The good news is the KDE update was a success! I am happy the update retained the classic kicker menu. I like those favorites.
The bad news is that logout still does not work. Hmmm.
Does that also happen when you create a new user and log in and log out there???
Yes. I just get a black screen with a black cursor. The cursor moves, but there is nothing to click on.
I get get a tty terminal by pressing ctl alt F2.
So I at least can get to a CLI from there, do terminal work, etc.
I would very much like to get back the sddm theme and gui on logout.
An inxi --admin --verbosity=7 --filter --no-host --width
would be the minimum required information… (Personally Identifiable Information like serial numbers and MAC addresses will be filtered out by the above command)
The output to inxi --admin --verbosity=7 --filter --no-host --width
is:
Kernel: 5.4.100-1-MANJARO x86_64 bits: 64 compiler: gcc v: 10.2.1
root=UUID=3e92a86c-02d3-4713-a91b-25cc8e788b68 rw quiet apparmor=1
Desktop: KDE Plasma 5.21.1 tk: Qt 5.15.2 wm: kwin_x11 dm: SDDM
Distro: Manjaro Linux
Type: Portable System: Dell product: XPS M1330 v: N/A serial: <filter>
Chassis: type: 8 serial: <filter>
Mobo: Dell model: 0U8042 serial: <filter> BIOS: Dell v: A15 date: 12/26/2008
ID-1: BAT0 charge: 35.7 Wh condition: 35.7/48.8 Wh (73%) volts: 12.6/11.1
model: Sony DELL 00 type: Li-ion serial: <filter> status: Full
RAM: total: 5.81 GiB used: 4.27 GiB (73.6%)
Info: Dual Core model: Intel Core2 Duo T9300 bits: 64 type: MCP arch: Penryn
family: 6 model-id: 17 (23) stepping: 6 microcode: 60F L2 cache: 6 MiB
bogomips: 9975
Speed: 2493 MHz min/max: 800/2501 MHz boost: enabled Core speeds (MHz):
1: 2493 2: 2553
Flags: acpi aperfmperf apic arch_perfmon bts clflush cmov constant_tsc cpuid
cx16 cx8 de ds_cpl dtes64 dtherm dts est flexpriority fpu fxsr ht ida
lahf_lm lm mca mce mmx monitor msr mtrr nopl nx pae pat pbe pdcm pebs pge
pni pse pse36 pti rep_good sep sse sse2 sse4_1 ssse3 syscall tm tm2
tpr_shadow tsc vme vmx vnmi xtpr
Type: l1tf mitigation: PTE Inversion; VMX: EPT disabled
Type: mds
status: Vulnerable: Clear CPU buffers attempted, no microcode; SMT disabled
Type: spectre_v2
mitigation: Full generic retpoline, STIBP: disabled, RSB filling
Device-1: NVIDIA G86M [GeForce 8400M GS] vendor: Dell driver: nouveau
v: kernel bus ID: 01:00.0 chip ID: 10de:0427 class ID: 0300
Device-2: OmniVision OV2640 Webcam type: USB driver: uvcvideo bus ID: 2-6:5
chip ID: 05a9:2640 class ID: 0e02
Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver:
loaded: nouveau display ID: :0 screens: 1
Screen-1: 0 s-res: 3199x1080 s-dpi: 96 s-size: 844x285mm (33.2x11.2")
s-diag: 891mm (35.1")
Monitor-1: LVDS-1 res: 1280x800 hz: 60 dpi: 112 size: 290x180mm (11.4x7.1")
diag: 341mm (13.4")
Monitor-2: VGA-1 res: 1920x1080 hz: 60 dpi: 102 size: 477x268mm (18.8x10.6")
diag: 547mm (21.5")
OpenGL: renderer: N/A v: N/A direct render: N/A
Device-1: Intel 82801H HD Audio vendor: Dell driver: snd_hda_intel v: kernel
bus ID: 00:1b.0 chip ID: 8086:284b class ID: 0403
Sound Server: ALSA v: k5.4.100-1-MANJARO
Device-1: Broadcom NetLink BCM5906M Fast Ethernet PCI Express
vendor: Dell XPS M1330 driver: tg3 v: 3.137 port: ef00 bus ID: 09:00.0
chip ID: 14e4:1713 class ID: 0200
IF: enp9s0 state: down mac: <filter>
Device-2: Broadcom BCM4321 802.11a/b/g/n
vendor: Dell Wireless 1500 Draft 802.11n WLAN Mini-card
driver: b43-pci-bridge v: N/A modules: ssb port: ef00 bus ID: 0c:00.0
chip ID: 14e4:4328 class ID: 0280
IF-ID-1: wlan0 state: up mac: <filter>
Message: No Bluetooth data was found.
Local Storage: total: 745.22 GiB used: 230.69 GiB (31.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480M500SSD1
size: 447.13 GiB block size: physical: 4096 B logical: 512 B speed: 3.0 Gb/s
rotation: SSD serial: <filter> rev: MU05 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: Toshiba
model: External USB 3.0 size: 298.09 GiB block size: physical: 512 B
logical: 512 B serial: <filter> rev: 5438 scheme: MBR
ID-1: / raw size: 109.29 GiB size: 107.07 GiB (97.97%)
used: 47.29 GiB (44.2%) fs: ext4 dev: /dev/sda6 maj-min: 8:6 label: N/A
uuid: 3e92a86c-02d3-4713-a91b-25cc8e788b68
ID-2: /home raw size: 27.34 GiB size: 26.79 GiB (97.98%)
used: 18.57 GiB (69.3%) fs: ext4 dev: /dev/sda7 maj-min: 8:7 label: N/A
uuid: 02f13436-7816-4203-b6ff-4d05738d8f10
ID-3: /run/media/dougrrr/694cb388-e813-46a4-a62d-fb97753f30f3
raw size: 282.18 GiB size: 277.63 GiB (98.39%) used: 31.2 GiB (11.2%)
fs: ext4 dev: /dev/sda8 maj-min: 8:8 label: N/A
uuid: 694cb388-e813-46a4-a62d-fb97753f30f3
ID-4: /run/media/dougrrr/8559c6ef-bdab-4a7a-b7bc-ad63466d08c4
raw size: 46.16 GiB size: 45.31 GiB (98.16%) used: 25.48 GiB (56.2%)
fs: ext4 dev: /dev/sdb6 maj-min: 8:22 label: N/A
uuid: 8559c6ef-bdab-4a7a-b7bc-ad63466d08c4
ID-5: /run/media/dougrrr/PHOTOS raw size: 142.46 GiB
size: 142.42 GiB (99.98%) used: 31.51 GiB (22.1%) fs: vfat dev: /dev/sdb7
maj-min: 8:23 label: PHOTOS uuid: 1E77-1CE7
ID-6: /run/media/dougrrr/SYSTEM DRV1 raw size: 61.09 GiB
size: 60.97 GiB (99.80%) used: 37.23 GiB (61.1%) fs: vfat dev: /dev/sdb1
maj-min: 8:17 label: SYSTEM DRV1 uuid: 1DD4-3606
ID-7: /run/media/dougrrr/b4e3dbbe-6193-5935-e9f1-c27ea264622c
raw size: 23.56 GiB size: 23.06 GiB (97.90%) used: 12 KiB (0.0%) fs: ext4
dev: /dev/sda1 maj-min: 8:1 label: N/A
uuid: b4e3dbbe-6193-5935-e9f1-c27ea264622c
ID-8: /run/media/dougrrr/ed9bfd43-5378-4423-b056-967335247543
raw size: 48.37 GiB size: 47.5 GiB (98.18%) used: 39.41 GiB (83.0%) fs: ext4
dev: /dev/sdb5 maj-min: 8:21 label: N/A
uuid: ed9bfd43-5378-4423-b056-967335247543
Kernel: swappiness: 9 (default 60) cache pressure: 100 (default)
ID-1: swap-1 type: partition size: 4.75 GiB used: 2.5 MiB (0.1%)
priority: 1024 dev: /dev/sda5 maj-min: 8:5 label: N/A
uuid: 8a99da3b-909d-3bfb-ded7-0e23dda7e60d
ID-1: /dev/sda2 maj-min: 8:2 size: 1 KiB fs: <superuser required> label: N/A
uuid: N/A
ID-2: /dev/sdb2 maj-min: 8:18 size: 1 KiB fs: <superuser required>
label: N/A uuid: N/A
Hub-1: 1-0:1 info: Full speed (or root) Hub ports: 4 rev: 2.0
speed: 480 Mb/s chip ID: 1d6b:0002 class ID: 0900
Hub-2: 2-0:1 info: Full speed (or root) Hub ports: 6 rev: 2.0
Hub-3: 2-2:2 info: NEC HighSpeed Hub ports: 4 rev: 2.0 speed: 480 Mb/s
chip ID: 0409:005a class ID: 0900
Device-1: 2-2.1:4 info: Sunplus Innovation Gaming mouse [Philips SPK9304]
type: Mouse driver: hid-generic,usbhid interfaces: 1 rev: 2.0
speed: 1.5 Mb/s chip ID: 1bcf:08a0 class ID: 0301
Device-2: 2-2.3:6 info: Holtek Keyboard LKS02 type: Keyboard,HID
chip ID: 04d9:1702 class ID: 0300
Device-3: 2-2.4:7 info: Toshiba America Canvio Desk type: Mass Storage
driver: usb-storage interfaces: 1 rev: 2.1 speed: 480 Mb/s
chip ID: 0480:d011 class ID: 0806 serial: <filter>
Device-4: 2-6:5 info: OmniVision OV2640 Webcam type: Video driver: uvcvideo
interfaces: 2 rev: 2.0 speed: 480 Mb/s chip ID: 05a9:2640 class ID: 0e02
Hub-4: 3-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
chip ID: 1d6b:0001 class ID: 0900
Hub-5: 4-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-6: 5-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-7: 6-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Hub-8: 7-0:1 info: Full speed (or root) Hub ports: 2 rev: 1.1 speed: 12 Mb/s
Device-1: 7-1:2 info: STMicro Fingerprint Reader type: <vendor specific>
driver: N/A interfaces: 1 rev: 1.0 speed: 12 Mb/s chip ID: 0483:2016
class ID: 0000
System Temperatures: cpu: 55.5 C mobo: N/A gpu: nouveau temp: 75.0 C
Processes: 196 Uptime: 2m wakeups: 1 Init: systemd v: 2
Looking at the sddm log, there is this suspect line:
Failed to read display number from pipe
In the future, when providing code/output, please copy-paste that output in-between 3 backticks ``` at the beginning and end of the code/text so that the output looks like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua.
Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat.
Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur.
Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.
instead of like this:
Lorem ipsum dolor sit amet, consectetur adipiscing elit, sed do eiusmod tempor incididunt ut labore et dolore magna aliqua. Ut enim ad minim veniam, quis nostrud exercitation ullamco laboris nisi ut aliquip ex ea commodo consequat. Duis aute irure dolor in reprehenderit in voluptate velit esse cillum dolore eu fugiat nulla pariatur. Excepteur sint occaecat cupidatat non proident, sunt in culpa qui officia deserunt mollit anim id est laborum.`
(as that makes both our lives much easier)
No need to do anything right now as I’m an editor here on this site and have fixed it for you already. However, in the future I might not see your post so review my edits by pushing the orange pencil above the post I just fixed.
Once is enough! (you pasted it twice)
Always provide the commands that you used to provide info:
Does this also happen on Kernel 5.10? (that’s LTS too nowadays…)
This also happens to me.
5.11 kernel
Ryzen 1700
Nvidia 980
Will try to post log here later
Different kernel, different video driver, same problem. Seems KDE plasma related.
Please don’t post a log… Let’s see if we can get this solved with @deroberts1 and when it is, just use the same solution and his question and solution!
Try logging out, switch to a TTY and then execute:
tail --lines=25 ~/.local/share/sddm/xorg-session.log
and provide the output of that, please?
Gdk-ERROR **: BadWindow (invalid Window parameter)
This is not all the lines it produces. I may not get back on Linux today. We will be manning sump pumps to battle the rising Ohio River.
Good luck manning the pumps!
Down to running two sump pumps. Progress! LOL!
I reported the bug to KDE. It had already been found by someone else. I added the results of the tail command.
Can you edit your answer with a link to the bug? Then we can close this question!
I found a similar thread here on the forum, where they mentioned that KWIN-lowlatency was the problem. I tried removing it, and that solved it for me.
I do not think I can do that, when I’m not the original topic starter?
Hi Fabby and Sarge, I am not aware of any solution yet. I am hoping to hear back when they figure it out. So far though, no fix as far as I can tell. I tried logging out after the update yesterday. No change.
