Hey all,
This place seems to be very helpful and I was wondering if there’s another problem you guys could solve. So, I’m using a Logitech C920 webcam at the moment. The video works great on it, however, even though it seems to recognize that it has an audio and video source the audio seems to not be working on it.
Here are some interesting data points if this helps at all:
v4l2-ctl:
greg@manjaro:~
➤ v4l2-ctl -d /dev/video0 --list-ctrls
brightness 0x00980900 (int) : min=0 max=255 step=1 default=128 value=128
contrast 0x00980901 (int) : min=0 max=255 step=1 default=128 value=128
saturation 0x00980902 (int) : min=0 max=255 step=1 default=128 value=128
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gain 0x00980913 (int) : min=0 max=255 step=1 default=0 value=0
power_line_frequency 0x00980918 (menu) : min=0 max=2 default=2 value=2
white_balance_temperature 0x0098091a (int) : min=2000 max=6500 step=1 default=4000 value=4000 flags=inactive
sharpness 0x0098091b (int) : min=0 max=255 step=1 default=128 value=128
backlight_compensation 0x0098091c (int) : min=0 max=1 step=1 default=0 value=0
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=3
exposure_absolute 0x009a0902 (int) : min=3 max=2047 step=1 default=250 value=250 flags=inactive
exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
pan_absolute 0x009a0908 (int) : min=-36000 max=36000 step=3600 default=0 value=0
tilt_absolute 0x009a0909 (int) : min=-36000 max=36000 step=3600 default=0 value=0
focus_absolute 0x009a090a (int) : min=0 max=250 step=5 default=0 value=0
focus_auto 0x009a090c (bool) : default=1 value=0
zoom_absolute 0x009a090d (int) : min=100 max=500 step=1 default=100 value=100
arecord :
greg@manjaro:~
➤ arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: SB [HDA ATI SB], device 0: VT1708S Analog [VT1708S Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 2: C920 [HD Pro Webcam C920], device 0: USB Audio [USB Audio]
Subdevices: 1/1
lsusb:
greg@manjaro:~
➤ lsusb
Bus 007 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 006 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 005 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 005 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 001 Device 003: ID 046d:082d Logitech, Inc. HD Pro Webcam C920
Bus 001 Device 005: ID 046d:c52b Logitech, Inc. Unifying Receiver
Bus 001 Device 004: ID 0bc2:ab38 Seagate RSS LLC Backup Plus Hub (Mass Storage)
Bus 001 Device 002: ID 0bc2:ab44 Seagate RSS LLC Backup Plus Hub
Bus 004 Device 002: ID 258a:0016 BY Tech Usb Gaming Keyboard
Bus 004 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
