@nikgnomic
inxi -Fazy output:
Kernel: 5.19.1-3-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 12.1.1
parameters: BOOT_IMAGE=/boot/vmlinuz-5.19-x86_64
root=UUID=7d192cdc-01ab-4aa3-812c-ac114ab9a848 rw quiet splash apparmor=1
Desktop: GNOME v: 42.4 tk: GTK v: 3.24.34 wm: gnome-shell dm: GDM v: 42.0
Type: Desktop System: Micro-Star product: MS-7C02 v: 1.0
serial: <superuser required>
Mobo: Micro-Star model: B450 TOMAHAWK MAX (MS-7C02) v: 1.0
serial: <superuser required> BIOS: American Megatrends LLC. v: 3.C3
date: 09/27/2021
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M310/M310t
status: discharging
Device-2: hidpp_battery_1 model: Logitech K520 serial: <filter> charge: 70%
(should be ignored) rechargeable: yes status: discharging
Info: model: AMD Ryzen 5 3600 bits: 64 type: MT MCP arch: Zen 2 gen: 3
level: v3 built: 2020-22 process: TSMC n7 (7nm) family: 0x17 (23)
model-id: 0x71 (113) stepping: 0 microcode: 0x8701021
L1: 384 KiB desc: d-6x32 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 3532 high: 4200 min/max: 2200/4910 boost: enabled
scaling: driver: acpi-cpufreq governor: schedutil cores: 1: 4199 2: 4199
3: 4198 4: 2200 5: 4199 6: 2200 7: 4200 8: 4199 9: 4197 10: 2200 11: 4197
12: 2200 bogomips: 100824
Type: retbleed mitigation: untrained return thunk; SMT enabled with STIBP
protection
Type: spectre_v2 mitigation: Retpolines, IBPB: conditional, STIBP:
always-on, RSB filling, PBRSB-eIBRS: Not affected
Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] vendor: Gigabyte driver: nvidia
v: 515.65.01 alternate: nouveau,nvidia_drm non-free: 515.xx+ status: current
(as of 2022-08) arch: Pascal code: GP10x process: TSMC 16nm built: 2016-21
pcie: gen: 2 speed: 5 GT/s lanes: 2 link-max: lanes: 16 bus-ID: 25:00.0
chip-ID: 10de:1c82 class-ID: 0300
Device-2: Logitech HD Pro Webcam C920 type: USB
driver: snd-usb-audio,uvcvideo bus-ID: 3-1.3:10 chip-ID: 046d:082d
class-ID: 0102 serial: <filter>
Display: x11 server: X.org v: 1.21.1.4 with: Xwayland v: 22.1.3
compositor: gnome-shell driver: X: loaded: nvidia gpu: nvidia display-ID: :1
screens: 1
Screen-1: 0 s-res: 4480x1440 s-size: <missing: xdpyinfo>
Monitor-1: DVI-D-0 pos: right res: 1920x1080 hz: 60 dpi: 55
size: 886x498mm (34.88x19.61") diag: 1016mm (40.01") modes: N/A
Monitor-2: HDMI-0 pos: primary,left res: 2560x1440 hz: 60 dpi: 109
size: 597x336mm (23.5x13.23") diag: 685mm (26.97") modes: N/A
OpenGL: renderer: NVIDIA GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA
515.65.01 direct render: Yes
Device-1: NVIDIA GP107GL High Definition Audio vendor: Gigabyte
driver: snd_hda_intel bus-ID: 3-1.2.2.3:8 v: kernel pcie: chip-ID: 046d:0a29
class-ID: 0300 gen: 2 speed: 5 GT/s serial: <filter> lanes: 2 link-max:
lanes: 16 bus-ID: 25:00.1 chip-ID: 10de:0fb9 class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI
bus-ID: 2a:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech H600 [Wireless Headset] type: USB
driver: hid-generic,snd-usb-audio,usbhid
Device-4: Logitech HD Pro Webcam C920 type: USB
Sound Server-1: ALSA v: k5.19.1-3-MANJARO running: yes
Sound Server-2: PulseAudio v: 16.1 running: no
Sound Server-3: PipeWire v: 0.3.56 running: yes
vendor: Micro-Star MSI driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 port: f000 bus-ID: 22:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: enp34s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-2: Intel Wireless-AC 9260 driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 27:00.0 chip-ID: 8086:2526 class-ID: 0280
IF: wlp39s0 state: down mac: <filter>
Device-3: Realtek RTL8152 Fast Ethernet Adapter type: USB driver: r8152
bus-ID: 3-1.2.2.4:9 chip-ID: 0bda:8152 class-ID: 0000 serial: <filter>
IF: eth0 state: down mac: <filter>
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
IF-ID-2: vmnet8 state: unknown speed: N/A duplex: N/A mac: <filter>
Device-1: Intel Wireless-AC 9260 Bluetooth Adapter type: USB driver: btusb
v: 0.8 bus-ID: 1-10:3 chip-ID: 8087:0025 class-ID: e001
Local Storage: total: 2.04 TiB used: 625.43 GiB (30.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO Plus
1TB size: 931.51 GiB block-size: physical: 512 B logical: 512 B
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 2B2QEXM7
temp: 38.9 C scheme: MBR
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDSSDA240G
size: 223.57 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
type: SSD serial: <filter> rev: 00RL scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 type: USB vendor: Inateck model: RTL9210
size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 120 GiB size: 117.56 GiB (97.97%) used: 81.45 GiB (69.3%)
fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: partition size: 16 GiB used: 0 KiB (0.0%) priority: -2
dev: /dev/nvme0n1p3 maj-min: 259:3
System Temperatures: cpu: 48.5 C mobo: N/A gpu: nvidia temp: 58 C
Processes: 416 Uptime: 4h 34m wakeups: 27 Memory: 31.27 GiB used: 12.09 GiB
(38.7%) Init: systemd v: 251 default: graphical tool: systemctl Compilers:
gcc: 12.1.1 clang: 14.0.6 Packages: 1867 pm: pacman pkgs: 1846 libs: 368
tools: gnome-software,pamac pm: flatpak pkgs: 10 pm: snap pkgs: 11
Shell: Zsh v: 5.9 running-in: gnome-terminal inxi: 3.3.21
pactl list cards output
Card #43
Driver: alsa
Owner Module: n/a
Properties:
device.enum.api = "udev"
device.api = "alsa"
media.class = "Audio/Device"
api.alsa.path = "hw:0"
api.alsa.card = "0"
api.alsa.card.name = "HDA NVidia"
api.alsa.card.longname = "HDA NVidia at 0xfc080000 irq 34"
device.plugged.usec = "4380659"
device.bus_path = "pci-0000:25:00.1"
sysfs.path = "/sys/devices/pci0000:00/0000:00:01.3/0000:03:00.2/0000:20:04.0/0000:25:00.1/sound/card0"
device.bus = "pci"
device.subsystem = "sound"
device.vendor.id = "0x10de"
device.vendor.name = "NVIDIA Corporation"
device.product.id = "0x0fb9"
device.product.name = "GP107GL High Definition Audio Controller"
device.name = "alsa_card.pci-0000_25_00.1"
device.description = "GP107GL High Definition Audio Controller"
device.nick = "HDA NVidia"
device.icon_name = "audio-card-pci"
api.alsa.use-acp = "true"
api.acp.auto-port = "false"
factory.id = "14"
client.id = "31"
object.id = "42"
object.serial = "43"
object.path = "alsa:pcm:0"
alsa.card = "0"
alsa.card_name = "HDA NVidia"
alsa.long_card_name = "HDA NVidia at 0xfc080000 irq 34"
device.string = "0"
Profiles:
off: Off (sinks: 0, sources: 0, priority: 0, available: yes)
output:hdmi-stereo: Digital Stereo (HDMI) Output (sinks: 1, sources: 0, priority: 5900, available: yes)
output:hdmi-stereo-extra1: Digital Stereo (HDMI 2) Output (sinks: 1, sources: 0, priority: 5700, available: yes)
output:hdmi-stereo-extra2: Digital Stereo (HDMI 3) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra3: Digital Stereo (HDMI 4) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra4: Digital Stereo (HDMI 5) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-stereo-extra5: Digital Stereo (HDMI 6) Output (sinks: 1, sources: 0, priority: 5700, available: no)
output:hdmi-surround-extra2: Digital Surround 5.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra2: Digital Surround 7.1 (HDMI 3) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra3: Digital Surround 5.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra3: Digital Surround 7.1 (HDMI 4) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra4: Digital Surround 5.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra4: Digital Surround 7.1 (HDMI 5) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround-extra5: Digital Surround 5.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
output:hdmi-surround71-extra5: Digital Surround 7.1 (HDMI 6) Output (sinks: 1, sources: 0, priority: 600, available: no)
pro-audio: Pro Audio (sinks: 6, sources: 0, priority: 1, available: yes)
Active Profile: output:hdmi-stereo-extra1
Ports:
hdmi-output-0: HDMI / DisplayPort (type: HDMI, priority: 5900, latency offset: 0 usec, availability group: Legacy 1, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 1"
card.profile.port = "0"
device.product.name = "SAMSUNG
Part of profile(s): output:hdmi-stereo
hdmi-output-1: HDMI / DisplayPort 2 (type: HDMI, priority: 5800, latency offset: 0 usec, availability group: Legacy 2, available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 2"
card.profile.port = "1"
device.product.name = "2778X
Part of profile(s): output:hdmi-stereo-extra1
hdmi-output-2: HDMI / DisplayPort 3 (type: HDMI, priority: 5700, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 3"
card.profile.port = "2"
Part of profile(s): output:hdmi-stereo-extra2, output:hdmi-surround-extra2, output:hdmi-surround71-extra2
hdmi-output-3: HDMI / DisplayPort 4 (type: HDMI, priority: 5600, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 4"
card.profile.port = "3"
Part of profile(s): output:hdmi-stereo-extra3, output:hdmi-surround-extra3, output:hdmi-surround71-extra3
hdmi-output-4: HDMI / DisplayPort 5 (type: HDMI, priority: 5500, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 5"
card.profile.port = "4"
Part of profile(s): output:hdmi-stereo-extra4, output:hdmi-surround-extra4, output:hdmi-surround71-extra4
hdmi-output-5: HDMI / DisplayPort 6 (type: HDMI, priority: 5400, latency offset: 0 usec, availability group: Legacy 6, not available)
Properties:
port.type = "hdmi"
port.availability-group = "Legacy 6"
card.profile.port = "5"
Part of profile(s): output:hdmi-stereo-extra5, output:hdmi-surround-extra5, output:hdmi-surround71-extra5
Card #45
Driver: alsa
Owner Module: n/a
Properties:
device.api = "alsa"
api.alsa.path = "hw:2"
api.alsa.card = "2"
api.alsa.card.name = "Logitech Wireless Headset"
api.alsa.card.longname = "Logitech Logitech Wireless Headset at usb-0000:2a:00.3-1.2.2.3, full speed"
device.plugged.usec = "6687047"
device.bus_path = "pci-0000:2a:00.3-usb-0:1.2.2.3:1.0"
sysfs.path = "/sys/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-1/3-1.2/3-1.2.2/3-1.2.2.3/3-1.2.2.3:1.0/sound/card2"
device.bus-id = "usb-Logitech_Logitech_Wireless_Headset_000D44D3C07D-00"
device.bus = "usb"
device.vendor.id = "0x046d"
device.vendor.name = "Logitech, Inc."
device.product.id = "0x0a29"
device.product.name = "H600 [Wireless Headset]"
device.serial = "Logitech_Logitech_Wireless_Headset_000D44D3C07D"
device.form_factor = "headset"
device.name = "alsa_card.usb-Logitech_Logitech_Wireless_Headset_000D44D3C07D-00"
device.description = "H600 [Wireless Headset]"
device.nick = "Logitech Wireless Headset"
device.icon_name = "audio-headset-usb"
api.dbus.ReserveDevice1 = "Audio2"
factory.id = "14"
client.id = "31"
object.id = "44"
object.serial = "45"
object.path = "alsa:pcm:2"
alsa.card = "2"
alsa.card_name = "Logitech Wireless Headset"
alsa.long_card_name = "Logitech Logitech Wireless Headset at usb-0000:2a:00.3-1.2.2.3, full speed"
alsa.driver_name = "snd_usb_audio"
device.string = "2"
Profiles:
output:analog-stereo+input:mono-fallback: Analog Stereo Output + Mono Input (sinks: 1, sources: 1, priority: 6501, available: yes)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: yes)
pro-audio: Pro Audio (sinks: 1, sources: 1, priority: 1, available: yes)
input:mono-fallback: Mono Input (sinks: 0, sources: 1, priority: 1, available: yes)
Active Profile: output:analog-stereo+input:mono-fallback
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, latency offset: 0 usec, availability unknown)
Properties:
port.type = "mic"
Part of profile(s): input:mono-fallback, output:analog-stereo+input:mono-fallback
analog-output: Analog Output (type: Analog, priority: 9900, latency offset: 0 usec, availability unknown)
Properties:
port.type = "analog"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:mono-fallback
Card #49
Driver: alsa
Owner Module: n/a
Properties:
device.api = "alsa"
api.alsa.path = "hw:1"
api.alsa.card = "1"
api.alsa.card.name = "HD-Audio Generic"
api.alsa.card.longname = "HD-Audio Generic at 0xfc800000 irq 89"
device.plugged.usec = "5974163"
device.bus_path = "pci-0000:2a:00.4"
sysfs.path = "/sys/devices/pci0000:00/0000:00:08.1/0000:2a:00.4/sound/card1"
device.bus = "pci"
device.vendor.id = "0x1022"
device.vendor.name = "Advanced Micro Devices, Inc. [AMD]"
device.product.id = "0x1487"
device.product.name = "Starship/Matisse HD Audio Controller"
device.name = "alsa_card.pci-0000_2a_00.4"
device.description = "Starship/Matisse HD Audio Controller"
device.nick = "HD-Audio Generic"
api.dbus.ReserveDevice1 = "Audio1"
factory.id = "14"
client.id = "31"
object.id = "48"
object.serial = "49"
object.path = "alsa:pcm:1"
alsa.card = "1"
alsa.card_name = "HD-Audio Generic"
alsa.long_card_name = "HD-Audio Generic at 0xfc800000 irq 89"
device.string = "1"
Profiles:
output:analog-stereo+input:analog-stereo: Analog Stereo Duplex (sinks: 1, sources: 1, priority: 6565, available: no)
output:analog-stereo: Analog Stereo Output (sinks: 1, sources: 0, priority: 6500, available: no)
output:analog-surround-21+input:analog-stereo: Analog Surround 2.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-41+input:analog-stereo: Analog Surround 4.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-51+input:analog-stereo: Analog Surround 5.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1365, available: no)
output:analog-surround-21: Analog Surround 2.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-41: Analog Surround 4.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-51: Analog Surround 5.1 Output (sinks: 1, sources: 0, priority: 1300, available: no)
output:analog-surround-40+input:analog-stereo: Analog Surround 4.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-50+input:analog-stereo: Analog Surround 5.0 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-71+input:analog-stereo: Analog Surround 7.1 Output + Analog Stereo Input (sinks: 1, sources: 1, priority: 1265, available: no)
output:analog-surround-40: Analog Surround 4.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-50: Analog Surround 5.0 Output (sinks: 1, sources: 0, priority: 1200, available: no)
output:analog-surround-71: Analog Surround 7.1 Output (sinks: 1, sources: 0, priority: 1200, available: no)
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: no)
pro-audio: Pro Audio (sinks: 1, sources: 2, priority: 1, available: yes)
Active Profile: off
Ports:
analog-input-front-mic: Front Microphone (type: Mic, priority: 8500, latency offset: 0 usec, availability group: Legacy 1, not available)
Properties:
port.type = "mic"
Part of profile(s): input:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21+input:analog-stereo, output:analog-surround-40+input:analog-stereo, output:analog-surround-41+input:analog-stereo, output:analog-surround-50+input:analog-stereo, output:analog-surround-51+input:analog-stereo, output:analog-surround-71+input:analog-stereo
analog-input-rear-mic: Rear Microphone (type: Mic, priority: 8200, latency offset: 0 usec, availability group: Legacy 2, not available)
Properties:
port.type = "mic"
analog-input-linein: Line In (type: Line, priority: 8100, latency offset: 0 usec, availability group: Legacy 3, not available)
Properties:
port.type = "line"
analog-output-lineout: Line Out (type: Line, priority: 9000, latency offset: 0 usec, availability group: Legacy 4, not available)
Properties:
port.type = "line"
Part of profile(s): output:analog-stereo, output:analog-stereo+input:analog-stereo, output:analog-surround-21, output:analog-surround-21+input:analog-stereo, output:analog-surround-40, output:analog-surround-40+input:analog-stereo, output:analog-surround-41, output:analog-surround-41+input:analog-stereo, output:analog-surround-50, output:analog-surround-50+input:analog-stereo, output:analog-surround-51, output:analog-surround-51+input:analog-stereo, output:analog-surround-71, output:analog-surround-71+input:analog-stereo
analog-output-headphones: Headphones (type: Headphones, priority: 9900, latency offset: 0 usec, availability group: Legacy 5, not available)
Properties:
port.type = "headphones"
Card #4523
Driver: alsa
Owner Module: n/a
Properties:
device.api = "alsa"
api.alsa.path = "hw:3"
api.alsa.card = "3"
api.alsa.card.name = "HD Pro Webcam C920"
api.alsa.card.longname = "HD Pro Webcam C920 at usb-0000:2a:00.3-1.3, high speed"
device.plugged.usec = "16483520155"
device.bus_path = "pci-0000:2a:00.3-usb-0:1.3:1.2"
sysfs.path = "/sys/devices/pci0000:00/0000:00:08.1/0000:2a:00.3/usb3/3-1/3-1.3/3-1.3:1.2/sound/card3"
device.bus-id = "usb-046d_HD_Pro_Webcam_C920_BD7FFEAF-02"
device.bus = "usb"
device.product.id = "0x082d"
device.product.name = "HD Pro Webcam C920"
device.serial = "046d_HD_Pro_Webcam_C920_BD7FFEAF"
device.form_factor = "webcam"
device.name = "alsa_card.usb-046d_HD_Pro_Webcam_C920_BD7FFEAF-02"
device.description = "HD Pro Webcam C920"
device.nick = "HD Pro Webcam C920"
device.icon_name = "camera-web-usb"
api.dbus.ReserveDevice1 = "Audio3"
factory.id = "14"
client.id = "31"
object.id = "126"
object.serial = "4523"
object.path = "alsa:pcm:3"
alsa.card = "3"
alsa.card_name = "HD Pro Webcam C920"
alsa.long_card_name = "HD Pro Webcam C920 at usb-0000:2a:00.3-1.3, high speed"
device.string = "3"
Profiles:
input:analog-stereo: Analog Stereo Input (sinks: 0, sources: 1, priority: 65, available: yes)
input:iec958-stereo: Digital Stereo (IEC958) Input (sinks: 0, sources: 1, priority: 55, available: yes)
pro-audio: Pro Audio (sinks: 0, sources: 1, priority: 1, available: yes)
Active Profile: input:iec958-stereo
Ports:
Properties:
port.type = "mic"
iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, latency offset: 0 usec, availability unknown)
Properties:
port.type = "spdif"
Part of profile(s): input:iec958-stereo
pactl list sources;echo -e “\ndefault source: $(pactl get-default-source)” output
Source #53
State: IDLE
Name: alsa_output.usb-Logitech_Logitech_Wireless_Headset_000D44D3C07D-00.analog-stereo.monitor
Description: Monitor of H600 [Wireless Headset] Analog Stereo
Driver: PipeWire
Sample Specification: s16le 2ch 48000Hz
Channel Map: front-left,front-right
Owner Module: 4294967295
Mute: no
Volume: front-left: 65536 / 100% / 0.00 dB, front-right: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 65536 / 100% / 0.00 dB
Monitor of Sink: alsa_output.usb-Logitech_Logitech_Wireless_Headset_000D44D3C07D-00.analog-stereo
Latency: 0 usec, configured 0 usec
Flags: HARDWARE DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:2:front:2:playback"
api.alsa.path = "front:2"
api.alsa.pcm.card = "2"
api.alsa.pcm.stream = "playback"
audio.channels = "2"
audio.position = "FL,FR"
device.routes = "1"
alsa.resolution_bits = "16"
device.api = "alsa"
device.class = "monitor"
alsa.class = "generic"
alsa.subclass = "generic-mix"
alsa.name = "USB Audio"
alsa.id = "USB Audio"
alsa.subdevice = "0"
alsa.subdevice_name = "subdevice #0"
alsa.device = "0"
alsa.card = "2"
device.profile.name = "analog-stereo"
device.profile.description = "Analog Stereo"
card.profile.device = "3"
device.id = "44"
factory.name = "api.alsa.pcm.sink"
priority.driver = "881"
priority.session = "881"
media.class = "Audio/Sink"
node.nick = "Logitech Wireless Headset"
node.name = "alsa_output.usb-Logitech_Logitech_Wireless_Headset_000D44D3C07D-00.analog-stereo"
device.icon_name = "audio-card-analog"
device.bus = "usb"
node.pause-on-idle = "false"
factory.id = "18"
clock.quantum-limit = "8192"
client.id = "32"
node.driver = "true"
factory.mode = "merge"
audio.adapt.follower = ""
library.name = "audioconvert/libspa-audioconvert"
object.id = "52"
object.serial = "53"
node.max-latency = "16384/48000"
api.alsa.card = "2"
device.string = "2"
Formats:
pcm
Source #54
State: SUSPENDED
Description: H600 [Wireless Headset] Mono
Driver: PipeWire
Sample Specification: s16le 1ch 48000Hz
Channel Map: mono
Mute: no
Volume: mono: 65536 / 100% / 0.00 dB
balance 0.00
Base Volume: 19944 / 30% / -31.00 dB
Monitor of Sink: n/a
Flags: HARDWARE HW_VOLUME_CTRL DECIBEL_VOLUME LATENCY
Properties:
object.path = "alsa:pcm:2:hw:2:capture"
api.alsa.pcm.stream = "capture"
audio.channels = "1"
audio.position = "MONO"
device.routes = "1"
device.api = "alsa"
device.class = "sound"
alsa.device = "0"
alsa.card = "2"
device.profile.name = "mono-fallback"
device.profile.description = "Mono"
card.profile.device = "2"
device.id = "44"
factory.name = "api.alsa.pcm.source"
priority.driver = "1872"
priority.session = "1872"
media.class = "Audio/Source"
node.name = "alsa_input.usb-Logitech_Logitech_Wireless_Headset_000D44D3C07D-00.mono-fallback"
device.bus = "usb"
factory.id = "18"
client.id = "32"
factory.mode = "split"
object.id = "53"
object.serial = "54"
api.alsa.card = "2"
device.string = "2"
Ports:
analog-input-mic: Microphone (type: Mic, priority: 8700, availability unknown)
Active Port: analog-input-mic
Formats:
pcm
Source #3300
State: SUSPENDED
Description: Monitor of GP107GL High Definition Audio Controller Digital Stereo (HDMI 2)
Driver: PipeWire
Sample Specification: s32le 2ch 48000Hz
Mute: no
Volume: front-left: 0 / 0% / -inf dB, front-right: 0 / 0% / -inf dB
balance 0.00
Monitor of Sink: alsa_output.pci-0000_25_00.1.hdmi-stereo-extra1
Properties:
object.path = "alsa:pcm:0:hdmi:0,1:playback"
api.alsa.path = "hdmi:0,1"
api.alsa.pcm.card = "0"
device.routes = "1"
device.api = "alsa"
alsa.name = "2778X"
alsa.id = "HDMI 1"
alsa.device = "7"
alsa.card = "0"
device.profile.name = "hdmi-stereo-extra1"
device.profile.description = "Digital Stereo (HDMI 2)"
card.profile.device = "7"
device.id = "42"
priority.driver = "632"
priority.session = "632"
node.nick = "HDA NVidia"
node.name = "alsa_output.pci-0000_25_00.1.hdmi-stereo-extra1"
device.icon_name = "audio-card-hdmi"
device.bus = "pci"
factory.id = "18"
client.id = "32"
object.id = "88"
object.serial = "3300"
api.alsa.card = "0"
device.string = "0"
Formats:
pcm
Source #4524
State: SUSPENDED
Description: HD Pro Webcam C920 Digital Stereo (IEC958)
Driver: PipeWire
Sample Specification: s16le 2ch 32000Hz
Mute: no
balance 0.00
Properties:
object.path = "alsa:pcm:3:iec958:3:capture"
api.alsa.path = "iec958:3"
api.alsa.pcm.card = "3"
device.routes = "1"
device.api = "alsa"
alsa.device = "0"
alsa.card = "3"
device.profile.name = "iec958-stereo"
device.profile.description = "Digital Stereo (IEC958)"
device.id = "126"
priority.driver = "1816"
priority.session = "1816"
node.nick = "HD Pro Webcam C920"
node.name = "alsa_input.usb-046d_HD_Pro_Webcam_C920_BD7FFEAF-02.iec958-stereo"
device.icon_name = "audio-input-microphone-iec958"
device.bus = "usb"
factory.id = "18"
client.id = "32"
object.id = "127"
object.serial = "4524"
api.alsa.card = "3"
device.string = "3"
Ports:
iec958-stereo-input: Digital Input (S/PDIF) (type: SPDIF, priority: 0, availability unknown)
Active Port: iec958-stereo-input
Formats:
pcm
default source: alsa_input.usb-Logitech_Logitech_Wireless_Headset_000D44D3C07D-00.mono-fallback
