I got recently a Logitech Ergo K860 keyboard with Norwegian Layout. The connection to my manjaro workstation works fine, but some of the keys seem switched. Examples:
- The keys for pipe-character (“|”) and the “<>” are switched.
- Alt.gr. and opt|ctrl keys are switched
- I cannot type an “@” using the key next to ENTER.
I tried all different norwegian keyboard layouts, as well as several of the keyboard models in the manjaro settings, but nothing improves the experience.
Any suggestions on what to do in order to fix these issues?
Thank you.
base) [dejhost@Workstation ~]$ inxi --admin --verbosity=7 --filter --width
Kernel: 6.0.0-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
parameters: BOOT_IMAGE=/boot/vmlinuz-6.0-x86_64
root=UUID=7c6ac262-7b71-4cba-b35c-72277acbafa9 rw quiet apparmor=1
security=apparmor udev.log_priority=3 nmi_watchdog=0
Desktop: Xfce v: 4.16.1 tk: Gtk v: 3.24.34 info: docker, xfce4-panel
wm: xfwm v: 4.16.1 vt: 2 dm: 1: GDM v: 42.0 2: LightDM v: 1.32.0
note: stopped Distro: Manjaro Linux base: Arch Linux
Type: Desktop System: Micro-Star product: MS-7B89 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: B450M MORTAR MAX (MS-7B89) v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 2.70
date: 04/21/2020
Device-1: hidpp_battery_0 model: Logitech Wireless Keyboard ERGO K860
serial: <filter> charge: 100% (should be ignored) rechargeable: yes
status: discharging
RAM: total: 31.3 GiB used: 17.65 GiB (56.4%)
RAM Report: permissions: Unable to run dmidecode. Root privileges
required.
Info: model: AMD Ryzen 9 3900X bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
Topology: cpus: 1x cores: 12 tpc: 2 threads: 24 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB
L3: 64 MiB desc: 4x16 MiB
Speed (MHz): avg: 3326 high: 4468 min/max: 2200/4672 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 3598 2: 3600
3: 3600 4: 2200 5: 2200 6: 2012 7: 3599 8: 3599 9: 3599 10: 3598 11: 3599
12: 3600 13: 3600 14: 3602 15: 3598 16: 4468 17: 2200 18: 1990 19: 3599
20: 3596 21: 3599 22: 3596 23: 3601 24: 3592 bogomips: 182493
f16c flushbyasid fma fpu fsgsbase fxsr fxsr_opt ht hw_pstate ibpb ibs
pfthreshold pge pni popcnt pse pse36 rapl rdpid rdpru rdrand rdseed rdt_a
rdtscp rep_good sep sev sev_es sha_ni skinit smap smca smep ssbd sse sse2
sse4_1 sse4_2 sse4a ssse3 stibp succor svm svm_lock syscall tce topoext
tsc tsc_scale umip v_spec_ctrl v_vmsave_vmload vgif vmcb_clean vme vmmcall
wbnoinvd wdt xgetbv1 xsave xsavec xsaveerptr xsaveopt xsaves
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GA104 [GeForce RTX 3070] vendor: ASUSTeK driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-08) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 16 link-max: gen: 4
speed: 16 GT/s bus-ID: 26:00.0 chip-ID: 10de:2484 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-4.4:11 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.Org v: 21.1.4 with: Xwayland v: 22.1.3
compositor: xfwm v: 4.16.1 driver: X: loaded: nvidia gpu: nvidia
display-ID: :1.0 screens: 1
Screen-1: 0 s-res: 11520x2160 s-dpi: 96 s-size: 3048x572mm (120.00x22.52")
s-diag: 3101mm (122.09")
Monitor-1: DP-0 pos: primary,center res: 3840x2160 hz: 60 dpi: 163
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
Monitor-2: DP-2 pos: primary,left res: 3840x2160 hz: 60 dpi: 163
Monitor-3: DP-4 pos: right res: 3840x2160 hz: 60 dpi: 163
OpenGL: renderer: NVIDIA GeForce RTX 3070/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA GA104 High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 3-3.1.4:10 chip-ID: 0b0e:0410 pcie:
gen: 3 class-ID: 0300 speed: 8 GT/s serial: <filter> lanes: 16 link-max:
gen: 4 speed: 16 GT/s bus-ID: 26:00.1 chip-ID: 10de:228b class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 28:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: GN Netcom Jabra SPEAK 410 type: USB
driver: jabra,snd-usb-audio,usbhid
Device-4: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k6.0.0-1-MANJARO running: yes
Sound Server-4: PipeWire v: 0.3.57 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-1: br-a88cee8f84e5 state: down mac: <filter>
IF-ID-2: br-a96c1ef81739 state: up speed: 10000 Mbps duplex: unknown
mac: <filter>
IP v6: <filter> scope: link
IF-ID-3: br-d5799e778888 state: down mac: <filter>
Message: Output throttled. IPs: 1; Limit: 10; Override: --limit [1-x;-1
all]
IF-ID-4: docker0 state: down mac: <filter>
all]
IF-ID-5: veth1634074 state: up speed: 10000 Mbps duplex: full
mac: <filter>
IF-ID-6: veth6f8647a state: up speed: 10000 Mbps duplex: full
mac: <filter>
driver: btusb v: 0.8 bus-ID: 3-4.2:5 chip-ID: 0a12:0001 class-ID: e001
Local Storage: total: 1.75 TiB used: 1.13 TiB (64.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Corsair model: Force MP510
size: 1.75 TiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 type: SSD serial: <filter> rev: ECFM22.5 temp: 38.9 C scheme: GPT
Optical-1: /dev/sr0 vendor: hp model: DVD-RAM GH82N rev: W204
dev-links: cdrom
ID-1: / raw-size: 1.33 TiB size: 1.31 TiB (98.35%) used: 1.13 TiB (86.2%)
fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5 label: N/A
uuid: 7c6ac262-7b71-4cba-b35c-72277acbafa9
ID-2: /boot/efi raw-size: 100 MiB size: 96 MiB (96.00%) used: 29.6 MiB
(30.8%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2 label: N/A
uuid: 9EFE-2CB7
ID-1: swap-1 type: file size: 38 GiB used: 1.98 GiB (5.2%) priority: -2
file: /swapfile
ID-2: swap-2 type: file size: 256 MiB used: 256 MiB (100.0%) priority: 50
file: /var/lib/systemd-swap/swapfc/1
ID-1: /dev/nvme0n1p1 maj-min: 259:1 size: 529 MiB fs: ntfs label: Recovery
uuid: A644FDD844FDAB67
ID-2: /dev/nvme0n1p3 maj-min: 259:3 size: 16 MiB fs: <superuser required>
label: N/A uuid: N/A
ID-3: /dev/nvme0n1p4 maj-min: 259:4 size: 428.38 GiB fs: ntfs label: N/A
uuid: 24D4FF51D4FF23A8
Hub-1: 1-0:1 info: Hi-speed hub with single TT ports: 10 rev: 2.0
Device-1: 1-9:2 info: eWBM Security Key(Goldengate G310) type: HID
driver: hid-generic,usbhid interfaces: 1 rev: 1.1 speed: 12 Mb/s
power: 100mA chip-ID: 311f:4a1a class-ID: 0300 serial: <filter>
Hub-2: 2-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
Hub-3: 3-0:1 info: Hi-speed hub with single TT ports: 4 rev: 2.0
Hub-4: 3-3:2 info: Genesys Logic USB 2.0 Hub / D-Link DUB-H4 ports: 4
rev: 2.0 speed: 480 Mb/s power: 100mA chip-ID: 05e3:0606 class-ID: 0900
Hub-5: 3-3.1:4 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
chip-ID: 2109:2811 class-ID: 0900
Device-1: 3-3.1.1:6 info: Logitech Unifying Receiver
type: Keyboard,Mouse,HID driver: logitech-djreceiver,usbhid interfaces: 3
rev: 2.0 speed: 12 Mb/s power: 98mA chip-ID: 046d:c52b class-ID: 0300
Device-2: 3-3.1.2:8 info: Xenta 2.4G Mouse type: Keyboard,Mouse
power: 100mA chip-ID: 1d57:0001 class-ID: 0301
Device-3: 3-3.1.3:9 info: Razer USA DeathAdder Elite type: Mouse,Keyboard
driver: hid-generic,usbhid interfaces: 3 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 1532:005c class-ID: 0300
Device-4: 3-3.1.4:10 info: GN Netcom Jabra SPEAK 410 type: Audio,HID
driver: jabra,snd-usb-audio,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s
power: 500mA chip-ID: 0b0e:0410 class-ID: 0300 serial: <filter>
Hub-6: 3-4:3 info: VIA Labs Hub ports: 4 rev: 2.1 speed: 480 Mb/s
Device-1: 3-4.2:5 info: Cambridge Silicon Radio Bluetooth Dongle (HCI
mode) type: Bluetooth driver: btusb interfaces: 2 rev: 2.0 speed: 12 Mb/s
power: 100mA chip-ID: 0a12:0001 class-ID: e001
Device-2: 3-4.4:11 info: Logitech HD Pro Webcam C920 type: Video,Audio
power: 500mA chip-ID: 046d:082d class-ID: 0102 serial: <filter>
Hub-7: 4-0:1 info: Super-speed hub ports: 4 rev: 3.1 speed: 10 Gb/s
System Temperatures: cpu: 54.4 C mobo: N/A gpu: nvidia temp: 55 C
Processes: 524 Uptime: 2d 3h 28m wakeups: 80 Init: systemd v: 251
default: graphical tool: systemctl Compilers: gcc: 12.2.0 alt: 10/11
clang: 14.0.6 Packages: 1620 pm: pacman pkgs: 1577 libs: 398
tools: pamac,yay pm: flatpak pkgs: 12 pm: snap pkgs: 31 Shell: Bash
v: 5.1.16 running-in: xfce4-terminal inxi: 3.3.21
