Logout hangs after application GUIs close but never finishes logout process
Hello! Like the title mentions, I’m currently having an issue with a new installation of Manjaro will sort of hang and do nothing after applications have closed when logging out. It will sit at a black screen with no options. I can switch to a different tty and issue a reboot command but the DE seems to just stop or something.
There is also another issue where the DE seems to just lock up during normal use, not even during a logout or shutdown. I can similarly go to another tty and reboot and I’m not sure if these may be related but I wanted to mention for awareness and happy to do a separate support request later if it persists after correcting the current logout/shutdown one. The random lock up is far less reproducible, so makes more sense to wait.
inxi
  Kernel: 6.11.2-4-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: root=UUID=ccee3d16-0810-4142-afc7-a57634bcd5d4 rw quiet
    cryptdevice=UUID=ad4f54fd-68ec-48ab-aa93-4ef78a7713f7:luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7
    root=/dev/mapper/luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7 splash
    udev.log_priority=3 initrd=\initramfs-6.11-x86_64.img
  Desktop: KDE Plasma v: 6.1.5 tk: Qt v: N/A info: frameworks v: 6.6.0
  Type: Laptop System: ASUSTeK product: ROG Zephyrus G16 GU605MY_GU605MY
    v: 1.0 serial: <superuser required>
  Mobo: ASUSTeK model: GU605MY v: 1.0 serial: <superuser required>
    uuid: <superuser required> UEFI: American Megatrends LLC. v: GU605MY.323
    date: 08/14/2024
  ID-1: BAT1 charge: 64.1 Wh (76.2%) condition: 84.1/89.8 Wh (93.7%)
    volts: 15.9 min: 15.9 model: ASUS A32-K55 type: Li-ion serial: N/A
    status: discharging
  System RAM: total: 32 GiB available: 30.76 GiB used: 5.59 GiB (18.2%)
  Array-1: capacity: 32 GiB slots: 8 modules: 8 EC: None
    max-module-size: 4 GiB note: est.
  Device-1: Controller0-ChannelA type: LPDDR5 detail: synchronous
    size: 4 GiB speed: 7467 MT/s volts: curr: 0.5 min: 0.5 max: 0.5
    width (bits): data: 16 total: 16 manufacturer: Samsung
    part-no: K3KL9L90CM-MGCT serial: N/A
  Device-2: Controller0-ChannelB type: LPDDR5 detail: synchronous
  Device-3: Controller0-ChannelC type: LPDDR5 detail: synchronous
  Device-4: Controller0-ChannelD type: LPDDR5 detail: synchronous
  Device-5: Controller1-ChannelA type: LPDDR5 detail: synchronous
  Device-6: Controller1-ChannelB type: LPDDR5 detail: synchronous
  Device-7: Controller1-ChannelC type: LPDDR5 detail: synchronous
  Device-8: Controller1-ChannelD type: LPDDR5 detail: synchronous
  Info: model: Intel Core Ultra 9 185H bits: 64 type: MST AMCP
    arch: Meteor Lake level: v3 note: check built: 2023+ process: Intel 4 (7nm)
    family: 6 model-id: 0xAA (170) stepping: 4 microcode: 0x1C
  Topology: cpus: 1x dies: 1 clusters: 9 cores: 16 threads: 22 mt: 6 tpc: 2
    st: 10 smt: enabled cache: 24 MiB note: check
  Speed (MHz): avg: 2001 min/max: 400/4800:5100:3800:2500 scaling:
    driver: intel_pstate governor: powersave cores: 1: 2001 2: 2001 3: 2001
    4: 2001 5: 2001 6: 2001 7: 2001 8: 2001 9: 2001 10: 2001 11: 2001 12: 2001
    13: 2001 14: 2001 15: 2001 16: 2001 17: 2001 18: 2001 19: 2001 20: 2001
    21: 2001 22: 2001 bogomips: 135212
    bts bus_lock_detect clflush clflushopt clwb cmov constant_tsc cpuid
    f16c flexpriority flush_l1d fma fpu fsgsbase fsrm fxsr gfni hfi ht hwp
    hwp_act_window hwp_epp hwp_notify hwp_pkg_req ibpb ibrs ibrs_enhanced ibt
    ida intel_pt invpcid lahf_lm lm mca mce md_clear mmx monitor movbe
    movdir64b movdiri msr mtrr nonstop_tsc nopl nx ospke pae pat pbe pcid
    pclmulqdq pconfig pdcm pdpe1gb pebs pge pku pln pni popcnt pse pse36 pts
    rdpid rdrand rdseed rdtscp rep_good sdbg sep serialize sha_ni smap smep
    smx split_lock_detect ss ssbd sse sse2 sse4_1 sse4_2 ssse3 stibp syscall
    tm tm2 tpr_shadow tsc tsc_adjust tsc_deadline_timer tsc_known_freq umip
    user_shstk vaes vme vmx vnmi vpclmulqdq vpid waitpkg x2apic xgetbv1 xsave
    xsavec xsaveopt xsaves xtopology xtpr
    conditional; RSB filling; PBRSB-eIBRS: Not affected; BHI: BHI_DIS_S
  Device-1: Intel Meteor Lake-P [Intel Arc Graphics] vendor: ASUSTeK
    driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 4 (7nm+)
    built: 2023+ ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4
    bus-ID: 00:02.0 chip-ID: 8086:7d55 class-ID: 0300
  Device-2: NVIDIA GN21-X11 vendor: ASUSTeK driver: nvidia v: 550.120
    alternate: nouveau,nvidia_drm non-free: 550.xx+
    status: current (as of 2024-09) arch: Lovelace code: AD1xx
    process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 8
    link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 01:00.0
    chip-ID: 10de:2757 class-ID: 0300
  Device-3: Shinetech USB2.0 FHD UVC WebCam driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-7:3 chip-ID: 3277:0051
  Display: x11 server: X.Org v: 21.1.14 with: Xwayland v: 24.1.4
    compositor: kwin_x11 driver: X: loaded: modesetting,nvidia unloaded: nouveau
    alternate: fbdev,nv,vesa dri: iris gpu: i915 display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1600 s-dpi: 96 s-size: 677x423mm (26.65x16.65")
    s-diag: 798mm (31.43") monitors: <missing: xrandr>
  Monitor-1: eDP-1 model: Samsung ATNA60DL01-0 built: 2023 size-res: N/A
    gamma: 1.2 chroma: red: x: 0.682 y: 0.322 green: x: 0.235 y: 0.725 blue:
    x: 0.137 y: 0.047 white: x: 0.314 y: 0.329 diag: 405mm (15.9")
    modes: 2560x1600
  EDID-Warnings: 1: parse_edid: unknown tag 112
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast gbm: drv: iris
    surfaceless: drv: nvidia x11: drv: iris inactive: wayland,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.2.4-arch1.0.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Arc Graphics (MTL)
    device-ID: 8086:7d55 memory: 15.02 GiB unified: yes
  API: Vulkan v: 1.3.295 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 4090 Laptop GPU driver: nvidia v: 550.120 device-ID: 10de:2757
    surfaces: xcb,xlib device: 1 type: integrated-gpu name: Intel Arc
    Graphics (MTL) driver: mesa intel v: 24.2.4-arch1.0.1 device-ID: 8086:7d55
    surfaces: xcb,xlib
  Device-1: Intel Meteor Lake-P HD Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel alternate: snd_sof_pci_intel_mtl bus-ID: 00:1f.3
    chip-ID: 8086:7e28 class-ID: 0403
  Device-2: NVIDIA vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie:
    gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
    bus-ID: 01:00.1 chip-ID: 10de:22bb class-ID: 0403
  API: ALSA v: k6.11.2-4-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.2.5 status: active with: 1: pipewire-pulse
  Device-1: Intel Meteor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:7e40 class-ID: 0280
  Device-1: Intel AX211 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:5 chip-ID: 8087:0033
    class-ID: e001
  Device-1: luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7 maj-min: 254:0
    type: LUKS dm: dm-0 size: 3.64 TiB
  Components:
  p-1: nvme1n1p3 maj-min: 259:8 size: 3.64 TiB
  Local Storage: total: 7.28 TiB used: 259.06 GiB (3.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB
    size: 3.64 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 32.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:5 vendor: Crucial model: CT4000P3PSSD8
    lanes: 4 tech: SSD serial: <filter> fw-rev: P9CR40D temp: 32.9 C
    scheme: GPT
  ID-1: / raw-size: 3.64 TiB size: 3.58 TiB (98.40%) used: 258.63 GiB (7.1%)
    fs: ext4 dev: /dev/dm-0 maj-min: 254:0
    mapped: luks-ad4f54fd-68ec-48ab-aa93-4ef78a7713f7 label: N/A
    uuid: ccee3d16-0810-4142-afc7-a57634bcd5d4
  ID-2: /boot raw-size: 1000 MiB size: 965.9 MiB (96.59%)
    used: 423.4 MiB (43.8%) fs: ext4 dev: /dev/nvme1n1p2 maj-min: 259:7
    label: N/A uuid: 10d6d172-d3ca-4830-81d0-84b61d4edd25
  ID-3: /boot/efi raw-size: 550 MiB size: 548.9 MiB (99.80%)
    used: 12.7 MiB (2.3%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:6 label: N/A
    uuid: 8666-C110
  ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 16 MiB fs: <superuser required>
    label: N/A uuid: N/A
  ID-2: /dev/nvme0n1p2 maj-min: 259:2 size: 3.64 TiB
    fs: <superuser required> label: N/A uuid: N/A
  ID-3: /dev/nvme0n1p3 maj-min: 259:3 size: 500 MiB fs: vfat label: N/A
    uuid: 4622-C39B
  ID-4: /dev/nvme0n1p4 maj-min: 259:4 size: 791 MiB fs: ntfs label: N/A
    uuid: B49476299475EDEC
  Hub-1: 1-0:1 info: hi-speed hub with single TT ports: 1 rev: 2.0
  Hub-3: 3-0:1 info: hi-speed hub with single TT ports: 12 rev: 2.0
  Device-1: 3-6:2 info: ASUSTek ITE Device(8910) type: keyboard
    driver: asus,usbhid interfaces: 1 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:19b6 class-ID: 0301
  Device-2: 3-7:3 info: Shinetech USB2.0 FHD UVC WebCam type: video
    driver: uvcvideo interfaces: 5 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 3277:0051 class-ID: fe01
    serial: <filter>
  Device-3: 3-8:4 info: ASUSTek ITE Device(8910) type: keyboard
    lanes: 1 mode: 1.1 power: 100mA chip-ID: 0b05:193b class-ID: 0301
  Device-4: 3-10:5 info: Intel AX211 Bluetooth type: bluetooth driver: btusb
    power: 100mA chip-ID: 8087:0033 class-ID: e001
  System Temperatures: cpu: 41.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 1900
  Packages: pm: pacman pkgs: 1344 libs: 381 tools: pamac,yay pm: flatpak
    pkgs: 0
    1: https://gsl-syd.mm.fcix.net/manjaro/stable/$repo/$arch
    2: https://mirror.easyname.at/manjaro/stable/$repo/$arch
    3: https://mirror.phoepsilonix.love/manjaro/stable/$repo/$arch
    4: https://ftp.psnc.pl/linux/manjaro/stable/$repo/$arch
    5: https://mirror.dkm.cz/manjaro/stable/$repo/$arch
    6: https://southfront.mm.fcix.net/manjaro/stable/$repo/$arch
    7: https://mirrors.nic.cz/manjaro/stable/$repo/$arch
    8: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
    9: https://irltoolkit.mm.fcix.net/manjaro/stable/$repo/$arch
    10: https://quantum-mirror.hu/mirrors/pub/manjaro/stable/$repo/$arch
    11: https://repo.ialab.dsu.edu/manjaro/stable/$repo/$arch
    12: https://opencolo.mm.fcix.net/manjaro/stable/$repo/$arch
    13: https://mirror.telepoint.bg/manjaro/stable/$repo/$arch
    14: https://ohioix.mm.fcix.net/manjaro/stable/$repo/$arch
    15: https://edgeuno-bog2.mm.fcix.net/manjaro/stable/$repo/$arch
    16: http://mirror.fcix.net/manjaro/stable/$repo/$arch
    17: https://mirror.archlinux.tw/Manjaro/stable/$repo/$arch
    18: http://ossmirror.mycloud.services/os/linux/manjaro/stable/$repo/$arch
    19: https://manjaro.ynh.ovh/stable/$repo/$arch
    20: https://fastmirror.pp.ua/manjaro/stable/$repo/$arch
    21: https://mirrors.ucr.ac.cr/manjaro/stable/$repo/$arch
    22: http://manjaro.mirrors.uk2.net/stable/$repo/$arch
    23: https://muug.ca/mirror/manjaro/stable/$repo/$arch
    24: https://manjaro.ipacct.com/manjaro/stable/$repo/$arch
    25: https://nocix.mm.fcix.net/manjaro/stable/$repo/$arch
    26: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    27: https://ask4.mm.fcix.net/manjaro/stable/$repo/$arch
    28: https://manjaro.c3sl.ufpr.br/stable/$repo/$arch
    29: https://mirrors.xtom.jp/manjaro/stable/$repo/$arch
    30: https://mirror.truenetwork.ru/manjaro/stable/$repo/$arch
    31: http://ftp.tsukuba.wide.ad.jp/Linux/manjaro/stable/$repo/$arch
    32: https://nnenix.mm.fcix.net/manjaro/stable/$repo/$arch
    33: https://ftp.nluug.nl/pub/os/Linux/distr/manjaro/stable/$repo/$arch
    34: https://manjaro.mirrors.lavatech.top/stable/$repo/$arch
    35: http://mirror.xeonbd.com/manjaro/stable/$repo/$arch
    36: https://codingflyboy.mm.fcix.net/manjaro/stable/$repo/$arch
    37: https://ridgewireless.mm.fcix.net/manjaro/stable/$repo/$arch
    38: https://ftp.halifax.rwth-aachen.de/manjaro/stable/$repo/$arch
    39: https://mirror.netcologne.de/manjaro/stable/$repo/$arch
    40: https://mirror.raiolanetworks.com/manjaro/stable/$repo/$arch
    41: https://manjarolinux-mirror.cloud.mu/stable/$repo/$arch
    42: https://mirror.leitecastro.com/manjaro/stable/$repo/$arch
    43: https://mirror.bouwhuis.network/manjaro/stable/$repo/$arch
    44: https://mirrors.xtom.de/manjaro/stable/$repo/$arch
    45: https://ipng.mm.fcix.net/manjaro/stable/$repo/$arch
    46: https://mirror.23m.com/manjaro/stable/$repo/$arch
    47: https://mirrors.manjaro.org/repo/stable/$repo/$arch
    48: https://ziply.mm.fcix.net/manjaro/stable/$repo/$arch
    49: https://mirror.koddos.net/manjaro/stable/$repo/$arch
    50: https://mirror.albony.xyz/manjaro/stable/$repo/$arch
    51: https://mirror.zetup.net/manjaro/stable/$repo/$arch
    52: https://mirrors.xtom.ee/manjaro/stable/$repo/$arch
    53: https://mirrors.dotsrc.org/manjaro/stable/$repo/$arch
    54: http://ftp.belnet.be/mirrors/manjaro/repos/stable/$repo/$arch
    55: https://www.mirrorservice.org/sites/repo.manjaro.org/repos/stable/$repo/$arch
    56: https://mirror.freedif.org/Manjaro/stable/$repo/$arch
    57: https://uvermont.mm.fcix.net/manjaro/stable/$repo/$arch
    58: https://mirror.funami.tech/manjaro/stable/$repo/$arch
    59: https://mirror.math.princeton.edu/pub/manjaro/stable/$repo/$arch
    60: https://mirrors.sonic.net/manjaro/stable/$repo/$arch
    61: https://volico.mm.fcix.net/manjaro/stable/$repo/$arch
    62: https://mnvoip.mm.fcix.net/manjaro/stable/$repo/$arch
    63: https://mirrors2.manjaro.org/stable/$repo/$arch
    64: https://mirror.init7.net/manjaro/stable/$repo/$arch
    65: https://mirror.xenyth.net/manjaro/stable/$repo/$arch
    66: http://ftp.tu-chemnitz.de/pub/linux/manjaro/stable/$repo/$arch
    67: https://cofractal-ewr.mm.fcix.net/manjaro/stable/$repo/$arch
    68: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    69: https://ftpmirror1.infania.net/mirror/manjaro/stable/$repo/$arch
    70: https://coresite.mm.fcix.net/manjaro/stable/$repo/$arch
    71: https://mirrors.cicku.me/manjaro/stable/$repo/$arch
    72: http://mirror.is.co.za/mirrors/manjaro.org/stable/$repo/$arch
    73: https://mirror.2degrees.nz/manjaro/stable/$repo/$arch
    74: https://mirror.ibakerserver.pt/manjaro/stable/$repo/$arch
    75: https://manjaro.kurdy.org/stable/$repo/$arch
    76: https://forksystems.mm.fcix.net/manjaro/stable/$repo/$arch
    77: https://manjaro.mirror.wearetriple.com/stable/$repo/$arch
    78: https://mirrors.ocf.berkeley.edu/manjaro/stable/$repo/$arch
    79: https://mirror.futureweb.be/manjaro/stable/$repo/$arch
    80: http://ftp.uni-kl.de/pub/linux/manjaro/stable/$repo/$arch
    81: https://mirrors.jlu.edu.cn/manjaro/stable/$repo/$arch
    82: https://mirrors.sjtug.sjtu.edu.cn/manjaro/stable/$repo/$arch
    83: http://manjaro.grena.ge/stable/$repo/$arch
    84: http://ftp.snt.utwente.nl/pub/linux/manjaro/stable/$repo/$arch
    85: https://mirror.yandex.ru/mirrors/manjaro/stable/$repo/$arch
    86: https://ftp.lysator.liu.se/pub/manjaro/stable/$repo/$arch
    87: https://mirror.kamtv.ru/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 430
  1: cpu: 31.0% command: firefox pid: 1560 mem: 665.9 MiB (2.1%)
  2: cpu: 12.8% command: firefox pid: 2889 mem: 686.5 MiB (2.1%)
  3: cpu: 9.0% command: firefox pid: 2317 mem: 388.7 MiB (1.2%)
  4: cpu: 8.4% command: firefox pid: 3335 mem: 287.8 MiB (0.9%)
  5: cpu: 5.2% command: kwin_x11 pid: 1143 mem: 204.5 MiB (0.6%)
  Memory top: 5 of 430
  1: mem: 686.5 MiB (2.1%) command: firefox pid: 2889 cpu: 12.8%
  2: mem: 665.9 MiB (2.1%) command: firefox pid: 1560 cpu: 31.0%
  3: mem: 388.7 MiB (1.2%) command: firefox pid: 2317 cpu: 9.0%
  4: mem: 368.3 MiB (1.1%) command: plasmashell pid: 1182 cpu: 0.9%
  5: mem: 330.8 MiB (1.0%) command: Discord pid: 2928 cpu: 3.4%
  Processes: 430 Power: uptime: 17m states: freeze,mem,disk suspend: s2idle
    avail: deep wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.27 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 256 default: graphical
    tool: systemctl
  Compilers: gcc: 14.2.1 Shell: Zsh v: 5.9 default: Bash v: 5.2.37
    running-in: konsole inxi: 3.3.36
journalctl --boot=-1 --priority=3 --catalog --no-pager
Nov 27 13:50:48 allie kernel: i915 0000:00:02.0: [drm] *ERROR* GT1: GSC proxy component didn't bind within the
 expected timeout
Nov 27 13:50:48 allie kernel: i915 0000:00:02.0: [drm] *ERROR* GT1: GSC proxy handler failed to init
Nov 27 13:50:48 allie kernel: intel_vpu 0000:00:0b.0: [drm] *ERROR* ivpu_fw_request(): Failed to request firmw
are: -2
Nov 27 13:50:48 allie kernel: intel_vpu 0000:00:0b.0: probe with driver intel_vpu failed with error -2
Nov 27 13:50:48 allie kernel: iwlwifi 0000:00:14.3: BIOS contains WGDS but no WRDS
Nov 27 13:50:48 allie kernel: iwlwifi 0000:00:14.3: Not valid error log pointer 0x0024B5C0 for RT uCode
Nov 27 13:50:49 allie kernel:
Nov 27 13:50:50 allie kernel: Bluetooth: hci0: Malformed MSFT vendor event: 0x02
Nov 27 13:50:50 allie kernel: iwlwifi 0000:00:14.3: Not valid error log pointer 0x0024B5C0 for RT uCode
Nov 27 13:50:53 allie kernel: ucsi_acpi USBC000:00: error -ETIMEDOUT: PPM init failed
Nov 27 13:50:53 allie systemd-backlight[1012]: nvidia_0: Failed to write system 'brightness' attribute: Invali
d argument
Nov 27 13:50:53 allie systemd[1]: Failed to start Load/Save Screen Backlight Brightness of backlight:nvidia_0.
β–‘β–‘ Subject: A start job for unit systemd-backlight@backlight:nvidia_0.service has failed
β–‘β–‘ Defined-By: systemd
β–‘β–‘ Support: https://forum.manjaro.org/c/support
β–‘β–‘
β–‘β–‘ A start job for unit systemd-backlight@backlight:nvidia_0.service has finished with a failure.
β–‘β–‘
β–‘β–‘ The job identifier is 1751 and the job result is failed.
Nov 27 13:50:53 allie systemd-backlight[1014]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 1767 and the job result is failed.
Nov 27 13:50:53 allie systemd-backlight[1016]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 1784 and the job result is failed.
Nov 27 13:50:53 allie systemd-backlight[1018]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 1801 and the job result is failed.
Nov 27 13:50:53 allie systemd-backlight[1020]: nvidia_0: Failed to write system 'brightness' attribute: Invalid argument
β–‘β–‘
β–‘β–‘
β–‘β–‘ The job identifier is 1818 and the job result is failed.
 expected timeout
are: -2
d argument
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
β–‘β–‘
Welcome to the forum. Your logout hang may be related to an issue with Plasma’s session saving feature. See β€œKDE Plasma hangs on Shutdown, Restart and Logout”:
With KDE Plasma 6.1, the session saving feature can make Plasma hang.
A workaround is to disable it in System settings > Session > Desktop Session, by choosing β€œStart with an empty session”.
I also see this:
This may not be the cause, but myself and others do advise to have at least some swap available. :wink:
Thank you for the feedback from each of you, @Takakage and @BG405! I’m going to read through the post and try to add swap tonight. Need to refamiliarize myself with the process to shrink the luks for it. I already miss hibernate and just been putting off addressing that, so maybe a two-for-one.
