Recently bought a Logitech Triathlon M720 mouse which is lagging when connected through bluetooth. bluetooth service is publishing following errors in journal:
I’ve the same mouse and sometimes the same problem.
Simply switch the mouse off with the switch on the underside and then on again immediately.
For me it works fine again.
I bought this thing 5 days ago. Restarted both the computer and the mouse at least 5 times today also, still it doesn’t seem to work for me properly.
It works flawlessly after booting for 30 seconds then again starts lagging.
I tried using the unifying receiver once, it did not work for me, as the instructions mentioned in quick start manual were only meant for Mac and Windows. It mentions a shortcut which I couldn’t map in linux :
Windows : fn + P
Mac : fn + O
How do you make it work with Linux ? Does it require any special software ?
