Logout doesn't work when pressed from the UI and freezes the shutdown option
I noticed that after the latest update, I am unable to use the logout button, if I did it takes me to the screen to confirm that I want to log out, I press yes, then it does nothing.
After that, if I press the button to shut down, it does not shut down.
However if from the menu initially I just press shutdown it shuts down with no issues or freezes.
I can shut down manually from the CLI without any issues if I press on logout first.
Is this a common problem with other users?
