic extd_apicid f16c flush_l1d flushbyasid fma fpu fsgsbase fsrm fxsr
    fxsr_opt gfni ht hw_pstate ibpb ibrs ibrs_enhanced ibs invpcid irperf
    lahf_lm lbrv lm mba mca mce misalignsse mmx mmxext monitor movbe
    movdir64b movdiri msr mtrr mwaitx nonstop_tsc nopl npt nrip_save nx ospke
    osvw overflow_recov pae pat pausefilter pclmulqdq pdpe1gb perfctr_core
    perfctr_llc perfctr_nb perfmon_v2 pfthreshold pge pku pni popcnt pse
    pse36 rapl rdpid rdpru rdrand rdseed rdt_a rdtscp rep_good sep sha_ni
    skinit smap smca smep ssbd sse sse2 sse4_1 sse4_2 sse4a ssse3 stibp
    succor svm svm_lock syscall tce topoext tsc tsc_adjust tsc_scale umip
    vnmi vpclmulqdq wbnoinvd wdt x2avic xgetbv1 xsave xsavec xsaveerptr
    xsaveopt xsaves xtopology
  Type: spec_rstack_overflow mitigation: IBPB on VMEXIT only
    conditional; STIBP: always-on; PBRSB-eIBRS: Not affected; BHI: Not
    affected
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 32 [Radeon RX 7700 XT /
    7800 XT] vendor: ASRock driver: amdgpu v: kernel arch: RDNA-3
    code: Navi-3x process: TSMC n5 (5nm) built: 2022+ pcie: gen: 4
    speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-2
    empty: DP-3,HDMI-A-1,Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:747e
    class-ID: 0300
  Device-2: Advanced Micro Devices [AMD/ATI] Granite Ridge [Radeon Graphics]
    vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
    process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 4 speed: 16 GT/s
    lanes: 16 ports: active: none empty: DP-4,HDMI-A-2,Writeback-2
    bus-ID: 15:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 40.0 C
  Display: unspecified server: X.Org v: 24.1.8 with: Xwayland v: 24.1.8
    compositor: kwin_wayland driver: X: loaded: amdgpu
    gpu: amdgpu display-ID: :1 screens: 1
  Screen-1: 0 s-res: 7040x1800 s-dpi: 96 s-size: 1863x476mm (73.35x18.74")
    s-diag: 1923mm (75.7")
  Monitor-1: DP-1 pos: primary,bottom-r model: Dell AW3821DW
    serial: <filter> built: 2020 res: mode: 3840x1600 hz: 144 scale: 100% (1)
    dpi: 111 gamma: 1.2 chroma: red: x: 0.682 y: 0.310 green: x: 0.267
    y: 0.675 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 880x367mm (34.65x14.45") diag: 953mm (37.5") modes: 3840x1600,
    1920x1200, 1920x1080, 1600x1200, 1680x1050, 1280x1024, 1440x900,
    1280x800, 1280x720, 1024x768, 800x600, 640x480
  EDID-Warnings: 1: parse_edid: unknown tag 112
  Monitor-2: DP-2 pos: top-left model: Acer XB271HU serial: <filter>
    built: 2018 res: mode: 3200x1800 hz: 165 scale: 100% (1) dpi: 136 gamma: 1.2
    chroma: red: x: 0.639 y: 0.329 green: x: 0.298 y: 0.600 blue: x: 0.149
    y: 0.059 white: x: 0.314 y: 0.329 size: 598x336mm (23.54x13.23")
    diag: 686mm (27") ratio: 16:9 modes: 2560x1440, 1920x1200, 1920x1080,
    1600x1200, 1680x1050, 1280x1024, 1440x900, 1280x800, 1280x720, 1024x768,
    800x600, 640x480
    device: 1 drv: radeonsi device: 2 drv: swrast gbm: drv: radeonsi
    surfaceless: drv: radeonsi x11: drv: radeonsi inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.2.1-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 7800 XT (radeonsi
    navi32 LLVM 20.1.8 DRM 3.63 6.15.11-1-MANJARO) device-ID: 1002:747e
    memory: 15.62 GiB unified: no
  API: Vulkan v: 1.4.321 layers: N/A device: 0 type: discrete-gpu name: AMD
    Radeon RX 7800 XT (RADV NAVI32) driver: mesa radv v: 25.2.1-arch1.2
    device-ID: 1002:747e surfaces: N/A device: 1 type: integrated-gpu name: AMD
    Radeon Graphics (RADV RAPHAEL_MENDOCINO) driver: mesa radv
    v: 25.2.1-arch1.2 device-ID: 1002:13c0 surfaces: N/A
    de: kscreen-console,kscreen-doctor gpu: radeontop wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Advanced Micro Devices [AMD/ATI] Navi 31 HDMI/DP Audio
    bus-ID: 03:00.1 chip-ID: 1002:ab30 class-ID: 0403
  Device-2: Advanced Micro Devices [AMD/ATI] Radeon High Definition Audio
    [Rembrandt/Strix] vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
    pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 15:00.1 chip-ID: 1002:1640
    class-ID: 0403
    vendor: Micro-Star MSI driver: snd_hda_intel v: kernel pcie: gen: 4
    speed: 16 GT/s lanes: 16 bus-ID: 15:00.6 chip-ID: 1022:15e3 class-ID: 0403
  Device-4: C-Media USB Advanced Audio Device
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 mode: 1.1 bus-ID: 7-1.3:4 chip-ID: 0d8c:016c class-ID: 0300
  Device-5: Gemini G4V driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 7-1.4:5
    chip-ID: 23c7:0465 class-ID: 0300
  API: ALSA v: k6.15.11-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.7 status: n/a (root, process) with:
    3: pipewire-alsa type: plugin 4: pw-jack type: plugin
  Device-1: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8169
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000 bus-ID: 10:00.0
    chip-ID: 10ec:8126 class-ID: 0200
  IF: enp16s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: MEDIATEK vendor: Foxconn driver: mt7925e v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 port: N/A bus-ID: 11:00.0 chip-ID: 14c3:7925
    class-ID: 0280
  IF: wlp17s0 state: down mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
  IP v4: <filter> scope: global
  IP v6: <filter> scope: global
  IP v6: <filter> virtual: stable-privacy proto kernel_ll scope: link
  Device-1: root maj-min: 253:1 type: LUKS dm: dm-1 size: 448.33 GiB
  Components:
  p-1: nvme0n1p2 maj-min: 259:7 size: 448.33 GiB
  Device-2: swap maj-min: 253:0 type: LUKS dm: dm-0 size: 17.13 GiB
  Components:
  p-1: nvme0n1p3 maj-min: 259:8 size: 17.13 GiB
  Local Storage: total: 2.27 TiB used: 340.02 GiB (14.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:5 vendor: Samsung model: SSD 970 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 38.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 1y 158d 11h cycles: 5,594
    read-units: 117,344,912 [60.0 TB] written-units: 207,551,171 [106 TB]
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 31.9 C
    scheme: GPT
  SMART: yes health: PASSED on: 41d 14h cycles: 757
    read-units: 74,506,826 [38.1 TB] written-units: 18,921,666 [9.68 TB]
  ID-1: / raw-size: 448.33 GiB size: 440.22 GiB (98.19%)
    used: 339.83 GiB (77.2%) fs: ext4 block-size: 4096 B dev: /dev/dm-1
    maj-min: 253:1 mapped: root label: N/A uuid: N/A
    used: 202.7 MiB (67.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
    maj-min: 259:6 label: N/A uuid: 4297-6367
  ID-1: swap-1 type: partition size: 17.13 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/dm-0 maj-min: 253:0 mapped: swap label: N/A
    uuid: 9607223d-6add-4bec-9e4a-a33b600e918b
  ID-1: /dev/nvme1n1p1 maj-min: 259:1 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  ID-2: /dev/nvme1n1p2 maj-min: 259:2 size: 1.82 TiB fs: ntfs label: N/A
    uuid: D2B8906FB89053B7
  ID-3: /dev/nvme1n1p3 maj-min: 259:3 size: 100 MiB fs: vfat label: SYSTEM
    uuid: 4026-72A7
  ID-4: /dev/nvme1n1p4 maj-min: 259:4 size: 16 MiB fs: N/A label: N/A
    uuid: N/A
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Hub-2: 1-6:2 info: Microchip (formerly SMSC) USB2734 ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0424:2734
  Device-1: 1-6.2:8 info: Pulsar 1K Dongle type: mouse,keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 3710:5402 class-ID: 0300
  Device-2: 1-6.5:9 info: Alienware Hub Controller type: HID
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 187c:1008
    class-ID: 0300
  Device-3: 1-12:7 info: Micro Star MYSTIC LIGHT type: HID
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0db0:0076 class-ID: 0300
    serial: <filter>
  Hub-3: 2-0:1 info: super-speed hub ports: 6 rev: 3.1
  Hub-4: 2-6:2 info: Microchip (formerly SMSC) USB5734 ports: 5 rev: 3.2
    speed: 5 Gb/s (596.0 MiB/s) lanes: 1 mode: 3.2 gen-1x1 chip-ID: 0424:5734
  Hub-5: 3-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Device-1: 3-2:2 info: Samsung Galaxy series misc. (MTP mode) type: still
    imaging,abstract (modem),CDC-data driver: cdc_acm interfaces: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 64mA
    chip-ID: 04e8:6860 class-ID: 0a00 serial: <filter>
  Hub-6: 4-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-7: 5-0:1 info: hi-speed hub with single TT ports: 2 rev: 2.0
  Hub-8: 6-0:1 info: super-speed hub ports: 2 rev: 3.1
  Hub-9: 7-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-10: 7-1:2 info: Genesys Logic Hub ports: 4 rev: 2.0
  Device-1: 7-1.1:3 info: SHARKOON GmbH Keyboard type: keyboard,HID
    driver: semitek,usbhid interfaces: 3 rev: 1.1 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 1ea7:0907 class-ID: 0300
    serial: <filter>
  Device-2: 7-1.3:4 info: C-Media USB Advanced Audio Device type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 4 rev: 1.1
  Device-3: 7-1.4:5 info: Gemini G4V type: audio,HID
    driver: hid-generic,snd-usb-audio,usbhid interfaces: 5 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 power: 2mA
  Hub-11: 8-0:1 info: Linux Foundation 3.0 root hub ports: N/A rev: 3.0
  System Temperatures: cpu: 45.6 C mobo: 43.5 C
  Fan Speeds (rpm): N/A
  GPU: device: amdgpu temp: 46.0 C mem: 62.0 C fan: 0 watts: 60.00
    device: amdgpu temp: 41.0 C
  Packages: pm: pacman pkgs: 2156 libs: 505 tools: pamac,trizen
    1: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    2: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    3: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    4: https://manjaro.mirrors.uk2.net/stable/$repo/$arch
    5: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    6: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirror.fcix.net/manjaro/stable/$repo/$arch
    8: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
Processes:
  CPU top: 5 of 462
  1: cpu: 22.5% command: firefox pid: 4024 mem: 747.5 MiB (2.4%)
  2: cpu: 15.0% command: firefox pid: 4571 mem: 556.1 MiB (1.7%)
  3: cpu: 6.2% command: firefox pid: 5496 mem: 278.8 MiB (0.8%)
  4: cpu: 5.8% command: firefox pid: 4928 mem: 418.9 MiB (1.3%)
  5: cpu: 4.8% command: kwin_wayland pid: 1932 mem: 300.6 MiB (0.9%)
  Memory top: 5 of 462
  1: mem: 747.5 MiB (2.4%) command: firefox pid: 4024 cpu: 22.5%
  2: mem: 568.6 MiB (1.8%) command: plasmashell pid: 2267 cpu: 4.2%
  3: mem: 556.1 MiB (1.7%) command: firefox pid: 4571 cpu: 15.0%
  4: mem: 418.9 MiB (1.3%) command: firefox pid: 4928 cpu: 5.8%
  5: mem: 415.8 MiB (1.3%) command: firefox pid: 4335 cpu: 2.5%
  Processes: 462 Power: uptime: 4m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.14 GiB services: org_kde_powerdevil,upowerd
  Compilers: clang: 20.1.8 gcc: 15.2.1 alt: 12 Shell: Sudo (sudo)
    v: 1.9.17p1 default: Bash v: 5.3.3 running-in: konsole inxi: 3.3.38
Kernel 6.15 reached EOL around two weeks ago.
It is recommended to replace it at the earliest opportunity, as updates for this kernel are no longer provided from the official Manjaro repositories.
You could either use kernel 6.16, or as is often recommended, the latest SLTS kernel – Kernel 6.12 (LTS) – which isn’t expected to reach EOL until 31 Dec 2026.
See Manjaro Kernels for information on how to manage your kernels.
Otherwise, I see nothing obvious that might contribute to an excessively slow boot.
What length of time is it that you are you calling “slow”?
Perhaps system logs (requested earlier) might reveal something.
Try journalctl -b0 | grep nvme for nvme-related log messages or journalctl -b0 -p3 for all errors.
âžś  ~ journalctl -b0 | grep nvme
Sep 06 15:53:37 manjaro kernel: nvme 0000:04:00.0: platform quirk: setting simple suspend
Sep 06 15:53:37 manjaro kernel: nvme nvme0: pci function 0000:14:00.0
Sep 06 15:53:37 manjaro kernel: nvme nvme1: pci function 0000:04:00.0
Sep 06 15:53:37 manjaro kernel: nvme nvme1: D3 entry latency set to 10 seconds
Sep 06 15:53:37 manjaro kernel: nvme nvme0: missing or invalid SUBNQN field.
Sep 06 15:53:37 manjaro kernel: nvme nvme0: D3 entry latency set to 8 seconds
Sep 06 15:53:37 manjaro kernel: nvme nvme1: 16/0/0 default/read/poll queues
Sep 06 15:53:37 manjaro kernel:  nvme1n1: p1 p2 p3 p4
Sep 06 15:53:37 manjaro kernel: nvme nvme0: 16/0/0 default/read/poll queues
Sep 06 15:53:37 manjaro kernel:  nvme0n1: p1 p2 p3
Sep 06 13:54:43 monster-manjaro systemd-fsck[739]: /dev/nvme0n1p1: 17 files, 51898/76646 clusters
Sep 06 13:55:05 monster-manjaro kernel: nvme nvme0: using unchecked data buffer
âžś  ~ journalctl -b0 -p3
Sep 06 15:53:37 manjaro kernel: hub 8-0:1.0: config failed, hub doesn't have any ports! (err -19)
Sep 06 15:53:42 manjaro kernel: hub 1-6:1.0: hub_ext_port_status failed (err = -110)
Sep 06 15:53:42 manjaro kernel: usb 1-11: device descriptor read/64, error -110
Sep 06 15:53:58 manjaro kernel: usb 1-11: device descriptor read/64, error -110
Sep 06 15:54:04 manjaro kernel: usb 1-11: device descriptor read/64, error -110
Sep 06 15:54:20 manjaro kernel: usb 1-11: device descriptor read/64, error -110
Sep 06 15:54:31 manjaro kernel: usb 1-11: device not accepting address 5, error -71
Sep 06 15:54:41 manjaro kernel: usb 1-11: device not accepting address 6, error -71
Sep 06 15:54:41 manjaro kernel: usb usb1-port11: unable to enumerate USB device
Sep 06 13:54:42 monster-manjaro systemd-modules-load[500]: Failed to find module 'v4l2loopback-dc'
Sep 06 13:54:44 monster-manjaro kernel: usb 7-1.4: 1:1: cannot get freq at ep 0x1
Sep 06 13:54:44 monster-manjaro kernel: usb 7-1.4: 2:0: cannot get min/max values for control 2 (id 2)
Sep 06 13:54:45 monster-manjaro kernel: usb 7-1.4: 2:0: cannot get min/max values for control 2 (id 2)
Sep 06 13:54:54 monster-manjaro dbus-broker-launch[1764]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Sep 06 13:55:03 monster-manjaro dbus-broker-launch[1900]: Ignoring duplicate name 'org.freedesktop.FileManager1' in service file '/usr/share//dbus-1/services/org.kde.dolphin.FileManager1.service'
Sep 06 13:55:05 monster-manjaro kernel: usb 7-1.4: 1:1: cannot get freq at ep 0x1
Sep 06 13:55:05 monster-manjaro kernel: usb 7-1.4: 2:0: cannot get min/max values for control 2 (id 2)
Sep 06 13:55:06 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=8, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_ZERO>
Sep 06 13:55:06 monster-manjaro org_kde_powerdevil[2299]: [  2299] Turning off dynamic sleep and retrying
Sep 06 13:55:07 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=8, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_Z>
Sep 06 13:55:09 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=8, sleep-multiplier= 2.00, Testing for unsupported feature 0x41 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_ZERO>
Sep 06 13:55:09 monster-manjaro org_kde_powerdevil[2299]: [  2299] Turning off dynamic sleep and retrying
Sep 06 13:55:10 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=8, sleep-multiplier = 1.00, Retesting for unsupported feature 0x41 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_Z>
Sep 06 13:55:12 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=9, sleep-multiplier= 2.00, Testing for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_ZERO>
Sep 06 13:55:12 monster-manjaro org_kde_powerdevil[2299]: [  2299] Turning off dynamic sleep and retrying
Sep 06 13:55:13 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=9, sleep-multiplier = 1.00, Retesting for unsupported feature 0xdd returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_Z>
Sep 06 13:55:06 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=9, sleep-multiplier= 2.00, Testing for unsupported feature 0x41 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_ZERO>
Sep 06 13:55:07 monster-manjaro org_kde_powerdevil[2299]: [  2299] busno=9, sleep-multiplier = 1.00, Retesting for unsupported feature 0x41 returned Error_Info[DDCRC_RETRIES in ddc_write_read_with_retry, causes: DDCRC_READ_ALL_Z>
Sep 06 13:55:09 monster-manjaro akonadi_control[3220]: org.kde.pim.akonadicontrol: "/usr/bin/akonadi_notes_agent" crashed too often and will not be restarted!
Sep 06 13:58:43 monster-manjaro systemd[1838]: Failed to start Kite Updater.
Sep 06 14:14:05 monster-manjaro systemd[1838]: Failed to start Kite Updater.
Sep 06 14:29:10 monster-manjaro systemd[1838]: Failed to start Kite Updater.
I’m talking about around 90 seconds longer boot times …
Sorry for the late response…
“fast boot” could have different names and no it is not Intel only.
No, I mean the normal power save states of the nvme. See:
sudo nvme id-ctrl /dev/nvme0
Took 22 seconds. Is it doing that fsck every time?
Then the usb 1-11 errors seem to be taking 60 seconds. Try booting with all usb devices removed.
Oh - sorry!
This should have been addressed at @LimitX - who didn’t even ask that question :grimacing:
I didn’t pay attention while reading.
Too late - I’ll leave it here now.
As far as I know:
The systemd service is active but the actual, perhaps a bit time consuming check and repair is only run if there are file system errors detected.
You would not want to somehow deactivate that functionality.
The default setting for ext4 file systems on Manjaro is to never force a check - unless there are errors.
You can set the default to require a check after each X mounts of the file system as a precaution.
sudo tune2fs -l /dev/nvme0n1p1 | grep Maximum
will show the current setting to be -1 (disabled)
sudo tune2fs -c 20 /dev/nvme0n1p1
will force a check every 20 mounts, whether there was an error or not.
If there was no error in this case, the check will be very quick since there is nothing to correct.
Not only. With ext4 (and its predecessors) it is also run automatically every 50 boots or so. I’m not sure on the exact number of boots, but one can tweak it using tune2fs.
Since I’m using an AMD CPU I think the option is actually called Memory Context Restore which I tried to enable, yielding the same results. Here is the output of nvme:
âžś  ~ sudo nvme id-ctrl /dev/nvme1
NVME Identify Controller:
vid       : 0x144d
ssvid     : 0x144d
sn        : XXXXXXXXXXXXXXX
mn        : Samsung SSD 970 EVO 500GB
fr        : 2B2QEXE7
rab       : 2
ieee      : 002538
cmic      : 0
mdts      : 9
cntlid    : 0x4
ver       : 0x10300
rtd3r     : 0x30d40
rtd3e     : 0x7a1200
oaes      : 0
ctratt    : 0
rrls      : 0
bpcap     : 0
nssl      : 0
plsi      : 0
cntrltype : 0
fguid     : 00000000-0000-0000-0000-000000000000
crdt1     : 0
crdt2     : 0
crdt3     : 0
crcap     : 0
nvmsr     : 0
vwci      : 0
mec       : 0
oacs      : 0x17
acl       : 7
aerl      : 3
frmw      : 0x16
lpa       : 0x3
elpe      : 63
npss      : 4
avscc     : 0x1
apsta     : 0x1
wctemp    : 358
cctemp    : 358
mtfa      : 0
hmpre     : 0
hmmin     : 0
tnvmcap   : 500107862016
unvmcap   : 0
rpmbs     : 0
edstt     : 35
dsto      : 0
fwug      : 0
kas       : 0
hctma     : 0x1
mntmt     : 356
mxtmt     : 358
sanicap   : 0
hmminds   : 0
hmmaxd    : 0
nsetidmax : 0
endgidmax : 0
anatt     : 0
anacap    : 0
anagrpmax : 0
nanagrpid : 0
pels      : 0
domainid  : 0
kpioc     : 0
mptfawr   : 0
megcap    : 0
tmpthha   : 0
cqt       : 0
sqes      : 0x66
cqes      : 0x44
maxcmd    : 0
nn        : 1
oncs      : 0x5f
fuses     : 0
fna       : 0x5
vwc       : 0x1
awun      : 1023
awupf     : 0
icsvscc   : 1
nwpc      : 0
acwu      : 0
ocfs      : 0
sgls      : 0
mnan      : 0
maxdna    : 0
maxcna    : 0
oaqd      : 0
rhiri     : 0
hirt      : 0
cmmrtd    : 0
nmmrtd    : 0
minmrtg   : 0
maxmrtg   : 0
trattr    : 0
mcudmq    : 0
mnsudmq   : 0
mcmr      : 0
nmcmr     : 0
mcdqpc    : 0
subnqn    :
ioccsz    : 0
iorcsz    : 0
icdoff    : 0
fcatt     : 0
msdbd     : 0
ofcs      : 0
ps      0 : mp:6.20W operational enlat:0 exlat:0 rrt:0 rrl:0
            rwt:0 rwl:0 idle_power:- active_power:-
            active_power_workload:-
            emergency power fail recovery time: -
            forced quiescence vault time: -
            emergency power fail vault time: -
ps      1 : mp:4.30W operational enlat:0 exlat:0 rrt:1 rrl:1
            rwt:1 rwl:1 idle_power:- active_power:-
ps      2 : mp:2.10W operational enlat:0 exlat:0 rrt:2 rrl:2
            rwt:2 rwl:2 idle_power:- active_power:-
ps      3 : mp:0.0400W non-operational enlat:210 exlat:1200 rrt:3 rrl:3
            rwt:3 rwl:3 idle_power:- active_power:-
ps      4 : mp:0.0050W non-operational enlat:2000 exlat:8000 rrt:4 rrl:4
            rwt:4 rwl:4 idle_power:- active_power:-
and for nvme0:
âžś  ~ sudo nvme id-ctrl /dev/nvme0
vid       : 0x144d
ssvid     : 0x144d
mn        : Samsung SSD 990 PRO 2TB
fr        : 4B2QJXD7
rab       : 2
ieee      : 002538
cmic      : 0
mdts      : 9
cntlid    : 0x1
ver       : 0x20000
rtd3r     : 0x30d40
rtd3e     : 0x989680
oaes      : 0x200
ctratt    : 0x10
rrls      : 0
bpcap     : 0
nssl      : 0
plsi      : 0
cntrltype : 1
crdt1     : 0
crdt2     : 0
crdt3     : 0
crcap     : 0
nvmsr     : 0
vwci      : 0
mec       : 0
oacs      : 0x17
acl       : 7
aerl      : 3
frmw      : 0x16
lpa       : 0x2f
elpe      : 63
npss      : 4
avscc     : 0x1
apsta     : 0x1
wctemp    : 355
cctemp    : 358
mtfa      : 0
hmpre     : 0
hmmin     : 0
tnvmcap   : 2000398934016
unvmcap   : 0
rpmbs     : 0
edstt     : 35
dsto      : 0
fwug      : 0
kas       : 0
hctma     : 0x1
mntmt     : 318
mxtmt     : 356
sanicap   : 0x60000003
hmminds   : 0
hmmaxd    : 0
nsetidmax : 0
endgidmax : 1
anatt     : 0
anacap    : 0
anagrpmax : 0
nanagrpid : 0
pels      : 0
domainid  : 0
kpioc     : 0
mptfawr   : 0
megcap    : 0
tmpthha   : 0
cqt       : 0
sqes      : 0x66
cqes      : 0x44
maxcmd    : 256
nn        : 1
oncs      : 0x55
fuses     : 0
fna       : 0x7
vwc       : 0x7
awun      : 1023
awupf     : 0
icsvscc   : 1
nwpc      : 0
acwu      : 0
ocfs      : 0
sgls      : 0
mnan      : 0
maxdna    : 0
maxcna    : 0
oaqd      : 0
rhiri     : 0
hirt      : 0
cmmrtd    : 0
nmmrtd    : 0
minmrtg   : 0
maxmrtg   : 0
trattr    : 0
mcudmq    : 0
mnsudmq   : 0
mcmr      : 0
nmcmr     : 0
mcdqpc    : 0
subnqn    : nqn.1994-11.com.samsung:nvme:990PRO:M.2:S6Z2NU0XB15292J
ioccsz    : 0
iorcsz    : 0
icdoff    : 0
fcatt     : 0
msdbd     : 0
ofcs      : 0
ps      0 : mp:9.39W operational enlat:0 exlat:0 rrt:0 rrl:0
ps      1 : mp:9.39W operational enlat:0 exlat:0 rrt:1 rrl:1
ps      2 : mp:9.39W operational enlat:0 exlat:0 rrt:2 rrl:2
ps      3 : mp:0.0400W non-operational enlat:4200 exlat:6800 rrt:3 rrl:3
ps      4 : mp:0.0050W non-operational enlat:2700 exlat:21800 rrt:4 rrl:4
I just did an fsck.ext4 on my root partition by booting into a manjaro live img and it is fine. Funny thing is boot times with the live img are around 50 sec in total and I don’t have all those disk devices in systemd-analyze blame output.
I also just booted with all USB devices disconnected, I even disconnected my case’s HUB on the internal USB header (also USB-C) except my keyboard of course and boot times are still the same, 1 min 40 sec. And for some reason dmesg still shows USB 1-11 but I don’t have anything connected.
I’m very close to returning this motherboard :confused:
Mod edit:- Serial numbers redacted from output. No charge.
Well, let’s see if turning off the power saving function makes any difference:
  1. Edit /etc/default/grub to add these kernel parameters in GRUB_CMDLINE_LINUX_DEFAULT=
nvme_core.default_ps_max_latency_us=0 pcie_aspm=off
  1. Run sudo update-grub
  2. Reboot
If you search that usb -110 error there are quite a few hits saying it’s something to do with power. A solution that seems to work for many people is to completely power off the system for 5 minutes (disconnect it from the wall socket).
https://daniel-lange.com/archives/183-Linux-kernel-USB-errors-71-and-110.html
The problem seems to have solved itself. Booting in 39 seconds total now:
~ systemd-analyze
Startup finished in 13.662s (firmware) + 829ms (loader) + 3.661s (kernel) + 16.931s (initrd) + 4.033s (userspace) = 39.118s
graphical.target reached after 3.585s in userspace.
Funny enough I was on holiday last week and turned off the electricity completely (before I read your comment @MrLavender). So this might’ve actually done the trick. Marking as the solution for now. Thank you all :slight_smile:
I still have those USB errors though :confused: But everything works so â– â– â– â–  it
