Login screen not shown when HDMI cable not connected
Hi,
I’ve recently bought a new LG 38 Ultra Widescreen. Before, I had two BenQ monitors connected via Thunderbolt and mini Display port on my laptop. After the latest update to Wynsdey I had some troubles with the OS, which I could finally solve be switching from Xorg to Wayland. However, with my new screen I’m facing the following issue now: When no external monitor is connected via HDMI cable, no login screen is loading, even on my build in laptop screen I just have a small white dash in the upper left corner. If I connect the new monitor (or an old one) via HDMI, I’m able to login. I’m also able to plugin the new monitor via Thunderbolt after successful login. If I try to switch to a different TTY while connected via Thunderbolt, my screen just appears frozen and I can’t see the TTY (works when connected via HDMI).
And as soon as I reboot no login screen is shown and I need to switch to HDMI again.
I already tried to apply SDDM - ArchWiki but w/o success. I didn’t try SDDM - ArchWiki yet, because I think something is messed up with the detected screens. Can somebody help in “resetting” the detected screens completely?
I’ve also tried sudo nvidia-xconfig and I ever since have a very “basic” Nvidia settings view for my Gforce RTX 3080 where I can’t configure anything:
inxi --full --admin --filter --width
  Kernel: 6.6.32-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
    root=UUID=601d4720-c81f-4755-b319-aa66d895c6ec rw quiet apparmor=1
    security=apparmor udev.log_priority=3 ibt=off
  Desktop: KDE Plasma v: 6.0.5 tk: Qt v: N/A info: frameworks v: 6.2.0
  Type: Laptop System: HP product: OMEN by HP Laptop 17-ck0xxx v: N/A
  Mobo: HP model: 88FE v: 86.39 serial: <superuser required>
    part-nu: 4H3G0EA#ABD uuid: <superuser required> UEFI: AMI v: F.26
    date: 01/28/2022
  ID-1: BAT0 charge: 76.6 Wh (100.0%) condition: 76.6/83.0 Wh (92.2%)
    volts: 12.6 min: 11.6 model: HP Primary type: Li-ion serial: <filter>
    status: full cycles: 15
  Info: model: 11th Gen Intel Core i9-11900H bits: 64 type: MT MCP
    arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
    process: Intel 10nm family: 6 model-id: 0x8D (141) stepping: 1
    microcode: 0x50
  Topology: cpus: 1x cores: 8 tpc: 2 threads: 16 smt: enabled cache:
    L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 10 MiB desc: 8x1.2 MiB
    L3: 24 MiB desc: 1x24 MiB
  Speed (MHz): avg: 808 high: 871 min/max: 800/4800:4900 scaling:
    driver: intel_pstate governor: powersave cores: 1: 800 2: 800 3: 800 4: 800
    5: 800 6: 800 7: 800 8: 871 9: 800 10: 800 11: 864 12: 800 13: 800 14: 800
    15: 800 16: 800 bogomips: 79888
  Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB: conditional;
    RSB filling; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
  Device-1: Intel TigerLake-H GT1 [UHD Graphics] vendor: Hewlett-Packard
    driver: i915 v: kernel arch: Gen-12.1 process: Intel 10nm built: 2020-21
    ports: active: DP-2,eDP-1 empty: DP-1, DP-3, DP-4, DP-5, HDMI-A-1
    bus-ID: 0000:00:02.0 chip-ID: 8086:9a60 class-ID: 0300
  Device-2: NVIDIA GA104M [GeForce RTX 3080 Mobile / Max-Q 8GB/16GB]
    vendor: Hewlett-Packard driver: nvidia v: 550.78
    alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current (as of
    2024-04; EOL~2026-12-xx) arch: Ampere code: GAxxx process: TSMC n7 (7nm)
    built: 2020-2023 ports: active: none empty: DP-6,HDMI-A-2,eDP-2
    bus-ID: 0000:01:00.0 chip-ID: 10de:24dc class-ID: 0300
  Device-3: Quanta HP Wide Vision HD Camera driver: uvcvideo type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6:4 chip-ID: 0408:5425
  Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 24.1.0
    compositor: kwin_wayland driver: X: loaded: nvidia gpu: i915,nvidia
    d-rect: 6400x1600 display-ID: 0
  Monitor-1: DP-2 pos: primary,left res: 3840x1600 size: N/A modes: N/A
  Monitor-2: eDP-1 pos: right res: 2560x1440 size: N/A modes: N/A
    drv: nvidia device: 1 drv: iris device: 3 drv: swrast surfaceless:
    drv: nvidia wayland: drv: iris x11: drv: iris inactive: gbm,device-2
  API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.8-manjaro1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel UHD Graphics (TGL GT1)
    device-ID: 8086:9a60 memory: 30.27 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce RTX 3080 Laptop GPU driver: nvidia v: 550.78 device-ID: 10de:24dc
    surfaces: xcb,xlib,wayland
  Device-1: Intel Tiger Lake-H HD Audio vendor: Hewlett-Packard
    driver: sof-audio-pci-intel-tgl
    alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 0000:00:1f.3
    chip-ID: 8086:43c8 class-ID: 0401
  Device-2: NVIDIA GA104 High Definition Audio vendor: Hewlett-Packard
    driver: snd_hda_intel v: kernel bus-ID: 0000:01:00.1 chip-ID: 10de:228b
    class-ID: 0403
  API: ALSA v: k6.6.32-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.0.7 status: off with: pipewire-media-session
    status: active tools: pw-cli
  Server-3: PulseAudio v: 17.0 status: active with: 1: pulseaudio-alsa
    type: plugin 2: pulseaudio-jack type: module tools: pacat,pactl
    vendor: Hewlett-Packard driver: r8168 v: 8.053.00-NAPI modules: r8169
    port: 3000 bus-ID: 0000:2d:00.0 chip-ID: 10ec:8168 class-ID: 0200
  Device-2: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi
    v: kernel bus-ID: 0000:2e:00.0 chip-ID: 8086:2725 class-ID: 0280
  IF-ID-1: br-0dc8eef77e03 state: down mac: <filter>
  IF-ID-2: br-53fc05bdcabf state: down mac: <filter>
  IF-ID-3: br-af15313e3499 state: down mac: <filter>
  IF-ID-4: br-c27b0c39ef97 state: down mac: <filter>
  IF-ID-5: br-d0512caeecf5 state: down mac: <filter>
  IF-ID-6: docker0 state: down mac: <filter>
  Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-7:5 chip-ID: 8087:0032
    class-ID: e001
  Hardware-1: Intel Volume Management Device NVMe RAID Controller driver: vmd
    v: 0.6 port: N/A bus-ID: 0000:00:0e.0 chip-ID: 8086:9a0b rev: class-ID: 0104
  Local Storage: total: 953.87 GiB used: 285.05 GiB (29.9%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron
    model: MTFDKBA1T0TFH-1BC1AABHA size: 953.87 GiB block-size: physical: 512 B
    fw-rev: HPS0043 temp: 58.9 C scheme: GPT
  ID-1: / raw-size: 488.28 GiB size: 479.54 GiB (98.21%)
    used: 284.97 GiB (59.4%) fs: ext4 dev: /dev/nvme0n1p4 maj-min: 259:4
  ID-2: /boot/efi raw-size: 260 MiB size: 256 MiB (98.46%)
    used: 87 MiB (34.0%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 47.0 C mobo: N/A
  Fan Speeds (rpm): cpu: 2002 fan-2: 0
  Memory: total: 32 GiB note: est. available: 30.99 GiB used: 7.83 GiB (25.3%)
  Processes: 368 Power: uptime: 36m states: freeze,mem,disk suspend: deep
    suspend, test_resume image: 12.39 GiB services: org_kde_powerdevil,upowerd
    Init: systemd v: 255 default: graphical tool: systemctl
  Packages: 2055 pm: pacman pkgs: 2049 libs: 458 tools: pamac pm: flatpak
    pkgs: 0 pm: snap pkgs: 6 Compilers: clang: 17.0.6 gcc: 14.1.1 Shell: Zsh
    v: 5.9 running-in: konsole inxi: 3.3.34
sudo dmesg --level emerg,alert,crit,err,warn
[    0.212920] ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
[    0.311522] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.TXHC.RHUB.SS01], AE_NOT_FOUND (20230628/dswload2-162)
[    0.311530] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
[    0.311537] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.TXHC.RHUB.SS02], AE_NOT_FOUND (20230628/dswload2-162)
[    0.311540] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
[    0.311544] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.TXHC.RHUB.SS03], AE_NOT_FOUND (20230628/dswload2-162)
[    0.311547] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
[    0.311551] ACPI BIOS Error (bug): Could not resolve symbol [\_SB.PC00.TXHC.RHUB.SS04], AE_NOT_FOUND (20230628/dswload2-162)
[    0.311554] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20230628/psobject-220)
[    0.311559] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311563] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311566] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS01._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311569] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311778] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311781] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311785] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS02._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311788] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311793] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311796] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311799] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS03._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311802] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311807] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311810] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311813] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS04._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311816] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311821] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS05._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311823] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311827] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS05._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311830] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311834] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS06._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311837] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311841] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS06._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311843] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311848] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS07._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311851] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311854] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS07._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311857] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311862] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311865] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311868] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS08._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311871] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311876] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311878] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311882] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS09._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311884] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311889] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311892] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.311895] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS10._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.311898] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312104] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS11._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312107] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312110] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS11._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312113] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312118] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS12._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312121] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312124] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS12._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312127] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312132] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS13._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312134] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312138] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS13._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312140] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312145] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312148] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312152] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.HS14._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312154] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312405] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312408] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312412] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS01._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312414] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312419] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312422] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312426] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS02._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312428] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312433] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312436] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312439] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS03._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312442] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312447] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312449] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312453] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS04._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312455] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312460] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS05._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312463] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312466] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS05._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312469] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312474] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS06._UPC], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312477] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.312480] ACPI BIOS Error (bug): Failure creating named object [\_SB.PC00.XHCI.RHUB.SS06._PLD], AE_ALREADY_EXISTS (20230628/dswload2-326)
[    0.312483] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20230628/psobject-220)
[    0.686997] pnp 00:03: disabling [mem 0xc0000000-0xcfffffff] because it overlaps 0000:00:02.0 BAR 9 [mem 0x00000000-0xdfffffff 64bit pref]
[    0.741877] hpet_acpi_add: no address or irqs in _CRS
[    0.779208] blacklist: Duplicate blacklisted hash bin:47ff1b63b140b6fc04ed79131331e651da5b2e2f170f5daef4153dc2fbc532b1
[    0.779209] blacklist: Duplicate blacklisted hash bin:5391c3a2fb112102a6aa1edc25ae77e19f5d6f09cd09eeb2509922bfcd5992ea
[    0.779226] blacklist: Duplicate blacklisted hash bin:80b4d96931bf0d02fd91a61e19d14f1da452e66db2408ca8604d411f92659f0a
[    0.779242] blacklist: Duplicate blacklisted hash bin:992d359aa7a5f789d268b94c11b9485a6b1ce64362b0edb4441ccc187c39647b
[    0.779263] blacklist: Duplicate blacklisted hash bin:c452ab846073df5ace25cca64d6b7a09d906308a1a65eb5240e3c4ebcaa9cc0c
[    0.779276] blacklist: Duplicate blacklisted hash bin:e051b788ecbaeda53046c70e6af6058f95222c046157b8c4c1b9c2cfc65f46e5
[    0.890313] wmi_bus wmi_bus-PNP0C14:00: WQ00 data block query control method not found
[    0.895587] pci 10000:e0:06.0: Primary bus is hard wired to 0
[    0.895840] pci 10000:e0:06.0: Primary bus is hard wired to 0
[    0.896046] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[    1.105047] pci 10000:e1:00.0: can't override BIOS ASPM; OS doesn't have ASPM control
[    1.105064] pcieport 10000:e0:06.0: can't derive routing for PCI INT D
[    1.105065] pcieport 10000:e0:06.0: PCI INT D: no GSI
[    1.129721] pcieport 10000:e0:06.0: can't derive routing for PCI INT A
[    1.129722] nvme 10000:e1:00.0: PCI INT A: no GSI
[    4.842968] systemd-journald[451]: File /var/log/journal/2c5ff5f0b0664a97a7349cd31887f38f/system.journal corrupted or uncleanly shut down, renaming and replacing.
[    4.955883] r8168: loading out-of-tree module taints kernel.
[    4.966632] resource: resource sanity check: requesting [mem 0x00000000fedc0000-0x00000000fedcdfff], which spans more than pnp 00:03 [mem 0xfedc0000-0xfedc7fff]
[    4.966637] caller __uncore_imc_init_box+0xfb/0x150 [intel_uncore] mapping multiple BARs
[    4.971980] nvidia: module license 'NVIDIA' taints kernel.
[    4.971982] Disabling lock debugging due to kernel taint
[    4.971985] nvidia: module license taints kernel.
[    4.975367] r8168  Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
                This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[    5.188416] Bluetooth: hci0: No support for _PRR ACPI method
[    5.189611] NVRM: loading NVIDIA UNIX x86_64 Kernel Module  550.78  Sun Apr 14 06:35:45 UTC 2024
[    5.190869] iwlwifi 0000:2e:00.0: api flags index 2 larger than supported by driver
[    5.283989] thermal thermal_zone1: failed to read out thermal zone (-61)
[    5.292755] iwlwifi 0000:2e:00.0: WRT: Invalid buffer destination
[    5.340299] ACPI Warning: \_SB.NPCF._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[    5.340332] ACPI Warning: \_SB.PC00.PEG1.PEGP._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20230628/nsarguments-61)
[    5.403996] kauditd_printk_skb: 53 callbacks suppressed
[    5.533701] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[    5.816519] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[    6.396952] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-0
[    6.406047] nvidia-modeset: WARNING: GPU:0: Unable to read EDID for display device DP-0
[    6.551542] Bluetooth: hci0: Malformed MSFT vendor event: 0x02
[    6.985999] nvidia_uvm: module uses symbols nvUvmInterfaceDisableAccessCntr from proprietary module nvidia, inheriting taint.
[    7.383708] iwlwifi 0000:2e:00.0: WRT: Invalid buffer destination
[    7.723347] iwlwifi 0000:2e:00.0: WRT: Invalid buffer destination
[    9.879008] sddm-greeter-qt[987]: memfd_create() called without MFD_EXEC or MFD_NOEXEC_SEAL set
[   10.083488] block nvme0n1: No UUID available providing old NGUID
[   19.942002] warning: `kdeconnectd' uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[  151.228160] usb 3-4: can't set config #1, error -71
[  168.296351] usb usb2-port1: unable to enumerate USB device
[ 1740.466893] ACPI Error: No handler for Region [CMS0] (00000000705f6a92) [SystemCMOS] (20230628/evregion-130)
[ 1740.466907] ACPI Error: Region SystemCMOS (ID=5) has no handler (20230628/exfldio-261)
[ 1740.466920] ACPI Error: Aborting method \_SB.PC00.LPCB.EC0._Q33 due to previous error (AE_NOT_EXIST) (20230628/psparse-529)
Something I found strange about the inxi output is
that my primary screen seems to be eDP-1 (laptop screen) as it is rendering the application launcher and status bar.
Well, SDDM still runs with X11/Xorg by default:
Note: As of SDDM version 0.20, Wayland sessions are listed and can be started from SDDM, but the SDDM greeter itself still runs in X11 mode by default, although an experimental Wayland greeter can be enabled.
So probably try the experimental wayland mode first. :arrow_up:
If so I probably suggest this configuration for KDE
/etc/sddm.conf.d/wayland.conf
[General]
DisplayServer=wayland
GreeterEnvironment=QT_WAYLAND_SHELL_INTEGRATION=layer-shell
[Wayland]
EnableHiDPI=true
CompositorCommand=kwin_wayland --drm --no-lockscreen --no-global-shortcuts --locale1
(the hidpi optional … use it if you have hidpi)
Should I keep /etc/sddm.conf.d/kde_settings.conf or shall I remove this?
[Autologin]
Relogin=false
Session=plasma
User=
[General]
HaltCommand=/usr/bin/systemctl poweroff
RebootCommand=/usr/bin/systemctl reboot
[Theme]
Current=breath
CursorTheme=breeze_cursors
Font=Noto Sans,10,-1,0,400,0,0,0,0,0,0,0,0,0,0,1
[Users]
MaximumUid=60000
MinimumUid=1000
[X11]
ServerArguments=-dpi 0
Yes, keep.
The extra config file is in addition.
