Login problem after suspend
after the last update (the one with the nvidia 570) i can no longer log in after a suspend. the screen remains black or after a few minutes I can enter the password, but it does not work. also faillock is active. there was no problem before. if i go to console and restart lightdm i can log in normally.
journal shows cinnamon-screensaver and pam errors.
as far as I have noticed, after resuming, I keep getting login attempts even though I am not doing anything.
mar 25 08:12:15 manjaro cinnamon-screensaver-pam-helper[1753]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mike]
mar 25 08:12:15 manjaro cinnamon-screensaver-pam-helper[1753]: pam_faillock(cinnamon-screensaver:auth): Error sending audit message: Operation not permitted
mar 25 08:12:15 manjaro cinnamon-screensaver-pam-helper[1753]: pam_faillock(cinnamon-screensaver:auth): Consecutive login failures for user mike account temporarily locked
mar 25 08:12:16 manjaro cinnamon-screensaver-pam-helper[1845]: pam_faillock(cinnamon-screensaver:auth): conversation failed
mar 25 08:12:16 manjaro wireplumber[1218]: spa.bluez5: BlueZ system service is not available
mar 25 08:12:33 manjaro cinnamon-screensaver-pam-helper[1845]: pam_unix(cinnamon-screensaver:auth): conversation failed
mar 25 08:12:33 manjaro cinnamon-screensaver-pam-helper[1845]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mike]
mar 25 08:12:33 manjaro wireplumber[1218]: spa.bluez5: BlueZ system service is not available
mar 25 08:12:34 manjaro polkitd[816]: Unregistered Authentication Agent for unix-session:2 (system bus name :1.67, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale pl_PL.UTF-8) (disconnected from bus)
mar 25 08:12:34 manjaro cinnamon-screensaver-pam-helper[1863]: pam_unix(cinnamon-screensaver:auth): conversation failed
mar 25 08:12:34 manjaro cinnamon-screensaver-pam-helper[1863]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mike]
mar 25 08:12:35 manjaro polkitd[816]: Registered Authentication Agent for unix-session:2 (system bus name :1.81 [cinnamon --replace], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale pl_PL.UTF-8)
mar 25 08:12:35 manjaro cinnamon-screensaver[1365]: Fractional scaling active: False
mar 25 08:12:35 manjaro NetworkManager[812]: <info>  [1742886755.2156] agent-manager: agent[804ec10259177fa1,:1.81/org.cinnamon.NetworkAgent/1000]: agent registered
mar 25 08:12:35 manjaro cinnamon-screensaver-pam-helper[1876]: pam_unix(cinnamon-screensaver:auth): conversation failed
mar 25 08:12:35 manjaro cinnamon-screensaver-pam-helper[1876]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mike]
mar 25 08:12:35 manjaro cinnamon-screensaver-pam-helper[1876]: pam_faillock(cinnamon-screensaver:auth): Error sending audit message: Operation not permitted
mar 25 08:12:35 manjaro cinnamon-screensaver-pam-helper[1876]: pam_faillock(cinnamon-screensaver:auth): Consecutive login failures for user mike account temporarily locked
mar 25 08:12:41 manjaro cinnamon-screensaver-pam-helper[1894]: gkr-pam: unlocked login keyring
mar 25 08:12:43 manjaro cinnamon-screensaver-pam-helper[1894]: pam_faillock(cinnamon-screensaver:auth): conversation failed
mar 25 08:13:14 manjaro cinnamon-screensaver-pam-helper[1894]: pam_unix(cinnamon-screensaver:auth): conversation failed
mar 25 08:13:14 manjaro cinnamon-screensaver-pam-helper[1894]: pam_unix(cinnamon-screensaver:auth): auth could not identify password for [mike]
  Kernel: 6.14.0-rc7-1-MANJARO arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    parameters: BOOT_IMAGE=/boot/vmlinuz-6.14-x86_64
    root=UUID=724d12cc-9e8f-446a-9313-fb093e3b045b rw quiet apparmor=1
  Desktop: Cinnamon v: 6.4.8 tk: GTK v: 3.24.49 wm: Muffin v: 6.4.1 tools:
    avail: cinnamon-screensaver vt: 7 dm: LightDM v: 1.32.0 Distro: Manjaro
    base: Arch Linux
  Mobo: ASUSTeK model: ROG STRIX B550-I GAMING v: Rev X.0x
    UEFI: American Megatrends v: 3802 date: 01/14/2025
  Device-1: hidpp_battery_0 model: Logitech Wireless Mobile Mouse MX Anywhere
    2 serial: <filter> charge: 55% (should be ignored) rechargeable: yes
    status: discharging
  System RAM: total: 32 GiB available: 31.25 GiB used: 4.65 GiB (14.9%)
  Array-1: capacity: 128 GiB slots: 2 modules: 2 EC: None
    max-module-size: 64 GiB note: est.
  Device-1: DIMM_A1 type: DDR4 detail: synchronous unbuffered (unregistered)
    size: 16 GiB speed: 3800 MT/s volts: note: check curr: 1 min: 1 max: 1
    width (bits): data: 64 total: 64 manufacturer: Wilk Elektronik S.A
    part-no: IRP3600D4V64L17/16G serial: <filter>
  Device-2: DIMM_B1 type: DDR4 detail: synchronous unbuffered (unregistered)
  Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 3
    model-id: 0x21 (33) stepping: 2 microcode: 0xA201213
    desc: 8x512 KiB L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3879 min/max: 550/4866 boost: enabled scaling:
    driver: amd-pstate-epp governor: powersave cores: 1: 3879 2: 3879 3: 3879
    4: 3879 5: 3879 6: 3879 7: 3879 8: 3879 9: 3879 10: 3879 11: 3879 12: 3879
    13: 3879 14: 3879 15: 3879 16: 3879 bogomips: 108796
    xsaves xtopology
    affected
  Device-1: NVIDIA GA106 [GeForce RTX 3060 Lite Hash Rate] vendor: ASUSTeK
    driver: nvidia v: 570.133.07 alternate: nouveau,nvidia_drm
    non-free: 550/565.xx+ status: current (as of 2025-01; EOL~2026-12-xx)
    arch: Ampere code: GAxxx process: TSMC n7 (7nm) built: 2020-2023 pcie:
    gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 4 speed: 16 GT/s ports:
    active: none off: DP-1 empty: DP-2,DP-3,HDMI-A-1 bus-ID: 07:00.0
    chip-ID: 10de:2504 class-ID: 0300
  Display: x11 server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 driver:
    X: loaded: nvidia gpu: nvidia,nvidia-nvswitch display-ID: :0 screens: 1
  Screen-1: 0 s-res: 2560x1440 s-size: <missing: xdpyinfo>
  Monitor-1: DP-1 mapped: DP-0 note: disabled model: Dell U2722D
    serial: <filter> built: 2021 res: mode: 2560x1440 hz: 60 scale: 100% (1)
    dpi: 109 gamma: 1.2 chroma: red: x: 0.639 y: 0.329 green: x: 0.298
    y: 0.600 blue: x: 0.149 y: 0.059 white: x: 0.314 y: 0.329
    size: 597x336mm (23.5x13.23") diag: 685mm (27") ratio: 16:9
    modes: 2560x1440, 2048x1080, 1920x1080, 1600x1200, 1280x1024, 1152x864,
    1280x720, 1024x768, 800x600, 720x576, 720x480, 640x480
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia x11: drv: nvidia inactive: wayland
  API: OpenGL v: 4.6.0 vendor: nvidia v: 570.133.07 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
    memory: 11.72 GiB
  Info: Tools: api: eglinfo,glxinfo gpu: nvidia-settings,nvidia-smi
    x11: xprop,xrandr
  Device-1: NVIDIA GA106 High Definition Audio vendor: ASUSTeK
    bus-ID: 07:00.1 chip-ID: 10de:228e class-ID: 0403
    vendor: ASUSTeK driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
    lanes: 16 bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
  Device-3: Thesycon System & Consulting GmbH SABAJ DA3 v1.2
    driver: snd-usb-audio type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0
    bus-ID: 1-8:3 chip-ID: 152a:85df class-ID: fe01
  Device-4: Dell Slim Soundbar SB521A driver: snd-usb-audio type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-2.4:5
    chip-ID: 413c:a510 class-ID: 0102 serial: <filter>
  API: ALSA v: k6.14.0-rc7-1-MANJARO status: kernel-api with: aoss
  Server-2: PipeWire v: 1.4.1 status: active with: 1: pipewire-pulse
  Device-1: Intel Wi-Fi 6 AX200 driver: iwlwifi v: kernel pcie: gen: 2
    speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 8086:2723 class-ID: 0280
  IF: wlp6s0 state: up mac: <filter>
  Local Storage: total: 2.79 TiB used: 479.53 GiB (16.8%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SKC3000D2048G
    size: 1.86 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: EIFK31.7 temp: 29.9 C
    scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Lexar model: SSD NM790 1TB
    size: 953.87 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 18950 temp: 34.9 C scheme: GPT
  ID-1: / raw-size: 97.61 GiB size: 95.52 GiB (97.86%) used: 14.3 GiB (15.0%)
    fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1 label: N/A
    uuid: 724d12cc-9e8f-446a-9313-fb093e3b045b
  ID-2: /boot/efi raw-size: 301 MiB size: 300.4 MiB (99.79%)
    used: 31.1 MiB (10.4%) fs: vfat dev: /dev/nvme0n1p2 maj-min: 259:2
    label: N/A uuid: F250-14B5
  ID-3: /home raw-size: 1.67 TiB size: 1.64 TiB (98.37%)
    used: 465.2 GiB (27.6%) fs: ext4 dev: /dev/nvme0n1p5 maj-min: 259:5
    label: N/A uuid: 5d8b9004-d0c4-40bf-82c2-968db18d9ae0
  ID-1: swap-1 type: file size: 32 GiB used: 0 KiB (0.0%) priority: -2
    file: /home/swapfile
  ID-1: /dev/nvme0n1p3 maj-min: 259:3 size: 306 MiB fs: vfat label: N/A
    uuid: 772F-1A9F
  ID-2: /dev/nvme0n1p4 maj-min: 259:4 size: 97.61 GiB fs: ext4 label: N/A
    uuid: 66ae1fa9-e7dc-4153-b5b0-ef4b22dfea01
  ID-3: /dev/nvme1n1p1 maj-min: 259:7 size: 16 MiB fs: ext4 label: N/A
    uuid: 59aa33ca-076b-4ac9-9691-a581936824ea
  ID-4: /dev/nvme1n1p2 maj-min: 259:8 size: 98.38 GiB fs: ntfs label: N/A
    uuid: 205A14A95A147DAA
  ID-5: /dev/nvme1n1p3 maj-min: 259:9 size: 660.16 GiB fs: ntfs label: Nowy
    uuid: 188E916F8E914662
  ID-6: /dev/nvme1n1p4 maj-min: 259:10 size: 195.31 GiB fs: ext4 label: N/A
    uuid: edb48b86-db1c-485e-995b-f57caf19e275
  Device-1: 1-6:2 info: ASUSTek AURA LED Controller type: HID
    lanes: 1 mode: 1.1 power: 16mA chip-ID: 0b05:1939 class-ID: 0300
    serial: <filter>
  Device-2: 1-8:3 info: Thesycon System & Consulting GmbH SABAJ DA3 v1.2
    type: audio driver: snd-usb-audio interfaces: 3 rev: 2.0
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 152a:85df
    class-ID: fe01
  Device-3: 1-10:4 info: Logitech Unifying Receiver type: keyboard,mouse,HID
    driver: logitech-djreceiver,usbhid interfaces: 3 rev: 2.0
    chip-ID: 046d:c52b class-ID: 0300
  Hub-4: 3-2:2 info: INGENICO 4-Port USB 2.0 Hub ports: 5 rev: 2.1
    speed: 480 Mb/s (57.2 MiB/s) lanes: 1 mode: 2.0 chip-ID: 0b00:5483
  Device-1: 3-2.3:4 info: QinHeng CH340 serial converter
    type: <vendor specific> driver: ch341,ch341-uart interfaces: 1 rev: 1.1
    speed: 12 Mb/s (1.4 MiB/s) lanes: 1 mode: 1.1 power: 104mA
    chip-ID: 1a86:7523 class-ID: ff00
  Device-2: 3-2.4:5 info: Dell Slim Soundbar SB521A type: audio
    driver: snd-usb-audio interfaces: 2 rev: 2.0 speed: 480 Mb/s (57.2 MiB/s)
    lanes: 1 mode: 2.0 power: 500mA chip-ID: 413c:a510 class-ID: 0102
    serial: <filter>
  Device-3: 3-2.5:6 info: Realtek USB2.0 HID type: HID
    chip-ID: 0bda:1100 class-ID: 0300
  Device-4: 3-3:3 info: HP HyperX Alloy Origins 65 type: keyboard,HID
    driver: hid-generic,usbhid interfaces: 4 rev: 2.0 speed: 12 Mb/s (1.4 MiB/s)
    lanes: 1 mode: 1.1 power: 500mA chip-ID: 03f0:038f class-ID: 0300
  Hub-5: 4-0:1 info: super-speed hub ports: 4 rev: 3.1
  Hub-6: 4-2:2 info: INGENICO 4-Port USB 3.0 Hub ports: 4 rev: 3.2
    speed: 10 Gb/s (1.16 GiB/s) lanes: 1 mode: 3.2 gen-2x1 chip-ID: 0b00:0483
  System Temperatures: cpu: 38.0 C mobo: 35.0 C gpu: nvidia temp: 49 C
  Fan Speeds (rpm): N/A gpu: nvidia fan: 53%
  Packages: pm: pacman pkgs: 1262 libs: 317 tools: pamac pm: flatpak pkgs: 0
    1: https://ftp.gwdg.de/pub/linux/manjaro/stable/$repo/$arch
    2: http://ftp.rz.tu-bs.de/pub/mirror/manjaro.org/repos/stable/$repo/$arch
    3: https://manjaro.kurdy.org/stable/$repo/$arch
    4: https://mirror.alpix.eu/manjaro/stable/$repo/$arch
Processes:
  CPU top: 5 of 379
  1: cpu: 15.1% command: electron pid: 3591 mem: 274.4 MiB (0.8%)
  2: cpu: 8.4% command: vivaldi-bin pid: 2521 mem: 431.8 MiB (1.3%)
  3: cpu: 5.3% command: vivaldi-bin pid: 2642 mem: 138.8 MiB (0.4%)
  4: cpu: 4.2% command: vivaldi-bin pid: 4278 mem: 270.5 MiB (0.8%)
  5: cpu: 3.8% command: electron pid: 3464 mem: 201.1 MiB (0.6%)
  Memory top: 5 of 379
  1: mem: 431.8 MiB (1.3%) command: vivaldi-bin pid: 2521 cpu: 8.4%
  2: mem: 390.5 MiB (1.2%) command: Discord pid: 3746 cpu: 1.6%
  3: mem: 352.7 MiB (1.1%) command: vivaldi-bin pid: 2882 cpu: 1.9%
  4: mem: 322.7 MiB (1.0%) command: vivaldi-bin pid: 2563 cpu: 2.4%
  5: mem: 319.5 MiB (0.9%) command: vivaldi-bin pid: 2697 cpu: 0.6%
  Processes: 379 Power: uptime: 14m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 1 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 12.47 GiB services: csd-power,upowerd
  Compilers: gcc: 14.2.1 Shell: fish v: 4.0.1 default: Bash v: 5.2.37
    running-in: guake inxi: 3.3.37
Switching to an LTS kernel might improve things; kernel 6.12 (LTS) as an example.
⋊> ~ inxi -S        08:19:34
  Host: manjaro Kernel: 6.12.19-1-MANJARO arch: x86_64 bits: 64
  Desktop: Cinnamon v: 6.4.8 Distro: Manjaro Linux
nothing changed…
Stick with kernel 6.12 (LTS) for the time being, as this will remove possible kernel issues (6.14) from the equation.
Aside:- I’ve noticed a few similar reports. It might be too early to know exactly what the issue is. I wonder if you could also add a brief description of your issue in the respective Update Announcement.
A wild guess: maybe it has to do with the xfce 4.20 and the screensaver-lock change, which may conflict with the cinnamon one. Check how many screensavers do you have, evtl. Uninstall one or the other
pamac list | grep saver        09:48:17
cinnamon-screensaver              6.4.0-1                      extra     1,7 MB
even if I disable the locking of the computer after entering sleep, it does not help because I have a black screen with a cursor only after waking up but after 1-2min screen appears…
maybe its related to latest nvidia drivers? can i downgrade it?
mar 25 13:08:42 manjaro cinnamon-session-binary[23586]: WARNING: t+10769.38376s: Calling CanHibernate failed. Check that logind is properly installed and pam_systemd is getting used at login.
mar 25 13:08:43 manjaro systemd-logind[818]: The system will suspend now!
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.7232] manager: sleep: sleep requested (sleeping: no  enabled: yes)
mar 25 13:08:43 manjaro ModemManager[872]: <msg> [sleep-monitor-systemd] system is about to suspend
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.7233] device (p2p-dev-wlp6s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.7235] manager: NetworkManager state is now ASLEEP
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.7235] device (wlp6s0): state change: activated -> deactivating (reason 'sleeping', managed-type: 'full')
mar 25 13:08:43 manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
mar 25 13:08:43 manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
mar 25 13:08:43 manjaro kernel: wlp6s0: deauthenticating from c0:7c:d1:f9:ff:0a by local choice (Reason: 3=DEAUTH_LEAVING)
mar 25 13:08:43 manjaro wpa_supplicant[886]: nl80211: send_event_marker failed: Source based routing not supported
mar 25 13:08:43 manjaro wpa_supplicant[886]: wlp6s0: CTRL-EVENT-DISCONNECTED bssid=c0:7c:d1:f9:ff:0a reason=3 locally_generated=1
mar 25 13:08:43 manjaro wpa_supplicant[886]: wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.9538] device (wlp6s0): supplicant interface state: completed -> disconnected
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.9539] device (wlp6s0): state change: deactivating -> disconnected (reason 'sleeping', managed-type: 'full')
mar 25 13:08:43 manjaro avahi-daemon[815]: Withdrawing address record for fe80::60c1:f9c:8f8f:cef2 on wlp6s0.
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.9541] dhcp4 (wlp6s0): canceled DHCP transaction
mar 25 13:08:43 manjaro avahi-daemon[815]: Leaving mDNS multicast group on interface wlp6s0.IPv6 with address fe80::60c1:f9c:8f8f:cef2.
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.9541] dhcp4 (wlp6s0): activation: beginning transaction (timeout in 45 seconds)
mar 25 13:08:43 manjaro avahi-daemon[815]: Interface wlp6s0.IPv6 no longer relevant for mDNS.
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.9541] dhcp4 (wlp6s0): state changed no lease
mar 25 13:08:43 manjaro avahi-daemon[815]: Interface wlp6s0.IPv4 no longer relevant for mDNS.
mar 25 13:08:43 manjaro avahi-daemon[815]: Leaving mDNS multicast group on interface wlp6s0.IPv4 with address 192.168.0.35.
mar 25 13:08:43 manjaro avahi-daemon[815]: Withdrawing address record for 192.168.0.35 on wlp6s0.
mar 25 13:08:43 manjaro NetworkManager[812]: <info>  [1742904523.9846] device (wlp6s0): set-hw-addr: set MAC address to 2A:D7:05:C0:5D:88 (scanning)
mar 25 13:08:43 manjaro avahi-daemon[815]: Joining mDNS multicast group on interface wlp6s0.IPv4 with address 192.168.0.35.
mar 25 13:08:43 manjaro avahi-daemon[815]: New relevant interface wlp6s0.IPv4 for mDNS.
mar 25 13:08:43 manjaro avahi-daemon[815]: Registering new address record for 192.168.0.35 on wlp6s0.IPv4.
mar 25 13:08:44 manjaro NetworkManager[812]: <info>  [1742904524.0423] device (wlp6s0): state change: disconnected -> unmanaged (reason 'unmanaged-sleeping', managed-type: 'full')
mar 25 13:08:44 manjaro NetworkManager[812]: <info>  [1742904524.1874] device (wlp6s0): set-hw-addr: reset MAC address to 98:43:FA:0E:2F:9F (unmanage)
mar 25 13:08:44 manjaro wpa_supplicant[886]: p2p-dev-wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
mar 25 13:08:44 manjaro wpa_supplicant[886]: nl80211: deinit ifname=p2p-dev-wlp6s0 disabled_11b_rates=0
mar 25 13:08:44 manjaro systemd[1]: Reached target Sleep.
mar 25 13:08:44 manjaro systemd[1]: Starting NVIDIA system suspend actions...
mar 25 13:08:44 manjaro suspend[46208]: nvidia-suspend.service
mar 25 13:08:44 manjaro logger[46208]: <13>Mar 25 13:08:44 suspend: nvidia-suspend.service
mar 25 13:08:44 manjaro wpa_supplicant[886]: wlp6s0: CTRL-EVENT-DSCP-POLICY clear_all
mar 25 13:08:44 manjaro wpa_supplicant[886]: nl80211: deinit ifname=wlp6s0 disabled_11b_rates=0
mar 25 13:08:46 manjaro systemd[1]: nvidia-suspend.service: Deactivated successfully.
mar 25 13:08:46 manjaro systemd[1]: Finished NVIDIA system suspend actions.
mar 25 13:08:46 manjaro systemd[1]: nvidia-suspend.service: Consumed 1.626s CPU time, 1.2G memory peak.
mar 25 13:08:46 manjaro systemd[1]: Starting System Suspend...
mar 25 13:08:46 manjaro systemd-sleep[46220]: User sessions remain unfrozen on explicit request ($SYSTEMD_SLEEP_FREEZE_USER_SESSIONS=0).
mar 25 13:08:46 manjaro systemd-sleep[46220]: This is not recommended, and might result in unexpected behavior, particularly
mar 25 13:08:46 manjaro systemd-sleep[46220]: in suspend-then-hibernate operations or setups with encrypted home directories.
mar 25 13:08:46 manjaro systemd-sleep[46220]: Performing sleep operation 'suspend'...
mar 25 13:08:46 manjaro kernel: PM: suspend entry (deep)
mar 25 13:08:46 manjaro kernel: Filesystems sync: 0.219 seconds
mar 25 13:08:53 manjaro kernel: Freezing user space processes
mar 25 13:08:53 manjaro kernel: Freezing user space processes completed (elapsed 0.001 seconds)
mar 25 13:08:53 manjaro kernel: OOM killer disabled.
mar 25 13:08:53 manjaro kernel: Freezing remaining freezable tasks
mar 25 13:08:53 manjaro kernel: Freezing remaining freezable tasks completed (elapsed 0.001 seconds)
mar 25 13:08:53 manjaro kernel: printk: Suspending console(s) (use no_console_suspend to debug)
mar 25 13:08:53 manjaro kernel: ACPI: EC: interrupt blocked
mar 25 13:08:53 manjaro kernel: ACPI: PM: Preparing to enter system sleep state S3
mar 25 13:08:53 manjaro kernel: ACPI: EC: event blocked
mar 25 13:08:53 manjaro kernel: ACPI: EC: EC stopped
mar 25 13:08:53 manjaro kernel: ACPI: PM: Saving platform NVS memory
mar 25 13:08:53 manjaro kernel: Disabling non-boot CPUs ...
mar 25 13:08:53 manjaro kernel: smpboot: CPU 15 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 14 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 13 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 12 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 11 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 10 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 9 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 8 is now offline
mar 25 13:08:53 manjaro kernel: Spectre V2 : Update user space SMT mitigation: STIBP off
mar 25 13:08:53 manjaro kernel: smpboot: CPU 7 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 6 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 5 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 4 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 3 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 2 is now offline
mar 25 13:08:53 manjaro kernel: smpboot: CPU 1 is now offline
mar 25 13:08:53 manjaro kernel: ACPI: PM: Low-level resume complete
mar 25 13:08:53 manjaro kernel: ACPI: EC: EC started
mar 25 13:08:53 manjaro kernel: ACPI: PM: Restoring platform NVS memory
mar 25 13:08:53 manjaro kernel: LVT offset 0 assigned for vector 0x400
mar 25 13:08:53 manjaro kernel: Enabling non-boot CPUs ...
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 1 APIC 0x2
mar 25 13:08:53 manjaro kernel: CPU1 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 2 APIC 0x4
mar 25 13:08:53 manjaro kernel: CPU2 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 3 APIC 0x6
mar 25 13:08:53 manjaro kernel: CPU3 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 4 APIC 0x8
mar 25 13:08:53 manjaro kernel: CPU4 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 5 APIC 0xa
mar 25 13:08:53 manjaro kernel: CPU5 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 6 APIC 0xc
mar 25 13:08:53 manjaro kernel: CPU6 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 7 APIC 0xe
mar 25 13:08:53 manjaro kernel: CPU7 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 8 APIC 0x1
mar 25 13:08:53 manjaro kernel: Spectre V2 : Update user space SMT mitigation: STIBP always-on
mar 25 13:08:53 manjaro kernel: CPU8 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 9 APIC 0x3
mar 25 13:08:53 manjaro kernel: CPU9 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 10 APIC 0x5
mar 25 13:08:53 manjaro kernel: CPU10 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 11 APIC 0x7
mar 25 13:08:53 manjaro kernel: CPU11 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 12 APIC 0x9
mar 25 13:08:53 manjaro kernel: CPU12 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 13 APIC 0xb
mar 25 13:08:53 manjaro kernel: CPU13 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 14 APIC 0xd
mar 25 13:08:53 manjaro kernel: CPU14 is up
mar 25 13:08:53 manjaro kernel: smpboot: Booting Node 0 Processor 15 APIC 0xf
mar 25 13:08:53 manjaro kernel: CPU15 is up
mar 25 13:08:53 manjaro kernel: ACPI: PM: Waking up from system sleep state S3
mar 25 13:08:53 manjaro kernel: ACPI: EC: interrupt unblocked
mar 25 13:08:53 manjaro kernel: ACPI: EC: event unblocked
mar 25 13:08:53 manjaro kernel: xhci_hcd 0000:02:00.0: xHC error in resume, USBSTS 0x401, Reinit
mar 25 13:08:53 manjaro kernel: usb usb1: root hub lost power or was reset
mar 25 13:08:53 manjaro kernel: usb usb2: root hub lost power or was reset
mar 25 13:08:53 manjaro kernel: nvme nvme0: D3 entry latency set to 10 seconds
mar 25 13:08:53 manjaro kernel: nvme nvme0: 16/0/0 default/read/poll queues
mar 25 13:08:53 manjaro kernel: nvme nvme1: 16/0/0 default/read/poll queues
mar 25 13:08:53 manjaro kernel: usb 1-6: WARN: invalid context state for evaluate context command.
mar 25 13:08:53 manjaro kernel: usb 1-6: reset full-speed USB device number 2 using xhci_hcd
mar 25 13:08:53 manjaro kernel: usb 1-8: reset high-speed USB device number 3 using xhci_hcd
mar 25 13:08:53 manjaro kernel: usb 1-10: WARN: invalid context state for evaluate context command.
mar 25 13:08:53 manjaro kernel: usb 1-10: reset full-speed USB device number 4 using xhci_hcd
mar 25 13:08:53 manjaro kernel: OOM killer enabled.
mar 25 13:08:53 manjaro kernel: Restarting tasks ... done.
mar 25 13:08:53 manjaro kernel: random: crng reseeded on system resumption
mar 25 13:08:53 manjaro kernel: PM: suspend exit
mar 25 13:08:53 manjaro systemd-sleep[46220]: System returned from sleep operation 'suspend'.
mar 25 13:08:54 manjaro systemd-coredump[46319]: Process 40465 (btop) of user 1000 terminated abnormally with signal 6/ABRT, processing...
mar 25 13:08:54 manjaro systemd[1]: Started Process Core Dump (PID 46319/UID 0).
mar 25 13:08:55 manjaro systemd[1]: systemd-suspend.service: Deactivated successfully.
mar 25 13:08:55 manjaro systemd[1]: Finished System Suspend.
mar 25 13:08:55 manjaro systemd[1]: systemd-suspend.service: Consumed 1.370s CPU time, 2.9M memory peak.
mar 25 13:08:55 manjaro systemd[1]: Stopped target Sleep.
mar 25 13:08:55 manjaro systemd[1]: Reached target Suspend.
mar 25 13:08:55 manjaro systemd-logind[818]: Operation 'suspend' finished.
mar 25 13:08:55 manjaro systemd[1]: Starting NVIDIA system resume actions...
mar 25 13:08:55 manjaro ModemManager[872]: <msg> [sleep-monitor-systemd] system is resuming
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.0501] manager: sleep: wake requested (sleeping: yes  enabled: yes)
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.0502] device (wlp6s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
mar 25 13:08:55 manjaro systemd[1]: Stopped target Suspend.
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.0513] device (p2p-dev-wlp6s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.0514] manager: NetworkManager state is now DISCONNECTED
mar 25 13:08:55 manjaro systemd[3786]: Started dbus-:1.2-org.cinnamon.ScreenSaver@5.service.
mar 25 13:08:55 manjaro suspend[46326]: nvidia-resume.service
mar 25 13:08:55 manjaro logger[46326]: <13>Mar 25 13:08:55 suspend: nvidia-resume.service
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.1005] device (wlp6s0): supplicant interface state: internal-starting -> disconnected
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.1005] device (p2p-dev-wlp6s0): state change: unavailable -> unmanaged (reason 'unmanaged-link-not-init', managed-type: 'removed')
mar 25 13:08:55 manjaro systemd[1]: nvidia-resume.service: Deactivated successfully.
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.1008] Wi-Fi P2P device controlled by interface wlp6s0 created
mar 25 13:08:55 manjaro systemd[1]: Finished NVIDIA system resume actions.
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.1009] manager: (p2p-dev-wlp6s0): new 802.11 Wi-Fi P2P device (/org/freedesktop/NetworkManager/Devices/9)
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.1010] device (p2p-dev-wlp6s0): state change: unmanaged -> unavailable (reason 'managed', managed-type: 'external')
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.1011] device (wlp6s0): state change: unavailable -> disconnected (reason 'supplicant-available', managed-type: 'full')
mar 25 13:08:55 manjaro NetworkManager[812]: <info>  [1742904535.1013] device (p2p-dev-wlp6s0): state change: unavailable -> disconnected (reason 'none', managed-type: 'full')
mar 25 13:08:55 manjaro systemd[1]: systemd-coredump@2-46319-0.service: Deactivated successfully.
mar 25 13:08:55 manjaro systemd[1]: systemd-coredump@2-46319-0.service: Consumed 208ms CPU time, 122.7M memory peak.
mar 25 13:08:55 manjaro wireplumber[3953]: spa.bluez5: BlueZ system service is not available
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3348] policy: auto-activating connection 'Auto Vectra-WiFi-24B3E85G' (74d2bdbd-338b-42f0-8846-ccaa09462d03)
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3350] device (wlp6s0): Activation: starting connection 'Auto Vectra-WiFi-24B3E85G' (74d2bdbd-338b-42f0-8846-ccaa09462d03)
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3350] device (wlp6s0): state change: disconnected -> prepare (reason 'none', managed-type: 'full')
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3351] manager: NetworkManager state is now CONNECTING
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3352] device (wlp6s0): state change: prepare -> config (reason 'none', managed-type: 'full')
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3353] device (wlp6s0): Activation: (wifi) access point 'Auto Vectra-WiFi-24B3E85G' has security, but secrets are required.
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3353] device (wlp6s0): state change: config -> need-auth (reason 'none', managed-type: 'full')
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3354] sup-iface[37d85f88fdd0dd55,6,wlp6s0]: wps: type pbc start...
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3357] device (wlp6s0): state change: need-auth -> prepare (reason 'none', managed-type: 'full')
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3358] device (wlp6s0): state change: prepare -> config (reason 'none', managed-type: 'full')
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: WPS-PBC-ACTIVE
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: WPS-CANCEL
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3359] device (wlp6s0): Activation: (wifi) connection 'Auto Vectra-WiFi-24B3E85G' has security, and secrets exist.  No new secrets needed.
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3359] Config: added 'ssid' value 'Vectra-WiFi-24B3E85G'
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3359] Config: added 'scan_ssid' value '1'
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3359] Config: added 'bgscan' value 'simple:30:-70:86400'
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3359] Config: added 'key_mgmt' value 'WPA-PSK WPA-PSK-SHA256 FT-PSK SAE FT-SAE'
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3359] Config: added 'auth_alg' value 'OPEN'
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3359] Config: added 'psk' value '<hidden>'
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3360] device (wlp6s0): supplicant interface state: disconnected -> scanning
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3360] device (p2p-dev-wlp6s0): supplicant management interface state: disconnected -> scanning
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: SME: Trying to authenticate with c0:7c:d1:f9:ff:0a (SSID='Vectra-WiFi-24B3E85G' freq=5220 MHz)
mar 25 13:08:56 manjaro kernel: wlp6s0: VHT information is missing, disabling VHT
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3630] device (wlp6s0): supplicant interface state: scanning -> authenticating
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3630] device (p2p-dev-wlp6s0): supplicant management interface state: scanning -> authenticating
mar 25 13:08:56 manjaro kernel: wlp6s0: authenticate with c0:7c:d1:f9:ff:0a (local address=98:43:fa:0e:2f:9f)
mar 25 13:08:56 manjaro kernel: wlp6s0: send auth to c0:7c:d1:f9:ff:0a (try 1/3)
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: Trying to associate with c0:7c:d1:f9:ff:0a (SSID='Vectra-WiFi-24B3E85G' freq=5220 MHz)
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3947] device (wlp6s0): supplicant interface state: authenticating -> associating
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.3947] device (p2p-dev-wlp6s0): supplicant management interface state: authenticating -> associating
mar 25 13:08:56 manjaro kernel: wlp6s0: authenticated
mar 25 13:08:56 manjaro kernel: wlp6s0: associate with c0:7c:d1:f9:ff:0a (try 1/3)
mar 25 13:08:56 manjaro kernel: wlp6s0: RX AssocResp from c0:7c:d1:f9:ff:0a (capab=0x1011 status=0 aid=1)
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: Associated with c0:7c:d1:f9:ff:0a
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: CTRL-EVENT-SUBNET-STATUS-UPDATE status=0
mar 25 13:08:56 manjaro kernel: wlp6s0: associated
mar 25 13:08:56 manjaro kernel: wlp6s0: Limiting TX power to 23 (23 - 0) dBm as advertised by c0:7c:d1:f9:ff:0a
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4117] device (wlp6s0): supplicant interface state: associating -> associated
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4117] device (p2p-dev-wlp6s0): supplicant management interface state: associating -> associated
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4322] device (wlp6s0): supplicant interface state: associated -> 4way_handshake
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4322] device (p2p-dev-wlp6s0): supplicant management interface state: associated -> 4way_handshake
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: WPA: Key negotiation completed with c0:7c:d1:f9:ff:0a [PTK=CCMP GTK=TKIP]
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: CTRL-EVENT-CONNECTED - Connection to c0:7c:d1:f9:ff:0a completed [id=0 id_str=]
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4897] device (wlp6s0): supplicant interface state: 4way_handshake -> completed
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4897] device (wlp6s0): Activation: (wifi) Stage 2 of 5 (Device Configure) successful. Connected to wireless network "Vectra-WiFi-24B3E85G"
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4897] device (p2p-dev-wlp6s0): supplicant management interface state: 4way_handshake -> completed
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4897] device (wlp6s0): state change: config -> ip-config (reason 'none', managed-type: 'full')
mar 25 13:08:56 manjaro wpa_supplicant[886]: wlp6s0: CTRL-EVENT-SIGNAL-CHANGE above=1 signal=-64 noise=9999 txrate=26000
mar 25 13:08:56 manjaro NetworkManager[812]: <info>  [1742904536.4900] dhcp4 (wlp6s0): activation: beginning transaction (timeout in 45 seconds)
mar 25 13:08:56 manjaro avahi-daemon[815]: Joining mDNS multicast group on interface wlp6s0.IPv6 with address fe80::60c1:f9c:8f8f:cef2.
mar 25 13:08:56 manjaro avahi-daemon[815]: New relevant interface wlp6s0.IPv6 for mDNS.
mar 25 13:08:56 manjaro avahi-daemon[815]: Registering new address record for fe80::60c1:f9c:8f8f:cef2 on wlp6s0.*.
mar 25 13:08:58 manjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mar 25 13:08:59 manjaro ModemManager[872]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:08.1/0000:09:00.3/usb3/3-2/3-2.3': not supported by any plugin
mar 25 13:08:59 manjaro ModemManager[872]: <msg> [base-manager] couldn't check support for device '/sys/devices/pci0000:00/0000:00:01.2/0000:02:00.2/0000:03:08.0/0000:06:00.0': not supported by any plugin
mar 25 13:08:59 manjaro NetworkManager[812]: <info>  [1742904539.8988] dhcp4 (wlp6s0): state changed new lease, address=192.168.0.35, acd pending
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.0411] dhcp4 (wlp6s0): state changed new lease, address=192.168.0.35
mar 25 13:09:00 manjaro avahi-daemon[815]: Joining mDNS multicast group on interface wlp6s0.IPv4 with address 192.168.0.35.
mar 25 13:09:00 manjaro avahi-daemon[815]: New relevant interface wlp6s0.IPv4 for mDNS.
mar 25 13:09:00 manjaro avahi-daemon[815]: Registering new address record for 192.168.0.35 on wlp6s0.IPv4.
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.0423] policy: set 'Auto Vectra-WiFi-24B3E85G' (wlp6s0) as default for IPv4 routing and DNS
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.0598] device (wlp6s0): state change: ip-config -> ip-check (reason 'none', managed-type: 'full')
mar 25 13:09:00 manjaro systemd[1]: Starting Network Manager Script Dispatcher Service...
mar 25 13:09:00 manjaro systemd[1]: Started Network Manager Script Dispatcher Service.
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.1049] device (wlp6s0): state change: ip-check -> secondaries (reason 'none', managed-type: 'full')
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.1050] device (wlp6s0): state change: secondaries -> activated (reason 'none', managed-type: 'full')
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.1051] manager: NetworkManager state is now CONNECTED_SITE
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.1054] device (wlp6s0): Activation: successful, device activated.
mar 25 13:09:00 manjaro NetworkManager[812]: <info>  [1742904540.2453] manager: NetworkManager state is now CONNECTED_GLOBAL
mar 25 13:09:05 manjaro cinnamon-screensaver[46327]: CsNotificationWatcher: Could not add match rule to bus - GDBus.Error:org.freedesktop.DBus.Error.MatchRuleInvalid: Invalid match rule
mar 25 13:09:05 manjaro cinnamon-screensaver[46327]: Loading AccountsService
mar 25 13:09:05 manjaro cinnamon-screensaver[46327]: Fractional scaling active: False
mar 25 13:09:05 manjaro cinnamon-screensaver[46327]: Trying to connect to logind...
mar 25 13:09:05 manjaro cinnamon-screensaver[46327]: Starting screensaver...
mar 25 13:09:06 manjaro cinnamon-session-binary[23586]: WARNING: t+10789.34674s: Could not retrieve current screensaver active state: Timeout was reached
mar 25 13:09:10 manjaro systemd[1]: NetworkManager-dispatcher.service: Deactivated successfully.
mar 25 13:09:10 manjaro cinnamon-screensaver[46327]: Cinnamon Screensaver support not found in current theme - adding some...
mar 25 13:09:10 manjaro cinnamon-screensaver[46327]: AccountsService ready
mar 25 13:09:10 manjaro cinnamon-screensaver[46327]: Successfully using logind
mar 25 13:09:20 manjaro systemd[1]: Starting Pamac Daemon...
mar 25 13:09:20 manjaro systemd[1]: Started Pamac Daemon.
mar 25 13:09:20 manjaro systemd[1]: pamac-daemon.service: Deactivated successfully.
mar 25 13:09:22 manjaro polkitd[816]: Unregistered Authentication Agent for unix-session:13 (system bus name :1.449, object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale pl_PL.UTF-8) (disconnected from bus)
mar 25 13:09:23 manjaro polkitd[816]: Registered Authentication Agent for unix-session:13 (system bus name :1.469 [cinnamon --replace], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale pl_PL.UTF-8)
mar 25 13:09:23 manjaro cinnamon-screensaver[46327]: Fractional scaling active: False
mar 25 13:09:23 manjaro NetworkManager[812]: <info>  [1742904563.4343] agent-manager: agent[c1837dd1d31553bc,:1.469/org.cinnamon.NetworkAgent/1000]: agent registered
after switching to wayland on cinnamon, the wake-up and black screen problem disappeared, but I have other difficulties already related to wayland itself. so I would prefer to stay on X11.
the next time it happens, use the Looking Glass tool to see if there are any errors.
Right-click on any panel and go to Troubleshoot > Looking Glass and scroll for any errors. Sometime applets will cause issues. If the Spices Update Applet is installed, delete it and then reinstall it.
